View Full Version : Evo Engine / Turbo / Drivetrain
- cams for the evo
- need evo parts
- Evo With Nitrous
- Tranny question
- Exede Twin Clutch Questions
- Walboro 255 fuel pump in a stock car
- Gm Syncromesh fluid, which one?
- ralliart ecu
- Dyno FLash??!!??
- HKS Exhaust Questions
- TSB bulletins - somebody hook me up please!!
- Grinding gears
- Clutch restrictor removal?
- SAFC2 vs. BuschurFlash
- Looking to get a short shifter
- ACT Street Clutch question
- Apexi AVC-R settings
- Greddy Type S Vs Blitz Bov
- HKS vs Jun vs Tomei vs Piper vs Works vs etc...
- What front pipe should i use with my Greddy Ti cat-back?
- 6 Grear tranny???
- Click behind dashboard from pressing gas pedal
- hearing nastly whine at decceleration
- EVO Engine to Lancer Engine
- cam question
- Greddy Type-R Bov
- Help! GReddy BOV adjustment screw broken
- what triggers P0139
- WORKS Downpipe
- Need opinions on Stutter Boxes>>>
- Check Engine Light Issue
- Has anyone used the new Comp Cams cam on their evo yet??
- 5th Gear Grind???
- evo 8 Clutch Out $1400 need your opinion...
- Intake Manifolds
- One BIG Turbo!!!
- Stock Turbo
- Car starts and idles, but breaks up BAD!!!
- Spark plug questions
- Stock Clutch Info Request...
- SAFC Settings
- Tial Bov anyone???
- Trany problem????
- HELP!! My EVO wont start!
- Exedy Hyper Single Clutch
- boost spike concerns
- ecu code po401
- Best piston rings
- Car won't start
- Some more noticeable mods
- buschur question...
- Official PO300 fix from Mitsubishi
- Defi D a/f reading?
- S-AFC + VTA BOV = Does it really work?
- nx n tercooler sprayer
- Best Full IC Pipe Kits??
- Anyone interested in a GB on a RPS Carbon clutch?
- Valvespring and Retainer install - Tools and difficulty?
- 1g BOV problem ???
- Dyno results
- fujitsubo RM-01A ti or HKS carbon-ti
- which would you rather get ARC or HKS RS
- How Much Power Am I Losing?
- why am i only getting 296 whp?
- Car is cutting out around 2,500 rpms
- Stock Gaskets on 3" exhaust
- Weird boost fluctuation
- Funny Fuel Problem...
- Injectors needed??
- Best clutch for daily driver / drag racer w/ 320 wheel horse power?
- Waste Gate Solenoid Placement – Blitz boost controller
- if i change the muffler, will it effect the hp gain?
- Has anyone/Could I?
- ....More clunking >=(
- who makes this radiator shield/intake scoop?
- Clutchmaster stage 3 or Exede twin plate?
- temp changes
- Piper cams? Vendors, anyone HELP
- Various parts questions
- Test pipe = ECU running lean or extra rich?
- Is my clutch dead?
- EVO8 Starter ????
- I need help!
- The new guy
- Cold = gear grinding???
- rattling noise with twin disc clutch
- Evo nitrous install Part One!
- New parts installed,,NOT too impressed!
- Will i Regret this purchase????
- Help me find good price on clutch and repair..
- Gas Pedal Sticking
- Nissan infinity 90 throttlebody
- Gtech Pro Competition
- What WHP will be generated by these mods????
- stalling issues after walbro fuel pump install
- GM Syncromesh?
- help! dont know whats wrong w/ my car!
- Cyl #4 Meltdown Issue
- Evo head porting pictures
- does an EBC cut the ecu completely out of the loop?
- Gasoline -> BP vs. Sunoco
- Timing belt question
- HKS Cams: Do i need springs and retainers too?
- HKS GT manifolds
- Short shifters: are they worth the upgrade??
- Pennzoil Syncromesh
- adding modds question.....
- Newbie stick driver, will I have clutch/TC problems?
- IC pipes
- Controlers, Timers, Sencors?!?!?!
- UR Blowthrough MAF first look..
- 15k+ Engine Oil Question?
- Anyone with the Buschur muffler delete pipe installed?
- MSD Ignition
- What is the stock exhuast piping size?
- my MBC is F'd UP
- AutoEnginuity Scantool / Speedtracer Results & Questions
- Vendors
- braided fuel lines
- is obx fpr good?
- Advice on a good performance clutch.
- Need advice on mods
- next mod
- whining noise???
- 116 octane race gas
- another turbo and another tune...
- New Clutch record!
- Engine turns off occasionally. HELP
- rnr v/s ams turbo kit
- A/F gauge problem :helpme:
- does an ebc compensate for altitude and weather?
- a detonation problem?
- Cam upgrade before exhaust?
- Blitz SBC i-D3 owners -- please help with settings
- What air intake do you use????????????????????????
- MBC Install Probs. Help!?!
- flywheel
- HKS 272 cams without fuel management
- Im about to get a 1G BOV to replace my stripped Greddy Type S, what do I need??
- Electronics help???
- Anyone stripped Adjustment screw on Type S??
- Look what I just got
- atp turbo users
- My Car is Running Awful
- Megan DP Vs the rest?
- Car being stupid
- How to spool turbo up all the time?
- better turbo for my evo
- Help! My BOV snapped
- B+B downpipe issues
- Axis racing dyno results (dyno dynamics)
- Turbo Back question
- Dumb cam gear question
- Modified Air Box
- clutch install step by step???
- MB Install
- Best Tranny/diff fluid for NE daily driver?
- Is it bad to downshift to 1st gear?
- exaust manifold same as dsm?
- horsepower estimate?
- Fuel pump and fuel pressure regulator issues
- Anyone removed the exhaust flap?
- Six gears
- evo engine specs?.
- Titanum turbo back??
- Trusting the S-AFCII Knock Indicator
- To all with Buschur racing Turbo back Please Read
- power mods
- 50 trim Dyno numbers
- Stock BOOST!!!!
- Free Mod!!! ....Kinda...
- What should the compression test results be.
- K&N Drop-in and 2 Piece Underhood Bushings!!!
- Boost Lag
- Evo aluminium drive shaft!
- ARC box or Apex'i filter w/ pipe?
- for those running highly moddified fuel systems
- once again.... clutch info....
- i want to set my SAFC to shoot flames
- test pipe
- Apexi TT Harness?
- Factory Thermostat Temp?
- 2nd Blown Motor Blown Clutch 3000 miles sucks
- Downpipe contacts frame
- At 21k I have to pay
- EVO III turbo
- Supra TT Fuel Pump vrs. Walbro
- My clutch's acting funny! Stiff shifting into gear!
- Special ECU Reset Vs. Regular ECU Reset
- stage 3 clutch slips!
- wastegate hole size
- Quick ? about HKS Ignition
- TurboXS MBC question
- Can someone tell me what this thing is?
- Tech help... car dies
- TC or transmission problems ????
- got a new intercooler today.....
- Transfer case failure question
- New Dyno sheet w/GT35R
- Can anyone confirm A/F?
- Shattered Center Diff
- Clutch Slippage
- Install prices for new clutch in Texas ?
- Am I hoping for too much???
- Clutch slipping
- Melted Pistons - Help
- Turbosmart Dual Port BOV...any good?
- Defi D Guage Installed Pics(white)
- Tanabe Down Pipe
- boost question
- Help me to choose a clutch
- Shortshifter: new B&M or Kartboy? >>>
- Anyone know the weight of the 4g63?
- TOPSPEED Catback Exhaust ?
- turbo timers
- fuel pump and injectors
- RS-R or RMR?
- electrical help needed
- Apexi S-AFC II Tuning Advice
- CLUTCH DISC vs FULL CLUTCH REPLACEMENT
- Ur Ic Pipe?
- before buying a clutch what should i do
- Engine oil level
- RMR Intake and Induction Pipe?
- how much power?
- Denso Iridium Plug Issues......
- Patch Harness Trouble
- Powershifting?
- Help: Exhaust system is rubbing
- Help! Anyone know where O2 sensor wiring harness clip is?
- w/ 3" cat-back, unstable idle?
- stock fuel pump check valve?
- Problem during cam install
- Need help resetting HKS ebc
- Ecu +
- HKS Turbo timer Type 0
- 92 or 93 octane same as 100 with WI
- Need new clutch.. HELP!
- quick tech topic....
- Ugly noise in 1st and 2nd!
- BOV sound clips?
- how would u start?
- dont wash your motor, it will start skipping
- Turbo Lag
- Mods that will shorten engine life
- A Call to Fabricators/Tuners -AMS, Buschur, TurboTrix, Vishnu
- Greddy Type-S BOV..is it VTA & recirc?
- Help!.... Car won't start!
- safe boost level for c16?
