- Anyone know what turbo this is ? Mad scientist ?
- where can i buy a new Evo9 turbo?
- Pushing Clutch Pedal Causes Engine to Stall. Help!
- Fuel return fitting size?
- question about intake manifold
- How much someone would pay for built long block?
- JDM EVO 4 Clutch question????
- Help diagnose my pulsing engine problem...
- DDM Performance ACD Ecu
- 06 EVO IX idle problem
- Need some help finding a connector
- mivec trouble
- Maintenance for a 2.3l stroker motor?
- Looking for a clutch
- Help with AFI Turbo kit install: Dump tube, radiator, and condensor?
- How big injectors before upgrading fuel system?
- Cracked TOB, fixable?
- Evo 8 Tick/Knock help- Video inside
- Plugs for OEM loom for COP setup
- MBC routing help
- Half Radiator help
- 2.4l alternator/serpentine belt issue
- Car wont start after timing belt job Help!!!
- hit a curb
- What non-power parts do you replace with an engine build?
- Grinding after fluid change
- HELP ID1000 injectors for evo dont fit
- Pics and Specs 2.1 Destroker (engine porn)
- I'm out of ideas. Help please!
- walboro 400lph fuel pump help
- Help evo 9 engine problems!!!!!
- Evo drops in rpm when clutch in and oil light flashes
- keep or remove Balance Shaft on 2.3L track motor?
- Coil system
- ACD pump Troubleshooting with tester and rebuild kit
- Will Evo 8 rear axles work on an Evo 6
- Choosing Injectors... Help
- IAC Alternative
- Fresh Build Turns over no start
- running rich??
- Disk plates replacement for clutch kit
- Evo not starting
- Evo 8 vs Evo 9 Fuel pump assembly differences?
- Comp stage 2 clutch
- Radiator fan wiring question
- Advice: Pressurized Coolant System
- Advice: How bad is this boost leak?
- axle seals
- which bearings to use for 2.3L stroker
- Head sealing issues on 2.4?
- Help, car will only go into 3,4,5,R
- Exedy twin with Monoloc
- Slipping clutch
- Comp surge on a stock VI Rs. at 1.2 bar, WOT, 3.5k rpm
- Is it necessary to change valve guide during a build and how its done?
- Evo IV-VI Stage 2 Tcases
- Megan O2 Housing
- When should the clutch be replaced?
- molybdenumnmn disulfide grease
- Exhaust question
- Possible causes of clutch sticking?
- avid billet motor mounts
- Injen UIC and HKS SBOV fit
- Stroker coming together. Opinions
- Unsolvable random clutch disengagement problem
- Brad penn oil
- difficulty shifting in cold weather
- Revs holding while at WOT
- need to I.D. cams
- Walbro 450lph E-85
- AMS High Flow Cat
- someone look at this fuel pressure log
- front diff? noise when turning in this artic chill
- My Nightmare...
- Oil/exhaust smell from passenger side of cabin
- Competition Clutch MultiPlate Clutch Kit 4-5152-C feed back?
- Bad injectors ???
- High or low imp. Injectors? help..
- Original Panda Update...
- 2000cc fuel injector issue found on routine clean up
- half radiator users
- Help identify this noise!
- My evo viii build new to evo world
- Evo 8 intercooler mounts
- help! weird boost issue! think i singled it down
- Rebuild rear diff or send it off?
- Evo IX Turbo Compressor Cover swap on VIII MR Turbo?
- QM hydraulic TOB on ATS tripple?
- Evo 9 turbo wheel question
- o2 housing compatibility
- Evo Head surface ,Porous casting ?
- Looking for upgrade advice
- Tomei Arms plus new engine - 2.0 or 2.3?
- Do We Need Cranshaft Balancing on Used OEM Crank?
- Meth injection vs e85
- Stock boost level
- oil in compressor housing fp black dbb
- Removing shift linkage arm tricks?
- Anyone ever tried this tool for measuring valve stem height?
- Valve Cover Baffle replacement?
- Can't boost more than 22psi
- Mitsubishi Evo 3 with MSD DIS 2 - Help Needed
- Half Shaft Definition.
- tial bov question
- Another "what turbo to go with" thread
- Boost Controller/ BOV Question?
- quartermaster hydarulic release bearing
- nos on a 2.3 stroker
- Driveshaft rubber part is torn, needs replacement. What is the part called? Pics insi
- Exedy twin disc clip replaceable?
- arp L-19 torque spec
- Have a question about my crankshaft sensor plate!
- Wiseco HD2 Gas Ported Pistons need help!
- what clutch should i use for my evo
- Kelford tx288 mivec
- help me choose between high z or low z injectors
- PTE turbo journal vs BB high rpm reliability
- FS: evo 8/9 head parts
- TPS adjustment problems
- Looking for a Wiseco long rod piston!
- Noisy transfer-case after fluid change
- Is this a stock boost control solenoid?
- Curiosity Question
- Engine Harness modification
- 2-3 gallons of regular?
- Plug Filing
- Gtx 2867 r
- Very light piston slap sound
- Need help over boosting at 1 psi
- HELP at a lost
- What clutch should I go with?? Please help!
- Blown turbo??
- USDM 03 Outlander t case into Evo 8 or 9
- Evo VIII GSR vs MR camshaft
- Broken cam bearing cap
- 90k service suggestions
- Weisco 10.5:1 piston users attn pleas
- exhaust crossover problem?
- Haltech Platinum Sport has no knock sensor what solution to tune?
- Hydraulic throwout bearing for evo 9 competition clutch twin disc
- Aluminum catback exhaust
- Evo sputtering problem. Please help!
- GodSpeed Turbo?
- ACD Tuning still around?
- unburnt gas smell
- Intercooler piping diameter, how big of a difference between 2.5 and 3" diameter?
- Engine Slow rev up, in and out of gear
- New starter and battery, still not starting!!!!
- My engine keeps doing this to spark plugs....
- timing issues maybe?
- Those of you in colder climates, what transmission oil are you running?
- MAP Sensor Pigtail / Car Stalls
- Pistones on jun stroker kit cracked can I use weiseco hd1400 piston
- Question for you Speed Density guys
- Any info on this FP Zero turbo paging FP
- Just installed BC 272 cams. Need some help
- Need turbo for Evo 9
- VIII 9.8cm billet 20g upgrade?
- Stock Evo 8 Upgrades????
- noise under cam cover/ timing belt cover
- Should i upgrade my wastegate actuator on a stock turbo?
- Evo 8 power steering whine?
- Evo 7,8,9 - rods&pistons diffrence
- 2.3 vs 2.4 - why do some shops really dislike the 2.4?
- Boost flutter after changing clutch
- Front 02 sensor clip on engine harness broke
- Loud ticking after bleeding lifters
- Tomei Specials on Stroker kits!
- Question about meth/failsafe testing?
- How to tell an Evo 9 6 speed transmission from a 5 speed transmission
- Bad Cruising + Idle AFR help please.
- Gtx3582r
- To New Clutch or Not To New Clutch
- removing evo 9 cylinder head?
- 2.3 stroker info needed
- Car vibrates and then thump/shudders like something is locking up
- Urgent help needed!! Engine rebuild gone wrong
- Weird odor from Transmission - Thoughts?
- MAP engine consumes oil?
- Help needed! Clutch difference between cp9a and ct9a
- Best Stroker kit??
- please help before i have my pumps!, to tune tommorow
- any real gains from an FMIC on a stock turbo evo 9?
- cold start problem after alternator replacement
- Transfercase rebuild?
- How do I identify a transmission?
- Want some advice on FIC injectors.
- Gt42r or 6466
- Trans and transfer case internal parts
- Looking for Evo8 Radiator core support!!
- 3rd and 4th Gear Grinding
- Help needed- evo 8 not reaching full boost
- Map O2. Yay or Nay?
- What camshaft are these I got them for free
- Which clutch QM TWIN 6-leg or 8-leg
- idle dip related to power steering pump???
- FP Red... Keep stock intake and exhaust manifolds?
- Loud whistle/air sucking noise under throttle.
- From a 2.3 to a 2.4 ----> Spool difference?
- forward facing or standard turbo setup?
- YOU with the Tanabe Medallion
- Balance shaft delete q's??
- Exedy triple life
- New Build spec opinion
- Normal for Evo motors to have blow by at idle?
- Grinding Noise only when taking off from a complete stop.
- Rattle from wastegate flapper
- P0300 and hiccup at idle, afr reading lean
- Buying evo 8 16g turbo
- End All Crank Case Pressure and Catch Can Solution
- Turbo Machining?
- time for a COP?
- Rear axles in passive (LSD) diff question
- *PICTURE REQUEST* TIAL QR bov installed on EVO
- Fuel leaking through wires help please
- replace my clutch
- Normal oil pressure at idle but low oil pressure when cruising?
- LSD question
- Intercooler Advice
- Evo ix Front Wheel Burnouts
- RTM Racing Tank to Tank Fuel Line Kit
- Evo 5 clutch noise
- Performing a boost leak test
- Next Mods?
- High HP, High Comp 2.4 4g64 User Chime in!!
- Evo 7/8 Ralliart intercooler hard piping kit
- Please help! Intermittent Boost Issue
- clutch pressure plate wear limit
- Bee*R Rev Limiter/Powerbuilder install instructions on Evo IX SE
- I have a fuel related question...planning to upgrade to -6 feed line.
- Looking for reviews of MAP 2.1 and 2.4
- Iac valve replacement
- Please help about cams
- New Clutch, Flywheel, TOB, TC Noise...
- Speed Density Issue
- Precision's NEW 6870 Turbo...coming soon!
- Evo 9 No Start After Cam Install - Good compression - Help me out
- ARP bolt fitments
- 2.3 stroker and matching turbo
- Experiences on FP stok location BB turbos
- car runs weird after compression test. help!
- Battery Tray nut size 12mm
- 1st 2nd 3rd Gear Lockout only When COLD - Help
- 2.3 stroker built--- pistons moving!! help need opinions
- Crank walk rebuild advice
- My 2.4 build and what im doing to make it work.
- Comp stage 3 vs Comp stage 4?
- Are both cam angle sensors the same?
- Help troubleshooting random stalling/lean spikes
- Evo 8 cutting in and out while cruising on highway
