- Oil Retrun Line
- Wont go past 15 pounds of boost?!
- My Buschur 2.3 stroker with hta 86
- short clutch release rod
- Evo 9 head to Evo 8 block
- Re-located ACD pump - problems with bleeding
- EPM O2 dump gasket
- need injectors!
- My car stalls when idling now..
- Non TC Related Deathwhine?
- MBC Installed but still low boost
- Stock Exhaust Manifold Flange
- intercooler piping Q
- Strokers and gearing
- Oil pressure light flickers on at idle.
- perrin Bov.
- Injector help
- weird noise from the engine bay at idle.Help
- Best T3 Turbo Manifold
- how much boost taper is normal?
- anybody feedback on garret gt 2835 turbo
- help... code after code
- what the eff. i dont know what's wrong
- what spark plugs for e85 on Evo9?
- Setup Questions
- HELP anti lock break flashing WTF!!!
- buschur down pipe and o2 housing gasket
- Timeing belt ate me V-belt!!! :(
- Who is running GSC S2's or Kelford 272's on stock springs?
- what exhaust is this? plz help
- AMS 2.0 build/ FP beehive, kelford 272 problem
- need hep !!
- finally drivetrain problem! 1st gear and reverse
- Transmission Broke
- Bypass stock fuel solenoid
- Help diagnose vibrating sound problem..videos inside.
- intercooler hose popped out three times
- Cel fix
- oil catch tank help
- 23 psi okay for evo 9 with a few mods?
- Which is better to install in a built 2.0 gt35 or 850r turbo?
- AEM Evo 8 Intake???
- car locks in turns
- clutch wedge collar!!
- Twin Scroll Comparison...Before/After
- Clutch acted weird
- Invidia O2 Housing help - need a flange for custom downpipe
- Evo 9 turbo outlet replacement
- Wiring diagram
- Rough Idle
- newbie:Questions on EVO MR boost
- Mivec IX valve cover on VIII engine?
- Clutch Slips When Tightening Crank Bolt
- Evo 9 2.3L Stroker into Evo 8- possible problems?
- AWD Motorsports ( Most H8D ) Black GSR is BACK!!!!!
- vibration after installing cams
- ECU Pin 43 - Clutch Position Switch
- will my turbo reach 120K miles or is it dead?
- 8/9 water cooling route
- Quick question... Is the AC and PS of Evo 8 and Evo 9 the same?
- Evo VIII Entire Drivetrain Mounts, Bushings
- Evo Billet 70mm Bolt on throttle Bodies
- EVO IX Down pipe size
- Best Boost Controller For IX
- funny boost problem?
- E85 vs C16
- Coolant overflow problem!
- Time Attack + DD Engine Build Help!
- Is this normal?
- How much $$$ could I get for this???
- Cutting out in boost
- autocross turbo?
- is this a good route?
- Which Turbo would you choose
- Lighter Driveshaft
- Wastegate Question.
- Flutter sound with HKS SSQV BOV. HELP!!!!
- is there someone who make this for the evo 9?
- is it ok to use this fluid for my tranny?
- Ingalls torque damper!!
- trouble installing the transfer case
- help!!! should i do 15w50 instead of 10w30 oil with this mods
- dual wastegates?
- Blox Front Motor Mount Install
- which cams would my Green like better?
- Lost 100wtq?
- Cam Help - What to get - Evo 9 MIVEC
- EVO IX COIL on EVO8?
- Ac trouble Car keeps stalling with it on!!
- Forced Performance's Newest Turbo Oil Feed Line
- Does my motor sound odd ?
- Twin disc HELP!!
- Weid Shifting Problem... very stiff in neutral but shifts fine
- crushing the dv/bypass valve
- best spark plug to get for evo 8?
- tranny oil leak
- FP WHITE RABBIT turbo info??
- oil leaks
- doubt on a simple mechanical question
- Would you say this clutch plate is only 10% worn?
- Twin feed line kit for the EVO8-9, no hacking required.
- Electircal Issue please help
- my custom 35r kit (pics)
- Hone type for "Drop in"
- What would you do????
- what psi to race on t28?
- Intercooler Fitment
- O2 Housing
- Engine Combinations Boost + Static Compression - Discussion
- Strange rattle/grid noise after exedy install help?
- plugs too hot???
- BR 3065 w/Tial wastgate fitment issues
- Growling Sound
- Are you 2.3l guys happy?
- how much for shortblock?
- Over 600awhp... 2.5" or 3" FMIC piping?
- clutch problems
- Clicking Noise from Frontend
- Question.. My evo feels like it's losing power
- better internal for green?
- evo 8 cams evo 6 head....problem?
- What Injectors to run?
- EVO VII-IX 75mm Throttle body from Boomba - bolts to any manifold on the market
- Here are my mods..would you recommend METH???
- when installing arp headstuds
- Help weird issue
- Is Royal Purple worth the $$$
- A question about evo 9 short block and evo 8 short block
- just got Kelford 272 cam's
- Will 06 MR Transfer Case fit my 05 GSR?
- possible throw-out bearing?
- New mods = loud noise in rear?
- Please help, stuck in neutral?
- 16V Charging System?
- Need your input
- Very bad problem?
- Transmission Bell Housing Material?
- IX FP RED FP5R "buit" motor build
- intercooler question
- Power steering problem!! Some one Please tell me how to BLEED power steering pump?
- From VIII to IX turbo, parts that are needed?
- Engine damper help
- Help! Clutch pedal is stuck, will not push in
- Looking for an intercooer, what about this one?
- Bang Noise under Hard Braking?
- Help choose torque damper!!!!!!!!
- Wierd oil light
- please give your best opinion
- Haltech Platinum 1000 P&P
- Anybody heard of TaipanXP exhausts?
- 500-600hp clutch options?
- Engine Rebuild Advice
- Want to decrease engine movement.
- Gt35r Exhaust housing question
- Prepping the block/head for new head gasket
- CompClutch Problems
- Is it ok to port turbine..
- cosworth m3 cams
- zero boost...barely driveable!! help!!!!
- How does this MAF look to you?
- o2 bung installation help
- should i do valve springs with the bbk full and kelford 272
- Finally, new lightweight rotors for the EVO8-9!
- pulled EVAP, question inside on when i fill up.
- peicing a turbo kit, where can i get these little items?
- FPR Solenoid?!!!
- My 03 evo 8 problem
- 3rd gear sounds like gears are chewing each other up when trying to get in.
- A/C Delete serpentine belt
- Is the O2 Housing Cover Necessary?
- engine specs(in depth)
- mitsu crank/ flywheel bolt patterns
- Wastegate Stuck open?
- Sizes of bolts to use for Downpipe to cat
- what the stock boost(Bar) on evo 8?
- Exhaust hangers
- clutch & flywheel?
- MR 6spd Drivers on FP RED
- Final drive for drag racing
- Walbro part #'s
- Stroker and FP Red?
- about ETS intercooler kit!
- 5 Qts. Mobil 1 Synthetic Oil & Filter $20 AR
- lets play: figure out how this exhaust hangs!
- tomei evo ix camshafts
- Oil Cooler Line Leak
- Exedy twin question
- clutch parts help
- Clutch Release Issues. Help/Idea's Needed
- RPM not going down quickly??
- Headgasket question
- Installing Water Pump
- PLEASE HELP. considering burning my evo to the ground
- Flywheel bolts
- Fitting size for stock fuel line to fuel rail?
- Transfer Case Leaking: Passenger's Side
- P0401 code with weird noise
- effects on to big exhaust and wastegates
- Greddy Type S
- Egt???
- need help asap with removing the end of the cv joint
- transfer leak pics
- hks cams question
- spark plug problem? or worse?...evo 8 GA
- clevite thrust bearing dont fit
- Evo VIII slight hesitation at WOT?
- Can't remove transmission
- Oil Leak
- Boost Tapering Too Much
- Guys Help! Car started shaking and pulling right
- Acd
- Opinions on Blow-Thru MAF setups?
- HKS Camshaft question
- Want to remove A/C?
- Transmission and Transfer Case has been at Shep's for 4 weeks and they are saying tis
- EVO VII-IX 75mm throttle body adaptor kits to Mustang 4.6 manifolds now available
- Installed clutch, cannot rev high.
- Issue with boost.....
- highest safe psi
- Messed UP DRIVABILITY...
- Any difference in perf between the FP red (64mm inlet) and the newRed (80 mm)?
- Power Steering Pump Noise
- Best bang for the buck mod?
- What cams do you guys prefer? Please help.
- Hks/kelford 272 cams
- best cams for fp red
- lost boost
- Tune needed?
- BBK Advice
- Can the stock clutch handle a couple of 400whp+ dyno pulls?
- Help with my Sparktech ignition!
- Cam lift versus RPM question
- some type of problem..please help.
- Ticking noise on cold startup
- Who has the best price on the PTE Billet 67mm?
- bottom end rebuild kits
- 2.4 storked to 2.7?
- Does the Dejon blow-thru UICP work w/AMS intercooler pipe kit?
- Fuel Pressure--URGENT
- Replacing the Front O2 sensor
- clutch purchasing advice
- HTA3586 vs 6262 turbo
- misfire
- o2 housings!
- Coolant Leaking Out back of Block
- the most hardcore evo i've ever seen...
- Spark plug Gap?
- Very odd coolant leak.
- new pistons old rings - where did my oil go??
- dumb question
