- Is it time to upgrade my stock IX injectors and spark plugs?
- magnacor wires question?
- Loosing boost through DV(stocker and Forge)...
- Profec B Noise????
- bov ???'s
- Spark Plugs For IX
- FMIC Thread request
- Walbro Importance?!!
- HKS Super Hybrid reviews??
- Help! Hiccupping problems :(
- CEL Light : EGR Insufficent air
- anyone know what about a GT61HP turbo?
- A chunk of my oil bracket fell off while driving. WTF?
- EVO 9 20G-LT + GSC S1 cams dyno!
- idle fluctuations after cam install?
- RRE GT3076R Turbo Kit Review
- Clutch and flywheel???
- EVO IX Cosworth Cam Dyno Results
- JUN-Revolver-Cosworth Cams?
- what do you think of the Turbo XS Short Ram Intake?
- GT37 76MM 52 TRIM 750HP. Is it direct bolt on?????
- Finally!! Full Blown Dual Pump with stock lines..
- 20G-9-5 to 20G-LT
- Forge FMDVEVO15 Diverter Valve on Evo 8????
- weird rain issue anyone have this happen?
- Dynoed 100 octane!!! ### inside...
- test pipe question(helix)
- i broke my evo!!
- Wow Look what i found. HKS LA CLUTCH (single plate)
- trouble with mbc
- bad idea to mix tranny fluid?
- Help Me Decide....on Exhaust setup!
- carbonetics carbon twin plate failure + pics
- Check out my Dyno results
- Gear grind only in 3rd
- Crushed MR BOV
- gsc280 cams or cossworth 272 cams
- vendors??? oil feed line from filter housing??
- Any Penzoil synch 2 BG 1 synch or BG 1 sync 2 Penzoil sync users?
- My EVO IX dyno #
- What your EVO needs for a fuel system, facts.
- ATP/Aftermarket Turbo Kit Boost Line Hook-up w/ Stock Boost Solenoid + MBC
- clutch probs, install new
- Anyone running SS oil cooler lines?
- for those running 35R with stock block and ecu
- RS Diff?
- evo 5 cam angle sensor orentation
- Buschur 20G-LT/FP Evo Green Arrived Today!
- drivetrain damage..
- Stock oil pressure?
- help with misfire~~~!!!
- Finally got to dyno my IX !
- Another Alcohol backfire!
- Fixed Profec B Spec Ii...
- tranny, grinding a lil.
- Any Evo's running Zoom clutch?
- HKS sequential Tranny
- Upgraded Ignition Coils
- different turbos?
- Ceramic turbines?
- OBDII pin description
- How To Tell???
- Came to the conclusion tonight....
- what all do i need for built motor?
- evo 8 tsb's
- Where can i find a dealer that sells GSC S1 cams for my IX?
- Big Boost
- Service engine soon..HELP
- Which intake manifold for road racing
- you think i can get around 300 whp with these mods?
- Quick time performance Evo downpipe
- Greddy TI - Decibel ratings?
- New Clutch
- Stock Fuel Pump Specs?!?!
- 20gLT/50 trims/gt35/??
- Which Fluid is better??? *PICs*
- Fuel Lines?
- Evo Tire / Gear / RPM / Speed Calculator
- Evo Ix Ecu Pins!!
- 2.4 Evo?
- 20G LT, 1st. day review.
- o2 Housing causing fuel cut off?
- What oil do you run??
- High Idle
- Fuel Pressure at Idle W/ Walbro
- turbo install advice
- Tune and Boost
- p0300 code on 03 evo
- treperformance 255 fuel pump
- GSC S1's soon to be installed
- Clutch options
- evo 9 stock ecu can handle up to 500whp?
- stock headstuds - high boost
- dyno graph with STOCK downpipe
- New Skunk2 Composite Intake Manifold
- results from tuning my IX!
- Hard to go into gear?
- BLE Solid Timing Belt Tensioner
- the drivability sucks with ac on
- Psi/kg
- Advice welders
- Proper use of EGT meter data
- Broken boost sensor: MBC = Quick fix?
- TREperformance fuel pump
- what should i get
- Cusco Hyper-Sinlge Clutch: Where to get rebuilt?
- 6Speed Stock rev limit question?
- Nitrous, Boost Leak?
- 2.5inch decat?
- Something New
- Stock vs TBE + MBC + EcuFlash
- Need Help On Bov!!!! Please
- Solid Lifters Or Shiems?
- Gears problem
- clutch questions
- open dumptube or recirculate into down pipe?
- large turbos louder
- Tilton Full Cerametallic Question
- Anyone using an eagle 94mm crank in a 2.2L stroker
- ATP Turbo Kit Intake Solutions
- What do you guys think??
- oil catch can?
- Code P0420
- Fynetune Gt37r Kit 695 Awhp
- Intercooler:
- Stock airbox cover removal on a IX
- Exhaust
- CEL came on tonite...
- Evolution IX Turbo VS. Evolution VIII 10.5 Turbo
- How much - Redline Water Wetter
- Stock BOV outside the intake?
- South Bend Clutches??
- 05 EVO 8 Turbo Kits
- To MuCh BoOsT!!
- Boost leak/Boost Controller issue?
- 20/80
- Exhaust clamps, Buschur(?) TBE
- Let Mitsu Replace Synchros OR ask for new Tranny?
- Various Intercooler Weights
- Buschur Evol 9 LICP installed
- misfire code need help
- New type K&N airfilter placed
- Oil leak at 300 miles...
- Hydraulic humming from rear of Evo
- SRT 4 Guys are Chasing us....
- danger to overfilled transmission and t-case?
- Exhaust again
- questions about the stock rs/mr gauge set
- 10.5 pound fly wheel
- Afr Question
- Boost drop...
- what kind of oil and oil filter do you guys use?
- Exedy Stage 2 four puck clutch - opinions
- Is This a Record?
- Cosworth Cams + 2.3 Stroker Dyno Graph
- Opinions on mods for $1100
- Anyone running a Garrett GT3071R
- TT cams on IX?
- Helix 3" Turboback Exhaust Review w/ pics
- Brian Crower Cams
- Case Study # 382 - AVCR EBC on a IX - rpm dependant boost adjustment pays off
- Mitsubishi PN# for a timing belt change
- P0171 Code
- Some spark plug questions
- Heat wrapping the cross beam by downpipe
- Would this turbo fit on my car? Any input on it? Thanks.
- what you guys think !! Evo VII
- Drive Belt Replacement
- HKS carbon/ti res delete.... Worth while?
- Alky Nozzle Size?
- Power steering fluid in differntial
- 15.5 from Mitsu Japan!!
- SLS Turbo Manifold/Turbo Kits
- cat converter for mitsu?
- Whats the oil consumption like on your stroker????
- Standalone or Ecu flash?????
- !!!why is my greddy rs bov keeps fluttering
- Redline shockproof Heavy in Tranny
- Snow Alchy Kit is decent on Evo IX Stage I - dyno sheet inside
- Any stock clutches over 80K miles?
- APEXi PS Revolution Exhaust--Anybody have it?
- Which MBC install method did you use?
- rear motor mount
- what size silicone coupler do i need for the stock throttle body
- Drop the subframe for clutch install?
- 700 miles...Needing new Synchros
- ACT carbon multi disc clutch.....
- How to fill a transfer case v2.1
- Meth injection a band-aid?
- XS power lower ic pipe fitment?
- Redline MT90 and MTL blend
- Would you take a free XS Power intercooler?
- Ahh!!! I cannot decide whether to go with GSC S1 or Cosworth Cams for my IX!
- What pistons and Rods?
- Low whp ?
- Evo 5 with 20g?
- 3076 On a IX ??
- no oil
- Rattling, Chattering, drivetrain noise w/ organic clutch. Why?
- 02 cel fix rubbing
- Help, A/C problem.
- Help!! Boost cut?, High limit?, or Spark gap?
- Monster Sport intercooler Piping kit
- Tranny, T-case, or What???!!
- Which intake???
- Limited Slip Differential
- Why Don't People Use The Hks Ssqv???
- I need your opinion...
- Stock turbo 10.5 hotside
- RNR turbo kits?
- Stock rubber intake hose Vs. Hard pipe?
- maybe boost leak
- clutch ?
- RnR Racing o2 Housing vs. eBay o2 Housing
- HR:evo 8 cam install 7 jan 07SUFFOLK,va experience needed
- What should I do?
- Injen Intake=What filter?
- greddy egt guage install
- FQ-400 1/4 mile question
- Help ! with rear axle removal
- PCV Rotation ??
- Max boost Apexi RX6 turbo kit
- Suggestion on installing Wideband!
- Who is running the Greddy or Jic Ti exhaust?
- !!The Best BOV For evo 9 Recommend!!
- How much boost on stock block evo..with stock turbo..??
- VIII & IX turbo mani the same??
- CC EVO 9 Carbon Fiber Cam Gear Cover
- Buschur Air intake Vs. Intake Kit, which one?
- problem with RSR Ex-mag
- Best Turbo for AutoCross?
- Opinions/suggestions needed(Low WHP problem)
- problem help please!!!
- Gearbox removal.
- Shifter Bushings...metal or poly?
- Aftermarket Oil Pan
- Not good. Ticking on start up.
- P0300
- Clutch and Restrictor Removal?
- Mr trans mission hard to get in gear in winter
- Stuck at 12 psi...
- How about a 25G (Greddy T67) and a 2.3L/280's combo?
- up the boost on my tune?
- 02 sensor help
- o2 sensor question
- Ultimate Racing FP Adaptor Threading
- Just Installed New Manifold...
- Evo 8mr
- Breaking in an ACT clutch
