PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Quiet exhaust options 2019?
  2. Need Assistance \ Bolt size \ Thread
  3. Evo 8 Redlines without pressing gas PLEASE HELP
  4. Stock evo want bigger turbo
  5. Torque spec for my build Rods and Main
  6. Clutch housing mounting point
  7. Bent lip on tensioner pulley
  8. Just a new guy
  9. Evo 8 not making anymore boost
  10. A wild hole has appeared!
  11. 4G64 over heating at idle.
  12. Boostin Performance Short Block / Cylinder Head Packages - The Ultimate Package
  13. acceleration problem! Help?
  14. Clutch slipping or not ?
  15. Evo 7 Block into an Evo 8 Head
  16. 2.5" to 3" Intercooler inlet/outlet
  17. Smoking after Wot/boost Help
  18. another ticking noise thread (with video)
  19. J pipe fitment
  20. Garret G Series Dims
  21. Evo No Start Condition
  22. Evo 5 intake and intercooler pipe relocation
  23. Need turbo suggestions
  24. stock pressure plate + 6 puck combo, how much torque can it hold?
  25. Wanting to build!
  26. Evo 8 rattle and ticking noise.
  27. Help with 450 Fuel pump
  28. evo speed sensor pinout
  29. Transmission issue evo 8
  30. Puff of smoke at start up
  31. Need help diagnosing a loud tick in engine - Video link.
  32. Back to Recirculating? BOV Question.
  33. Evo 8 clutch advice
  34. Invidia O2 owners
  35. Timing Belt Kits Available @ Boostin Performance
  36. Pretty sure something is wrong with my rear diff
  37. Wheel alignment after clutch install
  38. Tcase rebuilt?
  39. New Engine Components From Callies
  40. 4g63 or 4g64 for evo 8
  41. Unable to shift 6th gear ct9a evo 8 mr
  42. Integrated O2 housing and Downpipe?
  43. Old school FP RED GT3583R rebuilt GTX3582R
  44. Injector Cleaning / Balancing / Flow Testing @ Boostin Performance
  45. 03 Evo 8 (9.8) to Evo 9 Turbo (10.5) Requirements?
  46. Strange head noise (lifters issue)
  47. Replacing fuel lines. What are the sizes, and fittings needed?
  48. evo 4 bigger turbo
  49. Boostin Performance Powdercoating/Ceramic Coating
  50. Boost leak symptoms, no leak.
  51. Curt Brown intake manifold throttle cable issue
  52. Safe to use high-octane fuel on stock tune?
  53. Clutch Damage - Anyone seen this before?
  54. evo 9 oem turbo outlet
  55. Ready to take to engine builders but having second thoughts....
  56. HKS IC piping kit
  57. Sputtering and cutting out at 3 grand
  58. Help! Evo is stutter/bucking/hesitant
  59. 9MR 6 speed with RS LSD?
  60. Wont do above or below 27 psi
  61. Misfire on Cylinder 1
  62. Evo is super laggy
  63. Compression Question
  64. Tomei Arms 7963(japan) vs 7967(USA)
  65. Turn motor with starter
  66. Evo 8 won’t start after head rebuild!
  67. Map EF3 turbo
  68. Radium Engineering VTA Catch Can
  69. In tank fuel filter?
  70. EVO 2 CE9A Bolt on Turbo Help
  71. Exedy stage 1 PP part number
  72. Flex fuel kit. Buschur? driven fab? Or?
  73. Whining noise whilst spooling
  74. which EFR core can bolt on to a evo 9 MHI housing?
  75. Oil catch can ?
  76. Compression/Leakdown Numbers Boost leak
  77. Rod Bearing clearance
  78. 2.4LR E85 misfire or what?
  79. Would an evo 8 engine be compatible with an evo 9?
  80. Possible bad starter?
  81. Help to Id evo 8 cams?
  82. Engine Repositioning and CV angle limits.
  83. Who sells TI E5LM (veyron) pump?
  84. Will this shift selector work for a US trans??
  85. Evo Engine builders Tokyo area
  86. Need Help with Evo 9 Cams
  87. Evo 9 Drivetrain Problem
  88. Rod Bearing Questions
  89. Evo 9 stm and fp goodies unboxed
  90. Air fuel problem
  91. What downpipe is this?
  92. Evo 8 Shifter is Stiff
  93. Evo 8 feels naturally aspirated
  94. oem oil pump gear has play
  95. Really Strange...
  96. Why do people replace ACD with viscous coupling?
  97. Modding a EVO 8 Intake Manifold to Accept MAP Sensor
  98. 4G64 long rod n/a setup
  99. Is there a way to tell if my rear diff has the clutches setup correctly?
  100. Running funky
  101. Billet TC Housing! Magnus Motorsports is the Business!
  102. trigger plate problem
  103. Competition Stage 3 Clutch Issue
  104. Rod knock/spun bearing? Sounds like it’s coming from head though...
  105. TRE Magnetic T-Case Cover
  106. Ralliart Rear Diff Bushing part number
  107. 5$ **** fitting ruined my entire block....
  108. i need help
  109. Timing 2.4l evo 9 mivec. Pics for assurance! Ty!
  110. Titek O2 Housing Stock Donut Style Gasket?
  111. T-Belt Job = Oil leaks?
  112. What is this broken sensor on the back of the block?
  113. 500whp reliability
  114. Transfer case rebuild HELP!
  115. 20g wheel in EVO 6 turbo?
  116. New member with a question / Injector Question
  117. CAS relocation
  118. 4G64 timing help!
  119. Damaged valve seat repair
  120. Exhaust Manifold Flange Drawing - EVO 8/9
  121. FP Black/Zero...Is it worth to buy new?
  122. Exhaust leak at Midpipe
  123. what its broken?
  124. Evo 6 starter problem
  125. Transmission Input Shaft Seal Clarification
  126. Water cooled tial wg?
  127. Timing 64 block 63 head(mivec) with AEM Tru Time exhaust gear.
  128. Ticking Noise From Transmission (Not Lifter Tick)
  129. evo 9 trigger bolt
  130. Evo 8 New built, no oil pressare?
  131. Evo 8 fuze #8 popping
  132. Clutch Masters FX400 Clutch
  133. Is there a market for my engine?
  134. EVO 6.5 TME vs EVO 8.5 turbos in the real world?
  135. Evo 9 RS weird Ting sound
  136. Full-Race vs Sheepey Race..Need Advice
  137. Oh no, I see smoke! Thoughts?
  138. Evo 9 Weird TING sound
  139. Mystery oil leak!
  140. Fan control unit
  141. Building a Evo 9 Engine
  142. Definition of exhaust diameter?
  143. Cylinder 1 misfire.
  144. Anyone cut out the baffles of an aftermarket muffler?
  145. EVO 8 oil traveling question
  146. FAL Radiator fan install
  147. Clutch Adjustment On Exedy Twin?
  148. Wont go into gear with engine running, but drives just fine if I start with clutch in
  149. new exhaust
  150. Boost Issue
  151. Need a new exhaust....
  152. Transfer Case Outer Shaft Scratch?
  153. Gsc s2 Degreeing
  154. Coolent overflow tank question
  155. Heater Core Hose Diagram
  156. Evo IX Trans Rebuild
  157. BW S362 SXE TwinScroll Project
  158. 2.4l stroker evo 9 mivec head questions.
  159. 6466 4 inch or 3.5 inch from hotside
  160. Throttle issue still causing problems
  161. Block identification
  162. Taper on Block Deck
  163. 85mm Wiseco piston on a 150mm Manley rods
  164. DIY 6 speed transmission repair!
  165. Evo 8 piston,cylinder wall dammage
  166. Piston ring problem
  167. Clutch engagement point changed
  168. cylinder wall issues
  169. 2.3 Build
  170. Oil Pans
  171. Opinions/experience on twin disc clutch vs carbon single
  172. Do Kelfords 272 make way more power then bc 272 ?
  173. Why does my second gear pop out ?
  174. Options for non ACD transfer case guys. 03/04
  175. Can’t Shift Into 1st 3rd or 5th
  176. Clutch options
  177. Please help!! Timing belt teeth shreding off as I turn it to TDC
  178. RPM Ticking Noise
  179. FP hta 71 CHRA
  180. Wastegate leaking through o2 dump at idle.
  181. Replacing O2 sensor !!
  182. Clicking noise from engine bay under load
  183. Lost of power after spark plug change
  184. Okay to leave pass side motor mount off while working on car?
  185. Gas problem, lean at idle and cruising
  186. How to build a 400hp+ Evo 8 GSR
  187. Question about ct9a rear axle
  188. Evo 7 Motor rebuild
  189. Balance Shaft Discussion
  190. Freeze plug issues-Need input!
  191. Question about installing the head after head assembly
  192. New to evos, is this sound normal?
  193. New Turbo Time- Advice Please :)
  194. JDM bumper fit exhaust on USDM bumper?
  195. Loud bang ! then see piece of my donut gasket
  196. Slipping clutch?? Boost issue?
  197. Strange tick/chirp noise from engine
  198. Manley H Tuff rods on 2.3 and JE 270666 opstons
  199. Hurt My Head
  200. Engine rebuild opinions
  201. Boost Control Options
  202. Evo 5 vs 8 engine components
  203. Drivetrain Issues
  204. How to properly prep blocks surface
  205. New Product HKS GT III RS
  206. Usual Block Condition on Engine with Rod Knock
  207. High coolant pressure
  208. Lean Idle/Misfire - P0335
  209. To install bigger compressor wheel on a GT3582r
  210. Leaking Oil After Head Gasket!
  211. Identify this plug
  212. 97 evo 4 idle issue . Factory car
  213. Well I need a new radiator....
  214. Help identify transfer case.
  215. [Video] My 800 hp Block Build.Teaching myself how to bore out cylinders the right way
  216. Rough idle and wont rev or boost.
  217. Chips on EFR compressor wheel.
  218. Slow Getting to Peak Boost
  219. Spun bearing?
  220. For set up
  221. 6 speed housing crack around clutch fork pivot
  222. Solid lifters?
  223. Direct port Nitrous or Single nozzle (NOS)
  224. Is this the correct crankshaft for a 2.3l build?
  225. Callies H beam or Manley H Beam Tuff
  226. Help pls identify those evo 8 cams
  227. Any tips before i start pulling this down?
  228. No fuel- no spark- replaced crank position sensor (Please Help)
  229. Low Compression in 2nd cyl
  230. Boost leak or fuel cut
  231. Help! Max boost 13psi
  232. Another boost creep issue
  233. Evo 5 issues.
  234. IX want bigger?
  235. Help identify this turbo!
  236. EVO 8 leaning out at idle, misfiring at 2000 rpm, cannot drive
  237. 2001 Evo vii no boost at all
  238. Clunking Rear Diff
  239. Evo 8 rs usdm fp zero
  240. Need help calculating Torque
  241. ACD / AYC Without TPS
  242. Valvoline VR1 Oil Analysis Results 850+whp
  243. Where do you guys buy 3" OEM-size muffler 3 hole gaskets???
  244. Need help 2.4 lr mivec head
  245. Transfer Case Broken Maybe More?
  246. Evo 9 Exhaust on an Evo 8 Mr
  247. Is my setup good for 600+whp ?
  248. White smoke after oil change, switched oils.
  249. 2.0 Build 700 HP Help Reccomendations
  250. Results of the newer GTX3582 Gen 2
