PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Need info on Avid Front Motor Mount
  2. Transmission Cooler
  3. PTE 680cc Pump HP?
  4. Spark Blowout, bpr vs br?
  5. Upgraded -8 fuel lines now super high fuel psi
  6. stck vs built motor
  7. FP turbo oil line filter
  8. fp turbos
  9. Can i advance a tooth on GSC S2 cams setting?
  10. Is there anyway to duplicate the Revolver Grind?
  11. 1 & 2 gear hard to engage
  12. Help! Can't get right rear bolt off exhaust manifold outlet.
  13. Check my ported+caoted ex mani for me.
  14. Aem Gauge Logging
  15. Best daily driver solid motor mounts?
  16. deceleration noise
  17. Evo 8 10 PSI???
  18. Synapse Recirc Blow Off Valve
  19. R&R trans/clutch on a 4 post lift? (drive no type)
  20. Wierd idle bouncing problem
  21. GSC Lifter Installation Guide Needed..
  22. boost flutter in high rpms
  23. Bad alternator or something else?
  24. exhaust manifold shield ceramic/powdercoat?
  25. oil pressure gauge w sandwich plate?
  26. T-case will not mate trans???
  27. Clutch Slave Cylinder Parts Explosion Request
  28. cylinder 1 not getting fuel
  29. Who/How do you add Synchro Rev match transmission to an Evo 8/9?
  30. Car dies at startup or when clutch is pressed. Need help :(
  31. Should I put this back on or just buy a new one (another intake/bov thread lol)
  32. How High: RPMs on stock valve springs.
  33. Calling all Evos running a PTE 5557 Turbo
  34. Timing belt has SLACK between the cams at TDC
  35. Corroded wire and Power steering pressure switch code
  36. Evo 9 vs FP Green
  37. Massive over fueling.
  38. Boost Control PSI Level
  39. What Stage Clutch
  40. ACD fluid?
  41. Transmission/ clutch problems
  42. cosworth m2 cam setting
  43. Jack's Transmissions
  44. Compression change after line honing and raising the crank ?
  45. Turbo fittings info needed
  46. Ever wonder what 800ft/lbs of Torque does to a transmission?
  47. wedge collar questions.
  48. How many miles on your Tilton Carbon/Carbon twin!
  49. Best Turbo in T3 frame?
  50. whats this noise?
  51. installed new clutch but have a problem
  52. Annoying Vibration Noice
  53. Stock Mit Coils & Plug Cables matter?
  54. Clutch Pedal Travel too low after shop installed new Twin Plate clutch disks
  55. ToxicFab Forward Facing 6765 Videos!!!
  56. Custom Oil and Coolant lines, HELP!
  57. Car won't go into gear - Back Again.
  58. Who has actually owned a God Speed Intercooler?
  59. Does e85 damage stock fuel filters?
  60. P0300, P0303 Problems / Need Advice
  61. 4G63 Block with 4G64 Crank Question?
  62. Coolant leak ideas and advice
  63. HKS SSQV vs MR bov
  64. Gt3076R To GTX3076R
  65. What constitutes good dump pipe design .
  66. Engine "knock"
  67. Tial 50mm vs Tial Q???
  68. oil squirters and oil ring gap
  69. The best, most reliable and durable Head to run in my VIII
  70. Spool time question
  71. can i reuse axle seal?
  72. Evo 8 turbo upgrade?
  73. Cams on stock turbo?
  74. Is this turbo done/shot
  75. Power Loss
  76. Lean idle on coldstart
  77. Injector help
  78. need help with clutch
  79. Drivetrain noise help
  80. Best cams for stock IX turbo?
  81. Over heating problem help!
  82. TRE Rear Diff service experiance / review
  83. M11 x 1.25 Thread Chaser/Tap...I need one ASAP!
  84. new exedy twin plate convert to push style using tilton set up
  85. Exedy Twin Clutch Cover Bolt Torque Specifications?
  86. Bad Wideband o2 Sensor?
  87. Blow by
  88. apexi avcr and tial wastegates
  89. Clutch Vibration
  90. Should I instal head studs or not??
  91. External Wastegate With Stock Turbo
  92. Evo 7 vs 8 and 9 fuel rails
  93. Do these FIC 1100cc Hz Injectors Look Right?
  94. Front wheel bearing?
  95. First Evo 8, Need some help plz. No start.
  96. Front brakes draggin after ss line install + bleed
  97. Why my car suddenly "Knock" seriously?
  98. Air/Fuel Mixture too lean, help.....
  99. Please help!
  100. cant boost over 30??
  101. turbo upgrade question
  102. Another Transmission Thread
  103. Evo 8 with turbo and transmission for sale!
  104. What your thoughts on this
  105. anyone running MIL.SPEC cat?
  106. Need help with 2.0 build
  107. what to do
  108. buschur engine
  109. HKS 272 and Single Adj. Cam gear??
  110. Oil Analysis results
  111. Anyone using CP Pistons???
  112. AEM Wide Band Problem
  113. Fic low Z vs. Fic high Z question
  114. FASTEST spooling turbo capable of 700HP PLUS???
  115. Tranny noise... Please help!!!!
  116. JohnBradley's 2011 car update.
  117. Will i need a retune???
  118. Need some help
  119. what clutch should i use
  120. Prolong turbo life
  121. Shifter bushings
  122. Twin scroll single wastegate, fabrication questions
  123. Oil pressure gauge install questions
  124. Question on my FP RED Turbo...
  125. Stalls with clutch in and throwing 5 codes.
  126. CBRD, EVODAN build, and more...
  127. Code PO171 Problems
  128. Carbonetics Pro Blade clutch- Mini review
  129. intercooler core
  130. best clutch for me and why?
  131. it finally happened
  132. attention you 1/2 radiatEr's..
  133. Tial BOV not opening?
  134. Curious about Mitsy Turbos specs - 9MR and 10 ...
  135. Evo 8 grounding/starting issue.
  136. 400whp on 91 octane
  137. late spool up
  138. Drive Shaft Compatibility for Evo 5.
  139. Turbo Question
  140. stock motor
  141. Question regarding A/F meter reading
  142. Wave lock retaining clip
  143. weird engine noise, piston slap? (video)
  144. Gear positions are shifted to the right? 1st is where 3rd normally is.
  145. sputtering problems at high rpm
  146. best solid motor mounts? and should i change fluids when changing clutch?
  147. Run E85 with stock injectors, evo9 turbo, and Aeromotive FPR ?
  148. clutch
  149. Half width radiator users
  150. O2 Housing vs O2 Housing w/ Dump tube
  151. Ingalls ETD
  152. Turbo Choice
  153. Need Help
  154. Spark Plug gap?
  155. new block?
  156. Should I have more boost than 12 psi
  157. Evo IV ticking noise
  158. How to install check valve w/ catch can for PCV
  159. Intake or drop in??
  160. 2.2L owners chime in
  161. What to do next?
  162. What Vendors use Metal O2 Dump Gaskets?
  163. everything is going wrong!!!! need help
  164. DIY turbo surge fix!
  165. Transmission output shafts question
  166. Bleed RS Brakes (Non ABS)
  167. hybrid turbo flow?
  168. max HP on a 044 in series E85
  169. Revised Tomei Arms M7960????
  170. anyone using DI large plenum intake manifold?
  171. question about the clutch retaining clip
  172. Where to buy online valve springs shims
  173. Precision 6262/FP red owners chime in!!
  174. SparkTech COP - failures
  175. E85 Question
  176. FPgreen, HKS 280s, straight pipe, are 880 injectors enough for E85?
  177. Inline BOV, anyone tried it?
  178. Fuel rail install question on seals
  179. Tial 44mm WG help!!please
  180. Licp that works with gt35r?
  181. JE asymmetrical FSR
  182. Anyone knows what brand these injectors are?
  183. Anyone know which exhaust this is?
  184. hks 7460r pulls
  185. High Revving Setup
  186. Check Engine: System running too rich. Need help
  187. How to fix starter cable
  188. Wtk 2.3l build information
  189. No O2 sensor
  190. ATP High Flow 3" O2 housing for stock appearing turbos...?
  191. Somehow caused a p0031
  192. Has anyone powder-coated their turbo?
  193. Cams in a IX ?
  194. Got more than I paid for from Jiffylube today (damage)
  195. code P0456/ Not idoling
  196. Coolant Problems, Please Assist
  197. P0170 Code and Boost Question
  198. new 2.1 motor oil leak comming from exhaust manifold..
  199. Fix My ACD Problem and I will pay you!
  200. Intercooler comparison on stock turbo
  201. Need a new timing belt tensioner...Gates or OEM??
  202. EVO 4 tranny for EVO 7... NEED HELP
  203. Which map sensor to run on sd
  204. Which one? Walbro 255 HP, DW300, Aeromotive 340 Fuel Pump
  205. Battery Wire Color Question
  206. 20g or Evo 9 turbo?
  207. Separating Tranny & Engine
  208. Solid hub clutch on a MR tranny ?
  209. Ets t3 turbo kit
  210. Cylinder 4 misfire help!
  211. Evo 4 Valve springs question
  212. Whats My Displacement?
  213. can this work ???
  214. Valve spring Evo 4 to Evo difference???
  215. With EXTREME REGRET I post this warning.......
  216. WGA preload
  217. What do you think about this Turbo - BW S256 Non ETT?
  218. Never buy competition clutches
  219. Rc 1200 cc injectors
  220. HKS 7460 Howling
  221. Spark Plugs to hot?
  222. E3 Spark plugs....
  223. need to re build turbo any suggestions?
  224. Might be going a different direction....
  225. Another "What's that sound?!" Thread
  226. I need a shortblock!!!
  227. what brand gt35r!?
  228. tranny doesn't like 3, 4, or 5
  229. Why is my stock Evo 5 turbo lag???
  230. GSC S2 Cams Setting?
  231. Mounting Motor on Engine Stand
  232. Lower Cost Option A/c Compressor
  233. Best Camshafts duration
  234. How will cam work on stock head.
  235. Cobb Short Ram Intake feedback?
  236. HELP: IS A Evo 8 5 speed Trans TB/TB Fork Same as Evo 8 6 speed?
  237. How fragile are the iridium tip spark plugs?
  238. APS twin vent fitment
  239. Shifter Issues
  240. Need a few opinions on my build.
  241. Uhh Hellpp with balance belt and oil pump/timing belt question Please
  242. 20/50 in a 4G63?
  243. changing lifters only
  244. wot shifting problem
  245. what kind of turbo is this??
  246. 6262 Comp Wheel for my Garrett GT35R
  247. Removing Output Shaft
  248. First impression: QM v2 Twin Disc
  249. p0139
  250. Odd Compression Test EVO 8
