- evo oil cooler mod?
- evo won't start
- how do i install the pass side input shaft
- FYI - evo6 vs evo9 headgasket
- Down Pipe exhaust wrap?
- At what flow rate does a BOV port size start to matter?
- ACD Lights On
- 2.0L 4G63 or 2.4L 4g64
- Evo 8 turbo oil feed barb???
- Oil Pressure Switch
- Who's running a AMS F1 inake mani?
- fp red wit invidia 02 housing
- FP White feedback
- what promotes a flat hp/ tq curve?
- Evo 9 turbo with GSC S2 cams
- Independant fuel pump testing done by DSport puts Buschur Racing at the top!
- Real or Fake HKS SSQV??
- Weird Turbo Problem
- Clutch
- Need clutch advice
- Misfire Code
- Changing buschur bullet for buschur magnaflow??
- Evoscan 1.3U cable length?
- wtf !?!
- LC-1 WB values
- GSC S2 cam questions
- Stock Turbo with METH??
- QM clutch question
- Loud rattling noise!! Help!
- turbo blade chipped? large pic inside, need your thoughts.
- Twin scroll 6262??
- Installed used ACD pump, now have idle issues....
- turboxs type h boc
- 1993 Evo fuel issues
- why do i have this noise
- Car Stalls...NEED HELP!!!
- 500 HP with FP red and 93 octane?
- Not sure which size fuel injectors you need? Mellon Tuning can help!
- Syncro or clutch issue?
- New Thread Greddy Issue
- Magnus On Stock Turbo?
- white smoke after wot
- HELP Evo 9 over revving at gear change
- feels like random boostleak
- To go with FP Red or Black
- Build finally coming along !! :)
- Passenger side axle removal question
- HKS EVC 6 wastegate flutter
- quick question for u guys who know whats up
- Looking at cams, need help
- Hydraulic throw out bearing for exedy twin/triple
- Help! Loss of Power when cruising at 75-85mph.
- Evo 9 Main Bearing out.
- Got a weird problem with tranny..need some advice.
- Is IT WORTH PORTING THE STOCK MANIFOLD AND THROTTLE BODY???
- New Boost controller approach
- BOV and Boost Gauge on Same Boost Line?
- Flutter in 4th but not 3rd gear w/FP Black
- Can a stock new Evo 6 Valvespring withstand GSC S2 Cams
- Evo 9 Cylinder Head tech info needed .
- oil temp raising
- Will I pass smog?
- Greddy Full Titanium exhaust question
- Where is the green fluid coming from???
- Any other method to check Oil & Bearing Clearance???
- Issues while in boost (not a boost leak)
- Clutch/flywheel recommendations for 400whp
- Fuel Problems w/ new upgrade
- Cam Advise
- Engine ticking sound help...
- help car stalls in turns
- Many ???
- Clutch slips then grabs hard??????
- Engine Rebuilt Checklist
- What is the bore size for a JE 85.5mm Piston to a stock Evo 85mm block?
- Help with a code I'm throwing
- Boost leak from below TB shaft?
- Evo 4-9 Service and Workshop Manuals
- Any Alum Rod 2.3l's out there?
- Need to rebuild e7 trans. Part numbers? Where to buy?
- Question about exedy twin clutch
- FIC Injectors & Magnus V5
- Odd boost issue (or lack thereof)
- Tracking gear shifts
- 2.3 build w/ some questions
- Evo 8 clutch help please..
- Took my valve cover off and I noticed today that one of my lifters has a broken end o
- Aps downpipe on stock cat and exhaust?
- Best & cheapest connecting rods?
- OEM Head Gasket thickness?
- Leaking Coolant from back of block, think I found the reason, what to do about it?
- Crank Sensor pickup plate on crankshaft.. SHOULD IT HAVE PLAY or be solid and tight?
- clutch problems...not disengaging fully
- Tool/tip for you guys taking out your own trannies.
- Compresion help
- Oil the Buschur intake?
- how long is the left front cv axle?
- 2.3 build
- Help ID these springs/retainers
- Competition Twin Disc or Exedy Twin??
- solid hla to dial in cams
- car stalling in neutral/clutch down
- Replacing connecting rod bolts and head studs.
- Special oil for E85?!?!
- Tilton Twin plate ceramic (terrible street clutch)
- 120,000 mile DD Evo
- Would Higher C/R Spool T3 Faster?
- APS BOV adjustment?
- Evo 5 Turbo vs Evo 8 Turbo
- E85 sparkplugs always white, is this normal?
- What do you think of this manifold?
- AMS 850R vs GT900x
- about buying a Evo 9 shortblock
- Part Throttle Surge solution
- exhaust backfire
- how hard is it to replace your block??
- Parts Suggested for O2 and Ex mani
- Any Vender have 87mm 1400HD Pistions IN STOCK???
- is it worth the switch from the br ic to there bfic
- What is Chemical Cleaning & Blueprint for Head & Block?
- Woah ACT.....
- IF.........Free Shortblock.......choose.....
- Holset HX35?
- 50k miles of alcohol injection and no cracked pistons! Cheap alky kits exposed.
- Throw out bear WONT release,...
- ported my first evo head!!! (before and after pics)
- Stock block?
- Transfer Case and RTV , Good idea or Not?
- LOUD V8's and/or externally gated cars causing Stock MAF to malfunction on launch...
- need help with build
- Double pumper and fuel pressure
- forced performance intake fitment issues?
- 2nd gen fuel injectors work on a evo ix?
- cel light codes
- Is 2.3L Strk Engine Harder on the Drivetrain...
- Which engine roll stopper is better Agency power or Torque Solutions?
- getting a BR head or stay stock!
- You know what I hate? (dipstic rant)
- Synapse or Tial 50mm?
- ACT high rpm lockout
- Ams high flow cat rattle
- Mods to make more PAWR!
- lose power with no exhaust?
- transfercase issues
- Installing Torque Solutions mount kit 03Evo
- Cooling issue
- Fp green hta 73 *ball bearing*
- Evo gear question?
- stock evo 8 flow numbers anybody?
- What are the best injectors out there?
- Whats the most power the stock ingnition can hold??
- still on my build !!! :(
- Intake heat shield
- boost kicks in at what rpms. stock turbo evo ix
- Quick question
- HELP, keeps shutting off (video clip)
- serpentine tensioner
- can not find oil leak!
- Opinions on the best OEM intercooler replacement
- boost issue? i think?
- Hobbs switch/solenoid boost controller
- Help, lost boost.
- Missing at Idle after highway drive.
- Problem: Steering hard at low speeds binds up and stops car. Grey puopon stuff splatt
- Any O2 dumps work with stock undertray?
- Leak from EGR Block Off Plate
- Auto tensioner?
- Help Rebuilding My Evo 5 Engine
- putting an 850R on a stock block
- what the hell is this noise?
- How to re-tap timing belt tensioner tool threads
- clunking/rubbing noise from under the car
- Poor Man's pedal stop
- Time for a new cluch on the IX MR
- Normal IX Compression Test #'s
- Spool so fast that the turbo SURGES
- WGA question ix turbo
- Bumper Diffusers..?
- Need Your Expert Advice on these Pics
- Megan 3" DP...need opinions
- engine and turbo problems
- Earthen's 2.4/black build...
- AWD Motorsports driveshaft on the BadBish
- HKS BOV Recirc kit question
- Car wont go into gear when boosting..
- Has anyone seen this exhaust before?
- transmission and all diff's , TC
- Rotating crank shaft - loud pop from cam area. Anything wrong here?
- are mitsi odometers resettable?
- New Perrin bov?
- how hard to install a tial bov spring?
- Just curious difference with dynoing in the summer vs fall and winter
- Hallman Pro vs Hallman Pro RX
- need help with waistgate
- problems with exedy twin disc
- 6262/.82 billet wheel
- Advice needed
- Evo 9 Mivec pinouts?
- car shaking at idle after clutch change?
- oil press question
- What spark plug? gap etc...
- MR 5 speed swap shifter cables?
- ISC steps will not go lower than 40 ?
- Identify this tubular manifold
- Engine done?
- Need help with clutch fork with fresh install
- Is there any way to rethread a head?
- Need some clarification
- stock fuel rail Q
- Damn Throwout bearing
- Best BOV for UNDER 30psi: debate
- Random sudden 3rd gear grind. HELP!!
- po135 po151 codes ( help please )
- ringing noise in engine compartment
- Car won't hold boost...
- Rear motor mount/transmission casing... fell off?
- Forge 18 psi WGA ascillation
- Anyone running or have experience with the Shearer 02 dump?
- exhaust newbie
- Clutch pedal only comes up half way!
- TRE 6 speed
- Help with Invidia N1 Exhaust!!
- Can you tell me about this OEM exhaust manifold?
- 6 spd (MR) gearbox service manual...
- Alternator casing..
- Horrible Idle...
- Lockout only in 4th gear?
- Evo 9 MR timing belt change
- 2.0 Built Engine Project....
- Transmission/Clutch issue
- help!! fuel cut on wot after 5k rpm
- Help identifying old fp green
- What Injector should I buy?
- the evos launch control
- Best bov for over 30psi?
- Transmission rebuilds
- eVo IX + stock Turbo + E85...S1 or S2? what you think?
- GSC S3 cam broke
- How many cats does the evo 9 have?
- Shift Linkage removed, trans wont go in gear after reinstall
- Somethings up.. just built the motor not to long ago
- fp red 64mm spike.
- Starting issue, need help!
- Quiet exhaust for my setup
- Skunk2 throttle body
- 4g64 Or 4g69
- Check engine light after new tial q bov install??
- Best turbo for a street monster??
- new motor mounts!!
- Retaining clips for electrical connections
