PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 [139] 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. How do you know the ECU was reflashed?
  2. Help with emissions test in Denver
  3. New record for pump gas, set with the HTA35r
  4. anyone ever use?
  5. Fuel Trim Bank 1 Error Code
  6. Power question...please help
  7. Milti cylinder missfire error code?
  8. titanium downpipes
  9. E85 + 100% meth???
  10. how can you tell if a turbo is bad?
  11. Tilton or Exedy
  12. gt35 kit, need input
  13. Forge RS Adjustable...Car acts weird on 5th gear...
  14. Going for the EVO Green
  15. K&N Testing Site
  16. Are Boost Leaks Fixable?
  17. custom gt35r...whats your opinion?
  18. new to evolution scene
  19. custom downpipe for garrett turbo
  20. 459whp/394wtq with EvoGreen on E85! (Dyno Sheet inside)
  21. throttle plate sticking on high boost > 2 bar
  22. who runs eagle rods?
  23. Transfer Case Help
  24. EVO IX MR 6-speed Oil Additives?
  25. Smooth vs. rough surfaces
  26. Driveshaft help/advice
  27. Boost Leak from Throttle Body?
  28. Direct Exhaust Injection
  29. Want to replace recirc valve, which one would perform better?
  30. Thinking of a cam change... opinions?
  31. Cam Cards?
  32. 3rd gear grind?
  33. Front Axles
  34. general question on the evo8 dv
  35. Any one make their own cam install tensioner tool? PLEASE HELP
  36. will ams manifold work with BR FPHTA35R
  37. 600hp Peakboost GT37R
  38. 38mm turbosmart wastegate
  39. Shifter issue. IX MR
  40. new piston idea
  41. Rev limiter as shift indicator?
  42. My EvoIX goes into limp mode...
  43. Clutch/Flywheel weight combos...compared to
  44. *clunk* after vibrating clutch pedal
  45. spoolup comparison, 35r, 30r 3076, 50trim, green, evo9, evo8
  46. Best Cams for a 2.3 stroked GT35R car
  47. HKS Reloaded vs. HKS RS Filter Replacement
  48. DNP Stock turbo Manifold
  49. downpipe question
  50. 10psi 1st/2nd gear....30++++psi 3/4/5th gear. HELP!
  51. After I stopped I heard a unique wierd noise, Please help.
  52. Does this accessory belt look normal to you?
  53. where 2 get + ternimal fuse
  54. what size cam to get?
  55. turbo rpm
  56. Evo stutters. More info inside. Help
  57. where goes engine oil travel in order?
  58. Air temp & MAP sensor questions
  59. When does the factory un-ported head cause a restriction?
  60. ?'s about O-ringing head/block
  61. Problem With A Mod
  62. So whats the trick? Oil pump sproket bolt w/race balance shaft.
  63. engine sputtering at high rpms (in boost)
  64. 6 years of being an evo owner..AND..still confused...CLUTCH HELP please?
  65. cam break in period?
  66. Exedy & ACT single plates
  67. best shortshifter???
  68. fuel pressure regulator?s
  69. 20G-LT in the 10s w/ meth
  70. The end all thread of clutch rebuilds!
  71. motor heads only
  72. Wideband Users: what AFRs are you seeing during h/w cruising?
  73. solution to exedy single clutch chatter?!?
  74. Save 300$ Read this!.
  75. Green's in the 10's
  76. new clutch fixed my random misfire codes
  77. Do i need to upgrade the clutch?
  78. Another ACT clutch problem.
  79. WOW!!! I recieved my Green within 10 days of ordering!!!!
  80. intake manifold removal
  81. how much did you guys pay ?
  82. Swapped 6 speed to 5 speed and having problems (PICS)
  83. Front A/C fan removal?
  84. Getting Tranny Rebuild What's The Best Gearing?
  85. Cuts out, need help please.
  86. Blow By System (GM MAF) Questions and who is running it??? PLEASE ANSWER!!!
  87. Evo IX spark plugs
  88. Stroker or Stroked short block?
  89. 0300 misfire code
  90. Need Help Immediately!
  91. Gauge Dilemma, dont know what to buy....
  92. arp headstuds
  93. PTE vs Denso injectors
  94. List of MR Owners who has switched to 5 Speed
  95. PeakBoost HVS topmount 37R on E85 only!
  96. gas octane questions
  97. UICP & stock inake
  98. Camshaft effects on cylinder pressure and ignition timing
  99. 2.0 or 2.3 better?
  100. ETS, TURBO XS, Weapon R Intercooler Pipes !
  101. ets or ams fmic...
  102. My new parts list
  103. P0125
  104. It started with tapping for egt...
  105. cold weather boost!!!
  106. possible failing water pump
  107. synchro fluid
  108. mustang dyno vs. dynojet dyno
  109. buschur log manifold gasket matched?
  110. injen intake filter size?
  111. fluid change
  112. need help!!!!!
  113. Tranny Swap--> Am I missing Something
  114. What's wrong with my tranny/clutch?
  115. new build...opinions?
  116. Muse Motorsports Manifold
  117. Idle Fix
  118. Walbro 255 Fuel pump
  119. Has anyone swapped from an ACD TC to a NON ACD?
  120. Evo 8 won't pass Emissions/smog test.
  121. Stroker & turbo question
  122. Future Mods? But what?
  123. weird issue with my wife's Evo IX
  124. Coil Packs Won't Fully Reseat on New Denso Spark Plugs
  125. How is your 2 step launch limiter set-up?
  126. need help with my 2.3 build
  127. My Vacuum line Saga/Project
  128. toluene
  129. Shift Linkage? Lemon?
  130. Injector Fitment
  131. Fujitsubo Exhuast
  132. Valvetrain Spring Compressor
  133. coils?
  134. suggestions on Forged and Forced Performance heavy duty wastegate actuators
  135. My Zeitronix 2.3 logs!
  136. 27psi race gas tune on stock headbolts question.
  137. ACT Clutch Pricing going up December 1st 2007
  138. Cheap belts
  139. oem piston hp capability?
  140. I can hear whining somehwere in my engine....could it be TC?
  141. EVO MR 6-speed short shifter???
  142. Need answer PLEASE!
  143. clutch related?
  144. torque specs?
  145. aftermarket exhaust
  146. 400hp? Advice on how to get there...
  147. Upgrading Turbo .. CAM ideas please?
  148. Shift Linkage??
  149. Evo IX spark plugs
  150. brake / batt light? flicker?
  151. Evo ix backfiring??
  152. ugrading injectors
  153. When car gets toward full boost i lose power abruptly...
  154. Look what came out of my differential
  155. Anyone know What manifold This Is?
  156. CEL Fix Installed and Still SES Light on...
  157. Do dyno #'s lie?
  158. Why stock head bolts are not good for 30+ psi
  159. Help!!!! No Boost?
  160. New mods? Will they help? Please?
  161. Anyone tried the Clutchmaster twin plate clutch?
  162. 10.8 @WOT sigh
  163. IX Turbo ?
  164. Oil Additives
  165. Evo VIII vs. Evo IX Exhaust
  166. Need clutch opinion....
  167. !!ETS 61mm Tuned!!
  168. Valve Springs?
  169. Q about cam sizes
  170. Clutch
  171. Cosworth cams
  172. 650whp goal?!
  173. eibach valve springs?
  174. PVC Cap For Boost Leak Tester
  175. Cam Install Tips?
  176. BC 2.4L Evos...
  177. Flywheel inspection cover
  178. car wont start
  179. Evo 9 SE upgrades
  180. Evo 8 24k miles and I blew my stock motor?
  181. To cam or not to cam?
  182. VTA BOV with HKS EIDS...who has this set up?any problems?
  183. A/F @ Idle to high?
  184. Possiably getting MIVEC cams for Evo 9
  185. Green or 35R
  186. E85 tuning
  187. FP green question
  188. Quick HKS cam question.
  189. intercooler horsepower gains
  190. HKS mivec cams
  191. Flywheel bolts
  192. which throttle body to go with
  193. 3rd Gear Lockout
  194. Engine Tapping
  195. Question about Forge WG Actuator
  196. oil sensor problem
  197. Fuel Pressure....
  198. Turbo XS Hard Pipe Kit question
  199. drivetrain problem.. help...
  200. Question about altitude and octane
  201. Wintertime Tranny Fluid mixes.
  202. guys who installed LC-1
  203. looking into buying a evo
  204. Launch - Wheel Hop - Whining Noise - Gear Oil Leak
  205. Is this Exedy clutch any good?
  206. banging gears
  207. Two quick questions
  208. Blitz SBC-ID III ?
  209. Cost of clutch replacement?
  210. yeah change my spark plugs and the code changes
  211. Gears Grind and Adjusting the Clutch Pedal Does Nothing??
  212. Stock Turbo Efficiency by Redline
  213. Exedy Twin Plate Adjustment help!
  214. Exhaust HP gains-
  215. Taller 5th gear
  216. which turbo, help me decide
  217. Quick Cam install & Tune Question
  218. Some information I need confirmation on...? (boost/drivetrain)
  219. fuel pump
  220. A/F Question
  221. Oil Temp (normal driving)
  222. clutch problem
  223. How to check if LSD is installed
  224. Strange noise coming from belts.
  225. Header
  226. Normal Blowby ????????
  227. Ok Ive done it this time
  228. Bov???
  229. HTA 35r, new power gains and the quest for 150 mph trap speeds.
  230. When to use a Fuel press or water temp gauge?
  231. aftermarket turbo-back exhaust w/ converter???
  232. F-450 Turbo slapped on a turbo?!!
  233. Stock Intercooler Coupler Size?
  234. Weird shifting from 1st->2nd->3rd...
  235. tranny issue
  236. Help me understand this boostcreep problem
  237. Used quaife lsd?? Anyone have experience?
  238. EVO Green Options/Questions
  239. Boost issue after installing Injen intake/UICP/LICP
  240. Quickest way to 400hp
  241. check engine
  242. what is max boost?
  243. Installed Hallman Pro RX MBC
  244. help with install urgent!!!!!!!!!
  245. So I thought my engine blew - another lesson learned
  246. Opinion on the T3/T67 H.O BB
  247. OCTANE horsepower translation thread
  248. clutch install problem??
  249. logging on to evoscan makes my car run crapy!
  250. Forced Performance Turbo Install Kit
