PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 [200] 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. APS 3.5in Exhaust
  2. eliminate boost taper with elec. boost control?
  3. mounting the SMC alky controller
  4. Check Engine Light
  5. question on tial wastegate??
  6. Something wrong with my car...
  7. Random misfires, help!
  8. need advise from you guys
  9. Clutch and noise
  10. Help With Misfiring Cylinder!
  11. Question about running the EVO on 2wd Dyno?
  12. help....whats the benefits of cam gears
  13. Boost leak @ TB
  14. HKS Carbon Ti Clearance Problems
  15. HKS RS Q's
  16. Hallman Boost Setting
  17. Weird Noise Exedy Twin Disc
  18. Boost Leak or Turbo Spike?
  19. Modifications for backroad running and occasional track days
  20. black markings under valve cover?
  21. MoTeC M800 PNP Testing
  22. mini battery kits
  23. Clutch install question...
  24. evo maf maxxing out???
  25. Car low on power any ideas
  26. GT35R+3.5 Exhaust Piping?
  27. Downpipe Question***
  28. Need advice on internals of head/motor
  29. need help understanding how boost is controlled
  30. I'm going to the track tommorow,and have a question!!!!
  31. catch cans?
  32. Walbro 255lph????
  33. Buschur Racing *NEW* Spark Plug Covers
  34. Hks Twin Power Vs. Buschur Coil On Plug....
  35. White Rabbit Discussion - MERGED
  36. Do I really need a flash??
  37. just bougt turbo should i go 02 housing?
  38. Pre-Oiling/Priming New Motor?
  39. How much whp am I looking at with these mods?
  40. Seperating Transimission and Transfer Case
  41. This is why I love my FP WR! Video inside.
  42. intake help need to pick one!
  43. boost leak..help please
  44. Loss of Boost.
  45. louder exhaust after installing cams
  46. BS or not?
  47. EVO VII Throttle body leak,
  48. Need a machine shop for headwork
  49. John at TRE
  50. EGR Codes/ Misfire Codes and Dripping a lot of water! Help?
  51. problem with evo.. need help experts
  52. Tranny swap...
  53. Stock turbo efficiency?
  54. My compression and leak down numbers-what do you think?
  55. Does intake do more harm than good?
  56. Turbotrix tune+272/272 Cams+Troubleshooting help!!
  57. clutch pedal feels grainy, not smooth
  58. Boost Juice?? Methanol / water premix....
  59. What company will flow-check injectors?
  60. 02 Simulator?
  61. Headers vs. Ported exhaust manifold
  62. A couple of questions... noises..
  63. Turbo XS RFL-TI EXHAUST IS LOUD!!!(Pics)
  64. RnR GT3076R...Unbelievable Product
  65. Balance-Shafts Explained
  66. Over 800 hp @ 4 wheels
  67. Gear ratios and MPH
  68. Advice on Hks 272/280 cam set up
  69. anybody makes a NON stianless steel header ???
  70. Mod help please..
  71. Rattling under car?
  72. What size injectors w/ 272/272 cams
  73. Actuator adjustment and boost taper?
  74. Is my stock BOV installed correctly?
  75. Forged Transfer?
  76. tranny noise help
  77. Need Help Please!!!
  78. Gain to expect with Catback?
  79. Faster spool-up on stock turbo?
  80. Did only 350 AWHP ruin my triple carbon clutch?
  81. Review of new Buschur "RACE" fmic kit
  82. Forget about the Greddy T67 RVO Turbo upgrade, how bout the TurboTrix EVO 8 kit?
  83. 260 hp seem a little low ??
  84. I'm considering getting the Greddy T67 EVO 8 Turbo upgrade
  85. Problems with the transmision :)
  86. Big Trouble,,,engine died while driving....
  87. BG Syncroshift I & BG Syncroshift II
  88. just got dynoed for the first time today...
  89. check eng light after clutch install ??
  90. Wich downpipe for 05? With Flex Please!
  91. spoolup?
  92. Fuel temp?
  93. Acd Please Help!
  94. GT35r spoolup answers here
  95. hks evc v: i need help with hoses (confused)
  96. New Emanage Ultimate question
  97. RPS carbon/carbon rattles, need advise
  98. Alky and Race Gas
  99. exedy twin disc rebuild kits?
  100. looking for intake kit w/o MAF
  101. ACT after break in question
  102. HKS 280s Cam Gear Settings
  103. Apexi intake owners with MAP sensor
  104. Having engine problems, need advice
  105. What kinda cams for daily driving??
  106. What manifolds will work with Greddy T67 turbo?
  107. Flashed White Rabbits: Please post your numbers Here!!
  108. Boost Controller ?
  109. screw size for Downpipe
  110. Coolant question
  111. ARP HS install ????? Any symtpoms for an improper install?
  112. Patient Mr. White Rabbit on operating table
  113. wtf...clunking noise???
  114. Weapon*R's New SPL Edition Parts
  115. Best sounding exhaust?¿
  116. 1st gen eclipse
  117. HELP: white smoke from exhaust problem?
  118. Which Boost Controller
  119. Capacity of IC sprayer tank?
  120. Water Wetter directons...
  121. Vid: Is this normal for a trans?
  122. Cam sound clip?
  123. Ult.Racing 3 inch hiflow cat fit apexi GT exhaust/dp
  124. outer diameter of stock turbo inlet?
  125. spec clutches?
  126. 03's with the 10.5T
  127. Intercooler Piping!!!!AHHH
  128. Hallman Pro RX (ceramic ball) MBC
  129. Boost cut on the 03 Q
  130. HKS bolt up to Helix 3" hfc/dp
  131. Couple pics of my new upper pipe
  132. DIY Pressure tester (pic) and leaks found so far
  133. Hallman MBC
  134. just installed my AMS LICP
  135. Difference in 03-05 and Evo IV turbo?
  136. Spoolup question?Help
  137. Exhaust Manifold Torque Specs?
  138. Stock Exhaust Manifold/Heatshield Bolts
  139. please help me....
  140. Coil on plug using stock coils?
  141. WR Dyno Post Here
  142. Problems after clutch install...need help!
  143. HKS DLI-II Full review
  144. Wrap it up or not?
  145. Wrap it up or not?
  146. Just installed a Stillway engine dampner
  147. What bolts did you use on your downpipe?
  148. help...apexi GT dp
  149. The heat is on... Please help!!
  150. power switch for alky kit
  151. Vishnu Stage II - Turbo Adapter
  152. need help! clutch question
  153. How much boost shall I run?
  154. Downpipe Fitment
  155. New Spark Plugs = Loss in Performance
  156. EGT Probe Placement Idea?
  157. t76! picture inside!!
  158. Want to run race gas, stock headbolts safe?
  159. What size injectors
  160. Oil Leak After My Oil Change
  161. POS Weapon R Engine Dampner
  162. Anyone have issues with Dynpacks and their clutches?
  163. apology and revision
  164. DC sports Downpipe with 2005's
  165. Help help help **** **** PLEASE HELP BOOST ISSUES
  166. Injen inake and IC pipe kit?.....
  167. Catch Can or Breather Filter??
  168. *NEW* Buschur Racing Shifter Bushings
  169. how do i tune the E-01?????????
  170. Any gain to be had running open downpipe?
  171. MIVEC 4g63 tuning
  172. TurboSmart VS Turbo XS MBC
  173. question about 10.5 hotside!!!!
  174. ? on trans fluid before changing it!
  175. loss of all power at 3k rpm
  176. Clutch/Flywheel ??
  177. Want 480whp with meth HELP
  178. a few ATP GT3071R questions
  179. Idle Adjustment
  180. too much power?
  181. any garrett t-67 owners???
  182. what do you think about this turbo and price
  183. HKS vs. Turbo XS
  184. Clutch
  185. Which looks better exhaust on angle or straight out
  186. How do you check a wastegate for boost leaks ?
  187. Oil consumption??
  188. Spark Plug Removal
  189. My trip to Dyno4mance
  190. Hose between LICP & Frontmount Ripping?
  191. MSD DIS-2 wiring
  192. HKS EVC boosting issues??
  193. Helix vs RSR
  194. Difference between piping
  195. Helix taper????
  196. Buschur/Forge High pressure wastegate
  197. Rs-r Exhaust Problems Need Help
  198. Boost Taper
  199. Low temp thermostat. Tech answer pls
  200. Blitz drop in?
  201. Stock Evos Diff %
  202. Clutch change, evo 7 GSR
  203. diameter of OEM "MR" gauges???
  204. alky power vs bigger turbo
  205. Gearshift Lever Retainer (Short Shifter Install Need)
  206. intercooler sprayer!
  207. Chatter/whine in 1st and 2nd gear... what is it?
  208. New Building, New AWD Dyno, New Chassis set-ups.
  209. more TQ than WHP?
  210. Any disadvantage to in-car Hallman MBC?
  211. Cooling fan switch
  212. EGT Probe Questions
  213. What's the best way to tune in my setup?
  214. installed new act clutch... pedal is very stiff...wtf?
  215. blown tc?
  216. how to tell the difference w/ cams....
  217. Whinning noise after install white rabbit
  218. Stock Cams
  219. O2/Downpipe Bolt Size
  220. Ballpark Figure on HP?
  221. Realistic Estimate of HP on 91 octane and stock turbo
  222. Houston! we have a fuel cut?!?!?
  223. Methanol Corrosive?
  224. fluid question
  225. Installed my slim Blitz TT today with the HKS harness *pics*
  226. Down On Power?.. Opinions Please.
  227. twin turbo EVO kit on ebay
  228. Buschur GT 35R EVO install pics
  229. Alright how bad is my evo going to hate me.
  230. tme turbo
  231. Another Happy JDM MR Diverter Valve owner
  232. Bone stock 05 EVO hits 1.46 BAR in second gear???
  233. Exedy Organic Clutch Kit vs ACT HD Street Disc Kit
  234. Greddy RS BOV
  235. where is the boost guage line under the dash?
  236. Cams
  237. Figured out tranny problem...Now another question
  238. weird ticking noise... come listen
  239. why do people dislike megan racing?Megan haters come on in!
  240. Overboost & engine knock
  241. Downpipe rubbing transfer case?
  242. Shifter feels stuck
  243. Throttle response....
  244. AFC Tuning for HKS 264/264?
  245. Stock evo 8 exhaust manifold
  246. Cams & HeadStuds
  247. what do you guys think about this turbo
  248. my alky kit aint spraying...help
  249. Sirens at 3500 RPM after turbo back install
  250. Water injection
