PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 [156] 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Power Enterprise Install Pictures
  2. 10.5 hot side
  3. anyone know the bolt size for a 4 bolt gt turbo downpipe?
  4. Question about TurboSmart BOV
  5. Question about Tilton Clutch.
  6. Where to get HKS Spec-R?
  7. Pulled my CEL code, but do I need a new o2 sensor???
  8. HKS 280's...
  9. Ambient -> Post-Intercooler Temps
  10. Evo IX idle sound
  11. EvoGreen and Meth
  12. What DP the mates w/stock cat?
  13. Stock Cat Back Exhaust More Torque?
  14. IX Tranny help!!!
  15. Please help me choose a turbo
  16. anyone make a maf adaptor to fit a 4 inch cone?
  17. forge wastegate (uncontrollable boost)
  18. fuel pump electrical harness
  19. any one have dyno gains of 264/272 cams untuned?
  20. Exhaust silencer test...
  21. BOV/MBC Help!
  22. why does my car do this....
  23. supporting mod ??'s
  24. New version of Ebay IC with welded on brackets, 4" width and licp....Hmmm
  25. Is there really a difference w/ all these MBC
  26. Will raising the boost cause
  27. Important Question about cams
  28. im bout to buy cams 2nite, help me decide
  29. HKS Exhaust Brackets
  30. Gear ratios for evo8 usdm 5speed box?
  31. Which Clutch is better?
  32. Ebay intercooler testing from the Pros at Buschur Racing....the facts, the truth
  33. New HTA 35R testing finally done and in....
  34. How much material can safely be removed from a gt35r with porting and a maford manifo
  35. Intercooler Piping Question
  36. EVO 8 Cam Gear Fittment Applications
  37. Please Help - Radiator Fan Question
  38. Newbi question here about Evo PSI..
  39. turbo hx40 q's
  40. HKS 272 out, GSC S1 in? on viii
  41. evo probs of course
  42. Tapping IC pipe for smc or snow
  43. should i get a green turbo
  44. NEED HELP WITH Exhaust.
  45. 5zigen Pro Racer X-Tube S-Spec Exhaust.
  46. Hks Ssqv Bov
  47. VIII E85 401whp 362WTQ
  48. 02 housing 5 bolt flange, where to buy?
  49. Tans Help in the 6sp?
  50. turbo upgrade ?'s
  51. Stock Ignition & HIGH BOOST (28psi+)
  52. Tested... FP Green IX turbo...
  53. Weird noise after using no2
  54. Stock BOV question
  55. HKS DLI 2 install question
  56. Loud whining noise
  57. Does anybody get turbo surge from their atp gt35r?
  58. 6spd short shifter.
  59. Autometer Oil Press Gauge....dead?
  60. Buddy Club Pro Spec Exhaust. anyone?
  61. UK FP Evogreen dynoed
  62. Tranny Wont Come Off!!
  63. What if I square the atp hotside flange and do the same to a maxford manifold?
  64. 330 whp, 320 ft lbs
  65. Which spark plug to replace with??
  66. Cam poll
  67. Guys a little help...
  68. Just picked up an IX need some advice
  69. New Greddy ss,ti carback w/ bushur dp and what HFC?
  70. evo Suspension ????
  71. downforce games
  72. Forge UNOS springs?
  73. Can i port atp hotside to match dc sports manifold flange
  74. wiring diagram: boost solenoid
  75. What BOV is this??
  76. Oil Drain Tube GASKET - HELP!
  77. Machine work for AMS 2.3L stroker
  78. Oil Squirters???!!!!
  79. EGT placement, temps, and alky use ?'s.
  80. Fuel pump ??'s
  81. Exedy Twin Noise with Cluch Engaged
  82. ebay exhaust pics and results...
  83. What manifold can i use with a atp gt35r kit, does the flange matter are their side?
  84. Spal slim fan part number#.....
  85. opinions on the perrin foam filter?
  86. 2.4 in a evo
  87. Turbo Xs Down Pipe
  88. Who's running a Maxford header?
  89. oil cooler setups
  90. turbo glowing
  91. Am I cammed?
  92. Open air filter in engine bay?
  93. 50 trim on stock manifold ?
  94. Turbo spools, ready 2 go, car aint..
  95. AVC-R actuator valve gone bad?
  96. what does you boost taper to?
  97. smoke while on 2step?
  98. a few ?? on cosworth cams for evo 9
  99. Where can I get my turbo, manifold, and 02 housing, ported and polished?
  100. Idle issues after Walbro install / airbox mod
  101. anyone running stock clutch on evogreen?
  102. Transfer Case ring and pinion questions
  103. Stock Transmission/Transfer Case power Limits???
  104. turbo smart bov any good!!!
  105. Tuning Technologies IX 361whp 355lbft 91oct. Cossie cams
  106. evo and turbonetics?
  107. build me a built 2.0 monster
  108. anyone running 2.1L destroked?
  109. if money wasn't an issue
  110. F-CON VPro from Buschur
  111. Something is wrong with my car
  112. Forge UNOS MBC SPRING INFO Re: EVO IX & Tapering
  113. Spool up difference between br 3065r and 37r?
  114. Wierd BOOST ISSUES HELP!!!
  115. 3rd gear Synchro busted?
  116. Whitish smoke from manifold area
  117. Buschur DP and O2 Housing issues
  118. Tranny/ Diff/ transfer case fluid?
  119. Tranny fluid alternative
  120. clutch makes weird noise... normal???
  121. cams and valvetrain install time.
  122. engine whine after damper install....
  123. help! lower ic pipe off turbo outlet
  124. Installed Nisei Intercooler Pipe kit + Mini Battery Kit. EVO 9
  125. HKS Maf pipe or Buschur/
  126. stock to t3 adapter
  127. Turbo Timer Harness - MT-1 vs MT-6 - Am I screwed?
  128. ams lower ic pipe
  129. Need options?
  130. log of 28 pounds of boost.....93 oct
  131. Leaking IM spacer?
  132. intercooler fin engineering and design (ins and outs pics)
  133. HKS cam gears
  134. Wastegate Question
  135. CBRD ebay exhaust testing...
  136. 1st and 2nd gear noise in 05 RS.
  137. Curious about this setup w, Catback, DP and what HFC?
  138. evo 9 turbo custom manifold
  139. Engine building pressure
  140. Funny Noise
  141. is my stock wastegate actuator bad?
  142. EVO GSC S1 Cams For a Evo IX
  143. A couple of turbo swap questions (intall related)
  144. 35r turbine leak?
  145. loud noises from drivetrain
  146. What clutch to get?
  147. Downstream o2 sensor!!!
  148. car wouldnt start??
  149. Boost Problem...??
  150. Tial external wastegate problem
  151. which tubular header?
  152. discussion about how intercoolers work
  153. reading used plugs
  154. tech discussion: what keeps torque from dropping off?
  155. Oil cooler sending line leak
  156. technical resource - how mafs work
  157. choking car
  158. Low boost issue
  159. ebay 02 housing
  160. TECH ARTICLE: 16g turbos and all its variants (20g)
  161. Okada Projects
  162. Boost spikes like crazy all of a sudden
  163. EVO Exhaust variety *video*
  164. want your opinion on clutch
  165. Cosworth M1 cams: results on Evo8?
  166. stock to t3 adapter
  167. WORKS 76mm Downpipe w/ eBay o2 Housing?
  168. 381WHP on PUMP! (EVO 9 turbo)
  169. Authority exhaust!!!!
  170. Dyno'd Evo VIII 371 whp on stock turbo
  171. clutch bleed question
  172. Helix 272 V2 cam?? Opinions
  173. clean engine bays post!!
  174. Clutch dead?
  175. Differance between GSC S1 cams aand gsc 272s
  176. Twin scroll/divided housing manifold.
  177. Torque-split clarification...
  178. Which one of the Ebay O2 housing is correct?
  179. S1 Cams:
  180. AMS db's ?
  181. Help with Manifold Studs
  182. boosting problem
  183. How to convert atp gt35r .63 ar to twin scroll?
  184. Atp gt35r .63ar max whp with 93, meth and supporting mods.
  185. Braided Clutch Line.
  186. can i run the stock ecu with a walbro fuel pump??
  187. Balance shaft elimination kit install?
  188. Evolink computer
  189. what motor to go with?
  190. I can only boost to 15 psi
  191. Ebay FMIC testing (data log lab dyno) vs Stock FMIC
  192. weird noise from clutch
  193. missfire question and cylinder
  194. I went back to stock cams didnt resist the ticking noise during warmup.
  195. hallman mbc problem
  196. Can't build more that 11 psi.
  197. Intercooler Upgrade BIG question
  198. What to do next???? please help
  199. Po300 (isolated problem)
  200. Transmission mount stud inquiry
  201. Cossie Cams & FP GREEN Evo IX dyno numbers!!
  202. Dynoed - RnR BB 50 trim & Machines Gone Wild Tuning
  203. Do Not Buy From this Ebay company
  204. wondering what is that smell...need help
  205. Atp kit, will it work with a gt40r.
  206. transmission issues
  207. swapping clutch
  208. odd trouble codes need help
  209. question on stock clutch
  210. To much for Tranny fluid?
  211. Hunting the knock gremlin tomorrow!
  212. Intake/tune... confusion/concern
  213. t-stat housing gasket?
  214. t-stat housing gasket?
  215. Full Blown's Evo 8 Shop Car
  216. Long con-rods for evo engine?
  217. Drivetrain Fluids for IX?
  218. Got my IX tuned with graphs inside (stock + exhaust)
  219. Cams yes or no
  220. Agency Power?
  221. HELP!!! Low Boost at Full Throttle...
  222. Injector Upgrade Question
  223. engine flush
  224. Wastegate
  225. what turbo for my setup...GT35R or GT3076
  226. evo heads fit on 2003 lancer oz?
  227. Which blow off valve?
  228. PT67 and gt37r ??
  229. Evo 9 GSC S2 Cams 35R dyno Sheet and Vid
  230. Found two exhaust cams in the car.
  231. Which makes more power?
  232. Coolant Overflow tank.
  233. Boost problem please help.
  234. Got dyno tuned
  235. MAP conversion question
  236. Cant decide on Trans
  237. help !!!! pleas !!!!
  238. Which Injectors?
  239. WRC 4G63 Crank, My 4G64 Crank, and an... idiot's verison of 4G63 WRC Crank
  240. forge wga, Leaks like crazy??
  241. need help finding black manifold!
  242. Blouch Dominator 3.5 30psi vs 21psi DLL dyno plot
  243. cams, gsc 272 or 280s w/ BR3065
  244. Balance Shaft Elimination???
  245. where can i tap to get ported vacuum?
  246. Exhaust question
  247. 272 exhaust cam only, on a ix?
  248. Stock o2 housing port job?
  249. How my proyect is developing...
  250. anybody "crush their MR BOV like the 1g's?
