- Anyone recognize this exhaust?
- Good price for used gt35 turbo?
- Sticky Gear
- Wiseco or not?
- Tial Q help..
- Does the manifold really matter?
- My Engine blew on the dyno
- Oil pressure problems, please advise
- Boost controller Thread MBC vs AEM Mac valve
- 3 black spark plugs, 1 not...suggestions?
- IAT GM sensor help
- Need Pic of 1/4 TiAL 50mm line location
- Radiator Aux Fan Help
- evo operating temp
- Which Clutch should i go with - Build Specific.
- which intake/inlet pipe??
- ETS UICP and SD IAT sensor
- machine shop for block in michigan
- ingredients for 400 whp on evo9 turbo
- balance shaff
- Next Mod help please
- Turbo Question
- Differences between Manley I beam and MAP I beam 150mm rods?
- soooo how high do you rev your stroker?
- Who's running the Buschur cams? Buschur Vs S2
- World Time Attack qualifying: #1 Nemo / EFR 8374 #2 Tilton / S300SX
- Anyway of Reviving a WB02 Sensor?
- how to take tranny off a 2003 evo 8?
- Bushwacker Stage 1 making rattling noise (Sound clip attached)
- How do I switch to a non-acd tcase !!!
- Experts help please. P0462 Fuel Level Sensor Circuit Low Input.
- Home made double pumper
- Newb question
- Which bottom end to go with...
- Lean idle, yes i searched
- 2.0L enging upgrade,need your advise!
- Soft clutch pedal
- Carrillo H beam rod bolts
- Quick trans questionnssss
- Loss of power at High throttle
- Need to build transfercase or transmission over 600whp ???
- frount motor mount?
- pt 6265 upgrade?
- Lock
- Will these parts fit my Evo 7?
- Drilling for transmission temp gauge, has anyone done this?
- 550 whp setup !
- muffler delete = loud turbo?
- Coolant relief hose on firewall, or a severed line?
- Rear main seal housing - gasket or rtv?
- 2.4+6466 fastest possibe spool?
- Oil pressure light comes on, pressure gauge reads fine?
- Full head build questions
- Are these the stock under hood bushings?
- building Ultimate 5spd
- Evo won't start...HELP
- Only 28psi??
- Only 28psi??
- metal on metal ringing/rattling drivers side Please help!
- Excessive Side Loading on Fresh Motor?
- Choosing a aftermarket Exhaust Header
- Clutch Noise
- vacuum leak! please help
- A/C issues
- Stock turbo vs td-06 20g
- intercooler coupler keeps blasting off, need advise!
- Catch Can/Breather Setup
- Help Choosing EBC after MBC Fail
- problems with oem valve stem seals
- Switching from non-CDI to CDI?
- Jun 264º Cams Issues
- What is the best Intake Mani?
- gt3586r spool question?
- ATP GTX3076R - smoke from exhaust after hard deceleration
- 35r install ?? Helpppp
- Opinion on my 2.0 Build Plans pls
- 1.8 bar on stock internals?
- 02 dump exited by hood vent
- Tomei M7960 not boosting fully (120 kpa) until around 5k rpm
- Franken-motor
- evo 8 strange random grinding noise
- '05 Evo 8 3rd and Reverse trouble. Help
- need help degreeing cams..
- evo 8 800hp build help
- Wastegate preload mod questions
- Some issues, need help...
- 06 evo MR engine replacement
- spark plug gap setup..
- Evo ix oem springs/catback/downpipe/02 housing/wiper & motor
- Pls advise on this turbo...
- vacuum line unconected
- 84mm intakes vs. stock inlet - power gains?
- Cam gears with 2 dowels
- Evo 7 - 8 transmission synchros
- map o2 dump leaking at idle.
- thinking of turbo to switch to
- Is it worth it to upgrade my cams at my power levels?
- Need some help new Evo owner!!!
- Oil cooler line!!
- Valve Cover Gasket + Mitsu-Bond
- Competition Twin clutch guys: step inside, having an issue
- Sparktech COP CDI vs Non-CDI
- wavespring part number
- Mishimoto shroud and fan...
- buschur racing maf pipe
- Looking for an Evo V ECU
- Low Boost
- high oil temps opinions please
- Head Gasket or Not?
- Cams
- Evo 4 main bearing are the same as the Evo 3???
- Issues with my engine. Need Help!
- GSC S3 vs. Kelford 280
- 4g63 Engine noise, balance shaft?
- Should i buy the gt35r
- stock car with cams??
- Clutch won't disengage :-(
- Speed Density Question !!!
- evo 8 weird tranny noise, help please
- Need help wih parts for my Evo 8 MR
- boost gauge reference question.
- IX MR will idle at 3k rpms?
- evo 9 mr wont go over 5mp
- 2005 Evo 8 No reverse. any help? video inside
- knocking sound on cold start up
- Nisei mini battery post
- Push style clutch compatibility???
- Twin charge ??
- QM 8 leg clutch issues. need some advice.
- Clutch for a slightly moded DD!?
- Cams help??
- Riddle Me This......
- Whine from my rear diff/drivetrain (not death whine)
- Used 5 speeds price?
- silly question
- Possible T-case leak?
- Another "What Cams are These?"thread.
- P0172 car keeps throwing this code
- motor mount bolt size?
- Fluidyne radiator
- quick ac compressor question
- Anyone know of or have an extra ACD rebuilt kit they want to sell for less than $200?
- how to make turbo hit earlier
- Quick question on DiaQueen Super Multi Gear Oil 75w85 part # 3717610
- Need URGENT help. Solid shifter bushing broke of with the pin of the gear selector!
- Need some input
- Greedy evo 2 Exaust System
- Forward facing turbo questions!
- How long to use break in Oil?
- Noob Question about Limits of Evo MR Transmission
- 4Th gear turned into Neutral. CLutch issue?
- Thoughts on BBK 3b/stock cams
- Which coil on plug?
- Injectors leaking after new IM installed...
- Oil sender install help
- AMS Intercooler
- timing belt tension
- new build
- evo IX air conditioning gurus
- Crushed head stud washer?
- Oil pressure question.....built engine
- Homemade oil cooler
- Shep transfer case price?
- Best Turbo for 2.3L?
- Transfer case shaft pops out
- good mbc
- Who's running stock exhaust?!
- restacked plates - clunking noise from diff
- Evo 8 no spark
- I need 3inch piping exaust system that's not too-loud
- Spark Plug Cover Hole Leak
- bigger compressor wheel in 8 10.5 turbo?
- Over heating question
- My Homemade Tcase/Rear End Fluid Filler Tool
- does the factory 6 speed fd ring and pinion fit a 5 speed transmission??
- Need some advice with getting new injectors
- Good power but WTH with traps/ ET's
- Looking for all EVO 8, 9 people with 6 speed still.
- How much Boost should i run with my evo green turbo
- EVO 8 Cam profiles(technical)
- exedy triple questions
- MAF Sensor on intake needed?
- just spun a bearing, whats the best to go with pistons rods etc for alil more power
- FTW Purple Race fuel press release!!!!
- STM Oil Inspection Hole Breather - What fitting?
- evo ix interior fuse 1 blows instantly
- is it ok to buy cams with 35k miles one them?
- RC 1200 Injectors Install. Loose?
- I have 1000$ And a STOCK Evo 8 ! What do i do ?! HELP
- Can i plumb back to the IC Piping?
- Mitsubishi OEM turbo codes
- -10 AN fittings on valve cover ?
- water temprature high or normal?
- Have some questions on installing a fuel cell in an Evo 8.
- i blew a coolant line, but i cant find it...
- intake charge system malfunction
- Crimp spliced (no soldering)?
- Evo 8 low idle, stalling when cold...
- Clutch fork stuck all the way to the passenger side
- HKS Air Filter
- Exedy Twin Clutch Issues - Need some help
- Rear diff help
- Transmission Issue, Can u figure it out? doubt it
- Whats a decent clutch for the evo 9
- fx300 or comp clutch 1620
- my new ff set-up with working ac!
- Need a timing belt, and on a budget? Here's how!
- Clutch rebuild. Necessary parts?
- Leaking Fluid.
- Just Ordered My FIC 2150's
- is this a stock evo 8 piston??
- Turbo/exhaust setup questions
- Shaft Play : Gearbox to Transfer
- Evo 8 clutch install
- WTB used 156mm Rods
- What would you guys do?!
- engine oil question
- Transmission shift rough
- Turbo issue
- Did SpoolinUp Go Out of Business?
- T-Case Rebuild OEM ring&pinion w/LSD
- Need confirmation on specific name of part
- Timing question
- help antifreeze leaking from dump tube
- True short shifter (metal cage) for 5spd?
- Which fuse to pull for Compression Test
- New clutch
- bone stock evo 8 w/9 turbo
- Anyone good with evo trannies in NJ..NY/PA?
- WTB 2.4 block for my 8
- 2.3 Stroker life span
- Over heating/ weird noise?
- Let's play Indentify which fp stock framed turbo is this?
- Carbonetic Triple flywheel pictures?
- FMIC outlet Repair ??
- Building boost oddly
- preload/sputter, HELP!?
- Turbo selection ?
- Perrin fmic w ams licp bumper dont fit back on
- WTB 06 Evo oil feeder control valve
- Another TOB Clip popped off. What are the tricks to fix?
- Competition clutch ic pipe clearance ?
- What would be a better buy?
- Compression test on a built motor??
- Broken Banjo Bolt
- 6262, 6766, 6768 details
- High fuel pressure at 3k
- ACD bleeder valve leak, again
- Clutch replacement ?
- Help needed!!!
