PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 [240] 241 242 243 244 245 246 247 248 249 250 251
  1. Evo8 AWD system?
  2. Shepherd Racing Rebuilt Evo Tranny In!
  3. question for evo's running high flow cat
  4. Help Please
  5. Is the exhaust still so black after SAFC?
  6. Ikeya quick shift kit
  7. Mail order Dynoflash: Any proven improvements?
  8. Question for Redline MT-90 fluid users
  9. I hear the metal pad lapping sound mostly when I shift 1st to 2nd gear.
  10. Evos Mushy Gearbox?
  11. Got my Greddy 4
  12. HKS Racing Suction Intake Problems
  13. anyone use red line tranny lube?
  14. Disbelief / slipping clutch
  15. Poor performance with muffler delete pipe?
  16. Smell with race pipe
  17. HKS Camshafts-- initial dyno results
  18. temperature of crankcase gases
  19. backfiring / loud pop noise
  20. Who replace their washer on every oil/fluid change?
  21. Hi-Flow Cat or Straight pipe
  22. 3" high flow cat and a CEL to go along with it.
  23. I hear the metal lapping sound under my feet when I change the gears on EVO8.
  24. Aftermarket clutch + ss clutch line/restrictor removal
  25. US EVO 8 rear diff
  26. My DynoFlash on 10/25/03
  27. Is it worth upgrading the pressure plate?
  28. HKS Type ZERO TT...
  29. greddy type s on an evo
  30. Co2
  31. Defi Link Oil Pres. Install.... ?
  32. Gauge Questions
  33. Greddy Type S Bov Install
  34. Maxed out injectors????
  35. Buschur Racing..11.65 at 117 mph cont......
  36. What do you guys think ?? My exhaust plans
  37. Problem with Static Shocks and Cooling Fan
  38. If the EVOIV came with variable valve timing...
  39. Boost psi to bar
  40. Interest in JUN parts?
  41. First Test Drive...Very disappointed!?!
  42. New RMR Clutch
  43. HKS Type Zero TT
  44. Down Pipe questions
  45. Changed out my tranny fluids this weekend.
  46. Streetable Power
  47. Evo Garage ! My new Ferra valves are in !
  48. HKS Hi Power Exhaust Question
  49. oil burnin?
  50. Check Engine light after 800 mi.
  51. Problems with BOV
  52. My Boost is strange
  53. Engine Service soon
  54. Anyone install 8.5mm plug wires?
  55. what's OBD 2?
  56. I may have an Exhaust Leak
  57. Buschur at Norwalk
  58. Just Installed B&B Catback + Downpipe
  59. Spy photos of Pruven Evo
  60. Dynoflash is da shiznit! 312 whp on ****ty gas!
  61. ECU reflash by Dynoflash at PruvenPerf
  62. Blowing smoke...
  63. Just installed my HKS RS WOW!!!!!
  64. 305 whp! Totally stock evo with Dyno Flash and Ntercooler !
  65. Parts compatability
  66. Can you change the Apexi SAFCII light color?
  67. mitsubishi recomends 98 octane?
  68. HKS Hi-powerSS/Carbon tI
  69. Carbon/Carbon ?
  70. Shiv comment on C&D
  71. Increasing DISPLACEMENT and REDLINE.....
  72. Intake suggestion
  73. ecu reset when upgrading to better parts
  74. Anybody with RMR Intercooler Piping Kit?
  75. Does anyone know of an upgraded intake manifold for the 4G63?
  76. Change that fuel pump!
  77. Experiences with Short shifters? Post your reviews please
  78. is the Buschur exhuast slip-fit?
  79. is it safe to use 10-50 race mobil 1?
  80. ACT Clutch
  81. BR Turbo back
  82. Is running lean bad?????
  83. Reflash/ECU Poll
  84. Which blow-off valve is good for the evo 8
  85. 1st pass....11.65 @ 117.88 stock turbo
  86. ARC induction box installed...
  87. Injectors
  88. 12.6 @ 108 with stock evo @ dynoflash?????
  89. Those of you with an Oil Temp guage..
  90. Lose of Boost help
  91. Aem Ems Progress On Br Evo8
  92. Clutch noise downshifting
  93. boost in 1st gear?
  94. Swapped 4G63 w/Lancer engine
  95. PIGGYBACKS and losing your tune???
  96. Well it happened again.. i just have no luck
  97. Stock EVO FMIC
  98. Aftermarket front Diff
  99. Evos: How much oil are you using?
  100. Aftermarket transmission
  101. spark plug wires
  102. Dynoflash: Can it raise the idle?
  103. emergency brake won't hold
  104. What to upgrade next?
  105. Python 880xp alarm - engine light??!
  106. who is running a buschur dp and catback
  107. Mild steel v/s Stainless Steel - Pros and Cons...
  108. Boost Drop after Turbo Back exhaust
  109. gm mas on a evo?
  110. Super light weight driveshaft
  111. HKS Super AFR or Apexi Super AFC
  112. Tanabe exsuact systems
  113. Honey comb in the stock filter box?
  114. turbo xs h34 recirculating bov problems
  115. Time for the DP!
  116. *EVO 8 Custom Turbo Upgrade*
  117. When to upgrade your exhaust mani...?
  118. evo can sit all day and not overheat
  119. Repeatability of the Dyno Flash - long term study data and dyno sheet
  120. Defi D Gauge ( anyone know )
  121. Stock Idle values ???
  122. synthetics other than Mobil 1
  123. Royal Purple use in tranny/rear diff.?
  124. Brembo Brake Dimensions
  125. Fixing the flutter and stalling with my HKS VTA and SAFCII...
  126. Throttle Bodies!!!
  127. About Fuel Mileage and..
  128. EVOs and NOS
  129. DynoFlash and Dealership
  130. 525whp stock motor EVO8
  131. Dyno Question
  132. Downpipe or HKS Racing Suction Kit
  133. 50hp Tubroback???
  134. SAFC tuning @ Boost Solutions
  135. I/C Spray Question...
  136. What kinds of clutchs are made for the evo?
  137. Helix Power 76mm EVO 8 Downpipe - Just Released
  138. Clutchmasters stage 1
  139. best clutch setup
  140. Who can explain?
  141. whats the best boost control
  142. How much?
  143. Tune the EVO8
  144. Why are DP's so pricey?
  145. Exhaust Flames?
  146. Rear differential noise @ speed
  147. how about a EXHAUST SOUND CLIP thread
  148. Ahh, crap
  149. Vishnu Stage 1 or Ultimate Racing Stage 1 plus???
  150. TRanny or DIFF. MAJOR whining
  151. Stock Evo, different boost in each gear?
  152. Buschur Intercooler - can retain splash shield
  153. 3000 miles = clutch gone
  154. low boost issues
  155. what intakes you guys got?
  156. greddy e-01 help
  157. Perrin testpipe question
  158. Help!!!!
  159. JIC - Hayabusa - Apexi...
  160. What Whp should I expect with these Parts
  161. Alcohol injection / water injection
  162. Squeaky Shifter?
  163. HKS hi power or 30th anniv
  164. "Stage Rev" and Manual Boost Controller?
  165. MAF Adjustment Screw
  166. help me out guys
  167. engine break-in
  168. Hks downpipe and 30th anni. cat back
  169. Alcohol
  170. HKS Speed Limiter Remover
  171. cam tests
  172. problem, boost falling off?
  173. Whis is better gasoline for Evo?
  174. Leaded racing gas question
  175. Tranny/diff fluids
  176. evo 8 idle
  177. Broken Tranny with only 800 miles?
  178. A/F and O2 settings on Apexi TT
  179. HKS EVC adjustments.
  180. Jic Titanium Exhaust vs. Apex
  181. Another Dyno Flash w/ Buschur exhuast and intake . .dyno sheet
  182. Question for the Clutch restrictor removal and ss clutch line Evos
  183. Just Installed: Perrin Catback Exhaust
  184. stealth fmic
  185. Evo Tuners in DFW?
  186. mbc problems
  187. JIC Ti exhaust intalled
  188. Apexi SAFCII just installed... WOW!
  189. a lean evo at pruven
  190. what is the best shot to run "80-100or more"
  191. Rear Differential
  192. what is the best gap for NOs
  193. DynoFlash
  194. 1/4 after dynoflash?
  195. greddy e-01 19psi to redline setting, anyone?
  196. just installed hks rs kit
  197. I have a WEAK EVO !!!!!
  198. Clutch slipping????
  199. Apexi SAFCII install question, URGENT!
  200. A Quieter Buschur Racing exhaust
  201. Buschur MAS Pipe
  202. Stock whp variances
  203. Goal: building 400-500HP evo?? what is needed?
  204. Tanabe Ultra Medallion
  205. fuel cut and service light
  206. Mixing 92 and 100 octane
  207. JIC DP replace the stock 02 housing?
  208. hks bov or greddy type-s
  209. SAFC II delay normal?
  210. Look what Shiv's dyno tune did for me
  211. Dyno Flashed! 287.5 whp 298.4 ft lbs - totally stock Evo
  212. coolant temp not stable, please help
  213. *i Need Help Have A Problem With The Car Missing*
  214. Should I reset the ECU periodically?
  215. South Bend Kevlar Clutchs
  216. Diffrentials are Whining
  217. How much power does a down pipe add?
  218. Stand-Alone XEDE?
  219. Need your help.
  220. AEM intake and RNR cat back pics
  221. Just got Dyno'd!
  222. Grinding 2nd
  223. Installation of Short Shifter
  224. 272's
  225. Greddy Turbo. Who Has One?
  226. aftermarket ecus are they really needed?
  227. Bosst controller with XEDE...
  228. New Forge Motorsport Carbon Fiber Airbox
  229. tranny won't grind
  230. Clunk!
  231. Exhaust question for Dave Buschur
  232. Load pop heard on canyon run
  233. Intake Question
  234. This is unbelievable!!!
  235. E-Manage Settings
  236. questions on hks ssbov
  237. Very smooth Tranny now!
  238. WorksRally Exhaust
  239. Intercooler piping heatsinks
  240. Vishnu, dynoflash, or works Tuning in Michigan?
  241. HKS BOV adjustment setting??
  242. Turboxs BOV seized
  243. JIC CAT back smaller than 3 inch!!!!
  244. Tomei ECU installed
  245. Dyno Flash dyno day - November 1 at Pruven - special prices - 4 spots left !
  246. Anyone Have Dyno Figures on Ultimate Racing Stage 1 Plus Kit on Evo 8?
  247. Who is running the HIGHEST boost STOCK?
  248. What to look for in a tuning Shop?
  249. tubular turbo manifold for evo
  250. There goes the clutch...
