PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Trani pouring fluid out of cv axle inlet??? HELP!!!
  2. Stock frame turbo back pressure?
  3. Why does oil spit out of the oil fill cap?
  4. hello
  5. Weir 12 plate vs Stock corrected diff
  6. Megan downpipe not full 3"? Is this true?
  7. car sounds like it has cams at idle but doesnt have cams
  8. Boost Taper
  9. Need help quick
  10. Newbie needs help with boost problem!
  11. Weird problem with turbo
  12. Shep Trans & new clutch installed, in neutral, car slightly moves when clutch is out?
  13. Exhaust Manifold Heat Shield
  14. Boost my problem
  15. Camshaft question......... Stock cams
  16. I have a smoking problem....
  17. Severe Cluncking after clutch / struts install
  18. Best gearbox upgrade for 6 speed
  19. need some help on my build
  20. Wtb. Evo 9 turbo
  21. PTE 6766 vs FP3794 HTA
  22. best sparkplugs
  23. whats the difference?
  24. Help me get to 400whp
  25. Oil pan install
  26. ACD banjo bolt crush washer size?
  27. What all is going on in here?
  28. engine knock need help!
  29. Is ported Intake Manfold Right for me?
  30. Guys, I need help with this...
  31. best speed density BOV
  32. Best EBC that doesnt hook up to the ECU?
  33. Help picking parts
  34. Opinions on CP Pistons?
  35. Loud whine NOT drive-train related
  36. help plz need clutch specs
  37. ACD Fluid
  38. .020" overbore and head gasket question
  39. How much power will make on my new set up???
  40. interest in some upgrades
  41. Unsprung vs sprung
  42. Rear Diff Fluid Temps?
  43. Winter changes
  44. NOT normal engine noise (diagnosed, timing tensioner)
  45. car rumbles like subie at idle and with throttle!
  46. DriveTrain/AWD
  47. Oil coming out breather on BR catch can
  48. possible death whine? (video posted)
  49. Timing belt and Water pump
  50. alternators from autozone,advance, any fitment issues
  51. Carrier bearing stud help!
  52. Flywheel/Pressure Plate bolts
  53. Resurfacing Flywheel Question
  54. 9.8 vs 10.5 hotside difference
  55. Crank Sensor
  56. Evo 9 turbo question
  57. am i having boost peoblem?
  58. Fuel cut on stock Evo 9 MR
  59. Please help. Random Knock.
  60. Oil around the bottom of the exhaust manifold
  61. Competition Clutch Ultra Lightweight Steel Flywheel - Any Experiences?!?!
  62. Dynatek - ARC-2
  63. Major exedy twin problems please help
  64. Help with clutch?
  65. What size IC hoses should I use?
  66. plastic clicking sound about injector clips?
  67. Anyone have any info on the pte 5862?
  68. cam lobe seperation questions
  69. t4 versus t3 exhaust housing
  70. FUN READ! Dummy pulley and tuning help
  71. Losing Coolant after hard driving
  72. VALVES HIT PISTONS: New Built 2.4L / IX Head / Cosworth M2 Cams / Wiseco 9.7cr Piston
  73. Im stumped! Is it the tune?
  74. Transfer case leaking ACD fluid out of top
  75. Synapse BOV issue
  76. Building my Evo 8 need some input
  77. 444hp/412tq - Knocking on the stock rods limit?
  78. fuel problems
  79. Compressor Surge
  80. Evo IV stuttering under high throttle
  81. 4g64 evo swap? -edited-
  82. Boost Issues
  83. OEM 4g64 crank
  84. Deatschwerks Fuel Hardwire kit ??
  85. Crankshaft pulley ticking?
  86. Help
  87. 4G93T build
  88. dynomax vt installed.. love
  89. help!! just got my car back
  90. need input on mods for evo9
  91. evo 8 triple clutch chatter and noise
  92. How does this wastegate/flapper look?
  93. What Fuel Pressure???
  94. Clutch burning at idle?
  95. Anything to address while taking the motor out?
  96. Weird issue with electrical.... I think?
  97. Sparks from exhaust???
  98. help please. lag/misfire issue
  99. Trust Spec M cooler VS ETS/Buschur etc
  100. Guess how much our Display case weighs, get a free AEM wideband
  101. tranny: downshifting from 5th to 4th
  102. Clutch Or Shifting Problems Need Advice
  103. WGA bolts?
  104. Fuel problem/starting prob
  105. Need some recommendations for tune my evo up to 500whp
  106. The Ideal Daily Driver Build..... Keeping it 2.0L
  107. Borg Warner EFR 7670 T4 1.05AR - Detailed Pics
  108. Annoying Tick... was it my injectors?
  109. Is this turbo shot?
  110. MAP ef4 vs. Fp Black BB Turbo....
  111. compared 2 fp ht3586 turbos - different exhaust housings?
  112. input shaft seal?
  113. water pump fail again...PLS HELP
  114. tap and die set size for o2 sensor?
  115. Cannot put car into gear! HELP
  116. Daily driver VIII "mini" build
  117. grind noise >_<
  118. What to do with some extra cash?
  119. ? about my exedy clutch
  120. Can a HTA GT3076R make 500whp on Pump safely?
  121. jdm 5th gear conversion
  122. What exhaust is this?
  123. Cracked Hotside? Am I Screwed?
  124. Bad Mount and "Death Whine"??
  125. Aftermarket oil cooler vs stock
  126. New Clutch and Flywheel!
  127. what kind of gains can be expected?
  128. anyone running an fp3794?
  129. clutch set up for 800rwhp
  130. quarter master twin plate power limits
  131. hp from twin walbro setup??
  132. Turbosmart Race Port BOV - Premature Boost Leak
  133. ?who sells 100mm cranks?
  134. New turbo installed: HKSGTII 7460R, have strange problem
  135. Flywheel Bolt Questions
  136. show me a metal 4" intake for fp black, sd
  137. why would anyone buy this?
  138. ACD-Tuning Maps Review
  139. Street/Drag Trans setup
  140. used turbos - what to do if sitting on a shelf for awhile?
  141. Help Evo pulls left
  142. starting issue was fine before
  143. GSC s1 cams with problem, should I worry?
  144. Anybody have an autozone rad that comes with the lifetime warranty?
  145. Looking for more area under the power curve from newer gt35s turbo kit
  146. 38mm external wastegate good enough?
  147. How to make a proper electrical crimp (not asking, showing)
  148. Some basic fitting info
  149. evo 9 turbo
  150. EVO MR tranny limits
  151. Question: Twin Scroll Turbo on a Non Twin Scroll Manifold
  152. Need help
  153. frozen starter or stuck solonoid?
  154. question on upgrading fuel lines - difficult to remove stock lines?
  155. 03 Evo 8 stock turbo wga preload
  156. Strange engine failure, two different engines
  157. tuning a vta bov
  158. help car wont boost over 3 pounds
  159. Help... car wont boost over 3 pounds
  160. P0441 after clutch install?
  161. Oem engine head gasket
  162. VIII to IX Turbo Install: Reuse Banjo Bolts?
  163. At what HP/RPM is a Fluidampr harmonic balancer needed?
  164. Can the balance shaft be reset while the timing belt is on the car?
  165. Gates timing belt
  166. what downpipe for 6262?
  167. Kelford 272s: symmetrical or not?
  168. Evo 8/9 twin disc clutch questions.
  169. What LICP do I need for this?
  170. What now, and should I remove engine
  171. BOV retune
  172. Why is there an oily residue around the oil filler cap as if it is being forced out?
  173. Injectors neccessary for S2 cams?
  174. O-ringed head
  175. anyone using a walbro and external fuel pump in series for 750+whp?
  176. Best Gear Ratios for Uphill & Track...
  177. Time sert oil pan repair questions
  178. What is bearing nip??
  179. Clutch, LSD, and bottom end questions
  180. Doing a full rebuild have a few questions
  181. Oil pump and Balance shaft sprocket removal
  182. PLX DM Gauge feedback, anyone used???
  183. engine hits wall at WOT!?
  184. t case help
  185. t case help
  186. Installing a shortblock?
  187. QM twin disc failures on the hubs. I should get a prize for worst failure. Pics.
  188. 264/272 or 272/264
  189. injector scaling help
  190. Do i need a retune for upgrading my fuel pump?
  191. need injector help/info
  192. Will this fit?
  193. Crazy Spool w/ video
  194. Help sinking clutch pedal on Evo 9
  195. Is the turbo oil feed from the head pressurised??
  196. Whats the best 4G64 block to use for a build
  197. How do you physically get rid of the rear o2 sensor?
  198. new build for stock ix
  199. transfercase removal probelm...
  200. High ratio crowngear & pinion
  201. Rattle/buzz from back of intake or under. 4g63 w/ video
  202. Evo 8 Trans/Shift Linkage failure?
  203. txs bov users
  204. Burning Oil- catch can install help
  205. Fuel Pressure Regulator needed? Help?
  206. Hta3076r vs Hta3582r: Need Help...
  207. What Triggers Fuel Pump Relay #3? (Regulating Fuel Pump Voltage) (Fuel Pump Rewire)
  208. evo 9 engine failures please help
  209. Boost behavior has changed
  210. Autolite XP Irdium Sparkplugs
  211. Stock flywheel?
  212. Evo 9 stock cam part numbers
  213. Aquamist hfs-3 fail safe question
  214. oil pump rate
  215. quick ops question
  216. real hks cam? pics
  217. Excedy Twin Disk clutch anyone?
  218. Evo 8 4g64 timing
  219. Fuel pressure playing up
  220. Trying to buy a car online, got some pics of the oil
  221. which is the 4G63T's #1 cylinder
  222. TC question
  223. price out 4g63 block
  224. Stuck on motor decision...
  225. hot WG discussion!
  226. timing belt
  227. Spoolin Up Coil Kit
  228. Koyo EVO 6 radiator, what hoses should I use?
  229. New CBRD LMP V-band kit--
  230. manley sport comp piston wrist pin failure
  231. Safe way to make 400-450 WHP?
  232. what valves to get plz help
  233. Has anyone tried the M2 SS Exhaust Mani?
  234. Car wont get into gear. Please Help. Thanks
  235. quartermaster install
  236. Leaky rear diff
  237. Do I need an external wastegate??
  238. NO reverse lights WTF!
  239. Stuck in gear when shifting at high RPM's
  240. what clutch for shep, jack, or TRE
  241. what cams?
  242. weres the ops located at
  243. Need some Help fig. out what might be wrong with this evo of mine!!
  244. QTP electric cutout...just arrived!
  245. abnormal boost drops at 6k
  246. Serpentine tensioner SPRING replacement?
  247. Evo 8 FP Green build
  248. rebuilding motor advice needed
  249. Evo 8/9 differences
  250. Twin Scroll divider melted in GT35 housing...
