PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 [171] 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Could use some help, sudden sputtering
  2. Max Boost w/ stock fuel system
  3. Make Your Own Race Gas!!!
  4. GT35R, stock fuel system, walbro, confused, help?
  5. undivided t4 ex. manifolds???
  6. is my clutch broken in yet?
  7. Completely lost in the problem....need input
  8. Is Revolver ever going to release more cams?
  9. 50 trim owners, any surging issue at high boost ?
  10. The reason you MUST do a "boost leak test"!! Don't pass go. Read this.
  11. Acd
  12. Rear mount removal?
  13. Oil Temp Gauge On The Evo9 Mr?
  14. How much power till tranny upgrade?
  15. Flame off backfire question
  16. Quiet free flowing exhaust
  17. AEM TRU Boost
  18. Vta Bov's
  19. Smoke at WOT
  20. Power Steering Pump Whine?
  21. Odd rattle/noise when accelerating
  22. Clutch or transmision issue?
  23. My 2.3L build, lots o pics
  24. Details of Garretts GT37R - pics please .
  25. Invidia G200 Catback Exhaust? Anyone?
  26. boost control??
  27. Ported Turbine Housing
  28. Do i need a softer spring in the TIAL bov turbo is surging..
  29. ACD Wiring Diagram
  30. Motec differential controller. RWD Evos?
  31. Plug Life on Leaded Gas?
  32. Factory boost control questions
  33. Could someone please answer me the following question regarding AFR's?
  34. looks like I'll be giving shepracing a call tomorrow morning :(
  35. Massachusetts Exhaust Noise Laws - Legislation Update
  36. Backfiring when shifting and getting into boost, help?
  37. ISO good quality and accurate sensors ...
  38. coolant temp sensor broke help:(
  39. 10.5 HotSide Single vs. Dual
  40. Who powershifts exedy twin plates...
  41. weird grinding noise. please help!
  42. Misfire Shudder Problem
  43. throttle stuck open
  44. MR Transmission Cooler
  45. Rough idle - need some help
  46. Springs and retainers
  47. Evo 8 turbo on Evo 1
  48. tilton twin cerametallic owners
  49. My po300 problems
  50. Piston Bore Spacing
  51. Tilton Pedal Stop
  52. Evo problems
  53. ACD - Thoughts on using the E-brake
  54. How do these seals go in to the TB ??
  55. Aftermarket turbo boost leak test problem..........
  56. EVO VII - Overheating
  57. I need more than 255 lph.... SARD 280 lph ?
  58. Devo Tunings Quartermaster Twin Disk
  59. Warming up Tilton clutches?
  60. This is why YOU need an oil catch can*Pics
  61. CEL Fix / O2 Simulator on IX
  62. surging 3076r, anyone else w/ this problem ?
  63. HKS DLI 2 Harness
  64. Dynoflash Vs Bigvalley @ Atco
  65. Gauging interest on an aluminum drag spoiler
  66. SBR kit installed
  67. engine / turbo, something is wrong
  68. Front Bumper Plates and pics
  69. BG syncroshift II,big difference
  70. Evo IX Turbo Kits?
  71. helix
  72. will hks rs intake for 8 fit 9 turbo?
  73. New mods, what do you all think?
  74. 10lbs of boost
  75. bearings
  76. YES or NO to new head studs?
  77. Where is the road speed sensor located?
  78. balance shaft bearing help
  79. Lost hp / tq with 3" TBE ?????
  80. Act Clutch On Stock Flywheel...
  81. Are head studs the same for the VIII and IX?
  82. Unorthodox racing pulley & stock belt
  83. valve noise?
  84. Just installed HKS 280/280
  85. Help: parts yield bad smell and early rev bouncing
  86. Boosts in gear~
  87. lack of power...
  88. Heat coating for exhaust...
  89. spark plug gap for 20psi and for 24psi of boost
  90. Will this work? Or am I crazy?
  91. Launch Control and NLS from a Gizzmo
  92. identify this part please, transmission?
  93. Shifter parts ? swapping shifters
  94. Does this affect performance?
  95. What would net me more performance gains?
  96. New 20g From Buschur???
  97. I noticed tonite that something was broke...
  98. Head gasket Help.
  99. boost test goes straight out exhaust
  100. Is this manifold crap? - The cheap Ebay stuff
  101. boost flutter??? help please
  102. Coolant lines
  103. BG Synchroshift or Factory Fluid
  104. Another MBC problem thread
  105. Hotside temps?
  106. New Turbo on EVO 9? Check it out.
  107. which stroker kit would you guys go with??
  108. Few questions
  109. No boost leak = car is still slow ?
  110. Tial BOV issues , please help
  111. Does the boost solenoid have to be grounded ?
  112. 3 bolt flange and 2 bolt problem
  113. "LOUD" rubbing vibration noise after new clutch.
  114. Will I need a new bov for alky?
  115. How big a deal is a small boost leak?
  116. Why is my torque low
  117. Having a boost issue..need help
  118. IX Front Bumper Removal
  119. anyone heard of compition clutches?
  120. SMC alky problem
  121. Need help with AMS UICP and TIAL bov Install!
  122. XSPower (eBay) Exhaust Question...
  123. evo9 vs evo8 aircondition compresor
  124. FRom 264i to 272i...
  125. Just changed clutch about to fill the fluids...
  126. Do i have an Upgraded Fuel pump?
  127. Hard to shift from 3rd to 4th
  128. Cant get greddy profec type s to hit my initial boost right
  129. For those running 30psi+...
  130. DC Downpipe on a IX...
  131. Maximum boost for street/ ¼ mile
  132. Who's running higher than 28psi on meth and stock turbo?
  133. For those with an AMS base tune...
  134. Who is squirting meth WITHOUT using a catch can?
  135. 20 over bore
  136. High rpm's
  137. advice pls..do i need to adjust clutch?
  138. Help: Sticking clutch (twin disk) at low rpms
  139. What keeps the voltage charged in evo...
  140. Some issues after clutch install..
  141. Why are ported or Large Throttle bodies shunned upon or deemed useless?
  142. Greddy Oil Filter Block
  143. supertech valve spring specs
  144. any BBT04R turbo users?
  145. Spark Plug Diagnosis
  146. 6 puck or street disk?
  147. No more power after many new mods...wth?
  148. Did i totally screw my new ACT HD clutch?
  149. Car bucks when I punch it......
  150. Stroker kit purchasing question...
  151. stock whp?
  152. Weakest link..TC or Tranny??
  153. $900 to spend what to buy
  154. exedy twin disk?
  155. something happended today!!
  156. SMC Trunk mount braided line question.
  157. Check out my Fugley 4"intake and mini battery tray lol
  158. turbo failure?
  159. Question to those with EBC
  160. evo clutch/tranny
  161. Advice Wanted - EBC & TBE
  162. Whp Expectations ?????
  163. Does a GT3076R Exist? - And is it better than a 3071
  164. running higher boost on 100+ octane
  165. Lost my 6th gear at the track
  166. Greddy R-spec HG intercooler
  167. Front rattle drivers side Not TOB
  168. Evo 9 MR ECU Exhaust compatibility & Strut tower bolt
  169. need a gasket
  170. Car nudges when putting into 1st from stop???
  171. Crank Vents
  172. Fuel Trouble: Guru's / Experts Please Help
  173. Need new plugs...how much to gap
  174. Boost Creep &/or Spike Please Help
  175. need advice on clutch adjustment....
  176. RPM specific rattle
  177. 400hp help
  178. Where can I get a tranny mount for my evo 8?
  179. Warning!! Alternator and potential blow-up your ride!
  180. Greddy Ti soundclips.....
  181. Anyone put kn filter on hks racing suction pipe
  182. Installing Exedy soon.. Quick Question for the DIY guys..
  183. Overfilling the transmission
  184. 10.88 at 130 mph, pump gas+alky.
  185. Felt pieces on clutch slave cylinder.
  186. Have to get yet another clutch
  187. Installed clutch and now i cant boost.
  188. Part numbers to the 5th gear grind TSB-04-22-003REV
  189. Clutch is going but still works perfectly...should my gears lock out?
  190. What other options for getting cold air into our intakes? One of my ideas:
  191. Megan Catback Fitment Issues
  192. i need parts asap!! HELP!!
  193. another TC Whine noise question
  194. XS-POwer UICP fitment
  195. New Mitsubishi books are in and ready to ship.
  196. Who has the strongest stock turbo IX???
  197. Buschur pure power?
  198. Need some advice
  199. Injen FMIC VS Buschur FMIC
  200. Propeller Shaft boot broken :(
  201. Converting back to Pull style clutch(what parts!! HELP)
  202. Stock IX intercooler core size please
  203. axial supercharger amazing!
  204. 3" exhaust, open air filter, MBC, walbro, which are best and where to buy?
  205. Is my clutch shot?
  206. COP ignition
  207. Exedy Twin disc Vs. Single disc Question...
  208. injen intercooler
  209. 5 year smog.........LOL
  210. Do 03-04 axles fit 05's?
  211. I need pics of the Buschur intake installed - Please
  212. Cleaning up Titanium?
  213. whats better... 5 speed or 6 speed?
  214. Is SMC Good
  215. tme boost log in 3rd gear needed
  216. ACT clutch & gear lock in
  217. need help...
  218. Exhaust bolts???
  219. Mr Freeze injection kit
  220. Stainless steel cluchline
  221. Anyone have a Vibrant Cat-back?
  222. Stock clutch & Gear Lockout?
  223. ix turbo installed=>03 evo/comparsion(pic)
  224. Greddy V-spec Intercooler
  225. How much WHP with my mods ???
  226. RMR Turboback quesions
  227. Looking for a utec map!
  228. What are the steps?
  229. TC howling????
  230. o2 housing and port exhaust manifold
  231. People running 91 & Alky, come on in
  232. ARP head studs, is this the correct part?!?!?
  233. Anyone does OIL Change in MR by yourself? Q inside!
  234. Tranni removal tricks OMG????
  235. porting exhaust manifold and gasket matching
  236. 20g records, Stock Appearing Class etc.....
  237. 35R dyno results??
  238. c16 on 104 tune
  239. CEL Codes p0441 & p0452
  240. Need to adjust the clutch?
  241. new intercooler installed now a noise pleas help
  242. Quaife owners speak up
  243. transfer case
  244. pluging hole in intake for vta?
  245. push and pull clutch systems?
  246. TINY TINY CHIP on hks272 lobe.?
  247. Office Evo QTP Down pipe
  248. Hallman boost controler evolution and evolution rx
  249. evo8 tranny + t-case dimension?
  250. Stock turbo + Cosworth Head
