View Full Version : Evo Engine / Turbo / Drivetrain
- weird jolt at 80mph accelerating
- exhaust manifold
- Anybody useing water injection?
- rev limiter
- egt readings
- Those w/ Hks Evc 5
- Tuned Evo race Tuned STI
- How much is a stock Evo turbo worth $$ wise ???
- Friction Modifiers in the Transfer case??????
- Best Tranny, Diff fluid combo.
- Type S
- STI vs EVO (twisties)
- 1g Blow off valve
- boost controller settings help
- Installed stainless clutch line, does this look right?
- Whistling sound from aem intake
- exeedy twin disk
- Need opinion ASAP on HKS BOV
- Blowoff valve or Bypass valve, anyone?
- Rre Greddy Type S
- GT35R Kit Vs Greedy T67 Kit
- Best Way to Spend a G under the hood?
- Cam Gear Installation
- Unused Oil Port?
- Help with Turbo XS Exhaust!!
- Walbro Fuel Pump HELP
- Buschur Upper-Intercooler pipes
- 4G63 twin turbo
- Please advice, Please help(turbo)
- How much HP/PSI can a stock FMIC take?
- Is there such a thing as too short a shift?
- Looking to make custom downpipe
- Custom intercooler pipe for under $50
- RMR or ACT 6 puck clutch
- boost?
- timing question
- Hks Fcon S "evo Vii"
- Clutch Wanted INPUTS please
- TurboXS DP question
- Race Gas (C-16)
- Clutch is slipping
- What kind of Power steering fluid to add?
- EVO keeps leaking fluids....
- Help on DPs.
- Headers/Turbo Manifold
- This is awesome, listen to this....!!!
- Intakes!
- How can you tell if you have a bad syncro
- BIG Problem !!!??
- Serious Electrical problem!! HELP!
- quick easy hks ssqv adjustment question
- exhaust w/resonator pipe?
- hks cams
- Which is best oil catch can, if any?
- Questions to setting battery voltage, A/F value. and O2 sensor on Apexi Turbo Timer
- TurboXS DP + UR cat + MR Exhaust
- one hard launch and, clutch maybe gone?
- Why not RL Heavy Shock Proof in the TC?
- L.S. 3" Downpipe install questions
- is $75 good for a 0s simulator for the cat?
- A work in progress- EVO parts
- Make A Flamethrower Kit?
- How much can the stock internals handle?
- quick question about Pressure testing for boost leaks?
- Little help with hesitation...
- AEM SRS or KN Typhoon
- boost controler
- Clutch issue! I need your help!
- Ralliart intercooler Piping kit
- intercooler fluid
- Spark Plugs
- Hey all, some questions regarding some pipes :)
- Apexi Power intake filter
- Best BOV for my driving habits
- Competition Cams
- Where should i go next
- Cam and Fuel Delivery setup
- What could cause a T0138 code?
- Stock exhaust diagram?
- O2 Housing
- Exhaust Bolts (JIC exhaust)
- Cold air intake a bad idea?
- Questions on Pill Removal and Evo 8 and 7
- Will boost leak if cap on turbo nipple is missing when u have a MBC?
- Still cant hold boost plz help
- Cylinder Head Poll!!
- Have U Switched Flashes please read
- Greddy typeS lower vacuum port
- Tomei Cams
- t70 turbo?
- HKS a/f knock amp
- EVO VIII vibrating noise
- hks rs intake need oil?
- Does anyone have a picture of the stock lower I/C piping?
- New stock clutch
- My clutch!!!!!!
- Transfer Case Weakness?
- What's going on with my clutch and brakes?
- Bent my intercooler!
- exhaust help
- Megan Racing Downpipe
- need settings for evo8 stage1 afc2
- Just had 5k worth of work done...
- No boost taper on stock EVO
- Boost spiking to 1.5 bar or 21.7psi
- Help! Evo is making loud while while turning
- comp cams?
- Analyze my spark plugs
- Greddy Type S problems... slight leaking at idle and low throttle
- DC Sports SS Cat back now available!!!
- Octane: How much is too much for the 4g63
- Where can i get Dyno Flash
- Turbo kits for us
- cusco clutch
- SAFCII or ECU+ or Emanage?
- Best clutch for the money?
- Spark Plugs??
- Who would mod/tune you car?
- Anyone know anything about Works?
- ACT clutch question
- Limited Edition Gold/Red SAFC II in STOCK!!
- Clutch/Decel/ Letting off gas to quickly?
- help me!
- Hks Ssq Bov Kit
- Aeroshell 15w50?
- Ceramic Brake Pads
- My Viscous center diff took a dump
- 0 weight oil
- Buschur 3" catback datalogs
- Will 117 octane hurt performane if car is tuned for 100 octane?
- Suggested Oil change intervals?
- 272 cams...which valve springs
- Gauge Accuracy?
- HKS Super Sequential Or greddy-S
- Guages for CraigHardy
- What to buy?
- EVO8 Exhaust System Changeover: noob
- Downpipe & manifold for Evo 5
- Best Electronics for Evo 5? E-manage?
- poor boost on low gears .....
- Whats the best flow?
- ECU reset question.
- Service Engine Soon light after installing MBC
- car shudders at partial throttle as turbo spools up...
- kpa to psi conversion
- Emanage w/ bov VTA
- Cool Air Intake Guide
- Help me build my Evo 5
- Apexi Power Intake = Lower Boost ??
- Anyone else have this problem?
- 272 cam stalling issues
- Loosin BOOST with Hallman
- Fuel or no fuel?
- I need engine tuning or a flash
- Recieving Greddy Type S BOV very soon, anything special i need 2 know?
- Anyone have the Monster Sport Intake?
- question about ACT Street Clutch
- Mod #2 Installed... :)
- Walbro 255lhp
- Engine Knocking
- Pictures of my Helix catback
- Finally On My Way [MERGED]
- My new Greddy IC
- Aftermarket Wastegate
- what gives?
- HELP was going about 75 down rt 80
- Zing Sound What is it?
- Shane's Weekend Fun, story time, 'chall -Part 1
- Cut at upper rpms?
- Turbo Timer caused electric malfunction????
- blitz bov can only hold so much boost?
- evo has no power and has noise!!
- Write-up on dual stage boost controller
- greddy bov doesn't sound like a greddy bov
- GReddy BOV Type S... how to DIY ?
- Apex i GT exhaust
- Moded EVO
- Used Oil Analysis - 15k
- Woops, little 'accident' while installing new fmic.
- Will the 740cc injector mod work on an EVO?
- Titanium in The House!........
- urgent oil press gauge install question
- Clunking sound when shifting?
- EVO Scatter shields
- what upgraded intercooler piping to get?
- Anyone with NX intercooler sprayer?
- Ultimate Racing High Flow Cat
- buschur intake, car wants to stall when.....
- how much whp can the stock IC take?
- first upgrade downpipe or exhaust?
- Help! clutch problem - high pedal
- Evo VIII high clutch pedal problem - help
- Hallman bc w/ pics or location?
- HKS CAMS 272i/264e or 264i/272e?
- MAS mesh destroyed
- Yeah, yeah it's another bloody cam thread..
- Boost Gauge questions
- Evo 5 parts needed
- Anyone know how to remove the restrictor on clutch?
- Intake pipe with different Filters??
- which Boost Controller?
- Camshaft Angle Sensor Malfunction?
- Just ordered RNR Racing TI/Carbon TB
- po171 - System too lean (Bank 1)
- Check out this shroud...
- 13.4? Wtf
- Intake Question ??
- Installed Denso Iridium Plugs
- Having some tranny problems...
- Cam Gears
- Free Horsepower by tightening 1 clamp!
- Question regarding ECU & BC...
- Race 02 Housing
- how do you set the boost on hks evc?
- Auto mode for IC water spray kit pulls timing?
- Blown motor or blown headgasket?
- Checking ECU Code
- aem ems
- Shifter lights
- Pics of my Pruven FMIC kit!!!!
- Leaky BOV or Adjusting EBC?
- URGENT!! Need help soon
- Maybe some help on train. problems.
- Confused
- greddy boost gage problem
- Need 264 cams. Anyone in US have any?
- Cams 500+ Whp Evo Viii
- Need a BOV that doesn't....
- boost
- Mustang Mach 1 owner talkin sh*t
- p0300 misfire compadres: take a survey
- MR Turbo
- controlling boost, variable air temperature
- NEED Suport for clutch recall
- Differential pressure
- How many horsepower....
- I Messed Up My Car Then Mark From Quantum Helped
- Leak? or something else?
- should i get turboxs catback or greddy full titanium
- what do I do
- asking:: tighting hoses
- Put in the wrong power steering fluid...
- Evo Launches.......
- What is the fastest 1/4 mile time on an Evo with the stock clutch
- HKS GD MAX twin disc clutch
- K&N Typhoon Performance hit????
- Blitz Turbo Timer/Boost Gauge Question
- What causes white smoke from exhaust?
- 272/272 cam timing test and tune
- Need some info
