PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 [235] 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Samco Hose Kit, Is It Worth It?
  2. ATF Dexron3 on the tranny?
  3. Coil Pack for JDM 4G93 GDI Engine
  4. GET BuschurFlashed! Unleash the monster in your EVO!
  5. HKS 30th ANNY Cat Back & D}{P
  6. AVO Exhaust Review?
  7. Evo8 vs Evo7 Transfer case
  8. Off To Pruven!!!!!!!!!
  9. Whose selling this????
  10. troubleshooting help
  11. drop rpm problem
  12. Dejon Tool products...anyone?
  13. TurboXS RFL, or GREDDY "S"
  14. Need picts of the ic spray nozzles!
  15. It's 9 degrees outside, how much more horsepower?
  16. Denso plugs?
  17. Catco Hiflow Cats...anygood???
  18. Hit 9460rpms on a downshift!!!
  19. 89 octane?
  20. 3" buscher butt dyno wow!!
  21. When to upgrade fuel pump?
  22. Car seems slower, Check light, and stuttering/boggin issues.
  23. Help with Buschur turbo back install
  24. whats wrong with me evo???
  25. Seen this...Injen CAI ?
  26. E-01 & emanage
  27. XS Power IC upgrade/ Gialla Front bumper fit
  28. Clutch restrictor removed: results
  29. The proper/safe tuning w/mods?
  30. question for those using race gas....
  31. Buschur exhaust question
  32. Car Squeeking, sounds like a belt, at 6000 miles?
  33. Monster Exhaust
  34. turbo timer ?
  35. HKS cam part #, PLEASE HELP!!
  36. C16 (leaded) versus CAT: The stinky winner
  37. What exactly ECU flashes/re-flashes do?
  38. Sound for a-market Cams??
  39. possible exhaust issues?
  40. just got BUSHERFLASHED
  41. What lube in your tranny?
  42. Fluid confusion
  43. tanabe downpipe shots on weightless white
  44. RPM rises 400 when doing 3 to 4 shift [MERGE]
  45. Need advice on oil for engine, diff., and tranny! Opinions needed please
  46. Higher boost with 3" turbo back exhaust
  47. Rear Diff Clicking
  48. HKS GD max instructions
  49. Rear Diff Clicking
  50. Cold Engine Starts
  51. Clutch about to go???!??!??!???
  52. Ti intercooler pipes
  53. aftermarket clutch review
  54. Transfer Case Replacement [MERGED]
  55. Installed a BOV, car threw a cel
  56. Forge Blowoff Valve
  57. Aps Products: Good Or Bad
  58. for those who has greddy profec b II
  59. Can anyone tell me what these codes mean?
  60. how does your boost behave after WORKS P2?
  61. max bhp std turbo - facts please!
  62. Volt gauge Question.....
  63. aps piggyback installed + dyno runs
  64. Has anyone been able to test PSI3's single DIN data monitor?
  65. Changing Your Turbo????
  66. max bhp of std turbo?
  67. test car
  68. Ralliart Super Traction Front LSD Kit
  69. Looking to buy a BOV with the whistle sound, not the WOOOOSH
  70. Boost guage pods
  71. BuschurFlash Stage 3
  72. The Big Bang????
  73. Need new clutch.Help...
  74. Lag?
  75. FMIC comparison...
  76. New dyno sheet - Buschur upgrades
  77. Just Got BushurFlashed!!!!
  78. HELP! Symptoms of leak in I/C piping!
  79. boost gauge vacuum readings?
  80. Asking the length of original HKS SSQV adjusting nail thread.
  81. where's the water tank for the intercooler spray for EVO V?!
  82. HKS Hiper or SS
  83. Greddy Titanium, angled or straight?
  84. Is there an official TSB for 5th gear grind
  85. Hks .272 Cams
  86. Buschur Exhaust
  87. Magnaflow High Flow Cat?
  88. Open or closed deck
  89. Off to Pruven & AL
  90. tuning needed w/ turbo-back/RS intake/boost cont.?
  91. Clutch replacement advise ???
  92. Buschur...you just got a new customer....
  93. Question when putting in cams?
  94. Good customer service
  95. Clutchmasters Stage 3 Clutch
  96. t4/t3 powered evo
  97. Clicking noise when you press down on the clutch.
  98. Timing Belt Install
  99. specs on stock turbo
  100. Camshafts/WHP expectations??
  101. free mod on maf
  102. Pipercross induction kit?
  103. Peak boost at 1st & 2nd gear?
  104. Turbo Upgrade
  105. cyclic low pitch noise from drivetrain.....maybe?
  106. what tranny mods do you guys have?
  107. Tevolution
  108. The best TURBO
  109. stock turbo
  110. Boost Question
  111. evo 8 different?
  112. Spark Plugs
  113. A mechanic told me the EVO has self adjust valves, no need for a TUNE UP.
  114. HKS GDmax Clutch Install help!!
  115. AEM replacement filter
  116. Did I get a lemon? -_-
  117. ET on br500 turbo kit numbers/availability
  118. o.k. all you tuning gurus, answer this....
  119. Fuel System
  120. Buschur Stage 1 vs. Buschur Stage II
  121. Aout HKS SSQV BLow off valve
  122. HKS RS filter replacements
  123. NEW MODS IN...3inch intercooler piping (jdm welded) and many more mods
  124. blitz fuel injectors
  125. Buschur Racing dyno sheets as promised...
  126. Lowest possible safe boost?
  127. Has anyone tried a sheet metal intake yet?
  128. Help, broke something while tweaking BOV
  129. Parts for EVO 3 Motor Build Up !Please Help!
  130. 650cc injectors fyi
  131. Is it ok to replace my cams w/ HKS?
  132. Stock clutch broke....AGAIN!
  133. EST WHP with these mods...
  134. Need help!!!
  135. Super Wheels
  136. Is it possible to convert an Turbo XS RFL to a recirculating BOV???
  137. AUTRONIC vs ALL
  138. Plug wires....
  139. just installed my Buschur turbo back and....
  140. Stock Head Bolts
  141. 1/4 question
  142. results of my oil analysis !!!!!!!!!
  143. Help With Check Eng. Light...
  144. 4G63's limits
  145. Turbo XS RFL bov
  146. stupid question
  147. will dsm injectors fit evo?
  148. Unorthodox Racing pulleys, what do you guys think?
  149. Helix DP and UR Highflow cat
  150. UTEC vs XEDE
  151. XEDE or Dynoflash: POLL
  152. o2 Sims
  153. Looking to Buy Upper/Lower IC piping
  154. Need opinion/help with Buschur Exhaust...
  155. Shiv says test pipe worth 15 whp over 3" high flow cat
  156. anyone logged their timing for 2000-7500rpms ?
  157. Someday Fast, Someday Slow!!
  158. need tuning tips
  159. Fuel injectors .. anyone noticed ?
  160. Guys check my plugs...Pics
  161. GAIN 12-14WHP for only 200$!!!!!!!
  162. Buschur Flashed........WOW.
  163. New clutch and notchy question?
  164. Works Vs Jun Vs Hks
  165. The Evo is almost there :-)
  166. Tunning session with Justin Neni of Tuning Concepts
  167. Tuning with S-AFC
  168. Is my Profec B defective?
  169. How much should i expect to pay to have a shop replace my clutch?
  170. Worth getting upper and lower IC piping
  171. Best Cam Gears/shafts??
  172. 20g
  173. Is anyone running 11's WITHOUT race gas?
  174. head studs and injectors necessary??
  175. For those using GT35R Turbos
  176. New transfer leaking
  177. Engine stumbles at part throttle accel
  178. question about turboback
  179. that's enough! re-installing my Cat
  180. Would tuning be needed.......?
  181. Boost control voids warranty!
  182. Tranny noise when I downshift into 2nd
  183. I know the car runs rich but DAMN!
  184. How do you stop 5k rpm boost drop off?
  185. Tranny problems
  186. For those with twin plates
  187. MMi Dual Stage Ultra Boost Controller
  188. Im seriously considering a VNT conversion on my turbo
  189. Possible bad synchros
  190. looking for good prices on mods...
  191. Is the evolution's engine closed or open deck.
  192. Vishnu Tuning
  193. Over boosted ???
  194. Defi D gauge
  195. Clutch engagement changed and hard to get into gear!!!
  196. gear oil and other fluids
  197. Tuning
  198. Questions about boost and boost controllers
  199. JIC Magic 505ST
  200. ok, going the basic mods, need tips
  201. Fuel Pump??
  202. Please explain the ECU flash please
  203. CG GSR computer upgrade
  204. ive blown my engine. can our engines last help
  205. light flywheel
  206. Magnaflow
  207. Cams Upgrade
  208. Which BOV?
  209. installed some goodies
  210. Oil Catch can?
  211. What to use to display A/F ratio's?
  212. Loudest catback for the EVO???
  213. Question about the idle
  214. Turbo XS RFL TI Exhaust Questions...
  215. Experience with individual throttle body intakes?
  216. 2000 miles = engine repair :(
  217. What motor will hold more power on the stock block?
  218. Air Fuel Controller or Boost Control
  219. Boost control info ?
  220. RMR products or NOTHING AT ALL
  221. Anybody got the new Greddy Titanium cat back yet?
  222. 2 hour 45min Clutch install !!!!!
  223. ECU Reflash on Turbo/Engine life
  224. What can the stock turbo be boosted to at a safe level?
  225. stock evo turbo
  226. Need Help!!!
  227. Eye Candy - look:-)
  228. 2004 Front LSD
  229. Car wants to move forward while in neutral
  230. A different turboback question......
  231. Works Valva springs and TI retainers: necessary or not?
  232. Rear axel clunking!
  233. When installing the ARP head bolts, is there an aftermarket gasket?
  234. got that fuel smell in your oil??? wanna know what it is??!!
  235. Got my 3" RS-R Turbo Back with Ultimate Racing Hi-Flow Cat
  236. Fuel Cut !!
  237. When installing the 264/272 cams are new head bolts needed?
  238. Noise when accelerating and turning
  239. Engine Block Heater?
  240. Were is the ACT Man?
  241. SKUNK2 Cam Gears
  242. How much leaner
  243. which wire do i splice for speedometer..? for turbo timer?
  244. ECU Flash
  245. Dark oil
  246. Pulled a code, but don't know what it means?
  247. 5mph???
  248. Grinding noise with the Turboback exhaust?
  249. HKS GT3037 turbo kit
  250. Greddy T67 25g VS. HKS GT3240
