PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Upgrading Rod bolts on stock bottom-end - post if you've done it
  2. Monster Sports PFX Intake kit
  3. Need input..Wiseco,Ross,Manley,Pauter
  4. "regular" ARP headstuds vs. ARP L19 headstuds
  5. CCI stage 4 opinion
  6. wastegate not fitting turbo?
  7. Boost Creep
  8. manual transmission will not shift
  9. which o2 housing to go with?
  10. 1200 injectors or wait
  11. fp-red w/80mm cover or fp-blk??
  12. trans/starting problem.
  13. Anyone? Issues with 5th gear synchro, Evo IX?
  14. Upgrading wastegate actuator?
  15. OS Giken twin disc w/dampened center
  16. Clutch is shot right?
  17. ARP headstud questions....
  18. water pump problem...
  19. Need help/opinions on which route to go for best hp per $
  20. changed bov, gettin less boost now
  21. ivey transmission rebuild?
  22. Problems on mivec camshaft
  23. On my 3rd ACD pump!!!!
  24. 30r questions
  25. Excessive wear on Spark plug 2 & 4
  26. Blitz SBC-iD Spec R
  27. 2.5 Trans and Spec Twin Install ... not with out issues
  28. Car Breaks up doing 3rd Gear Pulls Only? Help
  29. Bled clutch; now pedal is dead and down to the floor
  30. something fishy going on with car... please help!
  31. Fitting Evo 9 BOV to Evo 5
  32. URGENT!! 2.3L Rebuild Problem
  33. timing(TDC) question
  34. filled newly built motor with coolant now leaking??
  35. Car won't start after I stored my evo 9 for 5 days.
  36. Building engine: Need help!
  37. Help, Please...
  38. Can Supra TT fuel pump fit in an Evo V/VI??
  39. Thermostat problem?
  40. Clutch or differentials HELP ?
  41. Low Idle oil pressure
  42. Cant get LICP to fit after Turbo XS IC and EPM O2 Dump install
  43. forged piston concept?
  44. 3 port wastegate actuator
  45. hks ssqv... Wont Vent?
  46. TC/Tranny bolt stripped = Leak ?
  47. Car breaking up
  48. STM's Evo first start up
  49. Cam gears or Cooler piping?
  50. i need a 3.5inch I.D. muffler. where can i get one?
  51. Clutch upgrade finally...few questions..
  52. Radiator fan issue
  53. Low oil pressure @ idle
  54. transfer and diff oil?
  55. Car running lean
  56. Fmic question??
  57. Starter Going???
  58. Possible Clutch Slippage
  59. BLE solid tensioner
  60. bfic or not
  61. SES light from Test pipe
  62. Boost gauge only reading 15psi **UPDATE**
  63. Headwork
  64. crazy loud noise!!!
  65. AMS vs ARC intercoolers
  66. VP Imports vs Q16? Anyone made a back to back dyno test?
  67. slipping
  68. Idle Surge
  69. wtf
  70. wtf is wrong?
  71. kelford 280/280 vs kelford 280/272
  72. exedy or act??
  73. Guestimate approx. HP Gain?
  74. What goes here?!?
  75. ebay licp
  76. RPM's acting weird at idle....?
  77. eBay O2 housing problem
  78. Geting Tired of Small Power and Feeling the need for Big Power
  79. WOT Throttle, Fuel Cut. then ASC off Light turns on!!!
  80. engine rebuild questions
  81. Q: Evo Timing Belt Length ?
  82. HELP with oil leak!
  83. FP HP WGA questions....
  84. Boost problems
  85. My Porting Job!!
  86. Boost is a lot less in 2nd gear comapred to 1st?
  87. Using port on Oil filter housing for FP oil feed line, now where do I put oil temp?
  88. Exedy throw out bearing OK?
  89. Flywheel scare
  90. power loss at higher rpms majorly
  91. BOV=No full boost?
  92. Oil Pressure Problem on 2.3L 4g63
  93. Quick problem, missing bolt on o2 housing
  94. Idle probelms....need so advice
  95. Mopar timing belt on evo?
  96. MBC users thoughts?
  97. Clutch HELP
  98. 3" vs 3.5" IC and fp-red
  99. got a few questions about making power
  100. I hope someone from Tilton reads this...
  101. what sensor is this???
  102. hks gd twin plate clutch
  103. starter problem
  104. My front axles going bad?
  105. Bearing clearances (again)
  106. What Cam Gear Are Good To Put On An Evo 8 With HKS 272 Cams??
  107. Apexi N1 Exhaust - How loud is it??
  108. possible causes for clutch pedal pressure lost?
  109. Good Exhaust combo?
  110. Need help choosing a turbo kit for my IX
  111. Non CDI Coil On PLug: Really worth it?? Good read!
  112. My $80.99 full ebay tbe
  113. NEED help/opinions/feedback on what route I should go with....IM vs Cam upgrade
  114. TOMEI ARMS 7960 vs BBK FULL ??
  115. Modding a car that has been previously tuned
  116. Exhaust advice
  117. evo 7 build from Australia
  118. i again call on the knowledge of EVOm
  119. TT600 stock frame style turbo!!!=)
  120. Why We Leak Test Each Intercooler! and HOW!
  121. ETS End Tank Design! - No One Compares!
  122. EVO 8 Shakes Violently Under Throttle
  123. Intake filter fitment issue
  124. Stock Exhaust Manifold...Is this normal?
  125. how does the fp-red sound?
  126. epm dump which version works w/ niesi licp
  127. the proper clutch for my power
  128. Help w/ 2.5" lower AMC IC piping to FP Red
  129. 2.3 pistons
  130. How not to install a CBRD radiator.... and, well.... everything I guess.
  131. new stock clutch vs. others.
  132. throttle kicker for antilag
  133. Another ACD thread...Sorry guys.
  134. Anybody Have Experience with Both GREDDY Ti-C and Ti Exhausts?
  135. ARP headstud installation problem.
  136. Bucking at 1/2 to full throttle
  137. evo 9 vs evo 9 mr
  138. Radiator hose kit comparison question
  139. Mechanical t-case?
  140. stp engine oil treatment?
  141. O2 housing fitment
  142. time to play "name that thing"!
  143. 2.4 Thread
  144. Mysterious oil leak
  145. Closer 5th Gear
  146. need diagram of stock map sensor pigtail
  147. Turboxs exhaust vs AMS exhaust
  148. what power can a greddy vspec front mount hold
  149. Cant get o2 sensor out of o2 housing
  150. FP Red looses punch after 120 mph.
  151. ALS on gt series or Fp turbo's
  152. Newbie questions.....
  153. and an idle problem
  154. Need some help..
  155. OIL comsuption!
  156. New FP red vs Old FP red?
  157. Anyone had the A/C condenser fan fail?
  158. WOW you will never believe it
  159. what ever happened to top mount turbo kit
  160. Carrillo vs Manley
  161. Fp black dyno #rs
  162. Boost Surging/Slipping?
  163. Cat Question
  164. What to do? max stoxk turbo or upgrade?
  165. anyone use these?
  166. My EvoIX SE w/ FP Black and stock block
  167. Gasoline Leak - Odd
  168. Suggestions for air/fuel "gauge" setups needed..
  169. Cosworth M2 IX lobe centerline?
  170. What size vacuum line?
  171. Polished up one of the turbo manifolds....
  172. evo9 head onto evo 4-8, what is needed?
  173. Ebay O2 housings
  174. coils keep burning??? need help??
  175. A lag monster is spawned! (cam timing)
  176. clutch question
  177. Kasey at MAP's 2.4 Hybrid Build
  178. fuel pressure gauge adapter
  179. Anyone running the new PTE ceramic bearing 6262?
  180. 35R Long Rod 2.0 Build
  181. Injector Resistor Evo VIII 2003
  182. exedy twin disc slipping!!!
  183. Help guys i just want to know if a t28 flange will fit on a t25?????????
  184. Question: HKS DLI (Ignition Amplifier)
  185. intercooler question.
  186. clearances...what's acceptable?
  187. My FP Black
  188. Braided Lines? What to Change?
  189. PT6262 in ... FP Red out
  190. Ebay HKS 272's , not really
  191. Installing new Motor Mounts?
  192. Coolant Smell
  193. ACD leak, checking for more obvious places for leak before dropping transfer case
  194. Unofficial Quatermaster Twin disk review
  195. MR Turbo
  196. Stock Evo 8 exhaust diameter
  197. MR trans fluid in my hihg mile EVO 8
  198. IX OEM bonnet heat shield removal
  199. coated housing/exh manifold worth it?
  200. Synapse Piping
  201. Bov ?
  202. Best Fluids?
  203. Evo IX revv hang?? Anyone??
  204. Oil leak under transmission
  205. Busher's 3” downpipe fitment
  206. Car acting weird under boost!
  207. HKS 280 cams, whats wrote on them, and rust issue
  208. Cars banging around?!?!?!?!
  209. cluctch ret. spring
  210. car whines alot but runs good ideas?
  211. lets play y wont my car start...again!
  212. please help !!
  213. HELP -water pump
  214. compression test
  215. water pump?
  216. 2 ?'s. Is an 044 overkill for stock lines? Who makes tank to rail lines?
  217. Tial Recirc BOV
  218. Why does Fidanza hate MR's?
  219. Code: P0240 Catalyst System Efficiency Below Threshold
  220. One wheel on air and the other 3 don't move
  221. 6 speed output shaft
  222. 12psi at full boost? maybe problem with UTEC?
  223. Getting past Emissions with catless tbe
  224. comparison
  225. jun oil baffle/ slicer
  226. CBRD halfwidth rad, design input..
  227. valid test?
  228. Will Exhaust Silencer Reduce Power?
  229. Help!!! Boosting 1.8 Bars!
  230. Those of you who do their own porting,...
  231. my ACD hard line under the car is dented HELP!
  232. Help My competition Clutch Wont Disengage At around 2500 RPM's
  233. siliconeintakes "non" catalytic converter
  234. MR (6spd) transmission drain plug magnet?
  235. BR, 2.4, high hp/high rpm build?
  236. Modifying your MIVEC cam gear
  237. Help!! Leaking oil!!
  238. Help: Ignition Coil Cooked itself...
  239. oil line and banjo bolt solution
  240. Another FP Black Thread
  241. Can P0420 error code be caused by air/fuel ratio gauge?
  242. HOW TO check for shaft play on turbo
  243. 2nd Gear clunk?? (yes, i searched)
  244. Sparktech COP? Big Turbo? Are you happy you did?
  245. hks twin disc
  246. idle problem
  247. black smoke after WOT
  248. My Epic Ebay TBE Install Thread.
  249. Stock Valve Question. Please Help.
  250. t-case gearing question...
