- surging? boost problem?
- clutch about to go out?
- Uicp
- Clutch???????
- Having your cake and eating it too...quiet, but performance exhaust.
- Clutch
- What LICP???
- Simple answer? Oil Loss 1 qt/ 500 miles. BAD BLOWBY?
- Has Forcedperformance been returning peoples calls?
- Time for cams!
- Expected HP for Turbo Setup /w my mods?
- FP Green Turbine Housing pictures?
- clutch
- looking to buy stock evo 9 turbo
- Few questions Im a noobie
- Witch one should I get?
- my idle is weird
- Cheapest Exedy twin-disk install EVER!
- My Zex Nitrous setup
- Turbo Smart E-Boost 2 Help
- injector size for e85? and how to do a double pump setup?
- Dual Walbro 800hp Fuel System Question for a GT40r
- FP Evo Green HP 18psi Preload
- Sticking clutch pedal..
- I think this would be a sweet intake setup......
- exedy lockout help, already searched...
- Need QuicK answer...
- slipping clutch
- FP Turbo Install kit
- Transmission issue?
- Reverse popping out of gear.
- Fastest Spooling Turbo??
- New Turbo Help
- Exedy Tech Support?
- New turbo purchased...Need help on setup
- Turbo upgrade - need help pls guys
- smoke out of the exhaust?
- Ding Dong the clutch is dead!!
- new turbo
- Please help!! TBE install as we speak!!
- Vibration in Gas Pedal, Rough Clutch
- E-bay intercooler kit! what do you think about that?
- Estimated Power?
- What exactly is P0401
- Ok. I'm stumped. Ignition help needed please
- FP White Rabbit or EVO IX Turbo
- were do I get replacment parts for a exedy twin disc
- to those using exedy twin disc HD
- Anybody do ARP rod bolt "Upgrade" stage 5 Buschur
- AEM Tru-Boost Install Instructions
- evo 8 10.5 vs evo 9 turbo
- Turbo XS Downpipe with aftermarket O2 housing
- Max power on GT4294R?
- How much boost??
- detonation hitting the rev limiter?
- ebay intercooler
- 5th/6th Gear Syncro or Clutch Adjustment?
- Quietest Evo Exhaust ????? WithOut Loosin Power
- Oil leak from dead center of car.
- blwon turbo....removing oil from intercooler?
- Front O2 sensor
- 30R dyno results
- Clutch is slipping, got a couple questions about the replacement.
- Question.
- low boost help
- need service manual ASAP!
- Buschur Lightweight Center Member Installed!!!
- Turbo Upgrade Questions
- Anybody have info on the evored?
- Car runs bad after cams
- EBC Boost solenoid question
- Issues
- Missfire, please help
- Expertise help need please
- HKS BOV & ETS UICP flange match-up
- backfire while spooling
- Clutch "whispering"
- FP HTA 67 - aka HTA 37R - anyone know anything
- Better then 272 cams? need help
- MAFT pro OR AEM ems to run METH
- Which Turbo spools faster ??
- Which Turbo will spool faster ...
- Looking For A Specific Thread...help Please
- ss Braided line setups (need info)
- Help deciding on an intake/filter combo
- Ebay o2 housing
- How much boost
- Wastegate adjustment?
- Power Steering Fluid???
- stock turbo seems laggy
- 14 psi stock?
- turbo oil system
- Aluminum VS Carbonfiber Driveshaft
- quick ?
- what flange
- Zeitronix will not log anything!
- Ebay Radiators anyone used one ??????
- Cold Side Intercooler Piping idea to shorten it up a lot !!
- pistons and rods
- Scatter Shield
- Boost Creep or not?
- how much boost on stock headgaskets and bolts?
- US Evo9 turbo vs UK evo9,(EVO400)turbo and there green????????????/
- removing trans ?'s
- Balance Shaft Delete
- Possible Major Problem Insight Welcome
- 8.5:1 vs 9.0:1 Pistons differences
- Misfire under load
- no boost! help!
- FP Green and Me....the 1,000,001 thread...
- Any difference between 05 and 06 rear differential?
- HKS3037S vs FPGT35R ???
- Fuel Pump Resistor?
- Forge Adjustable Wastegate Actuator
- Performance ?'s advice/suggestions please
- Improving knock resistance?
- ECU memory retention question
- Video of COBB AccessPORT EVO 8/9 install
- help: loud huming noise
- FP Green
- ARP bolts on Eagle rods
- What to do next???
- Extreme Turbo Systems
- Air Duct Plug??
- timing belt???
- Need FMIC selection advice
- 6 spd best place to mount a temp probe
- Stealthy Place to Mount an EVC Stepper Motor
- Ignition system problem. NO SPARK=NO START
- fuel filter? Where is it.
- Rear drive shaft removal
- Evo 9 head bolts and head gasket on evo 8
- new car hole in my intake manifold help!!!
- FP White Rabbit turbo
- Biggest Turbo to Purchase?
- Water temp ques.
- Poor gas mileage
- Engine wiring harness. 2005 VIII RS.
- Boosting to High?
- buschur twin walbros pump
- Car surging @ 4K RPMS Bad MAF????
- Mynes Performance Top Mount TS 35R/40R Kit
- HELP! running spacer/different offset can break diff!!???
- Evo Viii Pistons On A 2g 4g63, will it fit?
- couple P0134 code questions
- Fuel pump questions...
- turbo xs
- Evo 8 Turbos
- How much does the 3-Speed Scarrter shield weigh?
- Limiting factor in setting boost?
- Strange noises in rain? and gas mileage after Walbro 255
- HKS GD Max Clutch
- inj sizes for fp green
- Upgraded OEM Turbo
- Install ARP studs without head removal?
- some one direct me to evo performance..
- Clutch for 35R setup
- Anyone running a T3 37R (T3 67mm)?
- Couple driveability concerns, maybe time to re-work things
- Boost Pill or Boost Controller?
- Mad boost leak and it's still stock
- EVO9 Turbo or Cams next?
- Is this a evo green turbo?
- Is there anything else???
- Exedy Twin Rebuild where?
- Another FPgreen Tuned by The Shop
- need help
- just switched from hfc to testpipe
- Drivetrain fluids
- Basic 8 and 9 question.
- 426whp/445wtq on stock IX turbo
- Full Race Manifold on Evogreen IX - Yes or No?
- Problem with Timing belt
- MR Tranny Help
- Looking for a: FP Green
- COBB turbo back sound clip and dyno plot
- Apexi AVC-R vs. any MBC
- hollowed out catalytic converter
- More Power On My Evo 9 MR w/ Stock Turbo and 91 Octane
- Quick Camshaft Install Questions
- Hypothetically, if i slipped a tooth on my crank pulley...
- vibration problem
- death whine? or tranny gone bad? help.
- Quick power question.
- Stock Evo 9 throttle size??
- Tilton Twin Disk Question...
- ix turbo install w/ out tune
- ETS Turbo Kit never look so SEXY!
- Engine cooling for track use
- cam crank codes
- MAF cleaning
- Fitment of the ARC Ti IC Piping?
- Why wont Comp. read Innovative Wideband ?
- Trouble with Possibly bov please help figure out!
- Results From My HTA35R Turbo Kit From Buschur Racing!!
- Cost of Methanol rising fast
- Exedy Twinplate HD for $1150????
- Best and Safest Alky Kit?
- Tranny lock out, hard shifting
- Goodridge or Russell
- Finding water or gasoline mixing with oil in my catch cans. Need Advice
- Help with codes P0456 and P0401
- Oil squirters
- Largest cam on a stock ECU?
- Which turbo should I choose?
- HKS SSQV+ Condom...
- IX plugs?
- Anyone ever tried Brian Crower 272 cams?
- clutch replacement
- COBB Exhaust and Dyno Plot Video is here
- which dealer
- best turbo
- HKS ti-Carbon inner or outer diameter question
- Engine trouble
- misfire new spark plugs
- New E9 - Oil in Coolant (not Redline WW...)
- 50trim + 2.3L Dyno Numbers
- Fuel Injectors?
- Installed My Engine Damper
- Cylinder 3 over loaded with fuel - coming out exhaust unburned
- are these logs correct? It's gonna blow!
- What's the shelf life of Diaqueen gear oil?
- flange
- Clutch question
- header
- Post dyno charts on GT40R or GT42R.
- Stock Evo Oil filters...
- cant boost found the problem,type-s diaphragm torn
- lower i c pipe
- Clutch problem help!
- p0335 and p0340 help
- Tranny reinstall help: cant get up into bay
- Turbo Decision...3071r
- I think a valve is ticking.
- Transfercase Oil
- Cam question
- Can u use a Autometer A/R gauge for a Innovative Wide Band LC-1 ?
- New clutch installed now weird noise! HELP
- Please help with engine noise...
- Apexi Plug Wires
- Custom 35R? why not...
- OS Giken Twin Plate clutch
- 6 speed Issue
- Clutch line
- What exactly is a short block?
- What would white smoke mean pertaining to Air Fuel Ratio ?
- Aeromotive FPR
- What did I do wrong?
- boost taper..
- tire size & dyno numbers
