PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 [164] 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. should i get this lsd
  2. AMS 2.3 & GT35r on my IX, I need some advice
  3. New Evo MR need 400+whp??
  4. can new exhaust effect my boost?
  5. TO all Fidanza Flywheel owners
  6. HKS TT Type-0 ?
  7. GReddy EVO Upper Intercooler Pipe Install
  8. Problem with car...
  9. So why not E50, E75 or ethanol BUT E85?
  10. The E85 thread, talk amongst yourselves
  11. stage 3 turbo
  12. Quick Question...
  13. Twin Pump Install Pics!!
  14. Borla Cat-back rattle
  15. boost surging HELP plz !!!
  16. quick question about authority short shifter
  17. Bush surging help plz
  18. best fmic?
  19. Cheapest Place for Trans Fluids?
  20. Flooded the Evo....Please help.
  21. evo8 block in evo9 ? who has done this?
  22. So manifold cracked again!
  23. Turbo To4z Trade To Hks Kai
  24. oil leak...please help
  25. arp head studs install
  26. can't get transfer case back on
  27. O2 housing question...
  28. stock dv change?
  29. Clutch Problem
  30. How can you tell your oil pump is bad?
  31. Help with IX MR TBE
  32. Problem with car running please read and let me know what you thinks it could be...
  33. HELP no power to Fuel Pump car wont start
  34. EVO9 JDM rear bumper, the exhaust solution.
  35. Coated Intercooler Question(s)
  36. Tuned My IX...Finally
  37. Air "sucking" noise...
  38. Starter not spining
  39. ???????'s for folks with RS's???
  40. HKS clutch durability
  41. To the people with 35r and alky
  42. newb driveline issue 3rd to 4th grind,+ rpm issue
  43. throttle body MOD?
  44. E85 Ready!! with style :)
  45. Boost Profile Question...
  46. lookin to buy turbo
  47. DYNO EVO9 USDM Mivec map VS JDM Mivec map
  48. Hallman Evolution MBC help.
  49. Some teaser pics of my RNR Turbo Manifold (Stock Turbo)
  50. **attention All Vendors**
  51. PP0113, P0335, P0456 codes???
  52. Need your advise please... (spark plugs)
  53. exedy rebuild q's
  54. David Buschur should build a turbo like this
  55. Spark Plug question
  56. Braided clutch line
  57. Is this possible???
  58. NRR EVO covered under warrenty (POWER-TRAIN WARRENTY)
  59. whos running a megan dp?
  60. boost gauge may have crapped out
  61. hot better than cold?
  62. high pitched sound
  63. Anybody want to trade 880cc for 1000 cc injectors?
  64. HKS Type R intercooler
  65. what is wrong with my turbo?!
  66. New Option to Significantly Reduce Turbo Lag
  67. 2.3 Stroker/GT35 vs Evo IX 20G
  68. clutch install!! HELP
  69. Did I piss off the knock sensor?
  70. gutting stock cat
  71. Ti - Ti exhaust tone comparison
  72. help cat back install
  73. Best clutch for 500+ AWHP and high rpm shifting?
  74. Heavy pressure plate
  75. RMR Inter pipes/Agency BOV
  76. Is there a difference in brand of injectors?
  77. Greddy exhaust SP2 or EVO2 which one?
  78. Please give me your opinions on this pictures of my transfercase!
  79. Has anyone built a intercooler like the Runduce Evo?
  80. Fuel Pump Ring Studs
  81. HELP!! Oil Leak from valve cover!
  82. Hks Oil Cooler Kit On Evo Vi
  83. Ralliart ACD ECU
  84. 2.3L w/ GT35R on brand new evo9....how much am i looking at? i want reliable set up~
  85. Install gone wrong?
  86. Phenolic Intake Manifold Gasket...anyone use this?
  87. O2 housing
  88. IX boost tapering w/ hiflo cat
  89. Turbonetics 62-1
  90. Upgrading EVO Rods & Pistons w/o removing motor from car????????
  91. Exhaust comparison test
  92. What would you get first
  93. Evo 9 Turbo Flow n Actuator
  94. 5 speed clutch'flywheel fit 6 speed?
  95. torque!?
  96. alky and explosion in sheet metal intake manifold
  97. who sells the new RSR dp that fits IX
  98. Evo IX IS there any point for the 20G-LT
  99. Clunky noisy... lol
  100. cluth restrictor
  101. over boosting with ported manifold
  102. Surging on the standard VIII turbo
  103. early rev limit/fuel cut off at 5600rpms?!
  104. cosworth cams
  105. bc springs and retainers
  106. Rear Diff. Fluid change
  107. Weird noise after cams installed
  108. Blitz Dual SBC Spec R??????
  109. vacuum at idle.
  110. water pump leaking again
  111. Agency Power Gt35r and 30r turbo kit for evo???
  112. It happened:(
  113. TTP: dyno plot for your latest setup
  114. 500whp Evo VIII on pump gas (93 octane)
  115. Knowledge=Power : Brand new car, fresh motor, how do u like to break in?
  116. CEL with MBC install?
  117. DBB 50 trim Full boost
  118. 4G64 Destroker?
  119. stock valve spring and retainer?????
  120. BR 3065 kit...complete?
  121. Collapsing lifter?
  122. looking to switch from 6 speed to 5 speed. should i go through Shep for this?
  123. Most boost on stock fuel pump?
  124. EVO Green/20g-LT airflow numbers
  125. BR FMIC or Turbo XS
  126. Great Shop W/ Good Prices
  127. GSC 280/280 too much???
  128. LICP - Incomplete Bead - Would you install it?
  129. IX BOV Mod for Higher Boost
  130. Save yourself a fire or atleast a big mess.......
  131. GSC 280/ 272 cams with Dyno chart
  132. GSC Releases our New S1 Cams for the Evo 9 Dyno inside!
  133. ARC manifold heat shield?
  134. Are Cams wroth it?
  135. help! boost trouble leaking?
  136. Best alky kit for road race application?
  137. BR's Pure Power Package
  138. squeaky pedal
  139. Performance Gains?
  140. ? about ebay o2 housing
  141. IX Studders ...
  142. Greddy Turbo Timer harness?
  143. COOLINGMIST METH KIT evo people who have it and i need a experianced installer
  144. ingalls stiffy?
  145. AVO D-Series TURBO on a 2.3 Stroker!!!! Who Knows something about this KIT!!!!!
  146. 11.2 @ 120 on the stock turbo, but I want more. What next?
  147. HorsepowerFreaks 35R makes 568whp 442wtq on stock internals, intake manifold and TB!
  148. need help on next mod upgrade!!!!
  149. 20,5CC EVO VI Vs 2.2 EVO VI WINNER IS?
  150. Possible TC failure?
  151. act clutch and prolight flywheel installed
  152. EVO Staged Upgrades???
  153. Spool of 67mm+ T4 turbos?
  154. A Whining noise from Trasmissin
  155. TBE+02 housing=boost cut?
  156. Rev Hard Cast Exhaust Manifold
  157. 90k Maintenance
  158. Do you think Mitsubishi should place a recall on their transfer cases?
  159. Best diff fluid/TC fill method?
  160. Wont start.
  161. more HP?
  162. O5 transfercase in an 03?
  163. Jun Lash Killers
  164. replace clutch
  165. Lets get this strait 37R Q&A
  166. Bad Experience with MBC????
  167. High flow cat Q
  168. stock injectors with 20G-9-5@28 psi?
  169. Intercooler piping and BOV
  170. Jet-Hot - Not Recommended
  171. Jun 272 Vs Tomei 280 Camshafts
  172. stock heat range plugs + alky on IX
  173. High Idle?
  174. Crower Cam Question
  175. MIVEC IX into an VIII
  176. Help with SES light
  177. Part #
  178. cams before meth on ix?
  179. EVO IX w/ GT35R
  180. Safe w/ no flash until spring check...
  181. Got bored... made me a COLD AIR intake
  182. Oil Feed/Return Kits-Help!!!
  183. T3/T4 60-1 on pump?
  184. Necessary to upgrade OEM IX Spark Plugs with Alky Injection and higher boost?
  185. Is the Blitz drop in filter good?
  186. What's the best turbo kit for the street & road racing?
  187. installed testpipe..
  188. Dead After 3rd Gear...????..
  189. Turboxs DP owners with wideband please look
  190. wrapping your 02 or DP
  191. injen same as invidia exhaust
  192. E7 Rod Size / Piston fitment
  193. cat delete=failed inspection
  194. Bov help and ?
  195. IX, amazing - why?
  196. Toda 2350 kit or other stroker
  197. 0,5mm VALVES TO RUN UP TO 10.000RPM
  198. transmisson noise is this normal?
  199. Case Study # 151 - IX Evo with Intake and MBC makes great power
  200. Precision PT-67 spool time?
  201. Will a DSM manifold fit my evo?
  202. Buschur Delux FMIC & ams GT3076R?????
  203. 2.75" vs. 3" downpipe
  204. TurboXS DP
  205. Oil Light flashing WTF??!!!
  206. What Is The Higher Rpm That Evos Can Run Up To??
  207. BG Syncro Shift I vs II?
  208. Best way to make 600hp
  209. Aftermarket Throwout Bearing?
  210. Shearer 50Trim vs. HKS GT3037s
  211. OBX or Samco silicon intake hose?
  212. Stupid question...How hard is it to install a turbo kit?
  213. BOV or no BOV?
  214. Evo Ix Cams...
  215. Stock Dyno and a urgent question
  216. what flange do i need for a greedy bov
  217. HKS SSQV blow-off valve
  218. Question Regarding the IX O2 sensor.
  219. Big thanks to...
  220. Evo 9 cam timing only in the lower revs? is this true?
  221. New Tubo..how long before I need to tune?
  222. catback vs. tbe
  223. Tranny and tranfer case rumor
  224. JUN B.L. Exhaust Review
  225. Question about my new muffler
  226. Pure Tuning Evo IX Parts Dyno Testing
  227. Anyone Use Sard Or Magnaflow Catalytic Converters???
  228. AntiLock Light after install
  229. Oil Leak issue, Ruff idle
  230. !!!!! 5th to 2nd by accident what can happend !!!!
  231. Clutch Tranny Motor Mount or what
  232. Where to get- that gold foil heat wrap
  233. forge MBC and walbro fuel pump
  234. WARNING!! please read regarding transfercase oil!
  235. Turbo compressor housing question
  236. MAF removal? is there power to be had?
  237. Fuel Pressure Gauge Questions
  238. Looking for Options: 5k rpm pull drops off (06 IX)
  239. turbo issue or boost leakin
  240. For Street/race Use Best Clutch Are??
  241. Turbo Help-Please
  242. Best street clutch for around $500
  243. Large Thump?
  244. Blowthrough w/GM MAF installed....finally
  245. Twin scroll or not to twin scroll
  246. problems with leaky downpipe/o2 housing
  247. hard shifting at high rpm
  248. Need some help
  249. Engine shaking badly at stop!!
  250. Stock "2 step"?
