- Boost spike larger than expected.
- List your dyno #, dyno, mods and 1/4 mi time slip here
- Sequential Transmission
- AMS/Buschur Stroker kit install w/o removing engine?
- Lifter problems after cam install
- Clanging noise during startup...sounds like a wrench hitting a metal pipe
- Reverse gear grind
- Turbo Surge
- ROSS vs ARIAS
- Need help hooking up boost line
- what could be wrong?
- where to get new 02 sensor?
- ARRG - broke one clip, lost the other :mad:
- Anyone know if the EVO 7 and EVO 8 wheel bearings are the same?
- Is there a way to adjust the shifter?
- help me (trans problem)
- Supertech vs ferrea vs Rev. what good ??what bad ??
- Buschur Lower IC Pipe Install - HELP!
- More O2 Sen ?s
- Erratic oil pressure readings - any ideas?
- Boost Increase after DP and Cat Back
- WARNING! EVO Front Differential Issue?!
- Dyno Flash Evo 8 at - 2005 SEMA Show
- Exedy Organic Clutch Review Needed
- DogBox
- hks exhaust question
- Head gasket apperad to went bad with ARP head studs
- Using an Air Line filter in Boost Controller line.
- Q about the restrictor valve...
- Hks T04z
- HKS vs GSC???
- how much boost on built head and stock turbo?
- Next years project...
- BR8ES or BRP8ES?
- Other V-Clamp Downpipes?
- 10.5 HotSide
- Odd clanking noise from 2000rpm-3000rpm
- 255 fuel pump problem
- don't know if clutch or tranny
- ? about sticker on ecu
- CARBING induction box
- **Stalling/Car problem**
- Which clutch can handle 600whp and is quiet?
- downpipe question
- Car problem
- Short shifter
- knock link system...which one?
- HKS SSQV BOV Blow Off Valve Evolution Evo with I/C Pipe
- Evo 8 Starter - need help
- My Car Stalls When Cold Dont know what it is
- why is everyone using MBC and not EBC?
- Apexi exhaust ????
- T3/T04E Hybrid Question...
- Stroker & cams
- Is this BOV in backwards? Was it "crushed"?
- Updates!!!
- Whats the best clutch for my car??
- Evo Down, Help Me Diagnos My Problem So I Can Sleep Tonight!!!!
- (Cont.) Discussion with the good people at Revolver Cams
- best engine oil?
- Evo Accessories and going past 9000 RPM.
- Compression Test Too High?
- how important is milling the head
- Decisions... - DC Sports Manifold or Stock Ported/Coated
- Magnecore 8mm vs. 8.5mm?
- After market Dampner pulley?
- Stock adjustable (plastic) BOV, yes, it works!!!
- coolant leaking!
- JDM MR BOV is fluttering
- Who built your t-case/transmission for you?
- Pls confirm this is the EGR solenoid
- Upper IC pipe against radiater hose
- Blitz !!
- Car is coming together....Finally!!
- Which BOV w/ Injen Intake System?
- Lightened Underdrive Pulleys?
- 264/264 or 272/272???
- 272 intake /264 exhaust setup
- AMSoil MTL SAE 75w90 GL4 (Tranny)
- AEM intake
- Whinning noise only in first gear
- 05 clutch install
- New Dyno Results With New Toy - M A F Translator Pro
- Act Clutch Help
- help
- do i need to seal up the cap on alky reservoir?>
- windshield wiper washer same as 50/50alcohol & water?
- Will this turbo fit?????
- High Flow Fuel Pump?
- bolts
- Where do I mount the intercooler sprayer nozzle
- Which HFC won't throw a CEL
- Burping radiator please read
- Do cammed 05's really need a fuel pump?
- What kind of turbo is this
- greddy upper ic pipe install question ...
- Hallman MBC and boost tapering - stiffer wastegate actuator
- ACT street disc clutch
- Damn Drive train issue!!!
- Turbo Help!!!!!
- intercooler pipe question
- Forge MBC Troubleshoot
- No customer service at Hallman?
- shifter bushings
- ATP GT3037S turbo kit and SAFC II question.....
- alky kit install help
- ARP headstud install question
- Shepherd Racing Transmission rebuild / Upgrade
- 1.49 60' time with new Stroker
- FUEL CUT !! =( help !
- Waste Gate Arm won't reach after 10.5 install
- methanol question
- oil pump gear
- Transmission Fill and drain Plug-Diferent for MR?
- ATF SPIII On Rear differencial?
- Lost boost after injen and forge install.
- exhaust question..
- Greddy BOV's suck
- Ultimate Racing Test Pipe
- Turbosmart E-Boost 2 settings
- Is there a way to check the level of transmission fluid?
- Head gasket leak problems
- Finally dropped tranny again (8th time)
- An 02 sensor question
- Need help, car not firing up!
- Tuning for Water/Alcohol Injection
- Injector Duty Cycle???
- O2 swap out
- Apexi TCW15-P22 Turbo kit, any impressions?
- atp 3071 installed with jestr tuning reflash
- Max boost on Alky & stock turbo?
- Clutchnet Installed
- UR Test Pipe - 2.5" or 3"
- ACT pressure plate question?
- HKS Kansai Intake Manifold ??
- HELP Can i use the same exhaust on Evo 9 as the 8
- RS*R ExMag + high flow cat + downpipe
- Piper Group A Cams
- Best valves and springs?
- Exhaust leaks, Big deal or not??
- Dose my Evo 9 have the same turbo back exhaust as the 8
- Exedy Heavy Duty Twin Carbon Review...
- Best paper filter?
- know the cause of my crap idle - maybe interesting
- Anyone have a review for Cusco front LSD?
- Leaking oil
- OEM Tranny Fluid...
- IC piping that doesn't need mini-battery?
- Which exhaust to get
- any one want a Injen intake system
- Catalytic converter dimensions?
- Help! 5th gear grinding already
- 272s and the lopey idle...
- Best intercooler????
- 44,800 miles on stock clutch
- AFC with Mail In Dyno Flash
- System Readiness Check....Failed
- Heat/thermal wrap...do they make a difference?
- tdc
- transfer case
- Forced Performance Camshafts
- ideas?
- EVO 8 VS EVO 9 dyno charts from Buschur Racing
- cams and gas mileage - share experiences
- clutch problems... expert help needed
- knock link?
- Vishnu ECU arrived....
- Invidia 3" TB installed
- Detonation??? Or something else?
- ams intercooler question
- PO 300 code
- Helix Exhaust, DP, Test Pipe, o2 housing???
- question about MBC & tuning
- question on cam gear settings
- Which exhaust makes most power?
- Fujitsubo Exhaust Clips Enjoy
- Will the Greddy upper IC pipe fit with a HKS RS intake in the way?
- 680 CC Injectors 26 bux ???
- T3 Turbo Manifolds
- Timing belt tool info...
- What to do?
- evo IX magnesium turbo swap
- tubular O2 housing question
- How many RPM are you idling at?
- Aftermarket Oil Drain on Stock Turbo
- 30K mile service
- EVO IX exhausts and a few more BR330-350's...
- Who's got an aftermarket ignition setup?
- Pics from ATP 3037S turbo install...MBWW
- another "ricer" hks bov thread
- Your thoughts.....
- Ultimate Racing exhaust
- exhaust ticking noise???
- Ralliart spark plug 8 installed
- Anyone ever use a Super Sprint exhasut?
- How to get a hold of Jon at TRE
- Coolant problem. Odd
- How many tuners have a GT35R turbo kit?
- BR FMIC Deluxe users...
- ATS Single Carbon
- Evomoto hooked it up!!
- Vac@ Idle
- Critique my future setup...
- Boost Spike!
- rattling noise from engine
- fuel question
- Additional source of air inlet
- New Exhaust smell
- Tranny noise ?
- Clutch Hotness going in tomorrow... Cant wait!!!
- *Dynoflash/intake MOD*
- Vendors Look!
- My cars is possessed WTF
- XS Engineering Power Pack II Ignition Amplifier System
- Mitsubishi Evo IX Turbo Part #
- Will THIS Koyo Radiator Peform as good as stock??
- Strange Defi Guage Behavior
- TUNERS on FMIC's what's the deal??
- 272's or 20g?
- Pipercross Intake
- Exhaust Combo
- Finally have $$$ now, so which turbo back exhaust system and intercooler should i get
- Spark Plug Indexing
- hot side installed on friday
- For the guys running 100% meth or Alky what's your 1/4 time?
- where can i get methanol for my alky kit?
- fuel cut on stock 05 8, anyone have this?
- Connecting catback to testpipe
- EGT sensor probe keeps getting loose
- How come the DSM 20G didn't surge?
- Oil Feed line Banjo Bolt size and pitch?
- BR330/350, why no 3" downpipe?
- I love how my car sounds! o2, manifold, hotside installed!
- Proper substitute for Methanol in Alky kit
- mbc problems
- Can't go into gear
- Installing Springs/Retainers
- muffler
- Clarification between the 4G63 and EVO engine
- A few issues to discuss
- clutch installed...cant get car into gear!
- need help evo not runin HELP ME PLEASE!
- BOV Questions
- installed thermostat check engine light
- Clutch Squeak
- Clutch died...again...
- Ti or Stainless Exhaust?
- Let's talk EVO IX Aftermarket Intakes...
- 550whp
- Removed Stock Cat
