- Self tuning stock ECu????
- B&M Short Shifter
- 1st Gear Synchro Wear? Or ???
- FYI: GHL 3" turboback exhaust for $899
- cam tuning
- difference between 264 and 272 cam gears?
- Added a Catback, ECU reset?
- Miles per tank went from 300 to 200 to 280, spark plug related
- rvm ic pipe kit?
- Just wanted to let you guys know...
- 660cc injector size...how many are using them??
- Exhaust Whp?
- Rnr Gt30
- Problem with Blitz Turbo Timer
- TC or walboro fuel pump ???
- BOV with Injen Setup?
- Best spark plugs
- Selling stock parts any1 have luck?
- Jun Stage 2 Cams-need info
- Need Some Opinions!!!
- anyone know anything about these parts?
- Exedy Twin Plate???
- Greddy Type-S Lower Vacuum Port Connection...
- Calling all EVO owners and their MODS...............
- throw out BOV ..??
- Spec Clutches anyone??
- AMS Turboback anyone?
- calling all people with hks racing air intake system
- My exhaust question part2
- Oil Pressure and Oil Temp gauge install How-to
- Anyone running a sheetmetal intake with the stock ECU?
- will exhaust fit the 05
- Evo 8 Core head and short block ?
- Oil Leak
- My rear is bad
- UR test pipe
- average fuel pressure for evo tuners..
- Big FMIC bad idea with stock turbo?
- HKS 30th anniversary w/ 3 in DP and highflow cat
- Mitsu installed my clutch but..
- Installed Ralliart Wires and Denso Plugs, now have ?'s
- AEM 3.5 bar sensor
- Check out the new Invidia header and o2 housing
- new product at SEMA
- What's the Quietest & Deepest Sounding 3" full turbo back exhaust?
- Air intakes and HP
- More oil consumption
- how much to get into 12s?
- MR edition
- WTB: JUN 264 cams/springs/ti ret's
- afc2 install with settings?
- Hi-flow cat?
- question relates to exausts
- upgrading to evo 6 turbo...need info
- sucking whooshing sound when trying to accelerate
- # of turns on a Greddy Type-s w/stock turbo&boost
- n00b bov question answer plz
- My remote won' work after installing a HKS Turbo Timer Type1
- "Free Scheduled Maintenance" Mitsubishi Motors Extends Program For '05 Model Year
- Broken Linkage?
- BIG boost spike, help please.
- Census 2004 - MBC or EBC's?
- Car shaking and rumbling after clutch install
- I need consistent settings for the profec B 2
- 4th gear popping out
- EFI PMS display?
- TC destruction?
- Your chance to help design the turbo back exhaust you want...
- anyone here with revolver cams?
- Cam gears...any difference?
- Need help bad! p0137 code
- is 450whp possible with stock turbo?
- Oil Pump Failure
- Balance Shafts Removed...
- RPM rises then drops back HELP
- knock sensor
- 264/272 and tuning
- Engine braking and de-accel noise
- Will the evo 8 clutch,pressure plate and flywheel work on the evo 7?
- Which chart is the boost chart???
- Help! Need a Pic of the last 10-12" of uncovered wiring harness leading up to the ECU
- po 234 fuel cut problems
- Ordered my turbo kit
- Engine gone need parts
- HKS 264s - good for 20whp?
- Location of the stock Intake Air Temp Sensor on the EVO?
- Need some info
- Reg Maintenance ACD Oil Change?
- Custom Flash or Base Flash???
- ACD drivetrain question
- Cams, Springs and Retainers
- Invidia exhaust .. help
- 75mm Magnus Motorsports TB and intake manifold
- Make your selection and help a brother out
- loud whine when decelarating in 2nd
- broke transfer case and restrictor plate
- datalogging widband with profect e-o1
- Automotive Fuel Pressure Regulator, Fittings and Guages?
- I need advice
- Sard fuel pump
- A few technical questions
- What horsepower should I expect?
- Need afc wireharness or help
- Spark plug gap
- Koyo vs PWR
- taking evo into dealership tomorrow to get bov tuned
- Max torque and shifting?
- will Octane Booster raise boost?
- need help finding cigarette power wire (installing ebc)
- Houston, we lost an engine..
- emanage anti enging stall help
- P0420 = Catalyst Below Threshold
- HP output question
- using greddy a/f gauge as remote wideband lm-1 meter
- Stock FMIC okay for 325whp?
- Octane boosters good?
- service engine soon light came on?
- Dialing in cams correctly?
- What mods to get..
- Having problem with OS Clutch
- ACT Clutch Break In
- Cams with stock cat...emissions.
- Just installed Lancer SS kit
- Ralliart panel filter question
- Dual BB turbos
- Just purchased a 05' Evo MR, seeking upgrade Advice!
- Oil leak through intercooler piping?
- explain to me this fuel cut
- EVO MR's and Buschur 3" turbo back?
- Possible twin turbo??????
- which air intake you recommend?
- angine problems? clutch going? bad gas?
- What TURBO to go for
- B&M Short Shifter After Install Trouble
- New clutch, wich one????
- Importance of downshifting?
- My new exaust
- Exedy Twin Disc Sucks My White A$$
- What mods are safe without a flash
- Some mod questions
- Espelir JGT500 exhaust
- Performance Parts and the MR
- Need help with tuning BOV!!!
- RPM jump during boost
- Boost levels on MR
- boost questions?
- Tranny uprgrades for modded evo VIII?!?!?
- Watchout hits 11's on stock turbo
- What do you guys think. Turbo Manifold
- aftermarket clutch disc w/ stock pressure plate and TO bearing?
- Wining noises
- Teflon shift cable from MR on '03-'05 GSR
- What clutch does Turbotrix use in their evo?
- Anyone using a GT28RS yet??
- Blown Transfer case Poll
- Transfer Case poll
- mobil 1 synthetic vs pennszoil
- P0300 bottom line
- C-16, stock compressor, 411 HP.
- Stock compressor, 94 octane 375 HP
- AHhhhh Crap....
- Poll: which turbo timer manufacturer do you recommend?
- J speed downpipe
- NEED HELP Cam install, won't stay running
- 612.7 Whp At The Dyno Today!!!!wow
- What is the best clutch for 600ps+ ?
- need help on my setup
- Megan racing intercooler..GOod/Bad
- vaccum leak?
- 523 WHP with Flash and AMS Gt35R turbo kit
- Walboro 255
- Does this mean my clutch needs replacing?
- HKS RS Intake on MR
- What size is this catback system....
- What do you reccomend
- No turbo spool up??? Any help?
- Can the HKS EIDS be used with NON-HKS bov's?
- flywheel
- 5th gear grind
- compression test done after break in results
- Helix Catback Exhaust Reviews
- Can you drive with untuned cams?
- help in Hks Car gear settings
- Can I use Leaded Gas Now.?? NO Cats
- 03 exhaust on a 05
- Apex RX6 Turbo Kit
- Any Dif advice??? I think mine blew
- New HKS Cams
- Stupid Manifold/Turbo bolts!!!!!!!!
- This white/black smoke thing
- What's a good intake?
- Anybody with an Upgraded Turbo that have gone from HKS 272 to Jun 272?
- Perrin MBC problems
- Apexi Turbo Timer Question ? "HELP !!!
- How do I know that is time to change my clutch.
- Help with spark plug....
- Hallman MBC now car cuts out at 4500rpm
- SFP stage 1
- How to obtain 600 whp????
- Help me pick the next mod
- 10.5 Hotside????
- Intake filter heat shield?
- Stock Oil Temps?
- Does anyone know a clutch that will fit for the MR?
- HKS turbo kit pricing?
- Need help picking a BOV
- Stock WHP of 03/04
- Partial, half throttle pulls harder???
- Downpipe rattle??!!!!?? Help Please!!
- boost question
- Transfer case
- 1st gear to 2nd??
- Down pipe touching oil pan
- What gearbox is this? Any info on it?
- trouble downshifting at lower speeds on an evo
- had cams installed finally...
- good but not to complicated elec. boost control?
- Tuning nightmare and rescue
- Turbo Upgrade
- neccessary to have a turbo guage that records max boost?
- poll: which clutch manufacturer do you recommend?
- Attn Parts Whores
- my prototype air water intercooler
- FYI: Helix downpipe WILL NOT fit 05+ Evo
- Greddy Type-S BOV Tuning Questions...
- Instrument cluster lighting
- Wierd Popping sounds ~ 1 minute after car starts
- Turbo Boost Controller
- EVO Fuel Filter Location
- Impressions on the EVO6.5 RS T.M.E Titanium shaft turbocharger?
- car losing power at 3000 rpm and above??? HELP!
- How long for ECU to figure out I put in good gas?
- HKS 264 intake 272 exhaust?
- Exh Manifold -> Turbo Gasket Suggestion
- Transfer broke, please help!!!
- Turbo kits and downpipes
- Better revs with grounding kit
- Any alcohol powered EVO's out there?
- Wondering.. please help...
- Shifting/Clutch Question.
- Heat Shield
- How To: Eliminating A/C Belt
- RC Engineering Injectors ?
- Car jerking and S-AFC resets
- Apex'i Airbox questions
- t-case problems/ gear oil analyisis
- Newbie question on Profec B
- Turbo Timer Help
- Apexi N1 exhaust
