- Wideand and a couple of SMC pics
- No Tune/Road Tune/Dyno Tuned SAFC in the new SCC
- Spark Plug Gap Tool Warning
- Dropping new motor into my EVO (check it out)
- So what conclusions can you draw from this ?
- cracked transfer case?
- cam gears. r they a must
- Short ram, in the way?
- which fluids and why??
- Where to get Wiesco Pistons?
- wastegate acutator
- Cooling system problem
- K&N Filter best deal?
- *o2 housing question*
- TC Case Question
- Check Engine Light code?
- machine shop
- What cars have a 4g64?
- Blue EVO 8 gets retuned, fixed boost leak, better DYNO numbers!!
- cam oil seal...help
- ACD Problem!
- what sensors can be read from OBD-II?
- Small oil leak issue
- buschur race fmic fitment
- Gt35r problem, please help
- What are the following parts for?
- For Dragrace 4g63T or 6g72TT??
- manifold question...there has to be an easier way?
- Help me choose setup!!
- Lookie what the ups guy dropped off
- manifold w/ external flange
- my dreams crushed
- FMIC from ebay
- Buschur Racing's, 661 MD AWD HP.....just getting started
- what best turbo BR20G, GT30R,GT35R?
- FMIC Review
- Better than stock
- I modified my car and it runs great!!
- Evo 8 and 9 FMIC question
- Torque Monster Evo 9 MR!! Dyno plots!!
- Judge the tune, not the messanger....
- Driveability Issues
- needs some clarification
- EVO8 VS EVO9 Turbo compressor cover
- where do you get race gas?
- clutch pricing
- Finally, 20G-9 dyno #'s!
- Revolver Cams + Valvetrain Upgrade Finally Going In
- advanced my HKS 280's, ide now less lumpy???
- Turbine Housing Size?
- front diff? making rubbing noise now?
- bad spark plugs, detonating, knock
- Another 20G-9 MONSTER HP chart...
- Jon at TRE
- 05 owners please read!!
- Is my turbo blown?
- Methanol additive
- Dynojet HP numbers and what they mean......
- Will I feel a lot with a test pipe?
- head gasket replacment....
- 2.3 Buschur comming
- Blown Clutch?
- same boost leak every 1-2 months
- 10.5 HS, EBAY o2, Forge WGA, reviews inside
- BOV smaller than JDM MR BOV?
- Launch control bad for cars with cats?
- Agency Power TI CATBACK EXHAUST
- what mods to do on the evo 9?
- Evo IX SAFC or Flash?
- Lifter, Cams and Retainers (did Search)
- Problem when down shifting?
- greddy spec2 issue anyone know?
- BBTO4R response and boost recovery?
- swapping the hotside on the 50 trim
- Clutch line help
- I Installed my Midpipe yesterday and my engine light is commin on??
- Oil leaking from IX MR
- FQ400 engine oil?
- SMC new alky kit coming soon
- High Boost Actuator?
- Replace Head Gasket when upgrading head studs?
- stock EVO turbo differences
- aem intake on evo 9 mr
- Dynoed my 05 MR today Stock
- hard to shift
- Need some help
- Dealer wont look at my car for a 5th gear grind
- Went past redline...
- Turbo XS intake vs. Apexi A/F readout (no tune)
- BR350 Kit power
- Can someone give me some ideas to get this car started??
- stupid question..
- Clutch let go :(
- Stealthy test pipe with a catalytic converter look
- Where Is The Restrictor Pill
- Failing converters ?
- installed twin plate clutch..cant get it in gear
- Vibration Under 20mph
- I think i Blew my turbo. Please help
- Which Ebay Brand/Seller for O2 Housing
- Vacuum Leak?
- Why does the car keep running after pulling the alternator fuse
- Exedy Twin Plate??
- Any 20G dyno #'s yet?
- Turboxs knocklite where do i install knock sensor?
- How necessary to install forged rods over 350 WHP
- Please enter those with knowledge/expertise
- Some questions after a weekend of maintance on my evo.
- gsc cam marking?
- Bigger than 16g
- Ebay LICP on 2005 Evo?
- Hafe performance manifold??
- what the best my hybrid turbo?
- WTB: all part my 2G engine 500HP
- proper way to drive a twin plate clutch
- 02 Housings
- New exhaust manifold
- Is this supposed to be missing!!??
- Evo 8 to 9
- IX boosting too high?
- high flow cat for the IX? One with a bung...
- Walboro 255 pump problem....I think
- Intercooler water spray hose loose
- 2003 Evo 8 Performance Problems
- HKS Drop In Filter vs. K&N Drop In Filter
- problem with hesitation
- Spark plug help !!
- 2.3l stroker questions
- Off throttle grinding\vibe
- Injector and Fuel pressure information
- What is happening?
- Engine Problem Hoses? Need advice
- 280 exhaust cam on IX
- Boost Only goes to 1 in first and second
- truth about the clutch extender rod???
- What causes turbo coolant line leak?
- Megan DP, Helix TP, and HKS CF TI Exhaust?
- What a difference 30 degrees and a little tuning does....
- Feels like my 05 MR is losing power...Is it me or car?
- Roll Cage Installation
- zex nitrous or not?
- Buschar Cam install
- need info on a t38
- My RNR 50 Trim install!!!
- Fujitsubo dp ?
- Please HELP!! P0131 What to do???
- exedy clutch question
- Forge RS BOV + Alky @ 25psi
- Former DSM guys, please speak up about your BR 20G reliability.
- Guess my HP! Winner receives a pat on the back
- My likes and dislikes of the Buschur Motor mounts.
- Where to install MBC now?
- problem with hesitation help
- Lifter Tap is gone after installing JAM Lifters
- alky pump output psi Q...?
- Greddy Ti Sound Clip
- 345 whp & 331 tq. on Pump Gas
- New results no more E-manage
- aftermarket BOV sticking?
- does Blitz downpipe fit acd equip. Evos? (like the IX MR)
- MBC or WG problem
- check this out
- Fidanza Cam Gear Torque Settings Help
- ACT clutch acting strange.
- What Hotside do I have -115??
- MBC Hooked up...questions.
- AMS LICP- No bumper removal?
- help with aftermarket intake
- Boost Settings
- problems in the ix..
- Got the 35R, Now what?
- Which intake should i buy?
- RPS carbon carbon twin disc clutch flywheel
- Question on installing TBE on new Car...
- Boost control
- IT'S OFFICIAL.... my engine blown up !! 29,000 miles
- Should i be worried again?
- Tomei Cam Specs
- Internals on the IX?
- what does a wastegate do for the car?
- Shift lockout (sitting still) Trans?
- EVO IX - HKS 272 Dyno Numbers!!!
- Any good pics of Blitz TT install?
- Exedy clutch clamp load ratings...
- Choosing the right mainbearing
- Intake Manifold CARB legal?
- MAF question....
- Another IX exhaust question.....
- Meth. Pump is spewing methanol out the side!
- Just got back from TurboTrix
- what extactly is turbo surge???
- 20g-9 vs BB 50trim vs 3037 vs 3076
- Another weight savings thread
- Where to buy clutch?
- GT37r turbo question???
- Test = Bad 0'2's?
- P0456 -- Why?
- BOV HARD Coughing Noise
- Why so inconsistent....
- grind in 5th gear
- For those who installed cams.
- Dyno Results Follow-Up Comparison
- anyone with 05 evo that has gear grinding
- is ur aftermarket clutch "clutch"
- HELP! Really loud clicking noise after Overboost CEL..
- Big HP EVO's & Drivetrain Upgrades
- 280/272 anyone tried it?
- ARC 073, 079 and 073 wide
- BR Air Filter kit, LOUD!
- Air bags
- Porting the Standard Exh Manifold
- My newest toy
- Megan Exhaust
- IX Cam kit
- Selecting appropriate external wastegate spring
- Nor-Cal 05 Clutch Install
- turbos question
- Final Results!! Buschur Ported Parts + Alky
- dual bb 16g
- Anyone know the answer for this?
- Best Clutch/Flywheel for HPDS and Daily Driving?
- is this clutch slippage or what???
- Question
- Stock intake? Not what you think....
- Fluid Dynamics Questions: IC piping
- Exedy clutch faq
- Cooling System Problem? Or is this Normal?
- Tilton C/C rebuild costs
- Downpipe Questions
- Injectors
- IX MR (forge MBC installed) need advice
- 100 octane for stock '05 Evo VIII
- Forge Unos mbc and Powerflex motor mount reviews
- What BOV and Intake are you running??
- What am I forgetting?
- How to check timing on engine.
- What is going on with my car?
- 660s borderline small for BR Stg 4+/WR turbo?
- Anyone have Skunk2 exhaust?
- fuel cut?
- Installed 1g dsm bov...got a question
- GT3076R PeakBoost kit DD Dyno#'s
- borla cat-back and dcsport cat-back
- AEM short ram intake
- New Dyno Jet at ICS My #'s
- BR Race FMIC on the streets.....
- BRAKE light comes on?
- Initial Dyno Results - Buschur Ported Bits
- ACD Fluid??? Can I just use ATF fluid?
- Carbon Vs Metallic Clutch
