PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. TRE Transmission Rebuild
  2. turbo vaccume, need help!
  3. kinugawa j pipe?
  4. Can I buy EXEDY Stage 1 Pressure Plate Separately?
  5. What exactly is needed when rebuilding an Exedy twin?
  6. 2.3 Stroker, to 2.0
  7. Exedy STG 1... Legit???
  8. u think i can useams oil synromesh manual fluid in the gear box
  9. [VII] Lumpy Idle, Sounds Like Cams. No CEL
  10. Charge pipe?
  11. Oh, Spec Clutch
  12. FP5R cam comparison to any cams???
  13. Driveshaft shop axles
  14. 1st gear problem
  15. Secondary use for Gumout?!
  16. Lining Up Crank Gear
  17. Magnus SMIM opinions?
  18. Shaking at a full load of boost and stalling on a cold start?
  19. Who has installed 2 Piece Driveshaft shop aluminu driveshaft
  20. IHI RX6 TWC77 turbo with larger ex housing
  21. stock evo 78,000 miles power recomendation
  22. PTE Twin Scroll housing pics. T4 1.15 & 1.32
  23. Rod knock?
  24. Hydraulic TOB on single disc clutch
  25. Which Amsoil for the stroker?
  26. Some turbo sizing knowledge, why big and small turbos make diff power, same boost
  27. Benefits of this piston dish design?
  28. HELP Me Identify This Turbo
  29. Headgasket external coolant leak on new motor (have not started yet)
  30. HELP~~~~Engine compression test
  31. engine honing/piston advice
  32. Help to upgrade 4g63 evo 9
  33. PSA: How to Crank position sensor w/o removing timing belt
  34. Transfer Case Whine?
  35. Rod through the block dude
  36. Gas tank LxW
  37. please help .. lean idle boost leak
  38. Turbo Problems
  39. Oil pressure
  40. what kind of turbo is good?
  41. O2 housing gasket question
  42. Opinion on DD clutch?
  43. Interior leather shifter console issue. (5 speed in a 9 MR.)
  44. turbo problem,need help!
  45. Transmission grind at 4k rpm throughout all gears
  46. compression ration for pump gas daily driver
  47. Low boost help!!
  48. Stm balance shaft inspection hole breather fitting
  49. Size and thread for AMS oil pan?
  50. aeromotive regulator meth safe?
  51. Cutout exhaust and turbo sound problems
  52. 2.3l setup
  53. TC dust cover loose, how is it secured?
  54. Is this head okay to use? Need some opinions please.
  55. ayc pump only lasted 15 months
  56. TIAL housing
  57. Need Advice
  58. Need T4 Turbo recommendation...
  59. Spark tech 2ch vs 4ch
  60. advice me for dress up bolts and lug nuts
  61. 800whp+ stock port head?
  62. Evo 8 overheating under load!
  63. EVO IX 71HTA CHRA w/ WGA
  64. Car starting on 3 cylinders when cold.
  65. Egr delete and maf delete, no start?
  66. Serpentine Belt
  67. Evo o-ring cylinder head blueprint and questions
  68. looking to buy a MISHIMOTO RADIATOR EVO 9
  69. Idle problems
  70. STM 3 port catch can with ss clutch line?
  71. New stock frame turbo options from Blouch
  72. Exedy triple plate clutches
  73. Non essential component removal
  74. USDM Evo9 VIN needed.
  75. Competition clutch dual disc problem!
  76. FP turbo/manifold question
  77. Thinking about getting my tranny rebuild, what transmission shop do you recommend?
  78. Need help Diagnosing motor noise
  79. Evo 9 leaking gasoline, won't run right
  80. FP Green goes to turbo heaven
  81. Brand New Built 2.4L with Rod Knock Already??
  82. Front end clunk in neutral
  83. does anybody where i can get this air filter K AND N
  84. FP Zero vs FP Black vs FP Red
  85. Question about bearings
  86. Factory Clutch
  87. The good street clutch for Evo 600+ whp.
  88. Stalled when idling, wont start now
  89. Oil Feed Line for BB 5858
  90. 2.1L timing help...
  91. ACT 6 Puck Sprung Review
  92. Compression test readings
  93. Precision-style 3" v-band flange, where can I get one that's affordable?
  94. AGENCY POWER CBE for EVO9 REVIEW????
  95. Competition dual clutch doesnt engage!
  96. Which Evo does this go too?
  97. Turbo Help/Decisions
  98. External Wastegate flutter on boost
  99. balance shaft delete
  100. Thoughts on ATP 3582r Direct fit Ver 2 Turbo HTA option
  101. 2.0LR Build!!
  102. Price check, need some help! HKS 272's and valve cover
  103. 05 EVO 8 version 1 no start. help please!
  104. Most power on MAP rods?
  105. Mishimoto uicp
  106. Is this ported?
  107. advice on boost leak fix @ TB
  108. Car is STUCK in 2nd gear
  109. ATTN: FP BLACK owners with NO oil leak issues
  110. TS Comptuned ACD flash
  111. WTB Evo 8 Valve Cover
  112. advice on bolt on upgrades
  113. Can't downshift from 4th gear to 3rd gear.
  114. Misfire Problem
  115. Fuel Smell
  116. Low compression :( Any ideas?
  117. Engine rebuild
  118. FP and CBRD no longer have bolt on turbos - Whats next?
  119. Leakdown/compression Results
  120. Evo 9 BOV & INTAKE?
  121. Duel charging my Evo 8.. ( S/C and turbo )
  122. Turbine housing ticking, loose wastage?
  123. Advice on Synthetic Tranny Fluid Changeover- Evo 9 MR
  124. Mil Spec
  125. Maybe throwout bearing?
  126. Quest for 500
  127. Stumped! Please Help.
  128. axleshaft rebuilding / upgrading - CANADA - best options?
  129. help engine and tranny wont separate
  130. bad motor mount=vibration possibly?
  131. quest for 400awhp stock ix turbo 92 oct
  132. GSC S1 Intake COSWORTH M2 Exhaust Cam
  133. 6266 with stock cams?
  134. HELP evo 8 rear lock
  135. PT6266 turbo install help!
  136. Evo 9 crate engine
  137. horrible chatter when moving off
  138. Intake Cam Doesnt Want to Stay at TDC When Doing Timing Belt
  139. GTX3582r Short Runner TwinScroll Setup
  140. Evo IX MR Transfer Case Small O-Ring
  141. Evo 8 engine/tranny removal question
  142. Evo 9 No Start.....Stumped
  143. HKS intakes/filters Questions
  144. Clutch Rebuild Kit Vs. New Clutch
  145. Replace just pulley or timing belt and wp?
  146. No Injector Pulse
  147. Best fuel pump to run?
  148. CT9A ACD question
  149. Oil pressure and monitoring location
  150. How many miles on your Jacks T-case rebuild?
  151. tranny fluid????
  152. Evo IX: Compression Test Results (125, 137, 137, 140)?
  153. Please be nice and help?
  154. Which clutch kit for over 1000bhp for drag use
  155. Big Cam Rattle Under Valve Cover
  156. The right clutch for me
  157. Help please
  158. does the motor and tranny need to come out together?
  159. Evo Viii Timing Belt
  160. HELP! Engine power cutting out on partial throttle...
  161. Garrett GTW
  162. the amazing oil cooler delete kits
  163. Requesting help, engine whine
  164. Jdm Evo 4 vs US Evo 8 vs Jdm Evo 8
  165. Fuel Injector Development (FID), heard of/use them before?
  166. vaccume problem,need help!
  167. Evo 8 Trans rebuild 4th gear
  168. egr delete now boost gauge don't work
  169. Reverse Cooling the 4G63
  170. Transmission failures
  171. FP GT3794 Question
  172. Evo 8 GSR '03 Transmission Trouble
  173. A vid of the trans problems on the Evo
  174. EVO 8 -- Max hp and psi ?
  175. Mivec Maximum Power Level/RPM Level
  176. Is this a oem evo IX diverter valve?
  177. Evo 1-3
  178. Vendors/people willing to mill two - 10 outputs on valve cover?
  179. Evo 8
  180. Muse/ETS short route UICP hitting with tranny anyone ever have this issue
  181. need help with greddy type RZ bov
  182. How to tell: GSC Beehive single spring
  183. Evo 4 Engine Ticking Noise Help [VIDEO]
  184. ACD leak, unknown bolt
  185. How much longer will my clutch last me?
  186. Engine compression
  187. The right clutch for a lil over stock evo 9
  188. Exedy triple disc noise
  189. New to Evo 8 bought with milky oil
  190. FP Green downpipe setup???
  191. Water Pump Leak?
  192. Trans or Xfer case leak?
  193. Valvetrain noise after wheel bearing install
  194. Loud Clunk Sound When Downshift
  195. need help !!!!!!!!!!!!!!!!!!!!!!!
  196. Car stalled on the expressway last night, discovered low oil
  197. HELP!!! Vaccum went from -20 to -13
  198. Cam identification
  199. New Clutch, No power on Evo 8
  200. Action clutch company
  201. ALS Throttle Kicker
  202. EGT Probes, Yay or nay?
  203. Oil cooler relocation
  204. What exhaust system is more durable?
  205. Evo 8 turbo upgrade
  206. CBRD radiator questions
  207. Radiator recommendation for Stock EVO
  208. strange noise under low throttle
  209. over boosting and catch can question
  210. engine build
  211. Another decel noise thread - opinions please
  212. Oil Thermostat Issues???
  213. Evo 8 Rs ticking noise??
  214. Engine dies upon release of key to "run" position
  215. bearing noise from serpentine belt area after timing belt swap
  216. Modifying buschur double pumper for one walbro 485
  217. Balancer tensioner pulley- Install with "lip" facing in or out?
  218. What is round sensor in front of radiator/condenser?
  219. Quartermaster Race TOB issues. PLEASE HELP!!
  220. GSC beehive hi-rev valve springs
  221. Aluminium rods?
  222. unknown brand oil pressure switch on evo8
  223. Removing Mivec cam plug
  224. Anyone use king engine bearings?
  225. Is my BOV faulty??
  226. 0 PSI oil pressure! Rebuild?
  227. Help
  228. Shifter Cables or Clutch Fork?
  229. GSC Race Shaft and Oil Pump Gear
  230. small radiator+stock fan, anyone done it?
  231. Forward facing turbo
  232. weisco piston ring correct orientation!
  233. Help deciding on intake manifold & tb
  234. What is the pump gas record for a 6466?
  235. Car won't start in the cold
  236. Want a 4g64 bottom end.
  237. Just had head oringed does this look ok?
  238. Got my 8 head back !!!
  239. evo 6 stock turbo 29psi
  240. ACT clutch
  241. T3 SS or T3 TS?
  242. TB Shaft Seal or just Dirty?
  243. Is this compressor surge??
  244. Need some help with oil residue spots
  245. Cbrd bbk lite ported
  246. Track use with MAP O2 Eliminator
  247. Hybrid Turbo
  248. Some small problem. Help?
  249. How Bad? Compression Numbers IX
  250. Cold start up -> car don't want to reach target RPM
