View Full Version : Evo Engine / Turbo / Drivetrain
- Service Engine Soon light came on, why?
- EBC holds same BOOST EVERY GEAR ?
- Installed BoostG and MBC now..
- what risks
- ECU MAPs
- 4th to 5th grind?
- Who has the E-Manage?
- power loss after 5K rpm?
- rough idle and lost power
- HKS Headders
- Question about fuel
- 12.6 at 110 for stage 1
- Please HELP!!!!!!!
- BOV recirculation question, info needed
- Buschur I/C installed
- Apex power fc
- Hks racing suction kit for evo 6
- NX N-tercooler and NOS Wet System?
- is there any diy things you can do to the evo without buying anything?
- Valve Cover...
- Is there difference between a DV and a BOV?
- Get stainless steel clutch hose or remove restrictor?
- cat delete
- Ultimate Racing Exhaust?
- OBDii dtc p0170
- OBD2 to 9pin D connector pinout
- camshaft install
- HKS Hi-Power catback
- Forge DV bench tested
- Help!! Which cusco oil catch can works with EVO???
- Firewall Seam Not Sealed
- XEDE question
- People with EBC or MBC please Read!!!
- Bushur turboback System!!!
- Anyone dyno stock vs. Forge/etc DV's?
- Droppin' of my Evo at AMS on Tuesday...
- Spare Motor
- Under Drive Pulley Testing
- twin disk
- Turbo kit GT3037S
- Building motor
- Bad Synchros
- S-AFC Settings
- Bov Help!!!
- Problems... boost leak or clutch?
- Why can't we get this
- Evo intake-take away HP??
- finally got car back up and running!!
- How many shims for TurboXS DV?
- Afc settings
- Greddy E-01 Boost setting
- Grounding Kit????
- Fields Harness
- How much boost can an Evo VIII run???
- Boost cut or Fuel cut ??
- Is there a check eng light eliminater for sale
- cat-back exhaust systems
- Way OVER redline!
- HKS Camp System
- Where to Start
- Who has the answer?
- Will these TURBOS work for the Evo8
- So I took my airfilter cover off
- Car no longer pulls, possible wastegate/boostleak issue.
- Choosing BOV - HKS SSQV or Greddy Type-S
- TurboXS products
- turbo restrictor plate
- Clutch restrictor & rev-matching?
- Mitsubishi Oil Temp Sensor
- HKS flange kit for Evo 7 fit Evo 8?
- PWR Intercoolers
- Some details about PWR Radiator
- XEDE vs eManage vs Works Reflash
- AMS Downpipe?
- apexi avc-r
- Anybody running VTA blow valve and HKS Super AFR?
- Want to know everthing about the Evo?
- back to the track with our new FMIC
- will a 3" cat back on stolk EVO loose HP?
- Which K&N Filter with HKS Kansai Box and Ralliart Intake
- Torque specs for Evo manifold
- Hearing noises
- Anyone got the HKS SSQ?
- Does your evo stall?
- Fuel Rail Material
- SES light after heavy driving
- Fields harness
- Oil Filter
- Downpipe
- Dyno Results
- Lightweight Flywheels?
- anyone know the quietest catback??
- ARC induction Box
- what is the deal with the bb triflo exhaust?
- Anyone heard of Blitz DTT DCIII turbo timer?
- Who says u have to pay $600-1200 for a good exhaust
- Smell from HVAC
- RIP clutch
- Will the Buschur racing DP fit onto the Pruven Testpipe??
- Intake wars!
- Boost controller question plz help
- SS clutch line is mandatory!
- Aem Ecu?
- Clutchmaster's Anyone?
- aem intake system
- ecu reprogram
- Got a HKS Downpipe from EMR-Power.com
- Hello everyone! from RS-R!
- The Need for EXEDE?!
- rwd conversion
- dual blow off valves
- running way 2 rich
- TurboXS Utec
- Where did you mount your EBC?
- boost gauge readings
- 94 octain VS 93
- 383 WHP with no bottle or piggyback!
- Evo broken ...wtf
- Dyno Dynamics
- How often do you change your plugs?
- ARC induction box/titan bar
- Tranny Problem!
- Greddy Type R BOV
- k guys...even BIGGER problem now...
- Fire shot out of exhaust
- Anyone Broken a Tranny with Twin Disc Yet?
- Right Tailight not working...But brake light does
- Really need your help
- DESPERATE help on XEDE install!!!
- BOV experts here please
- Aftermarket Gauges please help?
- Turbo XS RFL BOV?
- Tranny fluid overfill???
- turbo timer, needed or not?
- 5th gear grind
- Works reflash/flash 1/4 mile times
- intercooler spray
- Under drive pulley's
- Installed HKS Type 1 where clock used to be
- Ever boiled the oil in your car?
- My review of the Exedy Twin Plate
- 4G63 engine model codes..
- AFC help please!!?!?!?!?!?!
- Does your A/C 'warm up' at a every stoplight?
- high vaccum
- Stroker Kit
- Clutch Replacement
- bad wastegate!!!
- BOV r u happy?
- Anyone encounter leaking coolent?
- What mods would you do?
- Power shortage?....
- How much HP gain from Test pipe and axle back
- Help! Check Engine light/bogging after 4k rpm
- cheapest site for the forge recirc valve?
- Tranny / Clutch Issues
- Apexi N1 Muffler
- Just ordered new evo ACT clutch!!!
- Help Please Needed
- Need your opinion
- Has anyone put turbo timer where the clock is? How deep is that space?
- Custom Turbo Back Exhaust
- Apexi AFC ?
- EVO cuts out with new DP
- please help me
- Apexi Afc
- FMIC's, axlebacks and changes to muffler.....
- Boost Leak at 5000 rpm
- EVO topend = gh3y??
- Air flow meter restrictions?
- loss of torque due to air filter?
- upper intercooler pipe
- have you heard of LS 3" Stainless Exhaust
- Amsoil vs. Mobil 1
- modification sequence
- will replacing the fmic with an aftermarket one void warranty?
- Why did Mitsu put the clutch restrictor in?
- Stainless steel clutch hose TSB?
- HKS EVO8 1.0mm head Gasket in stock??
- Mach CLuth
- Careful with the fragile EVO radiator
- Apexi Power-FC
- lean or rich ???
- WORKS Flash and MBC
- XEDE or E-Manage???
- what Turbo Timer to get?
- Serious Evo Idle Drop
- look what i've got...
- Anyone with a turbocharger.com turbo?
- Does a free flowing exhaust decrease mileage?
- Did I fry my clutch?!?!
- Is the stock flywheel single mass or dual mass?
- AFC from Buchur
- Is anyone getting the Unorthodox Racing pulley?
- XEDE Sub Zero....?
- The "new" xede,anyone have it??
- Have you got your problems fixed under warrenty??
- Someone help with clutch install please!
- HKS 272 Cams, what is the verdit?
- Field harness extender
- need to add coolant...anything specific?
- troubleshoot: boost falling off???
- Pruven or AMS intercooler?
- High oil level from factory??
- Evo 8 intake heat shield
- Clutch and the cheap answer
- Ultimate Racings Test pipe
- need ECU wire location chart
- Evo 7 driveline shunt
- Monster Garage EVO Shootout?
- cross reference for stock spark plugs
- High flow cat/test pipe dyno tests
- evo 8 intake heat shield
- Weight of stock flywheel?
- K&N Intake Evo8
- Exhaust flange
- Vacuum readings at idle
- HKS Turbo Timer Type 0
- Turned off without cool down...
- cam position sensor - if you've done cams, please come in
- Head Gasket...
- RnR CatBack doesn't fit
- Cam Swap Help - can't adjust valve timing belt tension!
- Nos Evo!?
- help, where to make hole in fire wall
- Installed my SAFC today..........
- need help with ecu
- Idle Promblems in 4th and 5th gear
- Rattling with Exedy Twin Plate?
- haveing major troubles installing clutch
- Throttle response
- IC Upgrade
- Good News for 1-2 Shift Problems...PENDING RECALL POSSIBLE!!!
- Greddy Type S, Raise your hand
- 2-Step Rev Limiter...
- Vishnu Standard Turbo Back Installed
- Autometer Colbolt boost gauge problem
- turbo size
- cam swap tips
- Installed HKS Downpipe & HKS Catback
- real simple ?
- Anybody with the JIC Turbo Manifold
- Apexi Auto Turbo Timer??
- HKS Type 1 TT Mounting
- steering wheel shake at highway speeds
- what would YOU do??!?
- Help with the order of parts from the turbo back on the Evo8...
- Question for Shiv
- Grease in your Forge BOV?
- Vishnu Stage 2
