PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 [148] 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Cams, Idle, and BISS
  2. Transfer case for my EVO 4
  3. flywheel
  4. My car idles at 2000 RPM
  5. fuel psi
  6. Clutch
  7. ?? Dual fuel pumps??
  8. Need Help!
  9. Power loss with LSD and HFC?
  10. new tranny break-in
  11. what system is better?
  12. Help with short in wiring
  13. uicp question
  14. Injector scaling question
  15. Duel Welbro Fuel Pump - FullBlown
  16. Aquamist Large Pump Meth Kit - review and tuning notes
  17. Camshafts On E9
  18. Stock BOV too Loud after Injen Intake Install??
  19. help.. How do you do this..
  20. Need Help!!! Boost leak? Smoking?
  21. Cosworth Head studs VS AMS/TMS studs?
  22. 2.4 Blocks and measurements
  23. Another ACD question...
  24. Forge RS Valve fluttering @ partial throttle
  25. What oil filter??
  26. Fidanza Aluminium Flywheel?
  27. what would you replace 269 cams with?
  28. new motor break in, and break in oil?
  29. Which Turbo?
  30. what's the best aftermarket radiator fan
  31. Helix v2 cam lob centerlines
  32. My turbo died..need help
  33. 42R questions
  34. gsc vs cosworth vs hks
  35. MR transmissions suck
  36. 264/272 cam gear setting comparison
  37. how can you tell if its an MR transmission or a regular one?
  38. 6spd MR stiff gear mounts....??
  39. What should oil pressure be at idle?
  40. got my green after 3 months, pics inside.
  41. After installing hks 272 mivec cams cant make sure if they are installed help please
  42. Big Drivetrain Problems!!!!
  43. little advice.... on clutch
  44. any one with the Bushur ported jet coated mani
  45. 35R Compressor Cover: 4" vs. 3" power difference?
  46. Smoking problem...
  47. Colder plug for evo 9
  48. Coolant problem
  49. Engine shudders at 18-19 psi and looses power
  50. My IX tuned vs. my old VIII w/ cams and TME tuned (dyno comparison)
  51. HKS GT3037S Installation problem, Plz help!!!
  52. Talk about a disappointment
  53. Exhaust advice
  54. EVO 9 MR, advice on my next few mods, and a few questions..
  55. P0304 CEL Light on 06 MR...Help!!!
  56. Evo8 GT turbo. need info.
  57. Knock sensor readings on a 2.3
  58. No 2nd Gear - All other gears fine
  59. buschur cast manifold vs. tubular manifold eg. full race, ams...
  60. What Turbo Kit?
  61. Trouble shifting @ high rpms
  62. I need help guys, My car wont go into any gears.
  63. SARD R2D2 Blow Off Valve
  64. Where to get o2 housing flange?
  65. How do I make sure I have the new version of the megan catback?
  66. MBC longevity and or maintenance
  67. cam diff.?
  68. Car won't start after being shipped across country
  69. Cannot go in gear after launch
  70. Spark plugs BPR7ES .026
  71. 20g stage 1 @lancershop
  72. Cams... Hks-comp-helix
  73. wastegate
  74. Tranny question
  75. Horrible clacking noise help if you know
  76. New Evo Owner - Mod Questions
  77. Another high flow cat question
  78. cam decision
  79. So I was removing my turbo and then suddenly...SPARK AND A LITTLE FLAME! What now?
  80. Boost leak test - leak from the dipstick ??
  81. Turbo Orgy
  82. 06 evo 9 timing belt
  83. boost problems
  84. If you cant afford an exedy twin disk....what to buy?
  85. CAMS or ALKY INJECTION???
  86. clutch advice
  87. Which front differential?
  88. Just got some go fast parts
  89. ACD + Dynopack = Bad News...?
  90. Max WHP/WTQ with 1000cc injectors on stock ecu
  91. here is a good one, lets see if anyone can help me figure this out
  92. Acceptable Drive Shaft Play?
  93. humming sound after cams, cam gears and belts installed
  94. question about intercooler
  95. fitting forged rods with standard pistons?
  96. Worthy gains in ported/coated stock manifolds?
  97. Pros and cons going from 50 trim to 35r?
  98. Tial BOV
  99. Evo green owners....got a question!
  100. Cusco Tarmac 35/65 Centre Diff
  101. competent shop for clutch install
  102. Drop in Boost Pressure
  103. Check engine code p0441
  104. Rode in a IX with Cosi cams untuned!!
  105. correct way to install DV/BOV pics inside
  106. Breaking in built motor hurts BB turbo?
  107. Where does this harness go to???
  108. Forge Waste Gate
  109. built 2.0 and reworked head+green?
  110. Exedy Organic Clutch
  111. Weigth of my jdm evo8 rs.
  112. Exedy twin disk HD
  113. help with new set up
  114. boost and turbo question
  115. stroker kit
  116. greddy 67r 25g turbo kit
  117. Ok my little reveiw of the S1 for a IX
  118. walbro without a tune??
  119. esplier catback with dc downpipe!!
  120. Transmission Problem?
  121. Breaking in(do's & don't)
  122. 03 VIII stock 16g
  123. P0300 code on IX...anyone else have it?
  124. Clutch delay valve
  125. Want more pump gas numbers-->check this thread out.
  126. more hp!
  127. anyone has pics directly comparing a 50 trim to a 16g or even a 20g?
  128. Starter install...
  129. new Pulstar spark plugs
  130. jackson auto machine(jam) vs cosworth
  131. Performance Package????
  132. Hooked up boost gauge today...and im only getting 17 PSI?
  133. bov on inake??
  134. Quaife????
  135. Intercooler lines blowing off!
  136. Turbosmart BOV Dual
  137. UICP&LICP question
  138. Was seeing lots of knock during tune
  139. Substitute for Mitsubishi's DiaQueen Gear Oil
  140. What years have a 10.5 hot side??
  141. Dependable injectors?
  142. Anyone else with new Cosworth cam results for Evo IX?
  143. cllutch problem?
  144. ACD controls...
  145. clutch install problem
  146. motors acting wierd
  147. timing belt question
  148. Cleaned MAF + BPR8ES plugs + race gas = lean (white plugs/exhaust tip)???
  149. has anybody in here dyno'd a 20glt without cams and fmic?
  150. Tanabe Touring or Borla XR-1 for IX MR?
  151. Downpipe cooking oil?
  152. Buschur 3582R installed!!!!!!!!!
  153. forge mbc problem
  154. aftermarket wga w/meth?
  155. HFC safe w/o tune?
  156. mivec head evo8cams hmm
  157. HELP Figure out noise......
  158. Full Race Turbo Kit Updates
  159. What supporting mods are needed to run a 20G-9LT turbo with 93 oct & meth @ ?? psi ?
  160. Help! Missfire, bov flutter, or something else?
  161. 93oct vs 93+100%METH VS 100oct+100%meth VS C16 racegas ??
  162. GSC S1 Cam Gear settings?
  163. noob who gots a clutch problum
  164. Where to Buy 5 mm Black Vacuum Hose?
  165. Where to Buy 5 mm Black Vacuum Hose?
  166. Walboro 255 LPH fuel pump burning a lot of gas at idle???
  167. squeaky belt?
  168. Anyone Using Aftermarket Radiator w/Buschur Turbo Kit?
  169. What is the LARGEST BOLT-ON turbo available for an Evo VIII / IX?
  170. Full-race's new toys
  171. best streetable clutch setup?
  172. please help me choosing an o2 outlet
  173. noise ?? have sound clip!! all ideas welcome
  174. just tuned a 20glt FP from bushur racing wow iam impressed!
  175. help me out please
  176. My new lightweight seats!
  177. 978 whp ! Dyno Flash Evo 8
  178. My buschur racing pump gas evo
  179. going to the track
  180. Other types of clutches...?
  181. Special Thanks to CBRD!!!!
  182. anyone have any BOV sounds?
  183. Dyno Results... evo ix gsc cams
  184. new turbo for noob
  185. Question about Air Flow
  186. Any trimming for BR deluxe ic?
  187. HELP!!! clutch installed & starter makes noise!
  188. BR Race Intercooler vs. Stock Intercooler
  189. Weird (Buschur) 20G9lt Issue
  190. Time to mod, but...
  191. Brian Crower? Are they good?
  192. Greddy M-Spec Intercooler
  193. Oil Pressure/temp
  194. Which gt35r outlet size is better?
  195. Case Study # 404 - You can not ever boost leak test too much !
  196. [B][/B] Weird Sound Coming From My Evo MR
  197. JDM MR Blow Off Valve
  198. need help new clutch making noise
  199. 20Lt Green vs. GT3071..
  200. waste gate/turbo outlet...
  201. Case Study #403 - EWG on STock Turbo IX
  202. WORKS High Pressure Shaft Seals
  203. Dyno Forum
  204. cam select
  205. advice for the Evo's 1st trip to the strip?
  206. Next Mod?
  207. Ported head a must w/ bigger turbo?
  208. Question on a Greddy Turbo Timer:
  209. Evo Ralliart Head Bolts / Studs
  210. ETS T4 61mm Turbo Kit Glamour Shots - 600+whp anyone?
  211. ebay 02 housing vs ported stock
  212. Dropped a socket into engine!
  213. MBC, Check Engine Light
  214. Another whine thread???
  215. EVO IX 5th gear problem - Not grinding!!!
  216. Weird Sound
  217. Do I Need a Lightweight Flywheel?
  218. Odyssey Battery Nightmare!!!!!!!!!
  219. Pics of Buschur ported/coated exhaust manifold + testpipe
  220. stock mbc
  221. How far could I drive?
  222. Shifter feel
  223. Fuel Pressure Adapter???
  224. WOT porting?
  225. TBE Installed
  226. What turbo for most low-end torque possible???
  227. peak boost gt35r anyone runnin it
  228. header options for T3/T4 turbo
  229. Boost issue around 5k
  230. tranny swap - new flash?
  231. is this a good deal.....
  232. ETS 3" FMIC Dyno Results
  233. something wrong with my evo!!! need help..
  234. My FPGREEN is going in soon look at the goodies PICs
  235. Coolant leak...
  236. Noise coming from clutch? Chatter? Throw out bearing?
  237. Clutch Install?
  238. ACT HDSS installed, 5th gear grind
  239. CBRD- got evo?!
  240. Turbo 8 vs turbo 9??
  241. Driving 200 miles on 880 inj. no tune a good idea?
  242. Spark plugs turned Orange?
  243. Trasfer case for EVO 4
  244. ETS Intercooler - Polished - BLING anyone?
  245. I took off my 50trim and went back to stock, is my A/F supposed to be leaner?
  246. Another mechanical CEL Fix, but better
  247. IC Pipping Help PLEASSE
  248. perrin tbe
  249. Car losing power in upper rpms
  250. radiator hose for 8 and 9 same?
