- ATP 3071 whp
- Installed aftermarket parts and boost went down?
- Is it necessary to have the metal honeycomb inside the maf
- My Project (56k, make a sammich)
- Boost questions?
- NEED HELP!! fuel pump...
- Wastegate for 50 trim, need opinion
- Engine
- Clutch That Can Handle 600whp
- Does Intercooler effect AFR?
- Next Mod?
- How much whp can I get with my 3071
- 10+ hours of searching im now more confused (Best Clutch)
- Evo IX Compressor on Evo VIII Turbo???
- Are all 4G63 the same??
- 20G-9 5blade vs 6 blade vs STock JDM EVO IX MAGNESIUM TURBO
- Please Help, Walbro fuel pump Noise / BOV Flutter (Sputter) at low boost
- Evo randomly shutting off while driving
- Next Upgrade?
- homemade manifold?
- gapping
- forget the pop sound wtf happend thread
- Megan Racing Manifold Experience
- knock link controller?
- Engine power support;
- White smoke- PCV related?
- Read my spark plugs
- Who is running the AMS 50R turbo kit?
- Sputtering misfire problem? plugs?
- Why am I hearing my BOV (dumb question?!)
- New mod to my car 93oct 385hp
- Vishnu vs. Buschur April 25th??!!
- MBC all they way up and only 15lbs boost
- gt35r
- 2.0 vs 2.3 stoker
- New toys!!!!!
- what IF you skipped break in?
- MBC continued with pics
- Anybody near Ralegih NC done a clutch install??
- Car Wont Turn Over
- Car needed for fitment in Akron, OH
- DC manifold and tapping EGT sensor
- HELP! Super laggy stock turbo, 22psi @ 3800rpm
- Throttle seems sticky
- Any reviews or oponions of clutchnet clutches?
- dyno/tuned
- Driving my 900 WHP Evo 8 - Round 2
- checking spark on an evo
- Tranny help
- Is this engine knock? (video)
- Valves
- Northern Guys, AFR's Changing In Winter?
- injector upgrade necessary with EVO 20G-9 STG 2??
- Exedy Twin disk SD or HD?
- 20g-9 and Forge actuator.
- Evo 9 Oil Filter
- -PICS- I Modified my HKS RS intake again, Amazing results inside.
- Invidia G200
- Anyone running cam gears with 264/272 combo?
- Exedy Tripple Ceramic Clutch
- DOG BOX and AMS DRIVESHAFT
- I Want My Car Back
- O2 sensor
- This just in! (TRE Upgrades round 2)
- Why did my CV joint brake?
- My custom Upper IC pipe and Small Battery kit **PICS**
- Will I get more torque with 93+meth instead of 100 octane
- MBC w/o Reflash
- do you need a flash for a test pipe?
- boost creep on my 37r
- Instructions for Power Entreprises MBC
- 3" catback vs 2.75" catback?
- tbe = loss in power
- VE / BSFC / pressure loss
- Shep Stage1 T.C.
- anyone using a centerforce DF clutch in theyre evo
- black smoke after shifting at redline
- Just got Flashed
- Godspeed Intercooler... how good is it??
- 2800 miles on new IX.... clutch toast + warped flywheel?
- UR testpipe
- Help with removing front half shafts
- intake pipes that fit stock air box???
- Popped my motor..... maybe
- Injector harness/clip went bad
- Lifters ticking?
- Forced Performance Petition
- Please help with clutch install!!!!!
- Does an FMIC lean out the AFR?
- driving on a slipping clutch
- Ultimate Racing GT35R
- question about tial wastegate
- new clutch issue...
- Buschur 20G-9 vs HKS 2835R
- That's not good...
- Think She'll be fine for now?
- the biggest turbo to fit factory mani.
- I am newbie, but i really need help
- boost settings and weather
- intercooler piping
- ok here are some pics of MBC
- Something interesting in O2 housing
- Vishnu vs Buschur and Al.......I LOSE!!!
- Quest for 400whp
- testpipe?
- Jun 2.2 Stroker motor
- New Toys Showed Up!!!! **pics**
- firing order
- ACT HD Extreme plate - Act Flywheel
- Successes of EVO 8 @ Rally NY
- Getting locked out from 1st to 2nd gear
- Clutch Wouldn't grab on launch
- Where To Buy Nisei Lower Intercooler Pipe?
- GT3076R-12 vs -13
- Pink Gasket type liquid on Forge RS.
- Coming to the darkside..WRX-EVO..????
- 475hp 419 ft lbs @ 26psi GT3076R ***VIDEO***
- Flowmasters on a evo, anyone
- Possible exhaust leak?
- Just Another Yellow evo Part II
- Fuel pump kit...
- Injen Intake Question
- Hi definition compressor maps?
- Boost gauge install questions
- stock boost
- 2.75inch or 3inch DOWNPIPE
- ECUFlash for EVO, Subaru, 3rd Gen Eclipse
- Blitz DD BOV flange?
- Safe boost increase w/ race gas?
- SBR GT3076R turbo kit
- Problem starting the car... please help me out!
- Anyone running GT35R w/Koyo radiator?what fan are u using?
- 31 psi oil pressure???
- Is 0 psi possible?
- Post Your Dynojet Run Files
- 4g64 2.1L Build Up
- BG SynchroShift ok to use in 06 EVO IX MR Tranny?
- Best Turbo for 93 + alky
- HUUUUUUGE exhaust leak or much worse than that?? VIDEO INSIDE
- Stay stock plugs or go 1 or 2 step colder?
- Fastest spooling pump gas (big) turbo?
- electrical smell please help!!
- Bad idea to add exhaust after a custom flash?
- pop sound wtf happend
- Harmonic Balancers
- Question about Turbochargers.com
- transmission =[
- Tranny wont come out
- Engine stutters when I open the throttle 100%
- fuel pump...
- need help fast with fron o2 thats broken
- Will a 2.3 stroker pass emmisions?
- Possible ignition problem...help
- stock bumper lip...
- For those with an aftermarket intake, Easy mod, This helps alot!!
- Maximum AWHP limits of 2.3L, GT35R, HKS 280's, 93+Meth??
- Oil Change
- clutch stats
- Winpep 7.1.3 Dynojet Charts
- IX MR clutch seems diffrent now....
- New Dyno #
- Evo IX went to the dyno
- Good choice? BB 50 Trim, T3/T4, E cover, .86 A/R, 4-bolt....
- To build or not to build a custom turbo kit?
- Will a Forge WGA reduce Boost Taper?
- Stumped by screeching noise under load
- 03 w/27k miles grinding in 5th
- CBRD PROJECT MR exedy twin disk and new lines etc... pics
- Cosworth = Cometic (head gasket)
- CNC Machine work question
- what else might i need?
- Dyno #s on Tomei O2, DP, and Manifold!!
- safe to run?
- where to get a anti surge cover for my 35r.
- Coolant temperature sensor swap...
- ACD in 03 Evo???
- Water Injection Kit
- i did a pressure test....
- How to install a Greddy Type-S By Pass Valve
- installed megan cat-delete and cat-back
- Why should anyone upgrade turbos?
- too much stagger for ACD
- Looking to get flashed...but not tuned
- 2nd Dyno day at BR
- Fuel Cut at 18psi?!?
- buddy club pro spec exhaust!!
- Spoolup question?
- Exedy Twin Disk HD Install Question
- Technical question: Turbo exhaust iris
- Licp question??
- Wastegate Problems
- EVO VIII stock fuel pressure
- SARD HF cat installed
- Which aftermarket manifold with T3/T4 flange to choose?
- GT30r ETs?? MPH?? WHP?? please
- Ported Turbo Manifold
- just removing my heat sheild
- Turbo experts please look
- help please evo boosting only 11-12 lbs
- Evo 8 Stage IV IX20G vs. Evo IX Stage I = both are 11.6 ?
- Does anyone have....??
- Clutch Install...
- Minor boost issue.
- New Manifold, New Gaskets??
- Slowboy racing intercooler fitment?
- Forge MBC problem.....
- 20g-9+2.3l stroker+Nitrous?
- Piston specs
- Will they hold?
- boost issue's with the 35R
- All you ever wanted to know about Evo gearing and gear speeds
- exhaust leak
- Boost question
- Evo 9 turbo....or.....TME?
- Cam timing theory?
- What size injectors for GT35R?
- Sunoco alky?
- 10.5 vs. tme w/10.5 help
- Exedy D-Core
- Sudden Intake Noise Decrease
- Why change pistons?
- boost help
- 544hp Stock Ecu
- Thermal Research Exhaust, Anyone have one? Input?
- Broken SPEC clutch pics
- I just broke my T/C and Transmission (Lots of pics)
- MBC pics....?
- SAYC In 06 IX Help
- My setup.. Need advice
- Clutch Master Cylinder Help
- Evo IX clutch issues
- Boost drop after fmic install
- Having a boost Problem give me a hand please =(
- Perrin Test Pipe Question
- Same driveshafts Evo VIII as Evo VI?
- Can the BR Bullet be hushed?
- Stroker
- best turbo manifold for the stock turbo
- Gas Poll
- ordered manifold yesterday
- Clutch for 2.3+30R?
- Invidia Downpipe on Ix
- clicking noise till cams warm up??
- Need pics for WG turnbuckle tightening!!!
- So, have you ever seen the center Viscous let go?
- Humming noise while turning the car to the right?
- This Is A Tough One...
- LICP recommendations
- 20g-9 Cams Question?
- Best spark plugs & gapping for 30psi boost+75hp shot nos on 35R
