View Full Version : Evo Engine / Turbo / Drivetrain
- Stock oil pressure?
- Borla Exhaust
- 493 whp at 22-24psi
- 2004 12th Annual DSM/EVO Shootout
- Which turbokit is equal to HKS 3037s turbokit?
- cams and cam gears from HKS
- Questions about Dynoflash
- Evo owners that have swapped synthetic to mineral/dyno oil
- SAFC Increases timing?? Hear me out....
- Is a cat delete pipe even worth it?
- V-Mount Intercooler and Radiator
- car buckleing
- New CEL ON NOW!!! Damn...
- Staged upgrades for the EVO8 with EMS
- Dynoflas is coming to CHICAGO!!!
- The power of Buschur and DynoFlash - 318 whp no cams
- Need for O2 eliminator DP?
- turbo timer trobles please help
- Kartboy short shifter?
- RNR o2 Downpipe... enough :(
- Blow Off valve
- Evo 6 head gasket to Evo 8??
- 50hp gained, 30% fuel saved from K & N filter!!
- Anyone elses 5th gear synchro shot?
- So now I see 2 turbo kits that sound pleasing
- Apexi Timer Killed Remote Lock
- Poll: Do you smell gas in your oil?
- Fix for shifting faster ?
- shaky car at idle
- fuel tuning
- Do I need larger injectors
- AFC installed = questions
- whats the point of larger injectors on stock turbo?
- a non-sacrificing turbo, does it exist?
- Exede mail tune users - free dyno time offer
- FREE Dyno test opportunity
- noise from clutch
- Which grade fluid to put in?
- Noobi3 questions
- Shell Helix tranny fluid?
- Fujitsubo and AVO exhaust info
- Broken stud on turbo.
- knock sensor
- what is detonation?
- My cheap catch cans
- The Turbo Kits Thread
- RnR Turbo Kits released
- AVO's plug-n-play piggy back
- Spark plug testing/info
- Dynoflash gave me a better car with an extra 30+ whp
- Custom muffler 3' turbo back .
- Muffler delete pipe!
- SFP turbo kits now released.
- AMS downpipe and testpipe installed! =)
- AEM short ram fliter
- U-TEC !!! Dec 25th
- Dynoflash VS Exede results!
- Another funny noise thread.
- launch control systems
- too much power worry!
- Blowoff valve causing rough idle?
- Evo Christmas
- 2nd Gear Grind
- Hallman Evolution Pro RX
- anyone heard of this mbc?
- JDM Titanium Exhausts
- Another LSD question
- Comparison of Buschur Muffler and Magnaflow
- Possible better clutch for those having problems
- SPEC clutches
- Heres what I've found with Tranny Oil
- So, which turbo-kit would you choose?
- New Final Drive Gear
- RNR o2 Downpipe installed !!!
- Loud Vibration sound
- SparkPlugs - BPR7ES?
- Buschur Or Hks
- bov
- Oil catch can??
- Is this normal?
- MBC: Boost level tapering off???
- e-manage vs. SAFCII can you help me?
- JDM style 3" exhaust finished....
- 2.5" downpipes ready to go...........
- fluid changes
- Almost killed by my cracked HKS manifold! BEWARE!
- Down pipe
- Datalogger/Scan tool options?
- Question about EvoVIII PSI?
- The car shakes when its cold
- Planning some upgrades...
- Apexi Power FC
- ECU upgrade side effects?
- STOCK BOOST and 403 at the wheels...
- best cam for evo
- What can be done to improve throttle response and reduce turbo lag?
- Exhaust Odor - My Car Stinks!
- Random 3" cat
- 419wHP EvoVIII on pump gas dyno graph
- Blow off Valve help please!!!!!!!!1
- Is Samco IC hose kit worth the money?
- Do you guys like this manifold?
- Battery Relocation
- Full titanium exhaust?
- Underdrive pulleys
- Your Opinion on First Modification
- Limited Slip Diff LSD
- Intake house question
- Another Satisfied Dynoflash Customer...
- Many XEDE problems
- blow off valves
- HKS EVC offset settings?
- Radiator overflow question
- Mobil 1 Oil Filters
- Please advise me !!!!
- Oil Filter
- **Very** sporadic idle issues. Aftermarket intake related?
- Custom tuned dynoflash is the way to go!
- Engine Block
- Crank Modification
- Has anyone installed headers?
- APS power systems
- crank it!
- SAFCII installed - few weird items
- Pesto360/SFP - Dyno Graphs?
- BOV poll:
- BOV flutter'stutter
- Got Dyno-Flash remap: Best Buy!!
- IS THIS SAFE? mega daily boost
- Greddy Profec B Spec 2 Problems
- Oil inside turbo compressor housing
- MAP or MAF
- HKS Twin Plate Problem!
- Who is using HKS EVC V ?
- newbie question
- what BOV/DV are you running in your EVO
- DynoFlash! Best bang for my buck!!!
- Intake Manifold Upgrade
- BOV or DV??
- TSB for 5th gear grind ?
- Applied Technologies and Research (ATR) Cat-back
- Lack of wheel hp due to VCU?
- Best tranny, brake, suspension upgrades???
- Got all Bushur intercooler and tubing
- 419 HP to the wheels on 93 octane
- Service Engine Soon light?
- where is the o2 sensor wire in the ecu?
- Get That Forge BOV/DV off your EVO!!!
- Catback Numbers - Just the Facts Please
- visual differences between stock cams and HKS cams?
- Help?
- Why can't you use VTA BOV valves in Evos?
- How does fuel cut feel like?
- The HKS T51R SPL is in...
- is there a pressure guage in a stock evo?
- Can you smell a cat del??
- Magnetic drain plugs?
- Noises..
- japan specs. evo
- Signs of blown headgasket?
- HKS GD Clutch Max Twin Plate for EVO VIII any good?
- Bushur Racing Whats going on??!!
- minutes to put on a T T
- quaiffe transaxles?
- Exedy hyper or twin plate clutch for EVO 8
- Megan Racing Exhaust
- Need Help Tunnig Greddy E-manage
- Need a good front mount.
- clutch squeak
- 2G MAF on evo???
- clutch restrictor, one way valve (check valve)??
- max boost from the stock turbo(16g)?
- What would cause erratic idle when the egine is cold??
- aftermarket BOV stutter
- clutch set up
- Hayabusa Pics!!!
- missusing exede?
- UR 3" test pipe...NO CEL??
- HKS Super Power Flow Filter
- Put in 5 quarts on last oil change, should I be worried?
- Misfiring?
- mods I'm thinking about making
- Ntercooler
- Intercooler
- Making less boost in the winter??
- Loosing coolant from radiator
- RMR exhaust & Perrin
- Moral Dilemma: SAFCII, Dynoflash or wait for AEM EMS?
- What should my EGT Gauge be reading?
- Which shell gear oil??
- Electronics
- Upgraded intercooler
- EVO VI V VI Clutch upgrade
- Need Help choosing tuner for 91oct...more>>>
- Bushur Exhaust pipe Installed - Questions
- most mileage on the 4G63 motor
- Red hardpipe kit
- Is this a BOV problem?
- The engine dies...WHY?
- how does an MBC/EBC work?
- differences between elec and mech boost gauge?
- diy : remove cat
- jackson racing head
- Who can get a Kakimoto GT1OZ Ti exhaust for EVO?
- what the hell is this plug for?
- Shifting problems?
- Any tuner offer complete stoker engines??
- greddy type s sound?
- Airtrek Turbo-R
- 239.9 WHP on my stock evo charts attached
- Shift fork destroyed. No 1st or 2nd.
- What is the best option to eliminate fuel cut?
- Front LSD
- Filter question?
- Did Mobil 1 gear oil kill my tranny???
- S-AFC: AMS or Buschur settings?
- Mine's Parts
- Drivetrain Question
- Upper I/C pipe, I/C chiller kit, or injectors & fuel pump? Which one?
- Video: Buschur Cat Back & WORKS Exhaust
- Top Speed?
- I dynoed my car yesterday....
- new clutch feels too light
- Mobil 1 oil filter
- Clutch, I am about to buy one
- Quarter Mile Times Registry
- Can the Evo support 600hp reliably w/o breaking parts(I mean the drivetrain)?
- 575 whp Evo spec sheet
- Good Job Buschur Racing
- B&B Downpipe-HELP!!! Rubbing
- BOV in atmosphere w/ safc ok ?
- Turbonetics MBC Problem
- SS Clutch Line
- boost restrictor pill REMOVED!!!
- Anybody have RMR's racing catalytic coverter
- Best 3" Cat
- Just Joined NY area
- O2 eliminator DPs
- greddy type s prob
- JIC exhausts and downpipes
- HKS Racing Suction Filter After 6K
- Which standalone ?
- turbo oil lines ne1 make braided???
- Mail Dynoflash
- Clutch on its death bed..?
- Greddy Emanage and MAF question...
- 264/272 MiX
- Very strange EBC/HKS EVC problem.
- what do think UR 2way electronic DP?
- Cooked my biscuit!
