PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Boost Logic BB Turbo kit?
  2. Turbo newb question
  3. FP Turbo rebuild wait time.
  4. abs pinouts
  5. Damaged/Chipped Cam
  6. 35R fittings
  7. Issues After 2nd 60k Service
  8. Adjusting forge WGA
  9. OBX Ramhorn Racing Turbo Manifold
  10. Is the HKS T51 SPL compressor housing the same as the GT40 compressor housing
  11. Head porting??
  12. oem shift retainer for short throw
  13. Grounding problem, problems starting car
  14. New FP 71HTA?!?!?!
  15. Injectors
  16. trouble bleeding ACD
  17. one WG on divided manifold ?
  18. Which blocks can I use?
  19. Reflective Gold Heat Barrier Foil
  20. Map stage 2 block??
  21. Tested: 1 million cycles Synchronic BOV/DV durability
  22. planning on doing a mirage to evo 6 conversion have a couple Q's
  23. Greddy Exhaust help please!
  24. best bov for evo9 mr
  25. AEM analog boost gauge not reading right
  26. GTX vs HTA 3582 turbos
  27. Help me with my set up
  28. windshield wipers and acd lights
  29. BBK Full wastegate actuator
  30. Timing belt failure at 57k
  31. oil pressures after oil cooler delete
  32. FP Black SD Intake advice
  33. oil/fluid leaking/burning after clutch replacement?
  34. FP Red rebuild in another shop other than FP?
  35. Clutch Discs: Sprung vs. Unsprung
  36. 5th gear vibration
  37. Bad Bish, episode XXX, picture and new build thread
  38. fp black + o2 dump - noob question
  39. i have a p0365 on my evo 9
  40. sub frame stud
  41. Tial BOV -vs- Synapse DV -vs- Cobb BPV ??
  42. Gear linkage help needed
  43. 03 Evo loss of power on Hwy
  44. Will the HKS cam gears work on Evo 9 ???
  45. Hard to pull out of 6 gear
  46. Junkyard head build project
  47. HELP! Need to identify cams
  48. Shearer Fab 6262 Kit with ETS LP2?
  49. Competition Twin pedal adjustment
  50. hks evc III connecting problem evo 4 with bov...
  51. Ets intercooler vs garrret intercooler
  52. turbo upgrade advice
  53. 84mm FP Compessor Cover?
  54. Subtle humming noise with shep tranny and t/c
  55. FP Green with 12 blade exhaust wheel?
  56. 10:1 compression with stroker
  57. buschur motor after a hard day of racing
  58. tranny staying in neutral - help!
  59. Mike Reichen's data acuistion stats with the 80mm Borg Warner
  60. Exedy compe-r twin flywheel & plates fried?
  61. New quarter Master TQ capacity?
  62. Gt3076 .63 upgrade to .82
  63. BC cutsom age 625+ vs Carillo CARR
  64. Trust Power Extreme II exhaust for Evo 8
  65. 4 bolt discharge flanges
  66. Knock prone stroker motors. Guru's help plz
  67. whining sound on the move.....Help
  68. VERRRRY WEIRD clutch problem! engagement\driving
  69. WHining sound with clutch out
  70. Crank scraper w/ stroker?
  71. GT4094R hta conversion
  72. HKS 272 cams
  73. How to recognize bad Idle Control Valve???
  74. Another Battery Reloation thread...Feedback wanted please...
  75. building my first evo engine
  76. Throttle cable sticking?
  77. Transfer case swap
  78. Full Blown dual walbro pump help
  79. HELP!!! cant find where this goes.
  80. screeching noise with clutch pushed in - quartermaster twin disc
  81. Fp Red vs Fp Green
  82. Omni sensor leak
  83. 1 pc drive shaft
  84. Best Clutch Kit for Evo 8 DD
  85. invidia housing
  86. My car stalls - not because of bov.
  87. FIC Injector on a PFC Ecu Question...
  88. A quick alternator question
  89. FIC 1100 Install
  90. 11:1 CR on E85
  91. Rattling noise with whine
  92. Injectors for FP Black stock longblock
  93. Any back to back comparison of HKS 7460R and 9RS Turbos ?
  94. Stock turbo & block with meth?
  95. What do you think about this?
  96. Anyone here using this?
  97. i keep breaking my serpentine belt tensioner
  98. Ikeya shifter and QM twin review
  99. No compression on rebuilt motor? Will not start.
  100. Turbosmart Dual Port BOV Review...
  101. Competition Clutch Stage 2 VS EXEDY Stage 1 kit
  102. ctg torgline vs driveshaft..Help me..
  103. Home made O2 Dump
  104. vacuum, bov, hks evc, fpr lines routing pls help guys...
  105. can someone tell me where these pipes should be attaches to?
  106. Idle drop???
  107. What Muffler/Exhaust is this?
  108. Strange noise on decel
  109. GSC 280 cams 0r.....
  110. Installed bf272s now starting is horrible
  111. 3" GM MAF Question
  112. 60k service questions
  113. Evo w/ E85 and n20?
  114. Advice please
  115. Exaust Header Manifolds on Ebay
  116. Rear Diff issue...easy fix or re-build?
  117. cel fast flash in 4th gear between 6-7rpms
  118. (Video) Backfire type nose (Pop Pop Pop) At WOT
  119. Is it OK to Clean and Paint thr Turbo?
  120. Big vs Small throttle body
  121. Vibrating rearend
  122. tOMEi valve spring & retainer.
  123. AWD Motorsports transfer case questions
  124. Wazmunstr - My transmission rebuild thread
  125. PTB Surging Issue
  126. Best cheapest place to get turbo/manifold gasket
  127. When it is freezing outside.....
  128. oil feed line question?
  129. Safety on stock block HTA Green or RED
  130. Anyone get ther used FR RED covered under warranty
  131. HKS 7460r on stock block and 93 pump?
  132. T3 manifold adapter
  133. I need ABS advice!
  134. Swap bullet muffler for s.d jdm rear muffler???
  135. Another FP Red bites the dust.
  136. Possiable Exhaust Leak
  137. Smoke from catch can outlet
  138. Where does everyone buy there silicone couplers and t clamps?
  139. 2.0 vs 2.3 Injector Duty
  140. FP factory feed line plug
  141. 5th Gear Issue...
  142. Boost Creep Help
  143. Clutch Swap
  144. 1,000cc PTE injectors on stock turbo?
  145. Drag suspension setup?
  146. Ngk brk6es
  147. Fuel pump issue need help
  148. Input/Output shaft....Can't get it in! lol
  149. Battery Reset - Cars running like crap!
  150. Old FP Green vs. new 73HTA Green
  151. what cams fp black 2.4
  152. ACD Problem-All 3 lights on
  153. Quick question reguarding shift linkage
  154. A/C Condensor Question
  155. Tial Q vs Tial 50 MM original comparison!!Must read!!
  156. removing front axle
  157. Is this the old FP Green?
  158. Help: new Gates tb, very loud, turbo probs
  159. Evo 9 Turbo swap, Tuning??
  160. No Downpipe?
  161. Why we dont use spacers
  162. Competition Clutch Twin - Another Review..
  163. Oil Light On
  164. should i go FP Black on my Buschur Build 2.0?
  165. 500hp 64mm red, thinking about swapping my buddy club cams
  166. Anyone running the Wilson Billet intake Manifold?
  167. WHATS expected to break over 700 awhp
  168. The proper clutch adjustment spec
  169. Breaking in a built motor?
  170. Putting stock motoer and stock ECU back in do I need to custom flash and dyno
  171. Supporting Modz
  172. Transfer case shim
  173. Dual gauges
  174. TORN between turbo choices. Im losing sleep over this!!
  175. Weird noise coming from my exedy triple
  176. Cool Vid - HKS GTII 7460R
  177. Oil Cooler
  178. AMS vs. Magnus
  179. Removed Heater Core: Need to recirculate lines?
  180. Iac
  181. MY 2.4l lr winter project / build thread
  182. can any1 tell me what this noise could be?
  183. Buy a built head or build head (if you have a good core)
  184. Is my friends tranny screwed??
  185. injector sizes?
  186. turbo info for my stock block
  187. what flange does the buschur cast hta3582 use?
  188. thoughts on cutting radiator?
  189. best stage 2 cams for evo 8
  190. Help: HKS 272/278
  191. Fullblown 1/4 Sputter
  192. Turbo blanket for stock turbo?
  193. About setting timing belt
  194. clutch pedal wont move
  195. how to tell a 9.8 hotside from a 10.5 hotside?
  196. Mikey's Single Scroll FP Black
  197. phantom knock! or real knock?
  198. Redline MT-85 Initial Review
  199. Fuel Pressure Dropping
  200. 2.5" vs 3" .82 Turbine Housings - Any Gains??
  201. LR2.4L engine break-in oil recommendations
  202. Any thoughts on the K&N Apollo
  203. Idle drops and stall during cold start and when the fan turns on
  204. Found hooked up o2 sensor under my pass seat
  205. Intake Manifold porting
  206. Car will crank but no Start
  207. QM Clutch pedal to floor
  208. help with 4g64/63 timing marks
  209. Some confusion on fuel injectors
  210. Difference in Evo 4 to 8 drivetrain?
  211. Fluctuating boost...too much wg preload?
  212. Wastegate ??
  213. 2.4 variations and long rod
  214. Which Clutch Kit to Use
  215. Anyone max out their HTA FP-GRN?
  216. who's maxed out their hts grn?
  217. Bushwhacker Transmission/ Clutch Problem w/Video
  218. supertech valve seals
  219. bov location
  220. Too much Knock?
  221. HELP:Weird Over Boosting issue
  222. Evo X and Outlander Sport
  223. awful grind
  224. Output shaft has a lot of play, normal?
  225. 9500 rpm setup?
  226. Evo Bottom End--What's letting go?
  227. Fluidampr part number for Evo 8/9 application?
  228. to 2.4 guys
  229. What is the best Turbo for my Engine Set Up?
  230. Blown Transmission?
  231. JIC bullet sus. who has one??
  232. Tcase blown, (and shaft from cv to tcase)
  233. FPGreen external waste gate
  234. Ngk iridium plugs for 500+whp?
  235. Replacing Evo9 Clutch for $1800 reasonable??
  236. Synchronic BOV & DV Reivew by MotoIQ.com
  237. 2nd OEM Head gasket leaking.... Whats a good aftermarket?
  238. help oil light stays on!!!
  239. Bushwacker trans making whining noise
  240. hard to get into gear when cold, clutch adjustment or fluid?
  241. What do you think about this Turbo?
  242. Piston to wall clearance confusion
  243. Evo 9 MR's tranny
  244. id 2200 injector problem...
  245. replacing water pump?
  246. SUPERTECH VALVES +2mm?
  247. evo rocker arms really needed?
  248. Tcase/tranny/diff fluids
  249. Passenger side axle stuck on output shaft???
  250. Odd Rear end thumping and shaking
