- How do you know if the BOV is bad?
- Where to buy a new O2 sensor?
- Looking for AFR data for an VIII
- Determining Correct Injector Size
- big FMIC conseqneces.
- 4G63 question
- pinging and bucking - no codes!
- Case Study # 350 - Comparison - IX20G turbo vs GT35R
- Case Study #349 - Why I love stock injectors & what happens when you buy a bad one!
- Clutch questions
- Rattling after turbo install
- compare the gsc cams and cosworth cams
- Where can I find polished upper raiator hose
- Evo 9 axels
- Mangus Intake Manifold, Good or Not??
- Apexi AVCR Vs HKS EVC V
- evo 8 turbo vs evo 9 turbo
- Anyone with a NON-Ball bearing Turbo Updrade PLS READ
- Uprated cams
- Code PO230 Engine Overboost problem
- Blitz Car Induction Kit
- Camshafts Solid Or Hydraulic??
- CEL not coming on for disconnected catback o2 sensor
- Forge BOV
- anyone have the perrin TBE ?
- 50 trim or gt35r
- ACT HDG6 - Best clutch for the money?
- Disassembling an Evo 9 turbo?Expert Help needed!
- 50 trim or 20glt
- Changing Shift Knob and Boots
- stroker vs turbo
- oil questions
- Anyone running a NON ball bearing 50 trim?
- Oil Galley? Stock Turbo Bracket?
- Do you buy cheap japanese car and parts?
- fabrication ?'s
- Help with test pipe
- 50 Trim Turbo Kit
- Fuel Pressure Regulator MOD
- Help!! -AN fitting frenzy!
- Main bearings and rod bearing gone... :(
- p0335 problems
- Is getting my head ported worth it?
- are these good prices?
- Code P0234??
- Does This Sound Like a Fair Price?
- Turbo xs BOV adapter plate
- exedy twin clutch wtf need some help
- act clutch
- I ran out of gas today =(
- oil temp reading on triple mitsu gauge
- Awd to Rwd
- 2nd gear throw
- For those that have installed a transmission cooler
- Testpipe Vs Resonated Testpipe
- EGT wire colours on replacement probe for Apexi gauge
- Clutch help!!!
- Is this a boost leak??
- electric/manuel cutout
- Springs and Retainers on IX's w/mivec
- EVO turbo upgrade
- shep trans, tilton twin
- exhaust manifold??? need aftermarket or keep stock??
- has anyone tried a centerforce DF clutch for an evo?
- 30r vs 35r??
- IX Turbo Elbow & Downpipe
- Buschur MBC install
- British 8.5 MR & FQ-400 cams
- carbonetics clutch
- Any factory Port Shrouded TO4S Comp Housings ?
- Garrett GT3576 Turbo Details please .
- Has anyone ever used ebay IC piping???
- 10 Psi Shudder
- TurboXS MBC questions
- pause at hi rpm 3rd gear
- carbonetics twin clutch
- resonator: bigger = lower exhaust noise?
- Centerforce DF clutch
- is clutch on its way out?
- Which Turbo
- clutch
- Case Study # 340 - Yes I tune AEM EMS - BR Stage IV with GT35R
- fusitsubo cat back and down pipe
- help me
- Need Help
- Vendors, honestly? GReddy Ti for less than $1000?
- hks rs intake or ARC
- fwd tranny for evo 6 engine
- Couple of questions on products...
- Oil.Coolant Lines-Plz Help
- Tranny Fluid GL-4 Part Number?
- P0335 & P0340 Codes at the same time
- Hose clamp blow-off problem bit me today, sheesh!
- Oil In My Intake and Filter
- Blit'z DSBC settings?
- requirements to run 50trims/gt30/gt35r
- GSC 280 results?
- How to ELIMINATE the 35R Fart Can
- walbro with install kit needed?
- EGR Code!!! Is It common and how to fix!!!!!!
- eclipsed evolution
- DownPipes?
- cutting out
- Sputtering problem around 80mph!!!!!!
- Slowboy question?
- how does the exedy street twin compare to the stock clutch
- Drivetrain Kit
- BOV of stock intercooler piping??
- i need TPS resistance value???
- Buschur UICP work with Greddy IC ???
- EVO IX - Buschur stage 1
- Anyone here running...
- the best catch can?
- Is it broke??? Help?
- Boost restrictor pill REMOVAL
- Oil filter relocation
- best clutch
- Head noise need help
- Bung placement on HFC for IX
- boost problem
- normal to hear turbo spin down when turning car off?
- How get more HP?
- Turbo inlet ID and OD?
- RNR manifold and Koyo?
- 358 miles on engine and it's running rough..
- Are clutches interchangeable between 8 and 9 EVOs?
- Buschur Racing 50 trim turbo kit......
- TME, IX, or JDM IX RS Turbo
- What Is The Best Setup To Reach 400hp+
- VNT,VG Like Turbo setup
- SBr Clutch
- Differential fluid
- Bottom End Built
- evo 6 tme transfer oil?
- HKS Type S intercooler
- Intake Decision
- Need help finding vaccum leak.
- Do you really need a lightend flywheel?
- Temp rising- Help
- Notchy feel on release of clutch...
- Cosworth IX cams in
- Boost problem :(
- Boost problem
- BOV Flange Question ...
- Black box
- K&N Typhoon Intake Short Ram
- Stock Cam gears
- Monster Sport Evo VII Air Duct Fitted to USDM Evo IX
- 06 MR dyno numbers?
- Greddy Profec B users chime in
- Turbo for BC 2.4
- best cam settings for my 2.0 with GT37R
- Weird noise
- Boost problem with GT3071R
- Valves clicking after oil change?
- Very weird problem Please help
- Drivetrain fluid?s
- JUN cams
- RMR hard pipe kit owners.......
- Ported exhaust mani+O2 Housing=Awesome!
- All MIVEC upgraded CAM owners...
- Upgrade suggestions.
- cusco twin carbon info pls
- Dyno'd my IX GSR
- Too much boost?
- Need some advice
- Broken rod (crower)
- car hard starting.Need to floor the X plus crank it for it to start
- HELP -- Oil on Transfer Case
- 4" intake ok?
- Perrin Fuel Rail - Review and Install Notes
- did i mess my clutch up?
- turbo whistling and whining!!
- Oil drain plug crush washer.
- trouble with Apexi WS2 Cat Back and Espelir Down pipe
- oil catch can
- few q's on the 20g lt
- leak test help
- Did a boost leak test and my Hallman Pro is the leak
- Misfire at 3500 to 4000 rpm
- max boost stock turbo
- How to crush JDM MR DV?
- FPEvoGreen First Impressions
- Tranny screwed
- fouling out one plug..
- Transfer Case problem pics inside...
- Update on build (pics)
- What else with my BR 35r kit?
- bov prob. i don't know
- Boost controller problems...HELP...
- 3500 RPM Engine vibration
- ACT HD with Gruppe-S Fly
- Found boost leak problem....please help.
- Trouble with methanol injection
- yes ANOTHER 2.3 35r build...
- IX dyno numbers
- Trouble shifting gears
- Boost problems
- electric cut out
- Transfer case what actually fails ?
- fuel pump stock or not?
- boost problem
- cams
- Part number and name request
- Heater Problem ...
- my boost leak w/APS bov: video
- boost??
- Shifter Bushings :: Underhood or Base?
- Noise coming from rear end?
- EVO IX...ARP Head Studs Question
- tune with o2 housing
- Took my car to mitsu to fix my grind...
- Built 2.4L Block with GT37R???
- how many people running 50 trim here
- HFC takes a poop.
- Idler
- Car hops in 1st gear
- need help..have question ?
- What clutch do i have?
- Reflash and Boost controller add 60whp??
- Vac line Routing question on sheet metal intake with aem ems
- OK GT35R Setup AMS
- Pics Request
- Case Study # 335 - Stage I Evo IX - good tuning picks up great power
- Stock airbox restrictive?
- Installed MBC and Downpipe/Cat-Delete and now problem
- Anyone with Magnaflow Sport exhaust?
- Best HFC for a IX with 02 bung in stock location???
- greddy sp2 cat back
- Sectioned Exhaust Tip
- ignition upgrade???
- CAMS on EVO IX????
- Got tuned with turboback Now im back to stock is this gunna mess anything up?
- HKS 280 Cams and stock valvetrain and more questions
- Kelford cams 280's
- stock intercooler sufficient for 50 trim kit
- Greddy full auto timer - questions
- Boost Controllers
- Turbo problem :(
- Exhaust Manifolds for IX
- Evo Spark Plug Wires - MSD Super Conductor
- ACT HDSS vs XTSS
- Squeaking sound from engine bay. timing belt/water pump?!?
- Need Advice Tonight! Maf Sensor Issue
- Help!!! Car bucks forward only loud popping noise when rolling forward!!!
- Head Cam Caps swap
- Evo8 on a Two wheel drive dyno????
- MAF Translator Blow Through....
- EVO 8 With out ACD ?????
- big turbo vrs little turbo
