- Competition stage 3 un-sprung vs Exedy double HD
- QM 6 leg wear question
- Evo 8/9 shimming specs for the 5 speed
- Proper fluids?!?!?!
- Missing Fuel Pump Peices
- rear diff noise and inner cv play!!!
- Advice brand for evo8 valve springs and valves?
- What is standard thickness for evo8 engine head gasket?
- Evo turbo upgrade kit
- FIC2150CC single walbro e85 ?
- Transmission problem! Help needed!
- Transfer Case Beaing for Diff Needed!
- Input on the 5858
- choosing IC
- idle speed problem
- Code P0134 Problem
- Did Injen change their intake filters?
- AMS balance shaft eliminator vs others.
- Can't bleed clutch
- Can't get TOB to Release
- Help timing a 2003 galant 3.0 v6
- EVO 9 Lean WOT
- Help with cylinder head removal (evo8)
- Compression Test Results, any advice?
- fueling problem
- No spark, no fuel, and no CEL after running perfectly
- Bad Omni 4 bar map sensor
- Easy way to remove the rear diff.
- Crankcase vent question.
- Hyd TOB compatibility
- Oil in Coolant Reservoir
- flutter during spool up or is it?
- ACD lights when balance shaft is fixed
- Random/intermittent loss of power.
- Timing Belt Snapped... Need New Engine
- what could potentially break at 650 awhp?
- What would you do if it was your damaged FP Black?
- Random misfire code p0300 help
- How can you tell when your oil pump fails?
- Weird humming/grinding noise at 30-40mph
- Weird Noise around 30-40 mph Info on car?
- Installing performance injectors
- how to install evo 8 clutch on a evo 4
- Review wanted. competition clutch stage 3 2300 segmented carbon disc
- Clutch install....needs serious help!!!
- Exedy triple disk question
- is this hotside still good? slight damage pics
- Gearbox mushy, has to be guided back out of gear
- Turbo Suggestions on Stock Block
- Evo 8 HS on a Evo 9 compressor housing
- Atp gtx3576r
- 550whp goal!
- Max power on FIC1100s running E85?
- Idle shut when release throttle
- can I use ARP lube ?
- Getting locked out, tranny doesn't feel smooth at all
- MAP EF2 boost creep troubleshooting
- How to identify a Evo 8 or 9 T-case?
- Oil/Grease in Rear Axles?
- exedy triple upgrade??
- 5858 T3 SS or 5862 T4 TS
- Clevite or ACL ???
- 4g64 block vs. 4g63 block
- Has anyone tested FPs 3073R HTA ?
- Quick question on ACD lights
- Removing accelerator cable..?
- Help - What is this
- 2.4lr build help
- Radiator Leak
- Valve seals in engine gasket set, 16 black and 8 red????
- Evo 9 Trubo
- 30-40 Thousands off flywheel?
- ACD tuning remap - First drive mini review
- valves ticking
- Tear down video of STM's, BR built 2 liter.
- Tear down of "Bricks" BR built engine after years of abuse.
- Adjustable t-case. Is it possible?
- other trans options??
- Need help identifying clicking noise in the head
- Kelford 290 Cams
- Spark Plug Question
- cam sensor
- Spoolinup DIY COP kit instructions
- Oem 2.4l crank weight
- What's this I found in my sump
- Throttle position sensor question
- Evo 8 engine oil leak
- Quartermasters 8 leg race clutch disc pad thickness?
- OEM or Aftermarket harmonic balancer on a 4g64?
- Valve and seat angles / Aftermarket Seats
- hesistating at WOT
- Half radiator mounting issue
- Evo IV 4g63T questions
- GTX2876r
- ARP headstuds install
- BR T3 kit and ETS FMIC
- high revs but mostly stock
- P0455
- Anyone ever used Castrol Edge 10w-30?
- low compression in three cylinders
- Fastest 1/4 with a GT3076r
- Oil lamp light
- is my walbro bad?
- 2 Issues After Clutch Install
- Compressor cover and turbine housing designs
- No Start issue Evo IX.
- Int. Parts 4 my 4!!
- No start after walbro install
- Is this buschur?
- Smooth as silk
- (Cheaper) Oil Filter Housing Turbo Feed Line Kit
- Alternative Venting from the Balance Shaft Inspection Hole
- Best timing belt for 650whp
- evo 8 suddenly will off the engine ,what is the problem?
- Stock block 6266!
- Whos DP is this? Brand*
- Building 2.1 with 4g64 block
- AMS evo 7-9 950R cast v-band turbo kit
- Have an Exedy Twin/Triple with a clutch fork stop installed?
- turbine cross section
- Erratic idle Evo 6
- drive train whine
- Can stock 8 cams sound like this?
- New to engine modding..
- Grimmspeed help!
- can u spot whats wrong here
- Evo 7 2001, No Spark , can't hear the fuel pump, engine cranks, but doesn't start!
- Fluid from Transmission in T-case?
- HELP, Grinding after engine shut off
- 2nd and 3rd gear crunching (Mainly at lower revs when shifting normally)
- Thanks Forced Performance!
- Input shaft bearing noise/issues
- Evo 9 mr 6 speed tranny
- HKS GTII 7460 - What to do?
- AEM vs Turbo XS intake
- exedy triple: resurface flywheel+dowels???
- Any idea on how much a stock TBE is worth?
- Which K1 crank to get?
- GSC S2 Cams Sharing...
- Complete ACD removal off 05?
- Do I need to bleed the ACD after removing the bleeder screw?
- Clutch Shudder?
- Exedy Carbon Triple Plate Clutch Disc Thickness
- Mixed messages
- Crazy metal hitting noise in head after exhaust mani replacement
- Clutch / Trans Issue.... Fluid Everywhere....
- Stage 2 competition clutch dead @5k!!!
- TiAL Q BOV w/ clamp/flange
- How to tell a Faulty Front NB02 Sensor?
- Clutch Issues?
- Need real life opinion: 6262 v 6266 on 2.0
- Evo Vii trany noise
- what is the thread pitch for the o2 housing spring bolts?
- Long Rod vs Short Rod
- Nisei mini battery kit
- maf to sd conversion
- Acd swap info
- Rebuilt my ACD Pump
- Guestimate max hp OG green
- AHH Help me with my shaft!
- transmission problems please help!
- Center Diff
- Not all intercoolers are created equal!! core comparison pics inside!!
- What is this?
- a lil trouble deciding on the ams clutch push conversion
- Turbo Howling
- Fuel pump won't prime with key "ON" but will with EvoScan...
- 5 speed to 6 speed swap questions.
- valve adjustment
- EVO IX Build Suggestions
- Front NB02 Replacement - HELP!
- TBE/O2 sensor question
- Simple Turbo Upgrade
- Clutch not engaging after clutch install.
- Only 8lbs boost..
- Best Test Pipe?
- bulletproof drivetrain!
- contacting CBRD
- Boost problem...AGAIN... Feels like vtec? lol
- 2 questions
- Building more boost - Launch Control
- Any full ETS exhaust? Or should I just get the Greddy comp. tic?
- No brakes after head swap/t-belt/cams
- our cars have a factory 3 port solenoid
- Turbo giving me trouble, ALOT!
- SWEET! Another blown motor maybe? HELP! *MANY PICS!* Start analyzing
- Mysterious overheating!! Evo 8 need help
- Broken valve cover baffle discovered
- Evo IX Injen intake
- Thinking about HTA73 Green...quick question though?
- bad vacuum, idle, air/fuel ratio. ?
- i doubt its the clutch but...
- Why only 28psi?
- Car apart, need help: spring clip on Throttle body shaft
- Vibrant MAF adaptor
- Car judders when shifting-cold
- Turbo possibilities
- Making plans for upgrading... What do you guys think?
- stock drivetrain
- Boost Control?
- Exhaust leak question
- Quarter Master 8-leg/ Push Style Clutch Issue on Stroker Engines
- another battery relocate question
- O2 housing good or no good??
- Cam identification question
- Throttle Sticking as high revs?
- Quick question on Evo7 oil requirements
- Is it worth it to upgrade my ic+licp?
- True Anti lag/EMS suggestions ?
- 1st gen fp green
- At what point will a -6an Head Vent become Insufficient?
- Anybody running Hks twin disk clutch
- Evo8 Speed Density Problem.. stalling/stumbling
- Help with WOT Surge issue?
- Evo starts but won't start up a second time for several minutes
- Destroyed Evo 4
- 6 puck question
- Most Power GT35R on C16
- GM 3-port BCS
- Can you fit a evo 7-9 front LSD into a Evo4-6 Transfer-case?
- Low z vs high z injector
- Evo IX MR Clutch Recommendations
- exhaust leak or boost leak?
- evo 8 turbo...need help
- HELP P0134 oxygen sensor replaced
- evo9 stock map sensor limit
- ID1000s SEALS O RINGS?????
- Turbo with a lag smaller and response better then stock?
- ACT Solid RIGID disc(unsprung) or ACT sprung disc?
- ACD & transfer case oil
- need some help!
- Are all gsr 5spd transmissions the same?
- Gearbox oil change
- Which clutch kit to buy?
- Whining noise coming from rear
- Fp Green Rebuilt kit needed
- gsc s2
- What is highest psi for stock evo 9 turbo?
- So did my turbo just commit suicide?
- Installed new clutch.. Car won't go into gear, help!
- will a dsm manifold work?
- Going E85
- What Fuel Pressure Should I Go?
- Darton Dry Sleeves.... Is it worth it.
- Valve cover internal baffle removal/reinstallation?
- Another Oxygen Sensor Thread
- Removing power steering pump belt
- DOes the Axle pop out when you take off passenger side front coilover?
- 4 bolt downpipe
- Fp green down! Need rebuild how?
