View Full Version : Evo Engine / Turbo / Drivetrain
- Whats the best IC pipe to use 2.5How much lbs/min is PT6262? PT6765? HTA37R? HTA3586?
- For those running AEM EMS and stock frame turbo...
- HELP! I lost my tune
- oil catch can or crankcase breather?
- Fml
- Bolt just spinning help!!
- Starter issues.. Please help
- Is this normal? (cam question)
- Car wont Idle... Stalls out
- vented VS. Non-vented Catch cans
- life expectancy of evo IX battery?
- Mods for SE
- just got my competition clutch stage 4 installed
- MBC hose diameter
- Walbro 255lph Fuel Pump
- HELPPPPP w/ injectors!!
- Help with Code
- Clutch Bleed?
- Wastegate Creep
- head gasket oil leak....
- build or not...
- mega money turbo gaskets
- pulling my motor... help...
- HELP rear drivetrain buck during power shift
- K1 Lightweight Crank worth the cost???
- New Hybrid Turbo
- HELP with a starter problem
- HELP, things are blowing UP IN MY EVO
- Pretty cool veideo....
- Backfire problem...
- 6 speed transmissions for auto cross
- What's a good asking price?
- Just wonderingg..
- HELP "Transfercase" plug missing..........
- EXEDY clutch - whitch to choose?
- Looking for your opinion.
- Removal of Motor,Tcase, Trans in one shot????
- Exhaust Gasket Questions
- Lack of crane cam users
- MFactory 4.0 Final for us 2.3L stroker guys!!
- Is .040 over OK on a 2.3 stroker?
- FP RED injector size?
- FP red new 80mm compressor cover
- Rear Diff Whining??
- evo 8 turbo w/10.5 hotside which wga to use?
- 4G64/63 power capabilties
- Deatschwerks Injector Service
- Pros vs Cons of boring your engine!?
- help diagnose pls
- Last clutch questions before I order...
- Revolver Cams vs. Kelford 272
- Boost Leak at Intake Manifold?
- Kart boy bushing
- Jun 272 or HKS 280
- battery and brake light come on today
- Hesitation during intial drive?
- ACD C161e Code
- Loss of Power??
- Boost Issue
- Engine rebuild recommendations
- EVO clutch opinions
- Stock Pistons on Aftermarket Rods vs stock rods w/ arp rod bolts
- my ball bearing 9 turbo (video)
- Help! Wont Start!!
- 20g surge question
- My Tranny Died on me.
- "Special" EVO Build
- good daily driving clutch?
- Just put the Tial on (vid)
- Wiring diagram for Bosch 15733 on a 2004 EVO
- valve seals keep getting pulled off guide
- Boost leak or not?
- grinding noise
- Don't care 4 the fix, I wanna know why. (cruddy shifting)
- Quick Question, LSD
- Where's the best place to get?
- DSM problem in my evo DIPSTICK !
- HKS DLI install guide
- Solved my 6spd 1st and Reverse prob
- I have one question? for evo 8
- Changing shifter base bushings on an MR
- Engine Codes GRR..
- ARP Flywheel Bolts
- Help! Turbo is whining?
- Pics - New Head Install
- Part Number for axle seal
- Modding advice...Need some help.
- need help,can't boost past 14 psi
- Generous present.....or bad luck??
- Question about porting
- New O2 sensor, now won't Start HELP!!!
- Defi boost gauge gone bad
- TOB removal HELP!!!
- turbo gasket kit
- EVOLUTION VIII oil cap
- Where can I get...
- Boost leak? or not?
- epm dump question
- ACT clutch
- Flywheel/Clutch Inspection Question
- SAFE EGTs...Please advice!
- Downshift whine
- NEED HELP ASAP leaking ACD bleeder
- Need help with my turbo gauge
- Need Help Car Wont Start
- issue with my basically new clutch, maybe someone can help?
- APS Bov
- CWiLL & TD Autowerkes team 780whp Build
- For those of you with a big turbo I need your help
- Rattle from Engine, Any Ideas?
- 880cc injectors
- do i need injectors for a fpgreen?
- Pcv system ?
- Boost & Spark Plugs go hand in hand?
- Help! Evo 7 GSR AYC DRAIN BATTERY
- What bolt size to plug up O2 bung?
- Clutch Noise
- Replacing Clutch On Evo IX
- boosting issues?
- AWD Motorsports Evo RS.. Precision Billet 67mm.. 818whp / 588tq!!!
- External Fuel Pump
- 2.3l strocker w/ i-beam ques.
- non stock plugs for evo 8 (no coppers please...)
- wow i feel like a newb
- Boost leak test and trange results...
- Temp transmission and tcase fluid?
- boost problems
- 5th gear misfire
- QTP hitting tranny on 'takeoff'..helpz
- turbosmart bov
- CBRD Rad into EVO 6
- Slave Cylinder Extension Rod
- aem wideband at 14.8 currently
- ets pt 61mm prob
- High Boost and Engine life?
- Two exhaust systems - which one to go with
- Synapse BOV & Injen kit
- could somone explain something for me?
- Whats The Point Of This Cover
- ACT guys . . . describe your lockout/shifting problems
- Weird idle Q
- Fan switch questions
- reving
- question: is it bad to have no 02 sensers?
- Odd clutch pedal movement, Ideas?
- Best LICP?
- any vertical ICs out there?
- EVO 9 Oil drain bolt
- Oil gunk on single spark plug.....
- Has anyone used this tool for valve springs???
- JIC Spartan Info
- Flat spot during WOT?
- hta vs...
- Radiator Support the same as Lancer?
- p0300 random misfire!!!!
- Question: Evo 8(2005) to a FP Red??
- HKS Turbo Timer.. Sometimes it works, other times it just turns off..
- 2004 Non-ACD, Front LSD
- Big thanks to STM
- O2 housing sensor
- ETS short route with ETS intake (pics)
- flywheel question
- NEED HELP fast. Plug tip broke
- HTA68: Any plans for the Evo?
- Tanabe Concept G exhaust for EVO X, too loud?
- GSC S1 or Kelford 264 cams???
- Getting the intake manifold off
- Oil on exhaust manifold stud???
- Piston to Wall Clearance - Various Piston Manufacturers Recommendations
- A/C COmpressor Troubleshooting
- 2.0 Build
- Anyone else have an ebay exhaust??
- New turbo for Evo IV?
- VP Q16 116MON race gas on 98 pump
- BOV doesn't sound anymore?
- evo 4g64 with 20g turbo
- NEED HELP?! whats happening?
- DTC 0121 with Tial BOV>>??
- ULTIMATE streetcar? Opinions
- oil light
- What is this knob on the fuel pressure solenoid for?
- Clutch Help ASAP
- went through a puddle..now im smokin!
- HELP! wierd noise at idle
- Clutch Advice Required
- OEM Headgsket Thickness
- mishimoto evo 4/5/6 radiator install
- Need help!!!ACD probleme
- gt30r
- Anyone ever rebuild their Exedy Twin? Results?
- Tomei 2.3L stroker specs
- My Cam and Spring Purchase
- Time for rebuild????
- Trying to build my Tranny need help!!
- Does anyone have an ARC oil catch can installed in their car?
- Just changed clutch line and bled it, have question
- Transfer case
- What do you guys think?
- speed density
- Question about timing belt service...
- HKS catback w/o resonator + taper
- Intercooler outlet size??
- Exedy twin wedge collar
- Clutch install 56k chillax right where your at...
- about how much whp?
- compression test results???
- White smoke when I turn the car on
- Weapon R Engine Torque Damper Question
- METRIC NPT and PT DEFI EGT
- oil in the intake question
- Dyno Speculation?? What will new numbers be?
- Engine noise, please help!!!
- what could it be?
- Street Or Race ACL Bearings ?
- **Product Release**AMS Mitsubishi Lancer Evolution VIII-IX Radiator Hose Kit
- Power output for Evo 8 with Stock Cams?
- Silicone Hoses
- Dead clutch pedal!!!!
- Main reasons for compression surge???
- Clutch Restrictor
- Cam question...interesting. No power after 5k rpms?
- Bleeding Clutch ...
- help needed asap
- Turbo comparo
- GReddy EasyCam 264/264 - anyone own these?
- CAT problem
- straight pipe catback
- anyone have this problem with their ARC oil cap?
- A/C problem
- Need a Part #
- worth porting a 10.5 housing?
- another rattle question..
- Questions on piston to wall clearance
- EVO VIII Blow Through MAF
- Fuel lines and fuel set up?
- Another coolant temp problem
- NGK BPR7ES Spark plugs (Discontinued ?????)
- How much power i can make with One Cam
- where should i run these vacuum lines..
- weird idle during rain
- Are you running a 3-Speed "Scatter Shield"
- Car won't hold idle ?!?!
- how much to get to 400
- Weight of Evo8 shortblock
- Rear o2 Sensor Removal / reprecussions
- cant boost past 12psi, need help
