- Help! (need quick answer)
- FP Black possible shaft failure :/
- Best way to make 450whp on stock bottom end?
- Spoolin Up CDi Ignition!?!?
- Speedometer reading slow
- Evo Engine - MAP
- 2.1 with 4g64 short block
- O2 housing and ex manifold studs and bolts
- Kinugawa Mitsubishi EVO9 Turbo Install Kit
- upgrades without a tune
- Shifter bushings
- Need advice on BOV and IAT sensor location (going speed density)
- 8 vs 9 Engine
- Need good machine shop in CT, NY, NJ, MA, RI
- miss fire
- Comp has done it again an even better Stg 2 clutch option
- Coolant Level go up at reservoir, why this happen?
- Need a Rebuild?
- cam and s&r choice
- Low Compression
- Random no start, AEM EMS.
- Is it possible to remove the VCU from the transfer case?
- Building a 20g
- Loud exhaust
- THE BUILD! He's Back! ...and looking for parts!
- Driven Innovations NEW DI intake manifold.
- What to do about the flywheel Hmm?
- Evo 7 differential in Evo 4
- Comp clutch stage 5? any input
- tb boost leak....help needed
- ported stock exh manifold or 1.5" ETS Long runner?
- Reflanging intake manifold for 70mm tb
- Intercooler sprayer delete for custom cold air intake?
- Little confused during Clutch Install
- Gaskets
- Transmission to tcase install
- High knock count!!
- Injen intake question
- Factory JDM Evo 7, 8 & 9 motor mounts
- aftermarket clutch slave?
- Need Help Please! Code P0117! Won't Start!
- CNC Staging brake for Ebrake on ABS equipped Evo?
- Evo6 idle issue with Apexi Power FC
- head options
- boost leak from throttle body linkage connection
- 03 to 05 Engine
- Evo 4g64 oil pump help
- A little Sputtering during WOT
- Two different Boost Reading
- 4g64 knock sensor
- Tomei 280 evo 9 cams on a 10.1cr 2.4L. What to expect?
- best filtering filter
- Degreeing Mivec Cam on Evo 9
- Flywheel resurfacing question..
- Looking for BOV testing with turbo speed sensor
- Review on Forge motorsports type rs vta blow off valve?
- Kelford 288 Cams
- coverting MAF to IAT
- CosM2 Vs Kel 272
- help me fix my evo
- genetrator brace fitment on a 4g64
- Warning! Kragen/O'Reilly/Autozone Loaner Compression Testers
- can i put Eclipse Block????
- Walbro 485 limits
- See anything wrong with this timing setup?
- Ideal seat pressures for upgraded valve springs for higher lift cams?
- Transfer case sound help!
- Full acceleration to stop = stalling
- Evo IV-IX transmission and transfer case
- Torque settings
- What to expect from jb HTA green
- evo 8 stutter
- Help to identify engine knock. Pistons?
- can an 01 galant oil pump be used on an Evo 8?
- GSC Power-Division releases R2 camshafts
- lean afr's when switching injectors
- Fuel pressure falling off in the upper RPM with dangerously high AFR..Need advice
- Gsc s2 vs gsc s3
- High Oil pressure at idle
- Clutch not disengaging when cold
- Crower adj. cam gears and timing
- low boost problem
- Unsealed Diaqueen LSD oil
- 2.2 4G63 Stroker w/ 94mm crank... Head swimming
- Another ACD issue (super fast prime)
- FP Black vs GT3076
- Forward Facing Manifolds.. Simple Guide
- Oil return line
- GSC 0-tick lifters different length?
- 05 Evo 8 Downpipe?
- Questions on e85??
- tephra NLTS cut issue?
- sputtering idle
- looking upgrades for my evo 9 mr
- question bout drivetrain
- Looking for an Alternative (2.3 vs 2.0)
- gsc s3 bbk full?
- FIC 1450's don't fit with Magnus V5
- Exhaust manifold gaskets on high power apps
- Which clutch for 600whp
- Inherent Evo noise or what do you think?
- turbo oil line restriction
- sparkplug wires/boot
- 6266 vs 6262
- What would cause this -- Radiator all bowed out
- 3" vband hotside outlets
- Which of the following parts is contributing to low end torque loss?
- HKS EVC 6 Overboosting....?
- Price range
- 2003 Engine Noise sounds kinda like a Volkswagen Bug
- stock 9 bov
- Wierd noise @ 4k rpm on 2nd gear
- non-ACD to ACD deleted t-case
- Need some advice and help on which way to go.
- E85 mix it or 100%
- Anyone go trough the Greddy comp tic install for the evo 9 MR?
- Noob question. Is there a difference between evo 8 and evo 9 Fmic?
- spool: BBRed/3B/BBGreen?
- Tial vta blow off valves, surging problems?
- Skunk 2 fuel rail questions
- Tcase leaking transmission fluid?
- 9RS transmission problem
- Am I correct about factory wastegate
- Tapping into fuel line for gauge...
- Wheel bearing question
- stock bov replacement ??!!
- Fuel Pump Upgrade question? (Did i go to big?)
- Is 18 psi stock on a EVO 7?
- experience with Yellow jacket ignition coil
- Major PSI leak, need input
- Torquing oil pump sprocket w/eliminated balance shaft
- TOB collar clip?
- Oil Pickup tube to pan clearance
- mystery in engine bay
- Oil temps 190F?
- Extending 02 sensor harness
- Rebuiling Engine Head With New Cam??
- Need Help : compression crossed
- Need Help : Compression Bad
- Lean at WOT... bad fuel pump?
- evo 8 valves fit in evo 9 head
- Weapon-r dragon for HKS kansai?
- Anyone got a torque plate?
- Tial mvr 44 questions
- Location of second O2 wire harness inside!
- Idle video of my IX with GSC S3's
- Help with tensioner bolt?!!!!!
- Cleaned throttle body high idle
- EF3 or EF4?
- Acd issue, help me out guys....
- Half Rad Question
- BW S300SX FMW vs. Garrett HTA3582 (or 86) vs. CEA 6262
- Weird drivetrain noises
- 2003 Evo VIII Valve Cover Bolts Question
- Installing back to the OEM boost controller
- Water in intercooler piping
- So after clutch install :(
- Exedy Twin Clutch Plate Paddle Hardness Problem
- hydraulic tob info needed! quick!!
- Sparktech or SpoolinUp COP and why?
- Muse UICP vs Buschur UICP
- EVO 8 5MT 5th gear Problem
- EF3 + Stock Ex. Manifold - To port, or not to port?
- Installed Cams today......twice :(
- Pros and cons of ECU controlled boost?
- Turbo choices????
- Evo8 rev bounce problem
- TC/Transmission part numbers.
- no spark, crank sensor
- Stock appearing exhaust housing for FP 3582 HTA?
- Front open diff swap?
- Evo 6.5 TME an upgrade?
- Blown Evo 9 MR engine. Where to find new engine?
- Cam bolt - any ideas?
- power estimate ??
- hanging HKS Carbon-Ti muffler
- 2.0L build, need advise.
- Is the exedy twin disc worth it?
- which pistons to use
- Clutches
- evo 9 turbo oil lines
- Need to replace HAFE manifold
- Best option for front diff
- stupid cam angle sensor housing bolt!!
- I blew my engine,, please help
- Pictures and info on Mishimoto MMRAD-EVO-01 radiator
- PROBLEM engine under load "choking"
- P0132 Trouble Code: O2 #1 Circuit High Voltage
- Spark Plugs (Again)
- Inconsistent shifting in 1st and 2nd
- 20 PSI stock?
- AMS surge tank evo 8/9
- Evo viii stutter and MAP sensor question
- Act HD pressure plate reuse??
- RS transmission swap
- Walbro pump size
- Any adverse effect by reducing the air suction pipe from 4" to 2.75"?
- Wiseco 2013 Piston Releases
- radiator fan issue
- Wastegate Solenoid
- difference between 8-9 turbos
- Compression ratio with stroker piston on Long rod 2.0?
- Okada plasma direct or spoolin up
- 400 Fuel Pump Pressure setup
- map ultimate duty rod issues!
- Help! Misfire with fuel smell!
- Really need to retune after Megan Manifold install?
- trimmed rod bearings??
- Leaking Evo IX transfercase
- Rebuilt Transfer Case Leak?
- Need all FP Black STOCK 2.0 guys input!!!
- Evo VIII Tech Help - Please
- Tomei M7960 MM size?
- What motor build should go with the 6466?
- Oil Filter EVO 8 MZ690115 or MZ690150
- comp clutch stg 4 updated reviews...
- Which radiator to buy??
- Does the double pumper require an FPR?
- How much is it to replace 3rd Gear synchro on Evo 8?
- White Smoke
- So did I blow my motor?
- evo ix clutch problems HELP!
- My evo 8 hta3586 110 or e85?
- Is the stock evo 8 turbo good enough?
- Binding, noisy, annoying drivetrain
- Help?????
- proper valvetrain components? searched to no avail
- Safe to remove Manifold shield?
- FP Red BB boost creep
- Exedy Hyper Single with 5 Speed Box - Late Release Point
- Why is my o2 dump causing boost creep?
- EVO 8 AEM Fuel Rail Install Question
- Talk to me aboot motor mounts
- qucik question over boost problem.
- JMFab Intercooler with Cusco Power BRace?
- Need help gsc n/t lifter install no compression
- titanium rods
- Which turbo wheel to get for .63 on turbonetics 60-1
- Installing invidia o2 housing question..
- Clutch Issue!!
- ACD pump not turning on
- 6262 turbo
- warmup tuning?
- HG replacement questions
- russell proclassic hose fumes
- WTA : Cosworth engine 2.2L
- Selecting Spring & Retainer
- Higher base fuel pressure - I like it...
- Exedy clutch. What did they update? Floater? Pressure plate? or what?
