- TurboXS 3" Ti silencer removal?
- gcs s2 cams
- fidanza aluminium or chromoly flywheel??
- Modded oil Pump?
- Precision 1200cc rebuild/service kit? help
- Forged engine noise and false knock
- Ams 2.3rr reliability and questions :)
- ****Need help from some experts-issue after mini battery install-STUMPED
- HELP! My evo9 made a pop noise and something is seriously wrong with it...
- How many miles on stock block running FP Black?
- Twinscroll T3 to Stock Manifold - Adapter?
- FP Ball Bearing Reviews
- Leak from between T-case and Trans help
- Atp 3076
- Tranny Noise? Please help
- egt tap blocker
- Underhood Fuel Pressure Gauge
- Can someone Identify this sensor for me?
- E98 in Ohio
- Balance shaft seal cost me a rebuild
- My Evo 9 MR Kinugawa 25g install - photos
- Can anyone identify these Cams??
- Turbo with best spool & 500awhp on E85
- My English Racing LR2.4 Build Begins
- "Brick wall feeling", building boost in neutral, random idle drops, ect.
- Tial Qr to Tial Q
- Fp black
- Tuning - Fuel and timing trim per cylinder
- DBW conversion
- older GSC springs & Chromoly rets
- Test pipe, is it obvious?
- My car randomly started running like crap today.....
- Fuel Injectors for E85 and 92 octane.
- Cant control boost
- Need opinions on a creative intake design
- transfercase bearings
- GSP cv axle from adavance auto
- connect wastegate directly to turbo
- What type of oil do you guys use??
- Turbo good or bad?
- Idling and code issues...
- The Cheap Build
- Kelford 272 or gsc s1 for stock 8 turbo
- Need turbo advice
- Clutch Masters FX400 questions
- How two LR 2.4 BUILD
- Oil press sensor issue?
- 02 External Dump with engine bracket?
- Injector opinions
- Pulled the Transmission!
- Coolant Temp Thread Size Needed ASAP - Pic Included
- HKS Type 1 turbo timer user manual
- Gt-spec manifold with EGR/sas.. does it crack easily?
- Forge bov question
- TRE still doing trans??
- Turbo whining
- Need help/advise
- Ac Compressor Failure help!
- 06 evo transfer case acd
- bearing oil clearences
- Turbo gurus
- after ABS DELETE and relocating
- DNP T3/T4 exhaust manifold (w/ 44mm wastegate flange)
- ACT P/N Questions!!
- High Pitch Whine above 3k rpms
- Looking for FMIC piping...
- Port compressor housing outlet opening?
- Broke some studs out of my fuel tank. help?
- What can I do to help my engine handle more than 400hp
- stock 560's question
- How long did you wait to get an FP turbo
- Good tranny shops near fairfield/vacaville CA
- Which Hose Ends and Hoses?
- Clutch Help...
- Evo 8 Engine knocking - Advice needed
- IX MR Reverse Lockout
- upgraded fuel rail?
- ACD pump dead. What should I do?
- 2nd gear lockout transmission
- Stock valve guides vs aftermarket
- VTA Catch Cans and FP Turbo Failures
- cams question
- Cam shaft information
- Diagnose this noise
- Looking for a 3" 02 housing for T3 turbo.
- Anyone still use or recommend BC stage 2 cams?
- help needed with boost
- Rod bolt stretch
- hks injectors vs injectors dynamics
- Trans and clutch time.
- rear grinding ID
- starting car have to give it gas!
- Any dyno sheets for a BBK-C Yet?
- Boost spike after IC pipe install
- Is this normal??
- 6262 vs 6266.
- Need help with P2W clearances on a 2.4LR 4g64 setup.
- scary transmission noise
- Evo Gearbox Shifting issues
- Rear Diff Humming. Is it cause i changed the fluids??
- Planning some surgery this summer
- Parts help on build
- AYC Diff Assembly Order
- 2 Problems, possibly clutch?
- big turbo question
- HTA3076 VS GTX3076 help
- What else to do along with clutch/flywheel install
- Fuel Setup Question
- Rebuild tranny?
- Valve spring help
- Help Diagnose? (Video)
- Evo 8 oil squirters issue
- Replacing head gasket. What to buy
- capabilities after a camshaft install???
- CBRD 2.3RB and LMP turbo kit- inside
- My Clutch is sticking when I press it help!!
- Temp sensor
- Required mods for 400whp IX MR on e85?
- How does the HKS MAX clutch compair to the Exedy double
- Max power on tomei expreme dump/o2 and downpipe + 2.5" catback
- need help choosing a turbo D':
- oil light wont go off need advise
- Combustion chamber vs. Bore size
- Wiseco piston help
- Rear diff question
- CBRD Big 3" Vbanded o2-
- Bad Effing day. Car Jumped Timing
- Finally FP BB upgrades available!
- Is this Perrin fuel rail for an EVO?
- jb 6766 vs bb 6766?
- ETS UICP Question
- exedy twin disk syptom
- Keeping timing belt tensioner unpinned.
- Is it worth waiting for E85? Few Evo build questions
- 3D Port vs Standard Port on o2 housings
- 22 psi evo 8 wastegate on a ix turbo?
- What is considered too light of flywheel for DD?
- do i need head studs for 27 psi
- Denso Spark Plugs s22PR-A7- Anyone use these?
- EVO VIII shifting issues. Need advice on a few things!!!
- Concerning oil pressure on new build
- O2 Housing Front O2 Sensor Part Request
- helix down pipe fits like crap
- Spark plugs
- Timing with The blance shaft gear
- Bigger injectors needed?
- skunk2 pro series 68mm TB
- Help me pick out injectors
- evo 9, 5 or 6 speed transmission?
- gains from forward facing turbo setups?
- New or Used Spoolin' Up COP?
- Axel seal problems
- Looking for the best LSD for an Evo VIII
- 05 mr acd delete
- USDM vs JDM evo 8 gearbox removal
- Don't use cheap turbo gaskets
- Need advice for a oil catch can setup for a hi hp evo!
- 4inch Downpipe & 4inch Aluminum Exhaust
- Tomei procam 270 vs GSC S2 vs custom GSC "S2R"
- Tial BOV Spring?
- Bad Coils?
- modified stock frame turbo for track use?
- Suggestions on Shiftknob/Boot
- ACD fluid level does not rise up after car sits for while.
- Help needed: Synapse VS WGDC Issue... Any ideas?
- EVO 6 TME turbo
- Tial Bov interstate flutter.
- Help im out of ideas
- Upper hose for Koyo half rad
- Cylinder 1 injector Not Firing-Please Help Me!
- Trouble with Timing
- Need help. Car misfires while cruising
- o2 sensor time.
- QuarterMaster Twin, Anybody have this problem...
- Evo wont go into gear!!!!!
- Where to get a pillar for 2 gauges 52"
- Small issue
- looking for 400whp and high reving daily?....
- Evo 4 knocking noise when turning left.
- Wideband needed for my evo?
- Evo 8 idle problem Please help!!!
- Exedy Triple - Have You Seen This Before?
- Anybody have experience with Innovative Motor mounts?
- injen intake w/ full intercooler piping
- Clutch disc replacement????
- Dealer told me to use Mitsubishi Diaqueen LSD fluid on my tranny, TC and RD.
- evo turbo hotsides 9.0 9.8 10.5
- Spoolinup Cop neccessary? or overkill?
- Running HKS DLI II with Okata direct replacment coil packs
- TurboXS resonator dimensions please .
- FP Red hotside
- Boost cut? Fuel cut? Im not sure what it is!! HELP!
- Infamous Starter Problem/Whine
- picture request: 4G64 waterpump bolt that is required to be trimmed
- Tial Q Spring
- slight metal shavings in oil
- quick piston ring confirmation needed
- dead cylinder 2 and 3
- Turbo Oil return keeps leaking!
- Why I like the Greddy Type S
- How long of a wait for fp black dbb?
- evo rear question
- 03 Evo 8 2nd gear pop out?
- Evo 8 Crankshaft Question
- Broken stock recaro seat back
- Location of Final Drive Gears
- WTB: ATP bolt on Stock Location GTX3071R
- Evo X T Case WTT
- evo 8 USDM vs JDM head flow / design
- smokey and the bandit HELP!!!!!
- Best cams to run on 6766
- Coolant issue driving me insane
- Loud clutch on decel?
- Diagnostic help with Radiator
- help broken bolt
- Upgrade my GSC 264 cams?
- 6262 or 6266 CEA wheel upgrade
- Evo. 8 GSR fluctuating idle and cuts off
- 2.5" downpipe w/ cat delete for EVO IX?
- Have you ever filed your piston rings by hand?
- Valve Head Lapping, first time, Help
- turbo torn
- evo 8 6 speed selector
- Lost spark.....two inside cylinders....spooning up COP
- Transfer Case Question
- Tb/Intake manifold
- Raising redline
- Good deal?? Will it fit???
- Propeller shaft problem...
- EF4 or FP Black?
- So... My Cosworth M2 Intake cam broke. Time to replace/upgrade...
- Kelford 272 vs GSC S2 vs stock cams on evo VIII turbo
- difference between these two turbos
- FF Manifold With A/C -Parts-
- Change clutch?
- 18psi actuator but 14.5psi gate pressure?
- Help! Noise After timing belt!
- Urgent help - 25 psi compression?
- Correct ring gap size
- Injector seals, on the cheap from O'reilly's Auto Parts
- Clutch Options for 600+ TQ: Exedy Triple vs Quartermaster 8 leg vs ATS triple
- What type of setup is this?
- Shep trans.....
- Radiator leak - small crack on top
- BBK-B BB or Fp Red BB Turbo. Which to go for?
- Evo RWD / Non-Transversed Engine, Got Pics?
- Hks blow off valve question
- How bad is rear end grind on decel?
- what kinda power can i expect??
- Good machine shop in NJ area
