- EVO VIII Stock Wastegate Question
- fuel questions
- The P0446 CEL fix. Its a sneaky one.
- Oil Port#1 for 4G63T
- M2 Performance exhaust questions
- What Motor Mounts Should I Use?
- BBK questions for people who have them
- Wont Start after engine wash!!! Help
- Intake Cam angle position sensor help
- What oil should i be using.
- is coolant overflow needed?
- Car acting weird , need some advise pls
- Exhaust fab questions
- Best place for tranny rebuild (stock/aftermarket)
- What tools are needed to do valve springs on the car?
- Rough Idle and Random ERG Check Engine Light
- Thoughts on going larger than Kelford 272/272
- Tranny seal?
- transfer problem
- S2 cams on stock turbo overkill?
- Exedy Twin Upgrade to Triple Kit?
- Intake Coupler for FP Black?
- Stock or aftermarket exhaust manifold?
- Need help with a broken bolt!!!!
- Just put on the New FMIC, Have some problems
- fuel pump help
- mil.spec throttle body question
- boost logs with FP Reds
- E85 and emissions
- Clutch master cylinder problem?
- what piston rings to get
- Kelford 272 cams installed and tune
- Pressure leaking out of oil cap?
- What pistons recommended JE, Arias, Ross
- Transfer Case issue
- coil on plug ignition setups
- samco hose w/ amsoil filter??
- Breaking in Motor with E-85??
- Evo Vibration HELP
- GSC Power-Division 2.2L 4G64 Vs Buschur 2.1L Stroker Kit (Not short block)
- flashing CEL after 4th and 5th gear WOT
- Q45 TB set up idle controle valve any one?
- Evo 9 Cams?
- to those who are running 4" comp inlet turbos
- Buschur/Motor Porn :-)
- What Sensor is this? (Pic Inside)
- Mysterious Ailment - Help Please
- weigtht 5 speed vs 6 speed???
- is it necessary to purge air from turbo coolant lines?
- Oil pressure sender question
- My first lathe project
- Volt gauge bounces from 12-14 during idle
- how can i incrase boost???
- transmission leak near starter!!
- wierd idle sound.. help
- Shep Tranny advice
- Help with gasket
- MBC installed - now car cuts and jerks
- wavy washer guestion with ACT HDG6 install
- Cosworth M3's FTL...
- Exhaust Question
- A weird turbo related noise...
- tial alpha q bov ??
- TOB Noise
- Out of storage tick... help
- Will 15's or 16's fit on a evo?
- starter not engaging after clutch install
- anyone else running the RalliArt UICP
- Energy Spent
- Auto Tensioner FOR evo VI
- Decent bottom end build
- Me changing my tranny, transfer and rear diff gear oil - PICS!
- Balance shaft eliminator kits
- Help with new clutch set up
- Evo 8 Clutch
- Evo 8 short block an evo 9 head?
- Surging problem after installed surge tank and fuel pump on my evo 8
- Motor Swap Q
- Who had the Hta 86 in stock?
- HKS 4.11 gears
- Kelford 272's vs FP-4R's on a IX
- Dump vs reg. o2 housing on FP Turbos
- car keeps stalling: codes p0335, p0340
- BR cast Manifold HTA35r kit or ETS Super value manifold with 35r
- Is tranny upgrafe the right choice?
- Missfire
- what fluids do i need?
- Help on identifying turbo
- HKS 3037s KIT vs FP black
- just bought new intercooler, need some opinions
- Can thermostat elimination cause overheating?
- Won't go in gear after a few passes??
- Gates accessory belt
- 4G64 100mm crank safe???
- Meth Kit
- Timing belt kit + Balance shaft removal
- T-case need rebuild
- New camshafts what else?
- What gaskets?
- HELP:Boost dumping at 12-13 psi?
- 1st and 2nd disappeared!
- 1 injector ticking loud???
- Another MAPerformance Evo Build!!!
- Can someone help me ID these parts??
- popping out of gear
- BBK Full OR HTA GREEN ?!
- T-case fluid: Redline HVY WEIGHT vs MITSU LSD GEAR OIL
- Help! Some sort of death-whine!
- transfer case noise
- ACD AYC Pump repair.
- Some advice. 40r with 2.0 BR Spec pistons?
- Part throttle diverter valve opens all the way!
- Sparkies! (Pulstar anyone!?)
- cossie 272 help!!!
- BG vs Redline
- car wont start
- car wont start
- Dyno tuning time?
- What next?
- Build suggestions
- GSC S2 or Kelford cams for BBK Turbo powered IX?
- Strokers - what cam profile is ideal?
- Trans Fluid Time
- Idle problem after tune
- FP Oil Line Install
- Time to buy something!
- 4th gear spins free..?
- Evo9 mivec problems help me out ???
- car bucks ... after transfer case and clutch install..
- Hitting 500's
- Best Bang For Buck Intake
- Any one running kelford 272 on stock head
- shifter cables made of gold?!
- Car wont start...Fuel pump?????
- Synchronic BOV
- Adding muffler to megan exhaust...
- rods
- clutch problems
- oil filter sandwich adapter?
- about transfer case wine
- How much does it cost for a Tranfer Case?
- help clutch pedal doesnt come back up
- Balance shaft Bearing failed at 37K
- Help somthing wrong with my CAR!!
- Identifying Marks on the Kelfords Cams
- Shifter not working correctly
- Help... how do u remove and replace the fuel tank
- evo 8 engine bay
- Precision 5857 vs 6262
- Quiet Clutch = Good Clutch
- Injen intake and intercooler piping?
- Rattle on Startup
- FP BLACK's life on a stock block?
- Car starts then dies...pleasee helpp!
- RE; evo 8/9 RS gearbox ratios
- Greddy Exhaust Q.
- Evo 8 chasis&AEM + evo 9 longblock swap HELP
- Evo engine problems
- ets intercooler Piping
- Best EBC for the money?
- camshaft indentification
- New bushwaker and exedy twin, confusing issue
- speed density with stock turbo
- Installed twin disc now noise when off throttle!!
- Problems accelerating with new clutch
- FP Red Help!!
- New cams...Evo falls on its face
- MAP stock turbo 02 dump
- Larger IC?
- Which downpipe fits the Invidia O2 Housing?
- greddy type s question
- Spark Plug Gap Change for Spoolin' Up COP?
- What spark Plug 7 or 8 with my mods?
- TME 10.5 max boost capacity
- Gettin code 335 & 340
- Tranny help!!
- Can I use a evo 9 t-case in a 03 evo
- read my plugs.....
- question about my idle after tune
- cracking sound coming from front end
- Definitive EVO8 vs EVO9 Turbo Specs
- Tuned, then all hell happens
- Hey Guys! Income tax just came in and need Help
- replacing just the DP
- Motor build options.. please brief a newb...
- what head gasket to use?
- Engine oil leak w/pics
- Is Royal Purple bad for a motor?
- evo flywheel
- Fp Green questions
- rubber hoses and clamps - weird issues
- BF 272 Cams VS Kelford 272,280
- exhaust to loud
- tdo5hr rebuild
- bigger injectors do i need to tune
- Exedy triple carbon questions..
- What to do with ACT clutch?
- ARP L19 Torque Specs **Searched**
- 3065 owners. When are you hitting full boost?
- A-pillar
- Rotten eggs
- fuel pump help
- LR2.4 H or I beams???
- installed ams 6 speed underhood bushings
- Upgrading / Reinforcing the 6 speed
- Stupid question (be gentle)
- APS BOV Sticking Open Please Help
- car smoking
- Need your help!!!!!! Reverse issue
- HKS Elec Idle Stablizer for SSQV
- different type of egt temp ??
- Rough guess on the difference between a .62 and .82 hotside on a 6262?
- GSC S3 for IX on 6262 setup
- what rod to go with?
- Help me find the issue (missing at idle)
- installing kelfords...need advice
- Balance-Shaft-Eliminator-Kit BR V.S AMS
- Turbo shaft play
- how does your gsc s2's idle in your IX?
- Advertised Duration for Comp 272 Cams???
- Exedy Hyper Twin Plate Clutch SD
- Injector Help!!!
- Exedy Stage 2
- any differences between these 2 bpr8es?
- Aftermarket Exhaust Manifold?
- Shifting into 1st gear at what speed
- Torque vs. Horsepower explained by Physics and not Joe Blow dirt track racer.
- Tranny Reinstall .. TOB Problem ...
- So i have a question.
- Forge rs bov question?
- How often to change spark plugs?
- Compression suggestions for a e85/6262 daily driven car.
- Mail in DynoFlash?
- ETS 2.5 FMIC or Ported IM/TB
- build thread
- Buschur Racing Dual Stage Boost controllers!!
- HELP!! car idles fine with maf unplugged
- Who's running a 2.4L Mivec???
- Buschur Racing, Innovators not Imitators, the battery tray
- Rythmic Sound in 5th Gear Only
- washer fluid bad in the long run?
- Old Greddy A/f Data unit... searched WIDEBAND
- Resolved stuttering and low RPM knock
- What is the length of stock cat-converter in EVO VIII???
- Megan o2 & Manifold
- Cylinder wear
- What would cause bent a shift fork?
- Yet another balance shaft and 4g63 q...
- Clutch Pill Removal
- Motor blown? Wont turn over...
