View Full Version : Evo Engine / Turbo / Drivetrain
- Lightweight Flywheel
- Broken Back Windows?
- Help me out: Changing Tranny and Transfer Case
- Mitsubishi Evo Viii Microtech Ltx-8 Computer
- OBD II Port, the white port next to it....
- HKS SSQV Question
- Need wiring diagram for 03 evo
- stock boost
- tranny noise
- 18G twin scroll turbo?
- check engine light!!!!
- fuel injection for the evo
- Update: Pics of boost gauge and turbo timer
- Official Brake Bleeding Sequence
- Boost gauge install (have searched)
- Stock boost pattern...?....? Why?
- Stock boost solonoid removed?
- Blow off valve testing, it really works!
- Dynapack diff resonance problems
- Oil catch can
- Mitsubishi Lancer Evo Mini Rc Car
- Small mishap, bent IC piping
- New affordable wideband O2 controller/display
- Anybody installed this intake yet?
- evo viii fq320 or fq340
- What is the Best Engine for my Evo 7?
- Cheap gas over 91 octane
- Installed Boost and EGT Guages
- Aftermarket cams?
- Recommend me some gauges?
- Questions - aftermarket headers on evo - what about the heat ????? help!
- boost on evo!!!
- AEM Intake
- PV=nRT ...... boost and CAI's
- Compressor map for EVO turbo?
- Stock Fuel System - specs?
- Aftermarket air filter comparison test!
- Quesstions about the towing of my evo!!
- RMR SRI Vs. HKS Racing Suction
- Vishnu Stage Zero: initial impressions
- dump tube for evo.....
- high boost on evo!!!
- Finally.. my first mods came in today.
- EVO 2 - 10.4's at 140mph
- Video AMS EVO 8 12.54 at 111mph
- Whats everyones timing advance at 6k-7k
- Fixed boost "controller"?
- Exhaust Versus Cat-Back
- What boost on race gas is safe?
- Does Getrag make the U.S. EVO tranny?
- Weird noise from 6k on up... anyone else?
- 3"Catback and boost rpm kick in
- Custom Exhaust
- blue wire in AFC for the O2 sensor
- Question Evo drivers only...
- My dyno result, just under 300whp
- Creak from the rear of the car in reverse...
- clunk/clang sound when shifting from first to reverse..?!
- Evo engine with LOWER KNOCK!
- Anyone install Open Air filter yet??
- Loudest exhaust? Yes, I want the loudest!
- Cooler weather = WAY more power!
- transmission grinding in 2nd
- questions about boost
- Installing HID bulbs?
- EBC troubleshooting
- FYI: front speaker sizing
- HKS Racing Suction Kit
- So. Cak Muffler SHops
- EVO VIII paint quality
- Clutch for Evo8?
- IPT Dashkit for Evolution VIII
- HKS SSQBOV VS. Greddy Type s
- I can't put on the s2k antenna!!!
- Does Anybody Know Where Get This?
- Best BOV for EVO8
- Need some quick HELP
- External Wastegate
- This is why you look after your EVO/Turbo Car
- Noisy breaks
- Took off evo spoiler is lacer trunk same size?
- Difference between these AirFuel computers...
- had my exhaust done for 60$ on my evo
- Steam cloud when it's raining?
- GL-4 gear oil
- AWD launch and boost ?
- is your Greddy Type-S making your car stumble?
- 5th gear grind
- Power Pulley for EVO7
- Are there anyone who NOT have the drivetrain rattle/buzzing problem?
- Boost gauge install question, hose routing.....
- Cam Question
- HKS camshaft
- Test pipe
- Better best 1/4 mile time!!!!
- evo exhaust choice
- Boost tapers off at high RPM
- evo viii upgrade
- Fog-light Bulbs on the EVO?
- short throw for evo!
- Help me out guys!!!!!
- IMMO in USA EVO VIII
- Boost gauge / turbo timer...?
- Need HELP with EBC install
- Help, sticky shifter
- RalliArt or K&N drop in filter??
- Evo VIII And 2g Eclipse Engine
- K&N drop in filter
- Service engine soon light just came on at 580 miles.
- AF meter install help
- intercooler piping
- Bov
- Evo Oil Filter
- Redline!!
- Rhys Millen Cat-Back Review
- please advise
- Just bought
- EVO VII GTA Engine Known Problem(s)
- Hydraulic Lifters..
- Forged Pistons and Rods in the EVO?
- $1000 for performance mod... what should I get?
- 25 PSI on Evo 8 motor..
- DSMLink and other ECU development...
- Exedy Twin Disc for Evo 8. Need part #.
- AFC's best-worst?
- Hks Super Afc 2
- Greddy Type s BOV problems, any help?
- Where to find switched power behind the dash?
- Need some advice
- Fuel injector & max duty cycle
- Is your aftermarket BOV recirculated or VTA?
- EVO VIII Service Manuals
- Bent FMIC fins?
- Clutch Issues...Possible bad Throw out bearing?
- Side Window Air Deflectors
- Ralliart parts
- BOV question
- Turbo Timer Question!
- Headlight height adjusment problem...
- greddy profect e-01
- Question for the tuners
- static shock
- Evo engine knock normal?
- JIC's ti-exhaust too short??
- Just got an Evo. What to do?????
- anyone else put a greddy type s in their evo?
- Good Manual Boost controllers?
- Where to get a boost gauge installed in SoCal?
- I took my evo up to 7620 RPm!!..
- FYI on Mobil 1 oil....
- front turn lights
- my evos ok
- New EVO Owner: question about drivetrain - Claudius?
- A stepless VTEC
- Damn, a new rattle...
- TRUST Intercooler opinion
- s-afc settings
- Difficulty and feasability of the JDM Evo VIII 6 speed?
- Torque Settings for Wheel Lug Nuts
- first problems with evo
- Anyone Tryed an Exhaust Cutout
- ECU Upgrade
- What's everyone running for fuel management?
- Gauge pod for the "A" pillar...
- Did Some Datalogging....
- 92 Octane highest in CA??
- Greddy BOV vent to air
- miles on evo
- TD05 - TD04 Hybrid question..
- Looky Looky
- Break In After 600mi?
- AFC alone with no other mods
- Buschur Racing's dyno numbers....
- Any EBC's installed yet?
- blitz sbc id
- How many amps to the fuel pump?
- props to vishnu
- Constant Power Wire
- kPA vs Psi...HELP!
- Can HKS VPC br used on an EVO??
- Mugen is to Honda as ??? Is to Mitsu
- Offical Mitsubishi Oil Filters
- What did you run in the 1/4 bone stock?
- Intercooler spray modes?
- How Many People Have the Problem W/ Tranny Noise
- B.o.v.
- ordered blitz v-spec fmic.
- WIll Mitsu put side air bags on the Evo?
- HKS Megaflow intake......
- CRAPPY gas mileage
- Evolution's Centerpiece.
- GReddy e-manage
- Intalling the GReddy Profec e-01
- boost gauge advice and pics
- Where to order OEM front LSD (Evo VII type)?
- 4G63t Heads,
- GT25 vs TD05 for 1.8L
- clutch failured allready
- S-AFC installed but....
- manual boost controller question
- Question about paint jobs done on Evo VIIIs
- automatic transmission
- My Clutch - Help Please
- Interior Lights
- Factory guage package
- transmission Question
- HKS SSQV Results and Tuning ?'s for any BOV
- Why boost gauge?
- Wiring Harness Update
- Joe P. E-MBC boost controller
- boost controller ????
- boost control following facotry boost curve
- Blitz FATT DCII wiring harness
- 2nd gear thunk
- HKS SSQBOV Problems on Evo?
- 12.53 @ 109.19 Woohoo!!!!!!
- Stock Boost Solenoid...
- SSBOV engine light??
- What's a safe boost lvl without AFC?
- 1/4 mile times not quite what i hoped
- port the turbo?
- HELP!!!evo 8 blitz DTT installation
- A/F guage in AFR??
- New dyno numbers from Buschur....
- Datalogging - Timing advance
- Different transmission fluids
- Turbo Lag on Evo8 ?
- Thermal Cat Back Exhaust
- rock pits along side my passanger side
- Is this normal?
- Gas Guage Wierdness
- Ayc
- Parts section with sound bites?
- Vivid CEL fix - O2 simulator
- Methanol Injection on 4G63T
- Engine longevity...
- bucking on throttle off.. compressor surge?
- conflicts with turbo timer and remote start alarms
- Ideal tire pressure for launching??
- Buschur but better???
- Which Turbo timer is best?
- Vibrating Screetching Noise in EVO Clutch
- Need for an Oil Catch Can?
- Vishnu XEDE
- Turbo timers alarm bypass
- Ultimate Evo Gearbox
- Staged EVO upgrades?
- smoking exhaust?
