View Full Version : Evo Engine / Turbo / Drivetrain
- O2 Simulator / Mech Fix?
- Pt6776r
- Stock IX with boost controller??
- Stalling issue
- Quick ? about BG Synchroshift
- stock BOV fluttering/ motor stuttering?
- Does adding a fuel pump after dynaflash??
- Buschur Magnaflow Exhaust Clips!!!!!!
- Apex WS or Greddy SP catback??
- HKS DLI 2 vs Sun Hyperforce Ignition
- Help deciding on Turbo XS Exhaust
- best cam combo
- Big Review : JunBL, Ultimate Racing, HPF
- Aquamist Install question
- Quickest/Cheapest way to get an Evo 8 to 300-350hp?
- Signs of a failing stock clutch?
- help boost controler
- Ams
- drop in filter intake
- IX Transmission Into 03 VIII?
- ATP 3071R Installed, All smiles one question
- Bruce Crower or Brian Crower Stroker
- Good Place to buy engine parts
- mr tranny drain plug
- shed some light on....
- exedy clutch problem...i think?
- I don't think this is supposed to happen...
- Cheapest turbo upgrade?
- eagle rods
- aem boost solenoid
- Help car won't start ??
- Clutch Pedal low engagement?
- EGT Probe Installed - Boost Down
- Walbro Fuel pump
- Cosworth camshafts
- leak down test just tested?
- Somethings wrong with my Evos turbo.
- GT35R + stock block *help*
- Brian Crower Evo VIII Cams Specs and Results...
- Stock IX Boost Question
- Need help!! uncontrollable boost
- WOW!!! What a difference!
- Anyone else noticed this with 5 speed?
- What cams to use on a 50 trim with UTEC?
- need some help, 3rd and 4th messed up
- boost leak test black box?
- boost leak test: bad throttle body?
- Possible to transfer 5spd into 6spd MR?
- Strange boost leak problem? Help...
- Evo IX Clutches???
- Should I use fuel injection cleaner even tho I use Chevron Supreme?
- Transfer Case Problems.
- Help With 500
- Bov
- Stock Turbo
- Exhaust
- 9 second engine bay picture...so simple.
- CV joint question??
- Nur Spec R - Pipe Lengths
- what you guys did with your wideband o2
- How do I fix a leaking valve cover.......
- AMS 2.3L + RnR GT30R results
- Problems To Start Evo 9 New Engine
- Need some input on Exedy 4 puck clutch
- 50trim vs. GT30r vs. atp-gt3071r
- Quick 02 housing question.
- TOB help!
- Has anyone ever melted all 4 spark plugs?
- Eagle rods, what bearings ?
- fuel system
- Solid Valve Train
- Fuel cut
- GSC 280 VS HKS 280 dyno sheet inside!
- What is wrong with Mitsu techs!!
- 9.97 at 142.32 mph !!!!!!!!!!
- 2.3, gt35r, 720cc?
- Hks EVC help plz
- o2 sensor cap
- Possible tranny issue?
- Evo Clutch install questions...
- This may seem like a stupid question
- meth air/fuel
- ~~exhaust questions~~
- RNR/HKS Carbon Ti TBE
- UTEC with 1000cc injectors on a 50 trim BB
- Loud Thump
- oil sensor
- new pistons
- anybody here with the blitz turbo timer can help me?
- LOUD noise / echo when in boost
- Help-cant fit spark plug antifouler on Buschur exhaust
- Long Rod 2.0
- Hallman ES MBC?
- Weird vibration/humm/buzz rpm specific
- Is Exedy the OEM clutch?
- need help/ input on problem
- Different hotside for ATP3071R?
- how much can the stock head studs handle?
- Rods & Power Level
- searched and everything still nothing.......
- Bypass hose
- 1st MOST POWERFUL 9???
- 10.5 hotside porting?
- For those that have installed headtuds..
- HKS Cams without tuning ?
- Shep T/C only?
- Evo 7 Cluncking rear diff when shifting
- Who sells Fluidamper?
- Help Fuel Pump?
- 2.3 strocker kit POLL
- Frustrated With Meth!!
- Questions about tuning options.
- Homemade intake
- Info on Gear Oil for EVO IX
- 2.3 Strokers
- Does Changing your crank pulley cause knock?
- Anyone having drivetrain issues when running big power?
- Arc 079
- Has anyone switched from HKS cams to JUN or Tomei with stock type turbo?
- best turbo out?
- car got jacked!!!
- Turbotrix 50trim Kit @ the Dyno
- crankshaft sensor
- Getting some Ratterling from HEAD!!!!
- Headgasket how to & torque specs? where can I find this
- 3" exhaust ID ?
- 3 inch downpipe problem
- Can BG Syncroshift
- 4 month backorder on OEM 16G IX!!!
- clutch question
- Front Crank Seal
- Removing transmission
- what bov for stock ecu 35R IX?
- helix cams?
- Dyno chart/datalogs of T-67R P-trim turbo on a 2.0L?
- Need help
- How to wire 2x SPAL rad fans to AEM and controll it?
- So I either fixed my boost leak, or broke something **PICS**
- DNP manifold
- Motor?
- 110 leaded
- Wait..what's this? Another true daily driver running 10.17???!!!!
- 35r equipped evo IXs jump on in!
- clutches.
- ATP 3076R Dyno Results = 485whp, 411wtq
- Issue with Turbonetics Evolution wastegate (dissassembly)
- HKS DLI2:how does it work?
- Stock OEM Replacement Parts
- Recommended drivetrain fluids...
- Well i back in the EVO game this time with a IX!Couple questions on mod's take a look
- GSC 264 cams questions...
- For MR owners
- 400whp+ evo
- 04, 05, 06 Evos
- different boost at different gear?!
- True daily driver.....10.19 at 143.70 mph
- selling stock exhaust and flywheel
- Supertech dual valve springs.
- Weapon R intercooler piping is garbage...
- Ti JIC MAGIC CATBACK INSTALL QUESTION?
- a few questions for 10 seg
- 2nd oil cooler
- The perfect daily driver cam
- will evo 8 O2 housing fit evo 9?
- have tbe/intake about to get tuned ?'s MBC or EBC
- Dynoed Evo IX with just Flash!
- just changed spark plugs, is this normal?
- need help on what to do next
- Time for a new clutch
- Update on TurboTrix HP61 turbo...
- Evo 4G63 Engine Rotation Direction
- Manley I beam rods
- Help with clutch install
- Help! Defi Controller Wiring w/ Oil Pressure Gauge
- Balance shaft alignment DSM GODS PLEASE HELP!!!!
- AMS GT35 or Buschur GT35 kit? A question for you guys from accross the pond:)
- about to install clutch need advice
- Need help. Possible Clutch Slippage
- transfer case oil
- anyone need flywheel?
- Stock MAP sensor?
- Horsepower Question
- Is there a Boost Gauge with built-in Map Sensor?
- 6 spd MR tranny weaker than 5 spd?
- Am I gonna blow my Driveshaft? Shaking BAD!! Intermittently
- Busted Crankshaft [Long w/ cliffnotes]
- thicker headgasket?
- My first dyno and tune
- BOV adapter, blanking plug?
- Buschur Racing 20G
- Drivetrain fluid drip on driveshaft
- I need help with an injector
- New water pump?
- ebay o2 housing
- Ported / Coated Manifold / Turbo???
- Best source pressure source for MAP sensor?
- dip stick blew off need help
- Noise from the front "transaxle"???
- boost trouble
- stock piston??
- hks cams
- CEL with Catback?
- Megan Racing TBE
- Need some quick help
- For those wanting to upgrade fmic with stock turbo
- Clutch choice Exedy or Tilton?
- Replaced Plugs now a stutter
- HELP please! A few questions on a clutch.
- Losing Boost on Evo 6 - Help!
- Caped off nipple? why?
- 16G IX turbo on '05 VIII?
- Camshaft Weights!
- No Front O2 sensor?
- Very intresting read
- Car wont start after O2 sensor installed
- Stalling at Idle and Wierd Noise
- B.O.V. Question
- boost spiking problem
- Anyone have the Defi Blue Racer Boost Gauge?
- missing boost
- problem inside, be nancy drew for me
- Normal Compression Per Cylinder???
- Brain Crower Cams?
- Too much boost? ***VIDEO***
- Calling everyone with a SBR turbo kit!
- XS Power TBE --> Pics, Video, Review
- Best FMIC?
- upper intercooler pipe that will work with stock airbox and diverter valve
- upper intercooler pipping?
- Meth questions
- newb getting dynotuned mon, wat numbers should i expect?
- Which Ignition??
- Please help me identify this turbine housing
- Trying to get backhousing out... please help
- Little Help With AMS VSR?
- Br20g?
- 35R or T0Z??
- So I sold the DSM...
- At what point is a HKS DLI 2 needed?
- Failed knock sensor?
- Pressure @ Fuel Rail
- TBE; with or without resonator?
- Ported stock intake manifold vs Magnus SMIM.
- cross threaded O2 sensor???
- Offtopic..Chris's EVO is for sale!
- looking for evo9 turbo upgrade....Grrr search suck...fatal errors...
- Awww man, my transfercase hates me...
- EVO_IX Clutch at 5000 miles!!
- Evo Ix Intercooler Piping!
