PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Engine Assembly ?'s
  2. Stroked vs built 2.0
  3. p0134 code new o2 sensor
  4. 2006 GG mr build. 272's red e-85
  5. Turbo Compressor Outlet Pipe Nipple (J Pipe) Question
  6. What is the best GSC S2 Cams setting for Low & Mid End Torque...
  7. Surging problem with FP Black - help please
  8. "Dynapack" opinions on the quality of tune on this type of dyno?
  9. power enterprise head gasket + o-ring?
  10. cam timing evo8
  11. Evo VIII Power Packages??
  12. Check Engine Codes P0456 and P0401
  13. Are eclipse 4g63 blocks same as evos?
  14. For those using or used Full-Race Pro Stock header.......
  15. The highest HP double pumper setup (BR specific on E85)
  16. Cams info
  17. tial wastgate problem
  18. Spun rod bearing getting prepared to build NEED ADVICE
  19. Shep's head leaving HeadGames...
  20. need a math check!
  21. Metal/Metal until oil pressure... Advise
  22. Spark plug install question
  23. Revs hold for split-second while boosting?
  24. Mystery CWP Bolts!
  25. Stock Block Power Threshold and Gear Specific Dyno Pull Numbers
  26. bov question... greddy type-s
  27. Spark plug reading..
  28. Redline Cocktail vs Mitsu Diaqueen MR tranny fluid
  29. AMSOIL Cold weather tick?
  30. Trans Leak
  31. Proof of concept: MBC + 3port BCS Hybrid
  32. Timing belt and engine noises - help me troubleshoot!
  33. APR head and main studs specs? help
  34. .060 over block and stock HG
  35. Need help with oil and water lines for GT35R turbo for my 03 evo 8
  36. Exedy Twin Rebuild
  37. Clutchnet clutch opinion on Evo's?
  38. Possible T-Case whine?
  39. Engine Bearings?
  40. ? Removing OEM fuel rail inlet line - someone throw me a bone? PICS inside!
  41. quick o2 sensor question
  42. Cams
  43. Evo 8 head porting
  44. ALLRIGHT. I read the sticky about bleeding lifters if doing cams It's 50/50. Y or N?
  45. Transmission problem help! Somethings locking on wide turn
  46. Wideband Dataloggimg Issue
  47. Oil Temperature and sender placement
  48. Alternator Charge Issue HELP!!!!!
  49. Exedy Twin -Lockout gears
  50. Spark plug cover bolts
  51. Need some help
  52. AEM SRI or K&N Drop In
  53. Bent shifter linkage cables, oh no!!
  54. 2.4 build motor. is it a good buy?
  55. E5/6 Fuel Pressure Regulator Sensor - Hoses
  56. FP Flow Advancement Port Cover for BBK
  57. Supertech spring retainer kit vs gsc spring retainer kit??
  58. GTII 7460R vs BBK Full photo shoot
  59. Can I run E85 on 93oct Tune?
  60. Rough idle occurs after warm up
  61. fuel line routing
  62. Please Help - GSC S2 Cams Setting
  63. Balance shaft removal
  64. Reflective Sound Cancellation
  65. Forced Performance 3794HTA now to come in Twin Scroll T4!!!!
  66. Buschur licp leaking at turbo?
  67. 28pis too much???
  68. Advice on how to achieve 400++hp and 380lb-ft Torque
  69. precision 600hp intercooler?
  70. evo 9 parts for sale in NY/LI
  71. 2.3 cranking psi?
  72. Finally at 221,000 Miles I change my ISC
  73. Questions/OOpinions/Ideas Catch can
  74. Injen Intercooler Pipe w Dry Filter and where to Tune +/-
  75. stock intake manifold
  76. Issue with MAP 02 Dump and A/C hose ????
  77. second opinion. housing damage
  78. sputter @ 1/4 tank w/ Full Blown DP issues??
  79. building my evo 4 transfer case
  80. Knock issues
  81. outof the game a while turbo question
  82. Bad lifter? Something else?
  83. FP black
  84. Car wont start ive tried everything
  85. Bad Bish's 8 second attempt over, the story and list of parts for sale
  86. FP Black on Stock 8 motor?
  87. new Qm twin..car not moving!?
  88. JSCautomation Catch Can
  89. Driveshaft for Rallycross
  90. Need Help
  91. 6765bb vs Fp's version?
  92. Anyone heard of S90 racing Throttle Bodies?
  93. Possible spun rod bearing. Any thoughts?
  94. FP-Red failure
  95. Evo Head Choke Point, Cutaway?
  96. ATTN: FP Red & Black Users - What You Need to Know About Oil
  97. How much Torque & Whp a Stock OEM Mit Clutch can take???
  98. Injec. Help
  99. 5th gear on 2006 SE
  100. Forge Diverter Valve - Part# FMCL007P - FEEDBACK NEEDED
  101. Motor mounts
  102. Stumped on idle issue, need suggestions...
  103. What is the Estimated Torque & WHP for my Set-up???
  104. RPM Spikes WOT
  105. Evo 6 Streering Rack Oil???
  106. Clicking/Ticking sound from TC's tailside
  107. evo 9 greddy easy cams
  108. Bad Trans.
  109. Quartermaster Review
  110. evo ix max boost 11 psi ?? help
  111. Trans?clutch?
  112. Something wrong with my tranny?
  113. Knock Sensor Clip
  114. Converting T-Case to FWD
  115. help with broken vacuum line...
  116. CEL flashs under boost after new spark plugs
  117. MAF removal?
  118. turbo housing thread specifications
  119. Help: Car won't boost past 12 PSI - Problem with WGA?
  120. up for a 500 whp quick spooling turbo
  121. Bad tranny or Tob?? :|
  122. Fic 1450 cc injector idle on s.d
  123. evo9 eagle stroker 2.3
  124. What is causing this camel hump (dyno)?
  125. Vac Lines.
  126. Help
  127. Spark plug or coil pack issue
  128. Breaking in a new built engine
  129. shutter from hard left turns
  130. 2.3L Stroker with a gt35r
  131. How much whp can a stock Evo7 head can flow?
  132. Evo8 winner?
  133. Fidanza Clutch question....
  134. Megan o2 Housing
  135. Bad Bish back to try and reach the 8's.
  136. Heeeelp plz
  137. FP Black on evo 8?
  138. dumb oil pressure question
  139. New HKS 274/278 Retainers
  140. Intake manifolds
  141. porting stock manifold is pointless
  142. Exedy snap ring wavy rings question.
  143. High Flow Cat 300 cell vs Straight pipe
  144. built motor + cold temperatures?
  145. what competition clutch stage should i get?
  146. Cast Stainless steel O2. possible?
  147. help with my idol.
  148. Does my engine sounded normal after rebuilt & with gsc s2 cams?
  149. Question about clutches
  150. Wtb: Review on TiAL Sport QR Blow Off Valve
  151. Car won't fire
  152. Should I switch to S3's?
  153. A Few Questions....
  154. shifting problems
  155. EGR question
  156. Question about FP Red with or w/o 02 dump
  157. Clutch Question : 6puck vs Exedy twin
  158. cam installation gone bad?
  159. HTA Green - the best IMHO
  160. Aftermarket O2 tested? i did search
  161. what intake will work with hks uicp?
  162. Anyone running the Billet 6765 in T4 twinscroll form?
  163. JMF 3" intercooler piping problem!!
  164. S.d tune and 4inch pipe vs 3 inch pipe
  165. Best Bang For The Buck?
  166. Another 2.4 build thread
  167. Tomei arms m7960
  168. Cosworth 272 cams and FP Red: need advice on other components to go with these cams!
  169. Does the front balance shaft have a keyway to orient the timing belt sprocket? PICS.
  170. Walbro 255HP "High Pressure" too much for stock FPR?
  171. Does the front balance shaft have a keyway to orient the timing belt sprocket?
  172. High Idle after TB Seals
  173. Opinions on t3 .63 to .82
  174. Synapse Engineering releases the Synchronic DV for Evolution
  175. exedy clutch disc question
  176. Hks hi power shoots smoke
  177. First in the World! Evo X Diff Swap into Evo VII
  178. stumped on clutch issue
  179. Boost problem need help think its the WGA
  180. Setting Tru-Boost Duty Cycle
  181. just noticed how short 4B11 rods are
  182. Shepherd Trans - Waiting time?
  183. evo drivetrain transplant
  184. 2.4 L with stock Turbo. injectors?
  185. What a broken 6 speed looks like..
  186. NY: Full Labonte meth kit. PRICED TO SELL!
  187. non hta fp green vs atp 3031r
  188. Odd Clutch Issues
  189. 6 Speed Tranny
  190. Timing belt alignment with oil pump/balancer screwdriver trick. Where should I orient
  191. Shep trans 5th gear grinding!
  192. Evo VIII Build Advice
  193. Milky pink transfer case fluid
  194. Evo NOT getting spark after engine replaced
  195. Most Boost on stock Motor and stock Head Bolts
  196. Bought an Evo IX!!!!
  197. Just saw on Buschur's website: "longrod" STG 3 2.0L vs. standard stage 3 2.0L??
  198. needing reasons why
  199. question on the synapse bov
  200. Necessary to replace valve locks?
  201. GSC vs. Supertech
  202. Car wount start! please helpp
  203. I don't know what is wrong. Low boost and burning oil.
  204. Best street friendly clutch/flywheel (least pedal pressure, most holding power)?
  205. Rod Bearings
  206. mivec swap
  207. idle knock
  208. intercooler pipe
  209. small blue wire?
  210. How to install kaaz rear LSD with ACD ?
  211. Custom Evo 8 Manifold w/ 44mm Wastegate (Stock Frame Turbo)
  212. Would it be stupid to...
  213. Weird problem after oil change
  214. turbo advice
  215. Best turbo kit???
  216. bigger valves
  217. Better downpipe??
  218. high impedance injectors vs low impedance injectors
  219. Evo VIII transfer case leak?
  220. HELP! Another GSC S2 Cams Question
  221. Higher compression on 4G63
  222. About comp turbo!!
  223. Any detrimental effect using these?
  224. 5 speed swap completed now my center console piece wont fit correctly
  225. Dead lifter? (vid inside)
  226. autometer z series boost gauge help
  227. boosting issue? PLEASE help. any idea is helpful
  228. FP Evo Flow Advancement Port Cover
  229. QM 7.25 V-Drive Discs vs PTT Discs
  230. Repair Manual for 6 spd Transmission
  231. TS T4 1.06a/r HTA3586
  232. EVO 9 oil pressure problem
  233. Odd sound when I push in clutch
  234. Forward Facing Turbo vs RAIN
  235. Engine torque damper/motor mounts...?
  236. Clutch problem?
  237. injen licp,and the stock ic coupler problems??????
  238. HELP! I CANT SET MY GSC S2 Cams for my Evo 5!
  239. Seriously what could cause this? (Lifter issue)
  240. Overheating
  241. BC 272 Cam idle
  242. question for the evo guys
  243. Blow off valve 32psi
  244. What are the next steps to obtain 450whp.
  245. Pushing 90000 miles....to late for turbo?
  246. 2.4l 150mm rod VS 2.4l 156mm(LR)
  247. Stock exhaust and big turbo.
  248. cams help for my build
  249. Does this sound right?
  250. double pumper question
