PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 [212] 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Which is better for auto x track?
  2. oil in my turbo inlet pipe?
  3. Anyone running a Gredyy Evo SP2 Catback?
  4. where did you mount your egt probe?
  5. Is my MAF backwards (PIC included)
  6. Buschur stage 1-MBC boost spike
  7. Mitsubishi Mods
  8. Magnus 2.4 liter stroker kit and fully built head
  9. Speed sensor, what happens when you disconect it??????
  10. Clutch problems, help!!!
  11. Ralliart Downpipe
  12. Dyno Video on STOCK TURBO....
  13. My post below is of my DYNO results....
  14. Vid of my EVO8 w/stock turbo all (buschur)..
  15. Evo Cams
  16. Turboxs TB exhaust sound clip anyone?
  17. megan racing
  18. MR with intake only - great power over '03's
  19. aps cai filter replacement?
  20. Should this Be capped off Greddy TypeS
  21. Dissapointed at the dyno
  22. Verdict on my oil leak(s)
  23. can any body help...
  24. rnr turbo kit
  25. Big turbo guys in here
  26. Has Any One Hit Fuel Cut On Their Evo Yet. If So, How Did You Go Arount It?
  27. will I lose settings on ebc if I disconnect battery?
  28. hallman pro MBC help!!!
  29. got ebc question
  30. What your evo oil pump should not look like
  31. Best Drop In Replacement Filter
  32. I got Intake, injen with i/c pipe. Any INSTALL Sug.
  33. acd question
  34. What size injectors?
  35. battery voltage at idle and cruise???
  36. Motor Mounts... do you want em?
  37. Zeitronix O2 simulator
  38. Difference between O2 housings?
  39. when are bigger injectors needed?
  40. 298 WHP at 22 psi on dynojet seems low?
  41. Is my evo on 3cylinders...
  42. Help! Car threw 2 CEL codes...
  43. Fujitsubo rm01a pics anyone?
  44. What are these sensors for?
  45. Timing Belt question
  46. Which 4G64 is best for EVO?
  47. TurboXS intercooler same as Hyperflow?
  48. Error code Po335, need help, car will not start
  49. need help figuring out where to set boost at
  50. Boost line question
  51. want new 6th gear
  52. Downpipe with cut-out
  53. Question on upgrading the intercooler?
  54. 350whp on Pump- possible witih stock cams, ecu, fmic, and turbo?
  55. Intakes
  56. Defi Boost Gauge Accuracy
  57. 2005 Stock Boost Spiking (2004 Also)
  58. Not sure what to do
  59. Clutch Slave Cylinder Bleed Guide?
  60. My project begins...
  61. Stock turbo - what boost will it hold at redline?
  62. Removing stock airbox cover good or bad?
  63. Need Help - Low boost in cold weather??
  64. looking for picture of turboxs cat back
  65. I got dynoflashed, now how muich of a gain is a boost controler?
  66. Proven Intercooler Install
  67. Coolant Leak???
  68. Manual or Electronic Boost Controller?
  69. Jet Hot Coating VS Heat Wrapping
  70. stock e3 clutch pressure plate
  71. SES Random Misfire Fix
  72. Buschur made me an Alcoholic !!!!! Dyno results
  73. Is there big difference between 18 to 20 psi
  74. max boost on stock turbo
  75. Blingin' eBay Catch Can Warning
  76. boost problem
  77. jdm evo III swap into a 98 talon tsi
  78. What's the best replacement Clutch?
  79. 10.5 hot side made a huge difference today...
  80. o2 housing, anyone make one with a wastegate dump??
  81. hallman or buscher manual boost controler
  82. evo/// motor
  83. Will the upgraded 05' turbo bolt-on to my 04' RS?
  84. EVO Replacement Clutch Question
  85. Question for Alcohol injection vendors:
  86. Where to go from here ?
  87. Ok i feel really bad about asking this...
  88. Boost controller problems
  89. Does anyone know where to get new bearings for T-CASE ???
  90. Bad Mass. gas burns my...
  91. Engine oil question.
  92. cat-back Vishnu vs Perrin
  93. Diffs making sound?
  94. Anyone heard of RVM BOV
  95. Am I running rich ?
  96. Best modifications for keeping stock exhaust
  97. Clutch install need HELP!
  98. Any feed back on the AMS turbo back???
  99. which HFC for hks downpipe and hks hiper.
  100. 3000GT Final Gear Ratio ?
  101. arc induction box
  102. Flat spot in between gear change
  103. magnaflow ti exhaust(where to buy)
  104. HKS carbon ti exhaust installation
  105. Ok, you fix an mbc...
  106. perfect remedy for loud exhausts...
  107. Check Out My Custom Header and Turbo Install!
  108. Change of plans
  109. Car dies when decellerating...
  110. Car dieing in 1st gear/slow speed..
  111. ANYONE HAVE the RMR Premium 3" Cat Back Exhaust
  112. free horse power? simple garage mods?
  113. Intercooler piping worth it?
  114. Clutch pedal and engagement problems
  115. Exhaust Fluttering
  116. New Clutch, weird
  117. Changing transfer case and rear diff. oil
  118. please help with bov question
  119. Any Wideband Suggestions?
  120. Need Some Advice
  121. Engine Management HW
  122. evo fuel pump
  123. please leave feedback on vishnu exhaust
  124. Question on Walboro fuel pump?
  125. A question about hoses
  126. Is a ecu re-flash or a piggy back computer necessary?
  127. So the EVO is going to the dealer on Friday...
  128. Crank HP w/ a few mods?
  129. Nearly hit the windscreen at 130mph
  130. Standard Buschur FMIC
  131. HKS EVC HIts boost cut @20psi HELP!
  132. Does anyone have a low profile fan installed?
  133. wondering about numbers
  134. 4 AVO Turbo Back Exhaust Systems
  135. Turbo kit upgrade = LSD/Transfer case problem?
  136. Oil Leak.
  137. where can I get the SS pipe for Apexi intake kit?
  138. GT35R & SAFC-II dyno sheet & drag street
  139. intermittent 5k RPM launch limit
  140. why are most people using the Greddy bov?
  141. Have you ever wondered...
  142. What is this?
  143. RnR/HKS Carbon TI Exhaust
  144. Upgraded FMIC and piping
  145. Exedy Clutch Problems
  146. Burning Smell
  147. HKS 264 or 272 cams ?
  148. Should i get a turbo back exhaust with a cat delete or high flow cat?
  149. Are reflashes worth it?
  150. Help Me Choose Best Exhaust Setup
  151. Turbo Upgrade Kit...
  152. Stock Air/Fuel Ratio??
  153. what size injector do I need?
  154. type of i/c and piping
  155. Greddy type S
  156. Guess my HP increase!
  157. Buschur FMIC + Injen upper pipe???
  158. WTB: Used/New OEM EVO Parts
  159. VRS exhaust or BR?
  160. Helix ic piping and hks intercooler
  161. Sound difference between UR 3" cat delete and HF cat?
  162. PeakBoost T3/T4 Equal Length Manifold
  163. If you have had t-case failure please help
  164. Stroker questions
  165. Question about gt35r or similar turbos (no not spool times)
  166. how much power...
  167. 4G63 Getting Fresh Air (and the turbo too)
  168. EVO 4 wiring diagram
  169. WHat should i get?
  170. Titanium Exhaust Q
  171. Evo Tb Exhaust/intake Dyno
  172. Difference in '04 and '05 turbos?
  173. Kevlar vs Carbon?
  174. Ethanol gas in the 4G63
  175. Camshaft pivots? gears?
  176. Loud licking....and not lifters either
  177. New snail....
  178. Best way to install 2 boost gauges
  179. 2.5''------vs-----3''
  180. did Greddy fix the type S boost contoller yet?
  181. Emulating XEDE boost curve w/ebc on Dynoflash/Buschur setup?
  182. Cams dyno charts inside
  183. aftermarket radiator question
  184. 20G vs GT3071R
  185. Factory Fuel Pressure Test Port?
  186. Exhaust
  187. hallman boost controller ?
  188. Big Turbo - Which BOV?
  189. 264's or 272's or combo???
  190. is there a turbo that spools under 3000?
  191. TC question again.
  192. anti lag, misfiring system??
  193. APS BOV - Who's got 'em?
  194. ARC Intake
  195. all of you who've wondered about the forged pistons
  196. 05 MR 700 miles Clutch broken
  197. ACT CLUTCH OWNERS, Clutch Adjustment?
  198. Clutch Adjustment/ Master cylinder info
  199. Exhaust picture thread - show off your cans here!
  200. **3" Exhaust systems**
  201. GSC Power Division
  202. need to see state ref
  203. Who can re flash an EVO 7 ECU ?
  204. Good Boost controller ???
  205. Problems with Transmission in the Cold?
  206. Will a 1g BOV work on a Evo??
  207. whats the best exhaust for my street legal evo
  208. EVO IV engine performance mods - need help
  209. Which turbo upgrade kit?
  210. Best Turbo for midrange power?
  211. installing cam gears will make the belt slip?
  212. Help decide what to do next
  213. cam question
  214. Iridium plugs - any downside to using them?
  215. cams, oh cams....
  216. exhaust
  217. dark oil?
  218. Quietest muffler for custom exhaust
  219. evo under construction!!
  220. Kinetic Intercooler, New?
  221. where to get Lower ic pipe.
  222. how do we run such high EGT's?
  223. Loud Injectors
  224. does your evo have lifter ticks
  225. Need help or suggestions with turbos
  226. Short throw shifter not short a$$ shifter
  227. Walbro 255 lph Pump Concerns
  228. what causes this tranny noise and p0300
  229. torn between HKS EVC V & Blitz SBC-ID3
  230. my situation (what else should i do)
  231. Boost Gauges, Vac/Boost or just Boost?
  232. Misfiring issue
  233. Most stock looking aftermarket Exaust?
  234. 2nd gear grind
  235. Car cover that fits the spoiler?
  236. Boost controllers? man or elect. which one?
  237. Problem, please help.
  238. Getting whinning in all gears
  239. Hks cam question?
  240. Test pipe smell??
  241. exedy carbon double or triple?
  242. New TC - strange sound -please help
  243. Apexi Power Intake Kit with Induction Box, got one?
  244. Best way to Prime motor?
  245. comparing manifolds
  246. 4000 rpms - Help
  247. has anyone tried the xs engineering amplier power pack
  248. Innovative 60-1 HIFI BB Turbo for the EVO?
  249. Who Is Top Speed?????
  250. Groaning sound when downshifting?!?!?
