PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 [134] 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. help guys noob here!!!
  2. turbo upgrade?
  3. new compressor wheel
  4. Evo 8 tranny, how long will it hold?
  5. 2.3 spool questions
  6. anyone using civic alum. radiators?
  7. Lookey what I got in the mail this morning, just in time for an evo modfest...
  8. Buschur Tax Return Sale
  9. 924 whp EVO VIII and crankshaft
  10. Tune This Weekend!!!
  11. evo 9 turbo manifold
  12. cold weather overboost?
  13. My Car Graphs
  14. Sudden Oil Leak on my Evo
  15. got tuned at eip.
  16. Blow through MAF ??????
  17. Basic Mods Needed
  18. Do i need new oil lines?
  19. Cylinder #4 misfire and a spark plug question.
  20. cam question 264/272?
  21. Jerky clutch when cold!
  22. exhaust manifold temp
  23. Twin Scroll Testing...Let us know how you want it done!
  24. Hyper intake manifold- its here...
  25. Gague to read JDM Map?
  26. Tranny help / suggestion
  27. Installing and verifying the timing in a MIVEC cam! Hints?
  28. Tune?????????????
  29. Cam Gear Tool
  30. Tranny recall?
  31. EVO 8-9 exhausts, help please
  32. anyone use this......
  33. going in for a tune.
  34. It's freezing outside and I boost creep.... :(
  35. Fidanza Flywheel not mating with 03 starter
  36. what causes this?
  37. turbo upgrade (question)
  38. What is a good price for Exedy Hyper Twin Plate
  39. transfer case ?????
  40. DTM stroker kit
  41. Very bad times...!
  42. Electronic vs Manual boost controller
  43. VIII w/ IX turbo power?
  44. Question With Turbos
  45. New clutch/flywheel install question
  46. IX - Spark plug gap options??? Heat range 8
  47. turbo kit
  48. spark plugs????
  49. Best Gear Ratio for EvoGreen
  50. Boost spiking like Crazy Help
  51. which dv holds high boost best?
  52. Full-Race on stock setup
  53. P0171, again yes i know but please read
  54. Please Advise!!
  55. My budget build up 50 trim results.
  56. finally got my FP HTA twin scroll gt3582R
  57. Excedy Hyper Single??????????
  58. Clutch Disengaging issue.
  59. stupid question
  60. ACt Clutch ??
  61. 2 litre + ? Turbo = Need to rev past 8,500 rpm
  62. Changing 5th gear...help?
  63. 2006 Ix Mr (gt35r)
  64. Are the evo 8 & 9 bottem end the same?
  65. New Numbers On All Out Pump Tune
  66. fuel filter??
  67. Obdii Po132!
  68. Does anyone have the eBay smoked headlight covers?
  69. What cams should I get?
  70. AVC-R... setting up for dual-stages...
  71. cam decision Please help!!
  72. 400whp with 98 octane.
  73. mis shifting ( help plz)
  74. Cold weather, high boost?
  75. AvGas?? (Aviation GAS)
  76. Florida Buschur exhaust owners..............
  77. T-Case fluids
  78. question about greddy profec b spec 2?
  79. GSC S1 -vs- HKS 272
  80. IX turbo install pics
  81. should i go with the gt35r or stay stock 06 evo IX? please help
  82. Blueish smoke from tailpipe
  83. Boost Creep, now Overboost?
  84. drop-in build @ 70k+ miles?
  85. intercooler question
  86. any buschur 2.3Ls in the house?
  87. Shifting - Evo VIII - New Owner
  88. Where to tap boost line
  89. who is using pauter rods and how much whp?
  90. New mods being purchased.
  91. better flywheel bolts?
  92. Maximum degree on the EVO IX exhaust cam!
  93. Putting Together Your Own Turbo Kit????
  94. bad spark plugs??
  95. Help with diagnosis
  96. Clutch knowledge
  97. Dyno tune tomorrow
  98. Switched to Royal Purple 10w30 today
  99. Exedy Stage 2
  100. Exhaust System Basics
  101. P0401 and p0420
  102. Heat wrap on downpipe, what temp?
  103. What cams are these?
  104. Recomended westcoast shop?
  105. what valvetrain?
  106. HKS Super sequential Vs HKS Super SQV Racing Single Valve
  107. removing exhaust manifold
  108. DP failure from Heat Wrap?
  109. P0234 code HELP...
  110. Want to get close to 350HP with out changing turbo.
  111. O2 housing
  112. output shaft
  113. Spark plug causing Backfire or is it my TUNE?!?!
  114. idle keeps dropping??
  115. tune needed?
  116. Does Walbro 255 LHP needs an installation kit for EVO 8?
  117. Test Pipe = More Psi
  118. Aftermarket clutch on stock car
  119. proper spark plug for mods??
  120. boost
  121. Is there an overboost failsafe?
  122. Manifold Studs
  123. Buschur Inline MBC installed and reviewed
  124. Is a tune needed?
  125. Cosworth M3 Idle Video?
  126. ix cams po11 code
  127. Please Br High Temp Coated Headers Pics!!!
  128. Tranny Problem!!
  129. Meth Injection Help
  130. AMS polished Turbo kit Pics...before and after!!!
  131. Manual Boostcontroller
  132. Major Misfire?
  133. hey guys question about evo front mount
  134. greddy type s bov
  135. HKS 272 Max Out
  136. MBC only boosting 10-13 psi
  137. 675whp 500ft lbs. TQ!!!!
  138. best stock fmic replacement!!!
  139. what do you think?
  140. Possible Boost Leak from BOV?
  141. Is there a power difference between a 4 bolt vs 5 bolt hotside?
  142. p0300 and 3001
  143. F/T : Perrin 3 inch TBE
  144. IX 100whp tune plugs?
  145. head gasket leak
  146. custom dumptube pics?
  147. decision on intake manifold..AMS or HKS?
  148. Stock turbo - how much boost???
  149. T4 Hta 35r?
  150. oil cooler leak????
  151. Question on Buschur TBE (fitment)
  152. Shifter bushings
  153. Need Some Help
  154. HELP! cel light after installing o2 housing
  155. Coolant leak, replace banjo bolt, gasket and ??
  156. more tq over hp?
  157. oil stabilizer
  158. Effect of ported stock exhaust manifold on spool up
  159. finding dumptube ??
  160. dumptube Help...
  161. when it rains it pores
  162. Coilpack question
  163. Help With Mods
  164. Timing belt cost??
  165. Upgrades/Rebuilds
  166. ACD transfer case in Non ACD Evo?
  167. GT3582R - Is this worth the headache?
  168. Carbonetics twin carbon or exedy twin carbon
  169. Replaced Buschur Mini Battery
  170. 4th gear problem
  171. Transfer Case Whine in 4th & 5th?!!
  172. Running Cool
  173. greedy E-manage
  174. Need Help Forge WGA
  175. Oil Catch Can Theory
  176. leaking gas
  177. need help and advice with a DTC
  178. My HTA dyno results (more boost)
  179. O2 Sensor or Evil EVO Gremlin?
  180. Blow Off Valve question
  181. Backfiring Problem
  182. Whistling sound when under partial throttle
  183. boost problems
  184. cam question
  185. 400 awhp
  186. Bone Stock IX knocking?
  187. alternator problems. need help
  188. Why is my car whistling??
  189. Changing timing belt...
  190. Which Hallman MBC is better for an EVO VIII?
  191. Transfer Case oil change interval
  192. Dyno Tuned
  193. Manley H-Beam Rods
  194. Got tuned BUT dont know spark plug gap.
  195. Some questions that I can't seem to search up.
  196. sbr manifold
  197. broken turbo fins
  198. Apexi filter and induction box questions
  199. Do DSM injector clips fit Evo injectors?
  200. DP hitting, how to fix
  201. Switching Camshafts
  202. Pressure Drop with Perrin FMIC?
  203. 600hp possible on 93 possible???
  204. Which moustache bar eliminator to buy?
  205. tdc mark anyone??
  206. greddy spec b prob
  207. Megan Gaskets
  208. TC problem in evo 9 6 speed
  209. Cosworth IX Idle Problems....
  210. Help, My EVO IX MR boosting w/ hestitation
  211. Compressor surge????
  212. Which oil
  213. broke my helical lsd.........
  214. Stock piston question
  215. Buschur HTA35R Exedy vs. Tilton (10 second street car!)
  216. T-case grease fitting
  217. Is the Works DP compatible with non works O2 housing
  218. EVO VIII Boost Problems
  219. boost activated cutout FTW
  220. Apexi Air Intake Install Question
  221. EVO 8 belt squeal,under load ( video )
  222. English Racing E85 Stock Turbo Package = Awesome!
  223. Tial Flange?
  224. Forge 1G BOV
  225. Prosport Electrical Boost Gauge
  226. BOV/Intercooler Pipe Help
  227. Clutch noise, Help!
  228. How I'm spending my tax return
  229. Norris Design 2008 Spec?
  230. Is it necessary?...
  231. ?Do you know This Problem?
  232. P0204
  233. New Product! AMS EVO Lower Clutch Line
  234. Sparkplug condition ok???
  235. Stock clutch vs. Aftermarket... longevity
  236. worst evo ever
  237. ARC Induction Box
  238. Diff Fluid Fill Level (Tire Rotation)
  239. Ball Bearing Conversions
  240. My Dilemma
  241. BOV DV question
  242. Stroker Kit???
  243. what other mods would i need to run the Buschur Racing FPHTA35R Turbo Kit
  244. clutch help
  245. Is the VIII and IX rear diff the same?
  246. Dual Fuel
  247. DTM 61mm Turbo Kit. Fantastic Results!
  248. fq400 turbo name? where to buy?
  249. How do my spark plugs look?
  250. winding noise after tc fluid changed
