- 2.0L OR 2.1L help me figure this out.
- What will this do WHP wise?
- injector resistors location
- weird clutch problem
- Stock BOV fluttering at altitude?
- clutch pedal vibration (help!)
- Best mod ever!!!
- should I install injectors?
- Boosting up to 30psi?
- help me
- weird clicking sound at idle, help!
- Did valvesprings and studs today have question
- Engine sputter at WOT?
- possible immobilizer issue
- Let's talk about oil a bit 0w-30 or 10w-60? Stock motor.
- Output shaft removal, clutch install HELP
- BOV noise
- 60k maintenance
- Cams on stock Turbo
- Magnus v5 intake + Boomba 75mm TB = Problems
- Amsoil Intake Air Filter Review
- Need Help
- People with a v band exhaust...
- o2 Sensor = Really bad?
- Kellford 272s
- ACT clutch kits..
- Evo going super slow and throwing MAF codes
- How often do you chande your oil on E-85
- Clutch Masters New 850 series twin disc?
- Is it neccessary to o-ring head??
- oil filter housing question
- oil return fittings for precisions. Where to buy asap?
- Question about AFTER Turbo Install
- 22 psi WGA?
- 80mm dia resonator ???
- innovate wideband random readings
- fp red injector size
- act hdss
- Where to get 02 Dump?
- Missing transmission plug?
- Stock Water Temperature Gauge Repair/Replace
- transfercase leak
- Weird clicking noise when i press gas pedal
- Help with MIVEC camgear
- Any company make this???
- where can I find good lifters for not too much money?
- ACT Clutch Problems today...
- Sleeving an Evo 8-9 block
- So, I switched to AMSoil. Rattle rattle...
- spark plugs
- Boost leak test... WTF?!?
- Fuel regulator
- New noise
- Whining noise when AC is on?!?!
- hallman mbc question
- Methanol Affecting Wideband ???
- Spec clutch for evo 9
- Valve Stem Seals
- Boost for stock turbo
- Low oil?
- Who runs Kelford 280's?
- kia or evo block in 4 cylinder dragster
- can someone please confirm arp torque specs
- Looking for shop.....
- JDM Evo VII in Thailand- input/feedback on planned mods
- aftermarket oil sump
- Throwout bearing noise? Could clutch adjustment reduce it?
- Install Valves or not. What to use?
- Prepping Evo IX For Launching
- MBC info
- HELP GUYS where is located the fuel filter????
- FP Green(16G 10.5) or AP TME 20G 10.5
- perrin exhaust/ perrin downpipe. test pipe??
- What happened?
- Megan DP issues out of nowhere
- Bigger turbo on stock pistons an conrod
- Balance shaft bearing install, Any tricks?
- need Downpipe to match with my Blitz 3" cat-back
- Fp green 73hta
- Turbo Evo 9 80 series
- Wheel hop launch, now I'm binding/popping on turns (help diagnose)
- HTA Green vs. BBK
- AVCR not displaying boost.
- how to wideband?
- RC 1000cc OR RC 1200cc
- SKUNK2 PRO SERIES 68mm TB
- Valve Train Install
- I have lifter ticking but im not sure what it could be. i think it may be a collapse
- Evo8 vs Evo9 bov
- JE Pistons Pro Series FSR Forged Pistons 22mm pin 4G63 DSM
- boost gauge and vacuum readings dilemma. car runs rough.
- Schooling on MAP Sensor, and Boost Controller, please.
- What parts exactly do i need to to have a evo head to run high and high rpms safely?
- removing oil pan
- Lean, Low Idle.
- Anyone have problems with low idle stalls?
- Replaced TC, found a leak, replaced o ring and seal....still leaking!!!!!!
- Want to change the turbo but without changeing the Pistons and conrod
- Low Tranny fluid?
- Spark plug recommendations?
- problem with evo2005
- Red turbo, 80mm w/ 35R blade
- Does a short shifter really wear synchros faster?
- 5 speed to 6 speed mr tranny question, HELP!
- Engine cutting out!
- Quick Question
- Anyone running this Blitz BOV VTA?
- noob question about bov and intake
- how much HP increase with cams?
- stock turbo, larger intercooler creates more turbo lag?
- Willl a JDM altered muffler work on a stock bumper?
- Intercooler Questions
- timing cover markings help
- Car keeps over-heating even after new thermostat, radiator cap, and head gasket
- NEED HELP !! clutch not fully engaging..
- Did I F up my clutch??
- Clutch seized!
- SparkTech NONCDI now tested to 700hp!
- ???Does the new HTA Green hold boost like the RED???
- Best core size for building my own intercooler?
- HELP!! Loud knocking from engine..
- DIY Transmission Re-Build Tips
- $1700, what power mods, why, and where?
- What Exhaust upgrades?
- MR BOV question
- HKS Turbo Kit owners with Cracked Manifolds
- sudden bog at high rpm??
- color of lightweight shockproof
- help weird noise
- hot side turbo questions
- when does fuel filter need replacement?
- *** TAK33r / TAK330r CBRD Turbo Owners ***
- Shep conversion help
- Power Steering Delete Kit
- GT35r vs HKS 3037s >which's better for my evo?
- Cheapest Place to Find Front Wheel Bearing
- When you think it's the lash adjusters, but it isn't...
- Downpipe hanger Bolt spec's
- Cylinder Head Tech
- t case/ center diff/ tranny fluid parts needed. sure its been covered. sorryyyy
- Looking for a certain type of shift cable bushing
- O2 signal wire
- Running @10psi?
- A Man, An Evo & 3grand
- 780cc enough for red??
- clutch upgrade opinoins?
- Fuel Cut? Boost leak...
- Head Gasket Issues
- JVT Racing TBE, cheap!?!?
- P0420 after running race gas mix...
- what should i see for compression? 9 mr
- Lesson learned on Boost leak tests
- problem boosting past 7psi
- Timing belt noise.
- LOUD Timing Belt Noise
- Evo 6/7 Clutch Issue
- Coolant under the car ...
- What Donut Gasket for Meagan Racing 02 Housing?
- what are the best spark plugs
- Which one to get?
- Should I build my bottom end? Reliable DD?
- BOV reccomendations
- Potential numbers from decent tune?
- Question about Axels
- Licp help
- Ecu wiring diagram
- can i put my ETS UICP in without messing up my tune?
- Just installed new clutch/flywheel
- Kelford 280/272 Cams on a IX
- Need help!!!!!!!!!!!!
- FP RED,,,80mm OR 63mm Stock >>??
- Piston Choice for Track day / Street 450 hp
- What mods to get daily driver 06 mr !!!
- Hypertune Intake Manifold + 77mm TB
- Started to hear a noise..
- ACD lights on / weird warranty issues
- adjusting tps on throttle
- waste gate set at 15psi?
- ATS/Carbonetic clutch
- So much for my AMS LICP
- What is Evo 8 rocker cover made of?
- HKS cams.. way to identify? 272, 280 etc?
- evo 8 evo 9 throttle swap
- ACD lights on
- Cooling system issues
- DV turned backwards..
- Is this normal? (pulley picture)
- Bloe off valve question. Please help
- 2.3 stroker on 85mm bore?
- Show me your setup for high elevation
- walbro Fuel pump whine Help?
- Kevin@MellonTuning's Stock Evo IX Build with pics and DLL dyno numbers
- Transfer Case Upgrade
- Idle Stays At 1200RPM
- TPS wire diagram for Q45 Nissan Throttle body
- Very Helpful BOV Sound Video
- Twin scroll vs t3
- 2 pP0300 codes.. HELP!!!
- 02 Dump; EMP Vs QTP
- Crower Valve Springs & Ti retainers ??'s
- short clutch release rod
- Clutch pedal stuck!!!
- Turbo Kits.... Which one do you think
- Evo engine twin turbo
- Lets talk oil quality and why?
- 03 evo 8 transmission Problem Help!!
- Boost leak locations..?
- Transmission inspection cover sealant?
- Clutch Pedal Adjustment problem
- infamous 5th gear grind
- Relocated Battery Now 3 acd lights when running, on= can change setting
- ANYONE KNOW HOW I CAN CONTACT Driven Innovations
- kevlar belts
- 4th to 5th problem
- What are the specs on a evo 8 IC HELP!!!
- What is this part!?!
- Another reason I love my wife
- transmission leak!
- Center Diff Question?
- What is the OEM cooling fluid?? What do you use??
- Cat Question
- HELP transfer case problems!!!!
- ac problems!
- BBK Full, FP Red... Another Thread!!
- Boost trails off after EPM Dump Install
- Planning for the future
- I need help car wont start
- Can 4G63T parts work on the 4G93T ???
- Grinding sound in neutral...
- which clutch with my red and aquamist setup?
- wiped out maf and now car doesnt run right until wot????
- exhaust mani & 02 housing
- squeak coming from pulley
- Oil return line leak?
- HELP! AEM intake problem??
- Stock intercooler sprayer? VIII/IX owners chime in plz.
- URGENT: No 1st or 2nd gear... uh oh!
- FP Green HTA Vs FP Red
- buschur race fmic question?
- Should I recirculate HKS SSQV if it doesn't stall when VTA????
- quick advice-on fp red
- What's a good way to clean the inside FMIC? What's the best solution to use to remove
- Beatrush Undertray and EPM o2 Dump
- EVO 8 Compression
- Stroker build opinions please
- Rattling question
- no power under 3k!
- whats an ok price to charge for this work?
- Drivetrain Thump
