- AEM BEWARE!!!, Tuners please look, AEM vs Motech vs Microtech
- Greddy T-67 25G VS. HKS 3037S
- Modifying the stock turbo...
- #1 Nitto 1320 Online racing game
- Think this is a fire hazard?
- Tranny noise
- Turbotrix! Anyone what is this nasty horrid thing?
- T51R SPL - 17psi at 6K
- More power of Buchur Racing and Dyno Flash - 3" cat back = 300 ft lbs trq at wheels!
- My 93 octane pump gas dyno sheet - 20 psi - 417 whp
- Denso IW24 (cooler) plugs on stock Evo - observations
- Compatibility Q's
- Who's running the Hks Rs, 30th anniv.cb, dp?
- k&N typhoon intake
- Downpipe
- Port and Polish on the 4G63
- turbo?
- I Am A Dumbass!!!!!!!!!!!!
- 3" 2bolt gaskets for UR pipe
- just to make sure
- Attn Hks Filter Users!
- Hks Ssqv
- HELP: twin disk install problem
- Newbie - 320WHP on 91octane?
- blow off valves
- Inconel Manifold
- guess wutt arrived to my door step
- Power gains with Turbo Catback?
- Been boosting 25psi?
- HKS hi power question
- Ralliart Panel Filter
- What do u suggest?
- ACT Clutches?!
- front helical-type lsd
- Boost gauge Void warranty?
- High flow cat
- What's the O2 eliminator?
- Magnus Sheetmetal Intake
- EVO shudders during acceleration?
- How do you transport your exhaust?!
- clutch noises
- Got a K&N Typhoon for $190 NEW!!!
- Stock EVO exhaust is not that bad or is it.
- Rs-r Exhaust And Hks Exhaust?
- Intake And BOV Questions
- Has anybody has engine problems?
- Downside to having a Resonator?
- The Evo is ALIVE , finally>>>
- Questions on a Reflash..........
- Studs?
- Xede And Avc-r
- Those w/ Autometer boost gauge...pls help w/ install
- 5Zigen Fireball Cat Back Exhaust Systems
- I'm legal ! (finally)
- ATS triple plate or twin plate?
- 262 Or 272 Hks.
- RMR 3 inch exhaust with 3inch downpipe and testpipe!???
- Best prices on ARP head studs and rod bolts!!
- Black residue on back of car????
- 3" Exhaust too Efficient?
- 3" 02 elim RnR HKS Carbon/TI TB, All SS Piping $900
- Recall on clutch problem?????
- any drawback to cams
- Vibration when cold!
- Cusco twin disc installed
- plz post your aftermkt clutch feeling here!
- RnR HKS Carbon/TI Turbo and Catbacks
- Blitz TT install ?
- Buschur mini battery questions
- How to fix a groaning racing clutch!
- Apexi S-AFC II + mods
- Post-Intake Installation Observations
- Boost Controller Vs. Plain Gauge install...
- New Evo rally version & its clutch
- Tial Blow off
- Mobile 1 0w30
- How many mods and why?
- Any one using N20 (NOS)?
- I need help! looking for Castrol Gear Oil (SAF-XO)
- Please explain header design in turbo applications...
- Engine Surging
- Cusco lower arm bars and Buschur downpipe?
- Re-flashed ECU and traveling?
- Another Buschur Exhaust Thread..with installation instruction.
- NEW CEL Light again. Found out why
- Safety of Dynoflash, Works P2, XEDE
- WRC Evo Engine have soo much torque?
- I need a turbo boost gauge
- clutchmasters lightweight aluminum flywheel
- safe mode?
- Clutch Line
- Al or Shiv???? we have a winner!!!! [MERGED]
- Problems With Buschur Exhaust
- How to Read a Dyno Graph?
- mods worth getting
- Factory boost cut????
- K&N Short Ram intake!!!
- Hallman Pro RX... how do you like it? and another ? about MBCs
- Clutch master stage3
- Got evo dynoed today!!
- shifting into reverse problem
- Think I did a boo-boo
- PIVOT Multiple Data Logger PIVADL
- VRS O2 eliminator Downpipe?
- 3rd gear problems
- Electrical Wiring clips
- Axel back-Exhaust question?
- Upgrading Coils and Ignition control
- Anyone removed the EGT?
- Help!!!.....please!!
- Should I remove the clutch restrictor?
- Soundclip of Buschur 3" turboback with magnaflow
- my experience improving the stock turbo .....
- Boost creep
- Damn check engine light!!!
- Buschur exhuast...
- Long-term evaluations of Xede
- Emissions and Mods
- ... stock evolution fuel injectors...
- AYC ACD Conversion
- I'm getting some smoke here.........help!
- power loss or what?
- Installed JIC Exhaust Manifold
- Buschur MAS pipe
- How to get more mpg on an Evo?
- Difficulty Shifting Into 2nd Gear
- changing oil question
- cheapest place to buy K&N Drop in filter?
- Clucth noise I've never heard before.
- What is wrong with my new Evo
- How do I know if the transfer case (front open diff) is gone?
- anyone with the HKS hipower 30th or regular
- Dynoflash or XEDE(XFlash) and for what purpose?
- Octane Boosters
- What Is The Difference?
- Anyone have any videos of EVOs?
- DynoFlash mail-in question?
- Megan Racing exhaust
- idle problem when using greddy type s?
- Would K&N Drop in filter add anything to Al's mail in REflash?
- In take on the EVO
- Works
- Removed my AEM intake
- Balance Shafts or No Balance Shafts
- Engine chatter???
- 5Zigen Miracle Catback EVO exhaust question?
- ATS Triple Plate Carbon Clutch pics!
- Dyno,Code Clearing, and Definitions Service
- JIC Titanium/SS Exhaust vs. Buschur
- Mount wideband O2 bung in downpipe?
- lancershop downpipe
- Garage HRS Turbo Outlet Housing!
- EVO Owners Unite!!! - Mitsu Fax #
- anyone have any problems with Dynoflash basic FLASH?
- Help with Exhaust decision
- CEL code for no cat
- Solid clutch disk hub. Daily-drivable?
- Castrol RS 10w/60!! Found it in the US
- Drain/fill plug washers?
- Do 2G injectors work in the EVO?
- a general question about freeing up intake restrictions
- New Spearco Intercooler!!! (thread merge)
- Should a BOV void a warranty???
- intercooler install pics?
- Buschur UICP installed
- Twin HKS BOVs and turbo in
- Best Price for HKS 264 cams
- EvoSPL is back. 5
- Whats the best clutch i can get up to 700 bucks?
- Can anyone clear some numbers up for me?
- Boost not holding till redline
- Bogging EVO
- Average Top Boost
- BR Stage 2 @ 343whp and BR Stage 2 dynoflashed @ 310whp??
- HKS major Help!
- dynoflash rev's????
- Autometer boost gauge users please take poll
- Boost lost over 6000 rpms
- Engine Died, not good, heard metal sound !!!
- Clutch Masters Stage 3 Clutch...
- B&B turbo back + stock cat ... anyone have this setup?
- Anybody elses car whistles??????
- People with dataloggers!
- CEL with HKS RS kit?
- To ppl w/ RMR Steering Column Gauge mount...
- ECU removal?
- Had my car DynoFlashed this weekend
- Rings are bad what now??....:(
- AWD vs RWD top end
- Difference between HI power and 30th ANNIV.
- 2.4 L Evo?
- Mobile 1 filter number
- Hks Hi Power Question?
- Cheap Ass Scantool
- Got Dynoflashed
- How many miles without Clutch line??
- Idle reading on GReddy ProfecII EBC?
- Just installed catch can. Lots of oil!!!
- 264, 272
- Intercooler frozen
- Quick question!
- Mobil 1 10w-30?
- please help!
- I used Mobile 1 Synthetic. Car now leaks.
- Race gas and tuning
- Help Clutch Problem
- Need some help here..
- Loss of power at altitude, why?
- Al's Dyno stuff
- CEL FRom test pipe installed
- Timing belt tensioner MD998738...SPX OTC part #????
- Ralliart Performance Upgrades
- Unlimited boost
- Apexi S-AFC II or Turboback exhaust
- Greddy Type S BOV and HKS RS Intake WoW!
- Exedy Hyper single plate clutch noise
- HKS HI Power Question
- Garage HRS Manifold used by CyberEVO is now available thru Gruppe-s!!
- GReedy Profec II
- To heat rap my down pipe or not to? your thaughts
- Anyone install the Cusco twin disk yet...?
- crankcase pressure problem
- How do you know you have a turbo problem?
- Building evo race engine...
- My 7000 mile review of the Exedy Twin Plate
- No metal shavings on 1st oil change
- blowoff valve affecting perfomance
- Modifying CLutch assembly
- Part#MD998738
- Dyno Flashed - Buschur Racing Stage two dyno sheet
- What was the probLem?
- Need help QUICk. Buschur IC install
- Why my EVO stumble below 40degF
- Cool down and warm up procedure??
- water temp, oil temp and oil pressure
- Stock BOV?
- Warning! Stick with the factory spark plugs
- Why is my Brake light turning on?
- "Speed Box" turbo upgrade!
- K&N drop in panel filter for $45
- Oil catch can--- 2 holes???
- Nology Hot WIres????
- Aps Exhaust
- How can you check if the piston rings sealed right?
- Is that thing z-Max worth it?
- Drivetrain fluid update
- TRASH day..........
- Anybody port/polish turbo, O2, exh
- something not quite right???
- Beta tester wanted in NY area - free tune !
