View Full Version : Evo Engine / Turbo / Drivetrain
- Anybody know the stock evo cam profile?
- dieing turbo
- boost cut, what the SH**!!
- o2 housing turbo outlet?
- Turbo's? Gt 30r-3071r-3037
- Helix dpwnpipe install
- New Clutch = bad syncro shifts Info needed!
- Bov
- clutch exedy vs cusco.
- Question about AMS FMIC
- Upper intercooler pipe ballooning!
- modding vs. modding w/tuning
- The "MILLION $ ?"
- Boost Question
- Exh Comparo
- Pics of stock clutch/flywheel @ 34k miles
- Can someone take a picture of...
- What to set 280 cams at/where to buy methanol!
- How the heck do I get these axels on?
- Help, just installed fuel pump and it's stalling
- lower intercooler piping
- GSC Cam Indexing - Help
- Motor Spun backwards
- Clutch gets stuck on MR why?
- Nitrous Kit Installed
- MR Clutch options
- evc III ?
- Can I lean out my flash by increasing boost?
- stupid question
- Magnus Motorsports-Not Just INTAKES!
- ANY 80mm CAT BACK?
- Help!!, Might be a Fuel Cut...
- GT35R Turbo?
- Tick tick noise in motor....normal???
- DSMLink in my Evo
- Made a mistake, maybe critical?
- MD & VA vendors/shops-need to buy a few things
- Need help with axle install...
- Fixed my low hanging BR Turboback...
- A Question for the "Go-Fast" Gurus
- Arp headstuds with cams necessary?
- Erratic Startup Issues
- Nexus Issues?
- I need tech input!!!
- 2005 alky injection
- custom tailpipe question
- 340 awhp & 360 ft. lbs on Mustang Dyno
- How often should I change Synchromesh tranny oil?
- What cars used the 7 bolt 100mm crankshaft?
- Installed Megan Manifold, O2 housing, and 10.5 Hotside
- What's needed for a cam install?
- installing BR stage 1 kit before the weekend
- Twin Turbo G35 giving the EVO props
- Is there as street legal resonator only exhaust for the EVO?
- water inj kit for less>>>>look
- espelir exhaust + Helix DP and Cat Delete :::I SEARCHED
- BOV sounds - greddy,HKS,turbo xs, etc.etc.
- Borla Tubular Exhaust
- Got a GREDDY SP2 Exhaust
- nice to have BOOST
- Buschur! Whats that new secret???
- EVO Guru's here's a setup question
- rpm's and stock head
- Question about clutch
- No Boost?
- Exactly what part's/sensors do I need to intall AEM EMS with MAP?
- O2 eliminator setup
- HKS TT harness with Blitz TT?
- Cylinder head work
- Question about Wiseco Pistons 10:0 Pistons
- boost problems.. =(
- REMOTE STARTER: Keeps firing.
- guru's wanted ! ! !
- AMS here I come!
- Going to buy intercooler today, Wich One?
- 3071 vs TME 10.5 hotside
- Megan Full Exhaust System, Good Buy?
- What is the highest WHP made with 70mm or smaller downpipe?
- Hey I Need Some Help Guy's!!
- Kartboy or Works
- Static compression HP/TQ numbers...
- Can the stock BOV just "break"?
- more boost???
- How boost leaks can KILL your power - and how to test for them
- 2.3L Stroker and durability
- Buschurs Ported Echaust Mani
- Max 4g63 bore???
- Will it be okay?
- just got done putting my APS cold air..........
- How pissed would you be?
- Anyone buy fuel from an Airport>?
- Greddy Type S BOV - upside down installation!
- WTF- Stange siren noise.....HELP!
- Transmission problems...help!
- XS Race Max downpipe?
- How much NOS can my EVO take?
- HFC, Test Pipe, what to do for emissions?
- gt3540
- 1st generation buschur exhaust (slip fit)?
- everyone with an APS cold air plz help!!
- MR trans limits?
- Erratic Idle, advice needed!
- Turbo Mani Temp???
- Which cams?
- a/f gauge question
- Question on camshafts...
- EVO VIII final drive ratio?
- Stock Turbo Vs Aftermarket Question
- 10.5 hotside HP gains:)
- t bolt clamp sizes
- Evo IX Turbo pics
- question on displacement and other things
- Mail in Flash for GT3076 Upgrade
- anyone dynoed 4g63 w/ no boost?
- Problem with ur test pipe & CEL
- Will I be first with a side exhaust?
- t bolts... where can I buy them at?
- Where to get a 10.5 hotside
- My new toys :)
- HKS2835 numbers
- how can i make the stock turbo better!?!!
- Mods installed... poor outcome :(
- biggest injectors with reflash???
- How big are the driver/pass motor mount bolts?
- port and polish question
- car is stalling what could it be?
- Does anyone have RnR's Turboback?
- Question About Boost
- throttle possition sensor
- retaining ring studs
- Installed my buschur tbe. hfc flow arrow points wrong way.
- did i install this right! greddy s
- How to install clutch extender rod?
- What do u guys use?
- Replace flywheel or not?
- Do intercooler pipes provide any real gain?
- Amuse Sound Clip
- Stock HP question...?
- anyone runnin denso 720's making 500whp???
- Helix Downpipe or TurboXS Downpipe?
- noob bov question
- New Turbo Kit?
- HKS TT Type 1- RPM wiring question!!!!!
- Atp 3071r can this hit over 400/400 whp?
- Axle oil seal replacement
- Installed Greddy type s BOV
- whining sounds coming from tranny
- Exhaust modification question
- Crazy coolant problem
- Driveline loss?
- Megan Racing Downpipe Install
- cams installed?
- OBX intercooler hoses
- 05 Tc?
- Buscher 3" TBE sound question...
- $3400 cat-back exhaust??
- downpipe only at the track???
- Electronic Controlled BOV
- Question about new cylinder head
- Whats a good aftermarket clutch
- Urgent
- Blitz SUS intake
- 3" O2 Housing Worth It?
- Apt, Buscher, Or Rnr Turbo
- My car stalls when........
- where can i get high quality 3'' exhaust gasket
- Engine tapping/nuetral rev
- Stroker for 3071r turbo
- asking for sound clip of greddy type s bov
- Limits of evo8 pistons
- EMS for the stroker & turbo??
- Buschur 3" downpipe... top flange is only 2.5" opening...
- Wastegate actuators....?
- Humidity affect on turbo..?
- Turbo trix limited diff?
- guys running clutchs got a ???
- To much oil
- New Exedy Carbon D-Core Clutch!
- Atp turbo kit owners
- Anyone have a Gruppe M Airbox?
- OBDII Pocket logger\code reader .......
- Anyone have an AP Racing clutch?
- TC "o" ring?
- Accuracy of tailpipe AFR sniffer?
- anyone using a MSD DIS2
- ıncrease 400-450 hp?
- what kinda oil on brand new evo 8?
- Sticking throttle? RPM's keep rising? Even clutch out!
- can we weld on lower intercooler pipes instead of having hoses?
- suggestions on Tranny fluids?
- advantages of running aem with alcohol
- Could a bad clutch install mess up the trans?
- Fluttering noise with Helix IC pipes.
- Megan Race Manifold
- New Vendor Checking In!!!
- Something chattering/whining when feathering the clutch in 2nd gear
- What supporting mods?
- Which is stronger ACD vs VC?
- Factory Boost above 20psi???
- Blitz Intercooler
- Mmmm...Swain Tech goodness inside
- Alcohol Injection Question
- question on check engine light
- 2nd gear grind?
- Problem with Turbo - HELP!
- RSR Downpipe Question
- Normal Oil Pressure Readings?
- Heat shield help
- Knock sensor CEL w/ Bushur DP???
- NGK sparkplugs: How often to change?
- Odd problem with the oil light...
- AFM details
- Dyno Run????
- having strange problems.. car went from mega rich to mega lean.
- Mbc Needed With Flash Control?
- Problem installing Megan TBE
- APS 3.5" Turboback SS Exhaust System
- JDM mr questions
- My Turbo "kit" w/ pics
- Buschur catless TB - will it throw a CEL?
- boost problem on a hot day
- helix titanium test pipe
- How frequent are TC failures?
- What U think about this????
- How much boost can I run?
- what tranny oil should i use?
- racing valve question
- 2WD vs. 4WD dyno #s
- IYO what is the BEST streetable turbo
- gasket questions
- Defi Bf Oil Pressure Gauge Questions
- help car is not right
- E-01 EBC Tuning Questions
- Torn Between What Cams, help me choose!
- upgrading my current EVO8 MR turbo, please help
- Boost Spikes and HP/TQ loss...
- Safe to run...
- Greddy Type-s and 5th gear
- Couple of Install ?'s
- crush washer
- Buschur Racing Axle Back for sale
- HELP!!!! Oil Pan Gasket
- boost question?
- Boost Leak from HELL!
- Wanted!
- Clutch install
- peak boost lowered?
- Sputter / Hesitating @ WOT [around 5500+rpm]
- Stock intake restriction
- pls help identify where this vac line goes?
