PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 [226] 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Black Sensor Under Intake Mani???
  2. Would 264/264 affect emissions?
  3. Clutch inspection criteria
  4. 392hp Stock turbo!!
  5. Can anyone beat 275.00 for HKS RS KIT...
  6. aem intake need opinion
  7. should i be concerned?
  8. cooling fan
  9. Stock ECU question ??????????
  10. What now?
  11. buschur intercooler whine
  12. Cricket in the engine
  13. leak at boost gauge??? or faulty gauge?
  14. did a new ball bearing turbo need to break in
  15. Crane Cams Fireball
  16. Outflowed Stock Airbox, Need Suggestions
  17. Too much pressure in crankcase, why?
  18. Which FMICs are a direct fit?
  19. Spark plug color
  20. MR turbocharger VS VIII Turbocharger
  21. JIC manifold-cracked after about 8,000 mi.
  22. JIC exhaust manifold and aftermarket turbo?
  23. Intrdusing my spark plug
  24. Leaking Boost!
  25. Greddy Turbo Upgrade Kits
  26. 5ZIGEN pro racer A-spec exhaust
  27. Ideas for an Intake Manifold??
  28. Where is the cheapest place to get HKS RS kit..
  29. Evo Underhood Intake Systems
  30. Anybody hear of or try this yet?
  31. HKS EVC problem
  32. Anyone use AMSOil Series 2000 20W-50?
  33. does helix DP use a donut gasket ?
  34. 6 speed gearbox Should I??
  35. Best deal on Fidanza Cam Gears ?
  36. Hard intercooler piping
  37. PLease read if you have installed your own Evo Clutch.
  38. Damn first problem with car
  39. serious boost bleed issues
  40. UR Piping w/ Greddy type-S BOV
  41. you think i will feel a difference?
  42. Compatibility btwn aftermarket exhausts and stock cat
  43. hks ssqv grrrrrr......
  44. PBC Boost Controler?
  45. Do i need a fuel pump? (HELP)
  46. 5-Zigen Racing A-Spec Exhaust
  47. $400 to spend on CAT-Back Exaust
  48. I hope someone has some pointers for this pickle I am in!!!!!
  49. P0137 Check Engine Light
  50. help with broken gasket!
  51. Megan Downpipe problems
  52. ? about RMR 3" turbo back?
  53. Fix for your CE light! o2 sim.
  54. Anyone use GReddy Profec E-01?
  55. Clutch Question
  56. Local Denso IW24 in south Cali
  57. Heatshiled Removal? Help...
  58. Who has this exhaust
  59. HKS Hiper exhaust questions?
  60. what should i do now?
  61. Cams and Break-in Period
  62. weird noise from diff??
  63. Boost line off the head... no boosting... suggestions?
  64. simple question on bov's
  65. 3rd Gear grinding on the upshift?? Anyone else?
  66. Uhhh... what's wrong with my Evo? What is this part?
  67. Bigger Turbo
  68. Almost Done
  69. Does anyone have the Grey 2 gauge A-pillar pod in stock?
  70. Help! New Tanabe exhaust!!!!!
  71. Thought stock was ok, have exedy twin..
  72. Catching Rubber in 2nd
  73. What is the inner diameter of the Fuel Pressure line to tap for a boost reading?
  74. Walbro 255 Pumps, difference between HP and LPH??
  75. Fuel set up 500 whp+
  76. Cooling idea for turbo
  77. HKS Racing Suction kit Idle probs
  78. Nology hotwires for the EVO
  79. When is it time to go to a cooler plug?
  80. FMIC's >>> Looks great!
  81. My CEL just came on!!!! :(
  82. Evolution Greddy exhaust
  83. For those with Greddy Type S
  84. A'pex-i airbox.........
  85. Intercooler CO2 spray
  86. Stock boost controller only boosting 10 psi, any advice, thanks
  87. Injen I/C plumbing???
  88. 2.75" Intercooler Piping???
  89. Besides Boost, what is the 2nd most important gauge?
  90. Service engine soon
  91. TPR Magazine EVO8 exhaust shootout.
  92. HKS VPC works with GReddy E-manage
  93. Only 600mi and the clutch engages REALLY high
  94. HKS RS for sale
  95. will i pass smog???
  96. Jeff Hill (TurboTrix) ran a 9.7 w/ his Evo VIII...Anyone know what turbo?
  97. Perrin Intercooler Vendors/Users? Price & Quality?
  98. Atp Turbo Kit Question
  99. EVO Turbo fit an Older Eclipse or Talon?
  100. Cleaning/Replacing cone filters...
  101. Weekend turbo project
  102. turbo question
  103. Class Action Lawsuit anyone??????
  104. O2 eliminator pipes.
  105. Need help replacing clutch restrictor
  106. BR 500 predictions this fri....
  107. What speeds are our evos geared for?
  108. HKS type-1 TT problem HELP!
  109. Another Intake Question
  110. ralliart dog gears
  111. Greddy I/C, Boost leak
  112. help with engine codes clarification!
  113. Blown Engine Pics.. Only for the brave !
  114. A word about pipe diameter
  115. HKS EVC Install Help
  116. Official 6k on the car clutch is done...
  117. Magnus Sheetmetal Intake Manifold?
  118. arrggh...why does my boost drop so much...
  119. My Engine (or Turbo) is acting weird~~
  120. What Do You Prefer 264/264 - 264/272 Cams
  121. BOV & upper IC pipe Question
  122. Help! New clutch in and there is a loud click noise
  123. Ceramic coated exhaust
  124. External Wastegate
  125. ThreeSpeed Sheild and the ATS conversion
  126. tranny oil please look
  127. Plz help: Install AEM c2di on evo 8 plz help !
  128. Cheap yet decent quality 60MM gauges
  129. Just got Dynoed...
  130. R-spl Installed
  131. New turbo kit baby!!!!!!!!!!
  132. UR high flow cat
  133. Anybody running RNR gt30 turbo kit
  134. Ecu????????
  135. ecu reflashing ?
  136. Differential broke down
  137. Tanabe Hyper Medallion exhaust
  138. Review of ATS triple carbon clutch....
  139. Is there such a thing?
  140. I need Help with my BOV!
  141. Clutch slipping Question ???
  142. Losing HP?
  143. Plug Wires - 8 or 8.5?
  144. Catback and BOV comparison
  145. Spark plugs: To go colder or not? Iridium or copper? Confused yet?
  146. Help 5th gear rattling sound when decel....
  147. New Clutch option for the Evo.. Centerforce..
  148. Anybody here Boosting 24 - 25 psi?
  149. Tranny Warranty Issues, Please read!
  150. ACD Upgrade?
  151. Fuel Problem....PLEASE READ
  152. BR580 Install
  153. Ack!
  154. ecu
  155. Exhaust/intake with no boost controller?
  156. Performance stroker characteristics
  157. Cam Specs - Hard numbers, really!
  158. Cam Specs - Hard numbers, really!(sticky, no replys)
  159. Tranny Problems
  160. Forum Administrator Abuse!?
  161. boost controller help please
  162. Hoses: which size to use?
  163. test pipe ?
  164. Clutch Slipping in some gears but not others
  165. Clutch and TC reliability with mods?
  166. Hayward & Scott full exhaust - w/ Video
  167. zeitronix wideband install
  168. Buddy club exhuast... anyone seen/heard/have this?
  169. Need Immediate Help....Buschur FMIC problems
  170. Anyone with AVO catback sound clips?
  171. What exedy clutch is this?
  172. B&B problems
  173. Sparkplug gap differences
  174. Vendors: Best price on Cusco Twinplate
  175. how much power will i gain???
  176. Scan tool help / question
  177. UK spec HKS intercooler pipes?
  178. BOV, VTA and Recir ? Two BOV
  179. Cams Needed ASAP
  180. which aftermarket exhaust is quiet as the stock
  181. 541 whp........not too hard to do.
  182. Tranny problem! Mitsu not covering, a must read!
  183. Downpipes! Getting theh best result with your stock turbo config!
  184. Metal air-intake tube and stock box?
  185. bigger intercooler = more turbo lag?
  186. FMIC or Cams, injectors and pump?
  187. Need AFCII Help!!
  188. What happened to my non-linear spool up at 3500 RPM?
  189. Anyone using the RnR Intercooler?
  190. How to have a good launch?
  191. gfb stealth bov?
  192. Squeaking, cricket like noise
  193. Just got HKS'ed Today!
  194. rr engineering clutch
  195. which would suggest cusco or ralliart twin
  196. Custom Exhaust Question
  197. Why in the HELL would this happen?
  198. HELP! Engine just starts back-firing at 4000rpm's
  199. Lead Vs Cat :(
  200. Stock 03 Evo Cam shaft specs??
  201. What Upgrade Injectors????
  202. Car being a retard
  203. APS or turboxs
  204. Ignition coil
  205. trans/transfer case oil
  206. Please Help w/ SSQV
  207. EVO 8 o2 housings
  208. upper inter cooler piping
  209. USDM RS driveshaft/rearend
  210. Oil/ Warranty Question
  211. Blow-Off Valve Question
  212. Help...Put Diesel in the Evo...
  213. HKS Cat?
  214. My EVO is sick. Need help.
  215. Turbotrix Saves the Day (Buschur Stage 1 -340WHP)
  216. APS Cold Air Intake or HKS Racing Suction Kit?
  217. ACT clutch with heavy-duty disc installed. Question?
  218. HKS Kansai Service Airbox
  219. HKS SSQV adjustment help
  220. Green Filter
  221. Anybody HELP me with my 1/4 mile time slips
  222. Transfercase is about to go boom i believe......??????HELP!
  223. Brake problem, i dont know whats wrong.
  224. Airpowersystems
  225. Please help service engine
  226. why are evo's so unrelyable.
  227. Clutch Problem
  228. Anyone blown a stock cat?
  229. Please help: Need Engine Specs evo VIII
  230. Drivetrain Symptoms
  231. vinshu turbo back
  232. TurboXS exhaust
  233. New Downpipe with Stock Cat
  234. The Misterious Black Stuff (on the underside of the car)????
  235. Best Drivetrain
  236. TurboXS H34 or MR DV???
  237. Cams for ATP 3071 turbo kit?
  238. TME turbo
  239. Denso or NGK? IW24 or BR8EIX?
  240. Engine service soon and Engine check light
  241. TT quick question
  242. Car keeps on randomly stalling?
  243. Transfer Case boom, wrong fluid
  244. Heat Shield for Oil Pan, w/downpipe
  245. Anybody have Buschur Intake Manifold
  246. Forge BOV Tuning!?!?!?!?
  247. My Heartbeat under the hood!
  248. Feels like a whole new Car...
  249. How can you tell if your Intercooler Pipes are leaking
  250. Tuning for Air intake filter?
