PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 [159] 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Bestest Question Ever
  2. Alki Injection... If you were to ....
  3. Divided exhaust manifold and WG... please help...
  4. Does anyone have the Monster Sport Power Filter?
  5. Customized Bolt-On GT35R Turbo
  6. Performance advantages to thermal coating?
  7. Hotside numbers?
  8. pulled valve cover off cam mystery numbers EP4604
  9. n00b
  10. TD06-20G vs. 50 trim
  11. injectors or valve ticking? vid inside.
  12. cammed evo, slow?
  13. Mobil 1 to Royal purple
  14. They make a 2.4 stroker?
  15. 16g question
  16. Garrett vs. HKS Turbos
  17. plx m-300 narrow band usage=p0031 cel
  18. Exhuast testing Round 2 - HKS vs Buschur
  19. ARC Induction Box Pre/Post dyno...
  20. main studes
  21. Invidia Manifold Released
  22. O2 housing ???'s
  23. anyone got picture of knock link sensor installed?
  24. valve spring install
  25. clutch for my IX 6 speed
  26. New Owner, Modded EVO
  27. Weird boost problem....Help
  28. Does anybody make a direct bolt-on DBB 50 Trim for the Evo?
  29. Intake blew off ..... Need Help Plz
  30. Paculiar noise at decel??
  31. do i need this for oil pressure guage installation?
  32. stock 16g flow lb/min.?
  33. tricking the o2 sensor with catless exhaust??
  34. gt3040r???????
  35. vishnu set up
  36. EVO VIII pain to get in reverse...
  37. Hks Clutch Gd Max Twin Plate
  38. Authority Cat Back quick help
  39. how long should it take to install these????
  40. how long should it take to install these????
  41. Nitrous?????
  42. Is this realistic...
  43. Is this my transfer case? Decel noise
  44. Top transmission bolt problems
  45. not boosting right...
  46. cammed evos...
  47. who has revolver cams, meth, 20g9-5
  48. 20G injectors
  49. Gsc 272/264
  50. evo8 with evo9 turbo
  51. Turbo Spool Fluttering
  52. How to tell if a turbo is bad?
  53. Car runs rough...
  54. Injectors
  55. White Rabbit - Evo Green
  56. gotta love 5th
  57. Perrin 3" hfc v/s Helix 3" hfc
  58. Atp Kit/pruven Dyno Results!!!!
  59. bov flutter
  60. HKS SSQV Recirc kit
  61. Weird Observation with a not so boost leak.
  62. What about these exhaust parts?
  63. OverBoosting
  64. compression tester tool
  65. custom exhaust idea
  66. Can you Warp the flywheel beond repair?
  67. Tranny Fluid mixture
  68. ix mr short throw shifter
  69. Pros/Cons of 100%meth or 50/50 mix
  70. Are Ferrea Dual Valve Springs, Seats and Ti Retainers a drop in affair?
  71. donut gasket
  72. Evo 9 20g Upgrade to Buschur
  73. Buschur DP & UR Testpipe ?
  74. 2003 Evo Syncro Grinding?
  75. boost leak.. need opinions...
  76. ARC intercooler.... bumper bar?
  77. Power Enterprise RX6R Turbo kit
  78. weird clutch noise
  79. Oil starvation during hard cornering
  80. Cheapest OE Timing Belt Kit?????
  81. Tial 38mm Wastegate spring?
  82. turboxs tbe install questions
  83. Very bad boost creep and boost wont go down.
  84. Supporting Mods For 50trim?
  85. EVC, Tial external wastegate hook up
  86. Evo VIII vs Evo IX gearing
  87. Help, RPM DIPPING.
  88. 2.3l build questions
  89. E85, EVO Green.................
  90. Titanium TBE
  91. Mahle pistons, who's using them in their evo engine?
  92. Water pump
  93. porting exhaust manifold
  94. Exhaust problem
  95. Spooly Jobby
  96. Do you have dyno graph for stock air filter vs KN vs Works?
  97. Power and MPG DOWN. Help Greatly Appreciated!
  98. Power and MPG DOWN. Help Greatly Appreciated!
  99. Car lost power in 5th under boost for a second?
  100. Rpm Boost On Gt30, 35, And 37?
  101. Whats the Max boost level on 98 Octane
  102. Best location 4 >> Oil Temperature Sensor ??
  103. serach search search!!!
  104. 05 MR Drive fluids confirmation
  105. Anyone make 340TQ or more at 3000 RPMs?
  106. E85 and 20g9
  107. 650WHP on E85 and Meth!!! at 36lbs of Boost
  108. Unhooked MBC still hitting 25psi???
  109. IX engine technical specs
  110. Buddy Club Cams for IX
  111. intake noise.
  112. Stock Boost PSI for an IX
  113. My Winter Project... 25.1E RWD Evo 8
  114. Buschur Racing Dp and HFC question
  115. No boost Leak, but still low boost?
  116. Bleeding the ACD
  117. Does a IX Transfer case fit on the VIII
  118. Gear Speed sensor?
  119. 20/fpgreen
  120. need as many pics of wr9 20g-9-5 as possible
  121. GSC S2 cams for IX
  122. General question about boost
  123. High EGT's
  124. anyone with forge dv please help.
  125. Problem with Boost Creep...??
  126. Agency power ti exhaust?
  127. Who's 50 Trim Should I go with?
  128. Turbo Spool Tables
  129. Mass Air conversion, to VTA 100% and no problems
  130. tial bov w/o ams ems?
  131. could the "Death Whine" NOT bet the transfer case?
  132. jun cams,valve springs and retainers
  133. What does it take to put a EVO IX turbo on my 03 EVO
  134. 12 flat
  135. IC sprayer pump
  136. Main Bearings & Rod Bearings
  137. What is the thread size/pitch of our knock sensor?
  138. Carbonetics Triple Plate any good ?
  139. Greddy Problems: Profec B Spec II Not Holding Boost
  140. BOV ??'s
  141. Precision 6152E (630hp rated) ????
  142. Pwr Intercooler Question????
  143. different ebay 02 housings / turbo outlet pipes
  144. Anyone tried: Forge WGA &20G-LT?
  145. Stock turbo and meth.
  146. Switching Exedy Twin Plate discs???
  147. where to find Jun cams
  148. cutout question
  149. Will the ebay o2 fit an 06
  150. new exhaust for new evo ix mr
  151. Ordering parts
  152. evo engine troubles!! please help!
  153. Anyone Confirm 8 and 9 FP the Same???
  154. Megan Racing Manifold back tbe??
  155. cosworth stroker motor ?
  156. can someone explain this to me..
  157. ATP Kit
  158. Fuel Pump
  159. Dynoflash@Chicago 2/10 Tune results
  160. walbro 255
  161. Cat heat shield exhaust install
  162. soo Green on the way....now what?
  163. Vacuum readings after move to Denver
  164. Exhaust cam timing on EVO IX with aftermarket cams
  165. 329whp/318tq - STOCK BOOST!!!
  166. Blew a plug out of my head.
  167. how much boost
  168. Fuel cut with stock boost lines?
  169. BOV to the atmosphere Solution
  170. Clutch Question (Tilton and Quartermaster)
  171. T51R/GT42R Turbine Differences ?
  172. Valve Cover Oil Leak
  173. fuel pump question
  174. "Hairdryer effect" and aftermarket FMIC
  175. Technical Head Question...
  176. NOS injection thru UICP??
  177. Blowin Smoke
  178. Exhaust manifold bolts
  179. 2.3l stroker kit
  180. Oil leak...
  181. Well Dave maxed out my turbo...
  182. rough idle?
  183. Fastest EVO IX turbo cars??
  184. collection of intercooler fin pictures (ic insides and outs)
  185. What turbo is used on this vehicle to get 600hp/710ft
  186. The thoughts of having a 150 mph trap speed "green" EVO.
  187. gt37r on the street?!?
  188. Thanks IveyTune
  189. LaG LOL
  190. o2 sensor 2 black wires???
  191. Valve blow by?
  192. while racing i get fuel cuts? how to solve that?
  193. Hks Mivec Cams....
  194. Evo 9 power w/o tune
  195. What are you afr's on pumpgas?
  196. Idle Video of GSC S2 Cams / Vavle Springs Installed!
  197. injectors OR cams???
  198. FPR hose
  199. Crank sprocket bolt won't come loose
  200. what all is needed to install an evo-9 turbo on an evo-8???
  201. 06 GSR drivetrain noise & shuttering
  202. Dyno'd- video- evo ix mr
  203. evo 9 clutch job issue,
  204. flashed fp green.
  205. Would adding a larger Perrin IC and hardpipe kit change
  206. Water Incetion vs Race Fuel
  207. Chirping Spool from exhaust leak...
  208. How much knock if any with stock ecu
  209. Boost gauge tap in point
  210. Turbo Install Completed
  211. head question
  212. Fuel Pump...
  213. ticking after clutch install!!! help
  214. Center Diff Wet!
  215. 605 bhp on Pump (99 RON)
  216. Ralliart Ring and Pinion
  217. Please Help Car Running Rich At Idle
  218. Blue By U Motor Build (Pics 56k Beware)
  219. Buschur coated turbine housing or 20g
  220. how do i get a higher sample rate with evoscan
  221. Injen intake and uicp or HKS RS or Just Apex'i?
  222. 23psi stock EVo...
  223. New Rear?
  224. Test pipe
  225. JDM engine
  226. Cam Gears....any real differences?
  227. I dont want to buy full race headers!...
  228. Need help... unknown error
  229. Intercooler piping....and Q's?. Vendors ps feel free.
  230. Fuel Line Locations?
  231. Velocity stacks in air filters
  232. HKS vs Comp Cams?
  233. Pic request of ring and pinion
  234. Exedy Clutch Stage 1
  235. Why do I have a boost leak?
  236. Exedy Twin Plate Clutch Knocking Noise
  237. Rough idle
  238. is rear motor mount worth the trouble?
  239. Ebay wastegate with inter cooler kit.
  240. Next Step??
  241. Umm....Something happen, engine died
  242. New headgasket need for cam install?
  243. HorsepowerFreaks Evo8 Complete Fuel System is Released!
  244. Immobilization code????????
  245. ams intercooler feedback
  246. ever have this happen?
  247. big problem with boost! plz help!
  248. Broken balance shaft belt=OUCH!
  249. Weird RPM spike.
  250. 2.4 block where to get it ?
