PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Evo 9 Whine in 1st Gear
  2. Dont know what turbo is right for my evo
  3. I need help asap
  4. How bad did I mess this up?
  5. Car goes lean when its warmed up like 14-15 AFR at WOT
  6. OEM part# for the 4G64 crankshaft
  7. 4g64 weight match or full balance?
  8. Future build input-FP green HTA
  9. Please help identify the oil leak!?
  10. evo 9 intake manifold
  11. So I started porting my head today
  12. Anyone with Evo 8/9 running the Topspeed single exhaust?
  13. 88mm, 94mm or 100mm crank with EFR
  14. [FS]Evo 9 bare head
  15. Camshaft upgrade
  16. machining FP EVO9 compressor cover?
  17. FP Red JB evo 9 data request
  18. Main/rod clearance question for build and other tid bits
  19. no power to fuel pump or injector?
  20. Best engine oil brand
  21. comp twin disc slipping already??
  22. Car is jerking when releasing the gas pedal
  23. Help! No Alt Charge No Dash Lights
  24. Forward facing T4 ts manifold for evo 6
  25. Perrin intake replacement foam filter
  26. 4g63T band new block main bore issue
  27. Which cams?
  28. Engine dies
  29. Condenser Fan Replacement
  30. Evo 8 Won't Pass 10 PSI
  31. Compressor Housing Nipple on PTE Turbo
  32. 9174 or 9180
  33. Exedy vs Competition
  34. Oil pan bolts
  35. Best Turbo for track??
  36. Feedback on Torque Solution Mustache Bar Eliminator
  37. need part number for shift linkage clip/washer
  38. Main Bearing Girdle Dowels?????
  39. evo 8 vs. 9 parts compatibility?
  40. Oil pressure concerns
  41. Using different lifters
  42. squeaky clutch pedal
  43. Needing some advice for my DD
  44. Evo 7 gta auto tranny in evo 8?
  45. Turbo decision
  46. What can make AFRs change so randomly
  47. Does anybody make a lightweight IX starter?
  48. turbo manifold
  49. issues with map sensor! need help
  50. 2.4 LR w/6870
  51. I am about to burn this thing. Need some help guys!!
  52. how much power u think i can make?
  53. What flywheel is this!?
  54. Evo IX piston rods full stuck in evo IV engine.
  55. Evo 8 head build
  56. 1 Step colder plugs to combat knock??
  57. Exhaust Clinking
  58. Kunigawa 25g compressor map is here
  59. Turbo Coolant Plugs
  60. Surge tank decisions: Is a surge tank necessary if you keep your tank full?
  61. Built Evo 8 Goes Lean at 2500 RPM
  62. evo 8 hotside on evo 9 turbo?
  63. Precision 6870 now in T3, opinions?
  64. Need Help! Wastegate question
  65. Will a EVO 5-6 transmission fit in evo 9?
  66. Drivetrain Loss on Dyno: Tire size & ACD/AYC
  67. Methanol Nozzle
  68. Can't decide on turbo
  69. MAP T3 Kit with larger Mishimoto Rad
  70. Noise/vibration after timing belt and cam/head work. Not likely balance shafts.
  71. Good t4 twin scroll housing 35r
  72. What is the Description of this?
  73. Bought used gt35r bad seals?
  74. GSC springs not enough lift for Kelford 272?
  75. evo 9 wideband install
  76. Do FP JB SS turbos leak?
  77. Cant make more then 500hp. Stumped-Help!
  78. Thoughts on new GSC S1 Billet
  79. Rebuilding Evo 4 block to prevent crankwalk
  80. k1 rods..?
  81. Leaky FP Zero
  82. Inter cooler piping question.
  83. Evo ix hard to shift keeps blowing ignition fuse
  84. Built 2.0L's
  85. FP Black flow rating changed?
  86. Timing belt issues!!! Need help
  87. So since Precision is taking forever to diagnose and quote the cost to fix......
  88. evo 8 5 speed bell housing
  89. what about HKS CAMS ON A FP BLACK TURBO?
  90. Problems after rebuild.
  91. what causes broken balance shaft belt?
  92. New build.. Which turbo?!
  93. Re-use clutch after transmission swap?
  94. HELP. Evo 8 Cam Identification
  95. HELP: Evo 9, no boost, loud whistle, hanging hose
  96. HELP Evo 7-9 non ACD Trans Case
  97. Rod bolts
  98. Review: FP 71HTA
  99. gsc s2 cams upgrade evo 9
  100. external wastage flutter?
  101. Car stuttering and afr at wtom going lean to 13:3
  102. help plz !
  103. Evo IX Crank Gear set after TDC
  104. Evo newbie
  105. DANGER! Could starting fluid have damaged my new motor?
  106. rebuilt head/timing belt installed. Car won't start now
  107. Porting stock exhaust manifold vs fp race manifold (what will yield more gains)
  108. Elapsed time, boost leak test.
  109. HKS 7460R question:
  110. Anyone using the Map T3 Kits?
  111. Compressor Surge with S2's?
  112. NEED HELP! Rpm Spike
  113. Evo IV - Need help with vac routing
  114. evo 9 engine stalls when you push clutch in
  115. Leaking Mishimoto Radiator ...again
  116. Intermittent breakup or misfire in boost
  117. HTA71 or HTA73 for e9 value
  118. Fan causing idling issues
  119. Cracked manifold, Greddy TD06-25G kit, need to find replacement!
  120. Off Timing after Cambelt Change Evo 5 - extremely poor acceleration
  121. Modifying Evo 9 cams to fit into Evo 8 heads
  122. Oil pressure drops in 2nd gear WOT, but not in 3rd
  123. Engine stalling
  124. Repairable Hotside?
  125. Ferrea Comp Plus vs Super Alloy
  126. Substantial drop in RPMs after lifting
  127. Cracked hot side = okay?
  128. what gasket set for Evo 9 with an 8 block
  129. No power to fuel pump
  130. Exedy twin brainstorming
  131. My FP Green won't boost over 18PSI. Please help!
  132. Hole in Evo IX transfer case
  133. Hole in Evo IX transfer case
  134. transmission issue please read
  135. Clutch with better drivability than Exedy Tripple?
  136. Stock rubber intake pipe size
  137. Clutch Noise
  138. Help with shifting and w/transmission, please
  139. Boost leak test = air from oil cap/dipstick
  140. Walbro standard 255lph to 255HP
  141. Leak from intake manifold? Help
  142. Evo rich at idle and during spool up
  143. 06' Evo IX tachometer jumping / car sputtering!
  144. HKS EVC VI Guide
  145. Quieter exhaust options
  146. Gear box, not getting 3rd and 4th gear
  147. Help!! What threaded plug is this on my VIII block
  148. Head Gasket 101
  149. Stock Throttle Body Replacement?
  150. Evo 9 5 Speed Clutch Side Bell Housing
  151. ACD pump connector question
  152. which valves to choose...?
  153. Engine Failure Question
  154. Turbo was taken apart. Need help to line up like stock.
  155. Too much fluid =leaking?
  156. QM 8 leg street problem
  157. Hood vented downpipe with an electric cutout to dampen the noise!!!!! Who tried it???
  158. injectors bosch
  159. Please Help: Headgasket Dilemma
  160. Borgwarner S369SXE (9180) w/Tial v-band Turbine Housing
  161. Idle high p0507 and rich idle
  162. 4g64 block 87mm bore
  163. V-band test pipe?
  164. motor problems... cams or cam sensor.??
  165. Clutch Recommendations
  166. Turbo seals starting to go? Or rings
  167. new motor strker :)
  168. Pulling Motor Question
  169. New Fuel Pump Pressure Issues
  170. evo ix intake
  171. Grinding small end of Manley I-beam rods for Wiseco asymm piston fitment?
  172. Any difference between 4g64 crankshaft key and 4g63?
  173. Can you reinforce a 6speed MR Tranny?
  174. 6 speed to 5 speed
  175. Problem with transfer or what? Video inside
  176. Air intake
  177. Bottom end swap set for 10/15 & I need your help!!!
  178. S200SX-56 turbine sizing
  179. Rear dif making clickin noise need advice
  180. Rear diff rebuild *pics*
  181. Tial 50mm boost leak
  182. Turbo advice - Help! EVO 9
  183. whining sound from tranny only in 1 to 6 gear, not reverse gear
  184. intake pipe options for FP 84mm compressor covers
  185. Evo 4 rear diff ayc problems !!!
  186. Garrett gt3076r turbo set up?
  187. Gruppe-S flywheel propper "step" with ACT HD 6 puck?
  188. Is it possible to install your own stroker kit?
  189. Engine Revs After Boost and Clutch
  190. fairly deep indent around exhaust valve
  191. Could not start engine due to anti-lock
  192. Shift cables, adjustment, and trans case issue?
  193. Injector Duty Cycle
  194. Divided manifold to single wastegate question
  195. Walbro 450 Not Getting Power
  196. vibration when hitting the brake
  197. Clutch Question
  198. Curious about a BOV
  199. Thoughts on new setup
  200. Evo9 compressor housing dimensions
  201. What hoses should I inspect/replace?
  202. Help please. Bad vibration from driveshaft with balance shaft deleted
  203. Evo 4 Turbo Inlet Size?
  204. Optimal 2nd Pump Engagement RPM
  205. Evo IV Oil Leak mystery
  206. P0125 code?
  207. In the market for a new turbo, Xona Rotor?
  208. Problem with Bogging/Loss of Power around 4k RPMS
  209. Blowing smoke under boost
  210. Need help with a "what cams are these" question
  211. smoke on decel BRAND NEW VALVE SEALS
  212. ALS wondering cable
  213. Oil scraper questions!!! Need answer
  214. Looking for Evo1 Transmission parts
  215. 0psi on boost leak test
  216. valve spring retainer locks
  217. Rear diff plate about to crack!
  218. Compression woes. Rebuilding head recommendations?
  219. Slightly rough idle, stumble on pulling away
  220. AMSOIL 20w50 during winter?
  221. Balance shaft too tight?
  222. Which cams would resemble stock as close as possible
  223. Fuel Pressure Regulator Problem
  224. fp black stock block
  225. Front drive shaft issues
  226. Odd case evo 9 build questions
  227. When do the stock valves become a restriction?
  228. Evo ix Ayc acd !!!! Urgent help needed......
  229. Very odd oil leak
  230. Bucking under boost
  231. cutting out during normal cruising
  232. Cryogenic Treatment
  233. Rich idle out of nowhere
  234. Donkey Power Injection 1200cc Review
  235. Clutch recommend
  236. Okada plasma coils
  237. What size cams should I run?
  238. Catch Can Advice
  239. evo 8 build dd
  240. 2.3L Piston advice
  241. Evo 5 speed swap
  242. evo 8 head
  243. Oil pressure drop at high RPM
  244. What cams are you running on 2.4LR?
  245. Trying to make a boost cut failsafe
  246. Banjo bolt on head for turbo feed line M10x1.5?
  247. Seeking expert help,Evo IX Launch behaves like ABS lock, Drivetrain keeps breaking
  248. My crankcase pressure issues.
  249. does new oem head and oem vales need lapping?
  250. The infamous P0011 code. Any one figure out a fix?
