- AP bov...rpms weird
- 5 speed into MR swap thread!
- Oil cooler line threads/pitch
- Rear LSD
- does anyone has a pic of stock bov on evolution????
- 6765 or 6262???? help please
- swap i/m and t/b
- What's better?
- BOV question on high mileage EVO
- Stage 1 vs OEM
- Act hdss not disengaging properly (new)
- how to clean wash Evo 8 head ?
- I have a fp red on my car and supporting and the boost spikes to 27psi, what should i
- Perrin Intake Tube (Blue) problems
- too much boost with ecuboost control/5th gear flutter help!
- whistle/ grinding sound... help!
- Car heating up, need advice
- hey wondering how to tell if i have a bigger wheel
- What type of engine oil to use
- High Temp Gasket Maker
- Transfer Case Diff Help
- FP Red Wait List
- Spark plugs.
- FP Red on stock 83,000 mile block
- Timing Belts
- bov fluttering?
- Help, turbo Xs D.P, Evo8
- Turbo back catted exhaust
- Slave/Master Cylinders
- Noise after releasing throttle
- too much boost/boost flutter in 5th gear help please!
- 1320awd buildup
- Head torque pattern order???
- trouble with leaking air from bov
- Engine prefix identification
- Stock Exhaust Bolt-Nut Sizes
- Tranny problem please help!!!
- Bushur and fp red turbo?
- Clutch: Decisions, decisions...
- Oil pan gasket
- Car stuttering on WOT.
- Blacken, overheated rod cap?
- Super rich under 2k, -4 vacuum at idle
- Megan Racing O2 Housing Issues?
- would 05 ecu work? with my 03
- ati, stock, or fluidampr?
- major install done by ME!
- Custom Mivec Feed line?? Braided steel line
- Tcase or rear diff
- problem with car driving
- o2 sensor cracked?
- Downpipe fitment
- new motor nee some help
- Dirty MAF Sensor?
- low end flottering? help
- New Evo IX MR, tranny bucking/ clutch noise
- Wastegate overboost and boost creep
- help with excessive coolant usage
- Whats the best 02 housing?
- HKS TWIN POWER ign
- I crashed my car!!!:'(
- Where is stock maf connector?
- Dipstick blown out
- Identify This Diff
- Glove Box Power Source
- FP Red Boost Creep
- Turbo info for beginners...
- need help, coolant question
- Motor Rebuild - What am I missing?
- info: will a stock muffler hot the turbo seals if i have 3' dp???
- Whine/Whistle/Whir from somewhere mid-car or up front.
- Mishimoto Radiator Installed Pics
- anyone have the vibrant maf adapter/filter ..... cheep!
- port and polish head??? Worth it??
- AEM to stock ecu = No start
- Cold engine noise
- Bov........
- Clutch/Transmission problems
- New clutch blues
- question about strokers
- 2.3L Rebuild. Someone Point Me In The Right Direction
- carbon build-up
- Cams are VERY noticeable after 2.3L install
- motor blows again :(
- Thick white smoke from exhaust, not coolant. Need expert opinion please!
- E85 and 91 octane??
- SparkTech Sequential COP on Procco/CFT EVO breaks 1000whp!
- Change in idle AFR after tubular O2 install?
- Change if idle AFR after tubular O2 instal?
- Worth Porting Stock Intake Manifold?
- Cam damage / scoring
- Anyone know what exhaust this is... (pics)
- Single Scroll GT3076R vs HTA35R or FPRED... for stock motor, need input
- Buschur Catch Can Condenstation in Oil..Anyone Else have this?
- RMR filter kit not fitting
- Whats goin on somebody help - idle problems
- Trans Help
- Help with p0069 cel
- High Idle ~ 2,500 rpm?
- Going with exedy quick question.
- what the best turbo for daily & drag use for evo4 ? fp green, red or GT28, OR ???
- Cam install ?!?!?!
- 550Plus WHP what clutch
- Help with Whine!!
- Car Jerking at WOT
- injen ic piping causing problems??
- msd dis-2 2 channel ignition on evo ix?
- Exedy Twin SD convert to HD
- Powertrain Technology Twin Disc Clutch Kit or QuarterMaster Twin Disc
- Picture Request: Stock intercooler pipe bracket?
- 2003 evo 8 turbo?
- Very weird problem....any help appreciated!!
- Break in for a new turbocharger?
- Evo Bolt-On 75mm Billet Throttle Body ( A MUST SEE PRODUCT )
- help!!!
- boost problem. help please
- Clutch Kit...
- Put in Mini Battery- Gettin Lower Boost
- Oil in catch cans (DC2) ??
- Compression results, leak down test results, and questions...
- help plz
- max hp with denso 720cc injectors???
- Buschur HTA 37R kit question
- WTF!?! Random misfire happening around 3k RPMs at 71-74 MPH in 5th gear only.
- 40+psi boost gauges
- 05 RS starting problems
- Turbo woes... your thoughts please!
- eBay ARC intake copy?
- Tranny
- How to measure turbine housing size
- Shifting when it's cold
- stock downpipe + 3" cat-back - how far have you gone?
- Greddy Turbo Timer not working properly
- Spark plugs
- help with Dynatek ignition
- Need Help !!!
- Most Horsepower on Daily Driven Stock Block?
- How many have modified their walbro (bypass mod), is it still running?
- FP Red with only meth and TBE
- Question that's got everyone stumped
- Our engines are air pumps!
- New Clutch for XI!
- Bigger clutch master cylinder
- Quick question...twin disc clutch engagement
- ACD 3 solid lights after transfercasse replacement
- Cutout exhaust, safe?
- Upgrade Intercooler??
- Anybody running Kelford 280's?(non-Mivec) Please share your results here!
- LICP Question
- Can't boost past 10psi...wastegate and vacuum lines ok!!
- Quick question... ACT clutch slipping
- HELP with high HP clutch decision.
- need help with car
- Clutch Shutter / Chatter
- What oil to use?
- Car wont start
- trans in and out 3 times this last week
- stock IX, 16psi max? -help please
- 2 Issues I'd like to resolve before...
- Lil Help?
- is there a single MAP sensor I can use for everything?
- Exhaust size
- Engine rebuild suggestions?
- Big Strokers: Low Rod Ratio Real World Durability
- Warranty covered????
- HELP: used hks cams
- What do you guys think ?
- FP Red failure
- transfer case
- Fujitsubo RM01A
- Exedy twin plate question
- Evo race bearings PLEASE HELP
- MBC back to stock...help a moron out
- People happy with the Buscher ported stock manifold?
- Lifespan of a tubular manifold
- 4g63 turbo block in Evo 8
- 6262/HTA86 or 6765/HTA88??
- Ebay Catch Can
- Question for u guys
- What is this solenoid?
- Is This Normal??
- Megan o2 housing different than the old ebay o2 housing?
- "Heavy Shockproof" review...
- check engine
- BlowOff Valve: Have Recirc or Move MAF sensor
- Help: Super Rich Idle
- AMS lower clutch line
- 02 housing
- Spark plugs affecting tune
- Getting ready to install Walbro 255
- Installing Manley I-Beam Rods ... HELP!
- banging from the rear during quick shifts
- ACD help
- Please Advise---Wont Reach Boost
- Who is running modified walbro - releif valve closed?
- Gas mileage and cams
- Built 2.0 or 2.3, and which Turbo??
- RPM Skipping HELP
- Samco vs. Perrin intake pipe
- EVO 9 GSC S1 cam owners or anyone...
- Need a Part Number
- Upgrade FMIC Intercooler
- blow off valve
- Having issues!!!!!!!!!!!!!!!!!
- Turbonetics MBC?
- 2006 Evo IX turbo lag!
- GREDDY cam gears out of balance??
- Clutch bleeding issue.
- ams tbe owners
- would like 450awhp
- Is it worth it
- Help me decide if to upgrade to the HTA 86 or not
- Evo cutting out.
- 550whp on pump gas
- 50trim upgraded to a 35r PICS INSIDE.
- hks intake cam upgrade
- DSM 1/2g Cam gears on evo 8??? marks r in different locations
- FIC injector question with large Pics !
- Big jolt when I let off the gas at high RPM.
- what clutch for 6 speed?
- where to buy motor mount inserts other than AMS
- Slowly using Coolant From Reservoir!?
- 9 turbo on an 8 only hitting 24psi...
- Ouch
- Is this normal?
- Weird sound while tuning...Head Damage?
- ATTENTION all ETS intake and upper IC pipe owners
- part # question
- Intake problem
- Loss Of Power
- Fuel Injectors
- Vibrating clutch pedal
- Help: Car breaking up badly
- Opinions on Budget Upgrades
- Looking to upgrade from the pt67
- Car sounds like a WRX?
- Tomei 260 Cams
- Ticking Noise coming from engine
- from stock turbo to hta86
- ? about T-ing the vac lines on Syn BOV
- Can't make up my decision on a transmission
- Clutch ? fadanze clutch...
- act clutch slipping
- forge "splitter" bov
- hey guys i was wondering how many miles should u change your timeing belt
- Reverse gear on 6 speed grinding only
- BBK or keep meth or both?
- Corroded stater wire
- 2.3L on stock ecu?
