View Full Version : Evo Engine / Turbo / Drivetrain
- Dyno numbers comming again from AMS...
- Skunk2 68 MM TB
- clutch question
- Anyone know where I can get a downpipe bolt at
- ACD Delete / Removal ?
- FP Red on stock internals
- Finally after months of wait Tomei 280's Evo IX
- hks camgear torque settings
- ATP mitsu to t3 adapter- anyone using them?
- FP Wastegate Problem!
- Turbo RPM! Good Tech Question
- How much power on a single Walbro 255??
- buying an evo ix
- Vacuum leak.
- Need help for cam choice
- Cam Damage! - PICS
- Compression Results, Good or Bad???
- Porting Differences in PWER?
- major exhaust question
- Stumbling evo
- My Dyno Numbers!
- 4:52 or 4:11 gears for 2.3L ????
- Another one bite's the dust 850R again.
- is this the right coolant?
- which clutch to get?
- Compression test low across the board
- terrible cutout in stock evo...
- Clutch/Tranny Problems
- drive train fluid
- Stock J-Pipe Coupler Size ?
- Can anyone awnser this for me?
- Exhaust swap
- does it work 2.4 lancer block for the EVO
- New Problem. trans issue. help
- Forge WG Actuator
- First time clutch job.
- start up not quick/smooth like it used to be
- LSD and AYC
- New stroker, can I start the car with my old tune?
- clutch gone again
- evo 8 and 3kgt vr4 wheel bearing=same part #??
- radiator hose touches manifold
- lean idle
- Anodizing is the best way to go in FMIC
- maf adaptor looks funny
- boost spike then fuel cut followed by oh s***
- Identify this filter
- supporting mods for fp green
- Modified Evo 9 turbo with a TD06SL2R and a MHI 20G???
- Evo 8 Turbo Questions
- Slight mis fire at idle and at WOT
- maf size
- Quick HKS SSQV Recirc question
- Fan not working..
- Any1 Used Lucas Oil products on their Evo?
- Clutch Position Sensor code thrown
- Comp Cams 280+ and stock valve springs
- Switching from pump gas to meth tune
- can't find a RNR manifold
- New Creader and P0300
- Just Opened My Engine . Need Some Input ( large Pics )
- Agency Power exhaust owners needed
- porting
- Boost Gauge. FPR or BOV
- what rods and pistons to go with??
- turbo compressor porting
- overboostin..help
- UR testpipe installed CEL! Need advice!
- ebay manifold
- Injectors Question????
- Boost Creep!!!! help
- slipping clutch and pedal adjustment
- Serpentine Accessory Belt, is it the same on Evo VIII and IX?
- Exhaust Question
- 2.3 .63 T3 Open Scroll to 1.06 Twin Scroll swap.
- Gates Racing Timing belts
- Shaft play on new FP Red???
- Q about my way to more power
- coil on plug wiring
- clutch question
- 4G64 Pistons
- 50 trim record hp and track times
- bad bov?
- Which Megan Downpipe?
- Crank angle sensor
- what to watch out for when buy an evo 8?
- Need help with 6th gear issue on IX MR
- which is better?
- help loud noise
- stock with build motor or trans?
- 95k Stud Install, HG too?
- where to get a tranny rebuild kit?
- cam spec sheet
- Wheel Bearings
- 2.3L and Green?
- notchy grabby clutch
- New starter new battery,,,Still click click
- which intercooler will fit??
- external wg hookup
- Going in for a retune soon, got couple questions
- Clutch noise while shifting
- fuel pump setup
- 02 housing??
- Car bogs when its not given enough time to warm up even in the warm temps
- A little help
- SUPER hard to shift when car is cold??
- I just replaced my broken Oil Feed Banjo Bolt and got this???
- QTP + Stock Exhaust Idle Problem
- EVO IX STOCK BOV fluttering
- How much boost can I run???
- UPDATE on my 9 Progress?
- what exhaust is this... ??
- what size thread chaser for the headbolts?
- cams question?
- Oreilly Auto Oem Axles
- Trasfer case question
- Help!!!
- Need Advise on Timing Belt Change
- Forced Performance WGA! Help Needed
- Mobil1 15W50... stock engine...discuss
- Perrin EBC Solenoid install
- Plugs for VIII with FP Red on E85?
- Where to get internal transmission parts?
- Car sounds like a subaru :'(
- Revolver Cams...Yea or Nea?
- downpipe wrap
- Tomei vrs evo-9-20g
- Break in period for new head..
- MISHIMOTO intercooler ??
- New car... first problem.. :(
- Headgasket?
- Turbo XS dual stage boost controller reasembly...
- Buschur Mivec stage 3 head
- 2009 is going to be good...Thanks to AMS!!
- Evo 9 MR BOV vs Tomei BOV
- Instaling new Circlip
- EVO hesitation, shutter HELP!!!!
- What turbo for street ?
- intake mnifold senser on top what is it???
- 850R or better
- Clutch question...
- OK, so my evo9 is all messed up...
- SES light with o2 fouler and o2 simulator in.
- Buy the kelfords already!
- Evo8/9 water pump compatibility?
- Question on intercooler flow?
- MAF Sensor
- transfer case warranty or TSB?
- Vaccum leak ?
- engine check light
- Injector 100%! Power Fc!
- HEAD GASKET 86mm
- Maxing out the 9 turbo on 91 & Meth
- How is the drivability and idle of the Kelford 272 on an Evo 8?
- grinds gear(s) after clutch install???
- Transfer case concern...
- No DV or BOV
- 5th Gear problem
- car wants to stall? need help
- strange noise
- anyone ever heard of water jacket failure on gt3076
- "help" car wants to die?
- Stage 4 6-Puck Competition Clutch: Any Reviews?
- Stock air fuel ratio's
- Anti-Lock Light?
- bye bye to my cosworth
- Turbo and TB coolant hose size
- Cosworth M2 VS Kelfords 272/272
- What would I need...
- ? for people who changed the cam side motor mount
- Small prbolem with EVO rod.
- Transmission Nochy till Warmed Up
- Result of stock retainers with upgraded valve springs. (Pics)
- Coil over plug ignition are they worth it?
- Death Wine----this time not the front!!
- Picture of titanium wheels vs inconel ?
- just did a compression test,questionable results?
- aftermarket 2.75 inch downpipe with o2 bung already installed?
- Help me ID this manifold & DP
- AEM Wideband Sensor... Where to buy?
- Best spark plugs for evo 8
- Billet Vs. Cast Compressor Wheel 60-1
- Cam Position Sensor & Crank Position Sensor Codes Simultaneously?....
- Spun Rod Bearing
- tranny help/
- what intercooler to get...
- Fuel gauge inaccurate?
- any way to identify these items?
- Positives and Negatives of a 4.11 Final Drive Ratio???
- Noise under the hood.
- How long has your Quartermaster or PTT lasted?
- Need some help!!
- doing a 2.0 build
- twinscroll/singlescroll TURBO SHOOTOUT -- full-race / VE engineering / vivids dyno
- Evo owners with SSAUTOCHROME FMIC please Chime in on this thread
- Walbro 255 Fuel Pump Install Help
- Help she wont start!
- Help Identifying cosworth cams
- Tial bov rattles on idle (rattle noise)
- Oil on turbo outlet. Seals about to sh!t?
- Has anybody here used the WOT box
- Chunk of metal on transmission drain plug???
- Inspection question
- Short Shifter Goodies?
- Changed Downpipe will it affect my tune?
- Can I use a starter from a 2003 evo
- battery dead?
- Cobb exhaust rattle.
- Oil Cooler Upgrade
- Exhaust rattle/scraping
- Who is a smart Evo 8 tech??
- T-Case Leak
- timing after build motor
- engine dyno...
- Who Is a good tech starting issue Evo 8
- High octane Fuel?
- Damaged engine?
- Oil leak from return fitting, anyone?
- TIAL exaust housing vs T3 twin scroll
- WTF is this possible?
- Help: misfiring under load
- HTA86 question
- My car stops Idiling
- Screamer pipe = More fuel???
- evo VIII "under load" problem
- Average hp tq numbers for people in Salt Lake???
- XtdŽ stage 3 clutch ?
- BF 272 idle clip
- Leaking valve seals, question regarding.
- Help: misfiring under boost
- Cheap Oil Changes
- yet another help thread
- bearing noise
- To Buy OR Not To Buy
- Help
- 9 turbo or e85
- Spark tec or HKS Twin Power DLi2 Ignition Amplifier
- electronic boost controller?
- Need Help Please
- Megan Manifold with Meth?
- Help Please
- Transfer Case probs I think. Help?
- hallman mbc?
- Heat not working properly
- Best Spark Plug
- oil catch can pic request...
- Dump Turbo?
- Evo DOHC-4G63T
- Need to know about a motor swap
- Swap spark plugs and car wont start anymore?
