- cam install at 43k
- Intercooler spray
- wideband sensor cable, how did you seal it?
- Boost gauge concern - help?
- problem with shifting (hard) Please help
- Need How Too on replacing Outer Transfer Case Seal
- Query on ACT Clutch
- NOTICE: turbo install kits- please read
- How to eliminate Compressor Surge or Turbo Surge ?
- Coolant temp sensor stopped working then got lean code??
- Buschur website out of date?
- Wastegate actuator question???
- The problem with boost controllers
- turbo trix 2.1 block and head finally arrived!
- Quick Spooling Turbo Upgrade
- Upgrading the pistons and rods
- 02 Dumps ?
- Precision injectors not sure what size they are help ??
- Error message p0441
- Another oil thread, but anyone heard of or used this oil??????????????
- 4g64 question!!!
- Looking to see. (mivec head)
- Ever had a rear diff problem at cruise?
- Mini Battery.
- Question about Blitz SUS Intake
- Need help !!! please look
- Got a tech problem ...need help!!!
- Transmission Help
- bf272 vs. kelford 272?!?
- Source for clutch wedge clip
- borla exhaust or greddy ti-c
- Wierd boost curve problem
- Buschur magnaflow exhaust hangers
- ACD to non-ACD T-Case
- Anybody know how long it takes??
- I'm 100% fed up with my car !!!!!!
- Upcoming Dyno tune
- fuel pump relay????
- Broken motor mount
- what turbo and wastegate should i do ??
- knocking problem at 4k RPM
- Need help boost problem?
- Headstud question?
- Evo 1 Rad options
- MIVEC / Big Cams -> Static Compression?
- help plz
- My car droped a bomb. need some ideas on what it could be.
- New revised QuarterMaster clutch months away!
- stripped transfer-case plug
- How to Remove Injector Resistor
- Who here is using aftermarket motor mounts on their cars?
- MBC high boost?
- Some connecting rod tech. I have a new favorite rod.
- can i install my o2 dump without getting another tune for a while?
- 156mm Carillo H-beam: Custom or Available?
- car in and out of boost with profec
- Car cranks, and cranks and cranks, but no start (big cams, cold weather?)
- 4G64 DOHC 7-bolt block with Evo head hybrid
- Swapping a 5spd into a MR
- Mini Battery and cold weather.....DEAD
- FP Red,or HTA3076???
- Car sitting for 2 weeks Help
- Positive battery terminal fuse blew!!!!
- Clutch engagement
- 4G64 w/ 96mm Crankshaft? Great idea?
- Evo 9 First gear Question
- Alright, really stupid question here regarding ETS UICP
- APS Cold Air Intake ?
- hesitation and bucking issues low rpm
- Help with Clutch Adjustment
- Pulling the Block
- Buschur double pumper
- wastegate actuator end piece?
- turbo kit?
- starter or mini battery going bad?
- car jerks at cold start.
- Synapse bov ?
- Engine rebuild, High Oil Pressure
- GSC s2 revised specs!
- is it necessary to upgrade ur o2 housing if u wann go over 300 hp?
- Any engine builders ever added deck height to 4g63 or 4g64?
- ETS 3" IC ok for a 400 whp set up?
- Small battery
- 4in. Intake???
- About driving untuned help!
- Megan downpipe gasket question?
- would this work?
- megan and buschur exhaust fitment??
- Upgraded Rods, Pistons?
- installed bosch 044 inline pump, now problems
- FPR issue
- Front Diff fluid?
- New intake for Evo! Little confused though?
- shift issue
- +1mm oversized valves any good?
- Stock evo8 10.5 hotside upgrade
- WOT in the Cold
- Well I blew the motor (pics inside)
- Seafoam
- !!!!JE pistons Pins?
- BR EVO8-9, 84 mm MAF pipe for the FP Red and Black!
- Anyone running a kelford 272/280 combo on a viii?
- Anyone running kelford 272/280 cam combo on a VIII?
- New Tial 44mm MVS Wastegate and Recirc Valve
- EVO 8 Axel shaft and tips
- Garrett GTx-R turbos/comp wheels.
- which brand to choose?
- New clutch and tranny....few quetions
- Ryu's hunting for 9's on the Stock Block
- Valve selection help needed
- Fuel pressure regulator question
- AWD Motorsports EVO 8.5.. " The Bastard " makes 523whp/523Tq on BBK Turbo!!!!
- Drivetrain Whine
- Electric Water Pumps - Pros/Cons?
- Searched but had no luck, Cold Starting
- Ss Clutch Line
- Garrett releases larger T3 divided housings
- Stock block & head at 30psi and 8400rpm max. What turbo?
- VTA last ditch effort
- Clutch fork stoppers
- Unknown Turbo System Issue...
- bad knock sensor???
- Full Boost on IX
- white smoke!
- should i cange my TB since i am running the FP red now
- Titanium exhaust flange = leaky?
- Exedy twin owners only please!!!!
- FP Black and ix turbo pics..
- bucks and wants to stall
- Polydyn or Tech Line coating?
- Stop boost spikes EBC or MBC?
- Meth Problem - HELP
- Spark plugs
- manifold change parts
- soon to put on the FP Red 80mm...
- Car sounds different after changing to 15W-50 M1 Synthetic...
- Which cam shaft ?
- Evo cylinder Heads
- Exedy Twin went in today!!! It wasn't fun
- 9000rpm
- Evo cylinder heads
- car wont crank
- AMS 950 R guy please step in...
- is this a reliable setup ??
- fp black on my 06 mr
- My evo wont start what to do?
- New ETS intake?
- Question about injectors choice.....
- In-line fuel pressure sender adaptor for defi?
- in motor drop in pistons pros and cons. techniq
- looking for a good set of aftermarket rods
- 2.0L 4G63 longrod setup questions
- power lost
- build help? 2003 evo8
- WTF !!!Battery problems!!
- knocking/ ticking noise
- best injectors for high hp
- Needing some advise on my setup
- problem with my car on idle
- Engine Leak..HELP!
- BBK full injector sizing choices choices!
- GFB bov question
- mixing motor mounts
- where do i get evo ix service manual???
- Ordered Fidanza 3.2
- NEW External Wastegate on Stock Turbo!
- Need help finding a arc cooling panel cant find it anywhere !!!!!!
- Act mb017x question
- Trans issues...
- What ECU is best for my setup ?
- Runs like a subaru.
- installed test pipe, running more boost?
- MAF Issue
- What drives torque curve shape, boost or tune?
- Throw out bearing LOL's
- Sloppy shifter?
- 8 second Street cars, Buschur's RS's quest and a lot of rambling, novel inside.
- lots of talk about blown motors
- Evo VIII 5SPD Vs. Evo IX 5SPD
- Upgrading the Injectors
- Need high flow cat - Mil.spec??
- Rebuilding...OEM part list help!
- Who sells Vband o2 housings?
- Finally doing the build
- mak1000 GT35R turbo kit pics
- Stroker Motor V.S Built 2.0L
- MAF issue
- little hole in downpipe
- FP Red
- Reasonable price for welding o2 bung????
- need somebody to identify this manifold and o2 housing
- Robispec swaybar
- IX acting funny during cold start ups
- part nr for crownwheel / pinion set
- IAC Valve question
- How much is IX MR 6spd worth used?
- My EVO is Whining!!
- Re-Installing Transmission
- pvc valve
- hta86 VS GTX-R3788
- How much torque will Manley H beam rods stand
- 35r to 6765 What do I need?
- 02 Eliminator downpipe vs 02 dump
- exedy twin rebuild
- aps bov help
- greddy rs res.b.o.v. adjustment...
- tial 38 MVS
- <MR OWNERS> 6spd or 5spd?
- undecided..some help
- Catch Can ?'s
- A 700 hp goal ..
- Stock ECU readiness / Go codes?
- No start/lumpy start/rough start....bad injector?
- what is the difference btn FP white and white Rabbit?
- water pump
- Which Tachometer are you guys using?
- powertrain technology twin?
- Will an Exedy Twin Hold This?
- driving untuned on cams?
- Another Drivetrain Bites the Dust
- O2 sensor behavior while logging?
- Noob help.... :(
- Standard vs ARP "L19" Headstuds
- evo help... not sure where to put this
- Lightweight crank pulleys?
- anybody have a how to for "bosch 044"?
- DIY COP. anything to worry about when selecting coils?
- Help please!!!
- Transfer case broken......now what???
- reconnected battery - now tarmac/gravel/snow lights are on
- Cool tech tip I wanted to share
- Turbo blankets
- fluidampr on a build 2.0L
- help. what just happened?
- my bad boy build
- Might be a dumb questiong, but...
- Valve cover oil leak
- Evoscan nb O2 front sensor voltage ?
- Clutch is HARD!
- new clutch slipping
- How long does a twin disk last?
- Fuse and Relay box picture (Help) Evo 8
- Holset powered Evo VI
- 6spd & FP Red characteristics
- Need help- 2 codes , car dies!!!
- Kelford 280's too much for a bolt-on car w/fp green?
- FP Red or Black
- how much can the stock clutch take?
- odd sound whien i shift above about 3k
