PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 [190] 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Next 3 Upgrades???
  2. Need Vacum diagram
  3. high pressure actuator = boost creep?
  4. problem with greddy turbo timer
  5. Look's like my luck has run out!
  6. Case Study # 115 - Evo-NY member 086 - (a/k/a "E1" a/k/a Henry) - Massive TQ - TME
  7. tranny problems!!
  8. Power difference in T04E compared to S-Cover
  9. Speed Density and Alchy Question
  10. How can i get 350 - 370whp?
  11. Problems with Turbo XS MBC.
  12. BOV Orientation
  13. manifold for gt30R
  14. which turbro
  15. HyperDrive Digital Alcohol Injection
  16. Help
  17. boost wont go above 15
  18. How much boost in winter?
  19. at my wits end. cant trouble shoot this problem
  20. Tomei 2.2l S/kit
  21. Cam gears alignment
  22. JAM 2.3 motors?
  23. OIL pressure problem?!!
  24. Whats the best FPR???
  25. Vendor who have ACT Extreme clutch w/6 puck disk
  26. Heads up Chicago: Good Dealer Good MITSU REP
  27. Does anyone make a fuel surge tank?
  28. BEWARE the "blue death" HKS rip off ebay intake !!!!!!!!!!!
  29. Pls help, I'm getting hiccup!!
  30. hks hi-power exhaust melting bumper
  31. powersteering fluid level
  32. Power Steering pump failure
  33. Revolver Cam Test! HKS who?
  34. DSM Mitsubishi-Style Exhaust Manifold for the EVO 8?
  35. guess this part on the T-Case
  36. torque setings for a down pipe.
  37. Damn IC pipes. what do you use to keep them on?
  38. ECU bleeding off boost cause of colder air?
  39. What Happened To ACT's EVO Flywheel
  40. New Intercooler Pipe Boost?
  41. Freeze plug popped out
  42. anyone running the ultimate racing exhaust?
  43. bad front diff Q
  44. If its not one thing...its another
  45. Deceleration After Being in Boost
  46. I really need some help
  47. Quick question about Hallman mbc
  48. Happy Thanksgiving from PhoenixTurbo.com/PeakBoost
  49. The TANABE Track beast transformation Thread!
  50. anyone has a dyno sheet of a stock Vs. tubular manifold?
  51. Turbosmart dual port BOV
  52. Exedy twin plate question
  53. need help guys...ASAP
  54. Forge UNOS or Hallman Pro RX MBC?
  55. Mach V STainless Steel HeadeR?
  56. Price for valve spring install
  57. Adding External Wastegate to Megan Manifold
  58. Thoughts on Clutch Masters FX300
  59. Rear End Noise! like loose socket in trunk!
  60. Anyone have a complete front differential (not just gear)...
  61. HFC question
  62. ebay xs power intercooler?
  63. Exedy Story... Kinda Long, But Worth The Read...
  64. Buschur intake filter quality?
  65. EBC and 101 octane
  66. Evo 8 crank sensor went at 3k!?!?!
  67. Ported 20g from turbochargers ?
  68. ecutec reflash and gt30r?
  69. Walbro255#342 won't run in hi flow. Normal ops?
  70. Resonator?
  71. Which Crankshaft?
  72. Buschur catback with non-Buschur HFC?
  73. Crower Crankshaft
  74. Boost leak test, gone bad!!
  75. Having some Idle issues
  76. Scan tools... which one?
  77. Boost Control Solenoid broken...
  78. Question on engine if it wasn't turbo
  79. 100 oct. how much boost?
  80. Metal Radiator Hose
  81. Help on how to adjust the cam gears????
  82. Ignition amplifier + alky injection
  83. Digimoto update 4.03
  84. cannot rev past 4k....
  85. Case Study # 112 - Why I love Buschur Racing Parts !
  86. Upgraded O2 housing for 2.75" downpipe?
  87. Update on my EVO
  88. boost problem
  89. Evo 8 turbo manifold
  90. How does a BOV work?
  91. Boost controller settings?(Blitz SBi-D) Need 27psi!!!
  92. 2.3 or 2.4ltr with stock turbo
  93. 03-04 Front Diff. Part #
  94. buddy club cams
  95. Stuttering problem when at 100% throttle
  96. turbos that bolts to stock manifold
  97. WoW
  98. Cold Air Box with Intake Tube
  99. no top end
  100. Engine Blew!!
  101. Problem with car
  102. My evo is scaring me......
  103. intercooler pipes that fit w/ACD?
  104. How much will a ported head give me?
  105. Venting stock mr valve to atmosphere
  106. ARC Induction Box and HKS BOV
  107. 4g63 Heads
  108. Helix 720cc injectors debut!
  109. IC piping trouble/problem...
  110. Wierd problem -- I think drivetrain related
  111. 05 clutch install
  112. Wiseco Vs Ross
  113. 5th gear grinding...
  114. how many people have installed 2g lifters
  115. Power made by raising revlimit?
  116. GT35R to good to be true?
  117. JEBUS CHRISTOS!!! Loud whistle!! HELP
  118. Question on i/c piping
  119. Case Study # 110 and 111 - Evo IX's with basic mods
  120. AVO S-Type Turbo Kit Installed
  121. 2.3L Stoker with a 5 speed tranny or 6 speed
  122. 500awhp? how
  123. Turbo flatter, tricky problem
  124. intake manifold help
  125. Quick 2g question?
  126. Question about fuel pump ??
  127. Stock BCS solenoid lines
  128. br440 or new 20g?
  129. First problem with the car, it stays stuck in gear....
  130. Need advice on engine setup for track racing
  131. comp cams????
  132. stroke or not
  133. mods to run 11's (yes i know , i know)
  134. Buschur BR330 IX dyno results
  135. New Full-Race Turbo
  136. Fuel pump problem
  137. Fuses... Help.
  138. The not-so-offical EVO 9 ECU tuning thread
  139. Anyone else get a large boost spike after 10.5 install?
  140. Does anyone elses engine CLICK?
  141. How Much Power Can The Stock Turbo Produce..
  142. :confused: WHAT HAPPENED TO ALL THE WR TURBOS??
  143. Have a small oil leak, what could it be?
  144. walbro sputter...
  145. evolution transfer case problem
  146. Specs on a Borla Cat-Back Exhaust...
  147. Rear Gear?
  148. stock evo turbo question
  149. Breakdown of AFR's through RPM range
  150. Who makes a fuel rail to fit MSD injectors?
  151. Evo Crankwalk????
  152. MSD DIS-2 installation question/problems
  153. check engine light
  154. Want to shut your whining Walbro up?
  155. RMR/Greddy combo ?
  156. How Streetable is this set-up
  157. Why am i running out of fuel?
  158. made list of next mods to get...any suggestions or comments?
  159. Rough idle and misfire
  160. Winter Project: GT35R, nitrous. any advice?
  161. clutch slipping.....
  162. Need help w/ friends Evo!!
  163. wtf! defi boost guage way off
  164. Driving with a bad syncro???
  165. New catback exhaust smoking... Normal or serious problem?
  166. Advice on clutch install....
  167. Which air and fuel ratio?
  168. engine blew cause of failed alky kit?
  169. Turbo Comp. Surge Fixes?
  170. service engine light soon at 2000 miles
  171. JIC Exhaust
  172. Fuel pump ?s
  173. Is anyone else getting 1st gear shutter when taking off from a stop?
  174. Gt3065r?
  175. idle dropped
  176. Alky VS 95-96 Octane mix
  177. remove air box lid
  178. Alky Users & Winter Weather ??
  179. What intake should i use? hks looses power
  180. 05 MR clutch problems...?
  181. Evo 8 Boost
  182. Test Pipe with Catback?
  183. automated ems???
  184. valves tapping
  185. best down pipe to go with espelir catback?
  186. how come my SSQV sounds like it is leaking boost on WOT
  187. Better Fuel Pump Needed?
  188. DLI plus Mini Battery?
  189. Can someone help reassure me I won't blow my car up?
  190. evo internals into turbo 2g eclipse??
  191. Broken Propeller shaft components...
  192. Alky Wiring Problems
  193. coolant, headgasket, leaking OH my.......
  194. Cusco Oil catch can question
  195. AMS turbo?
  196. AEM Serial guages?
  197. Bigger injectors = more boost?
  198. Clutch change! Stock flywheel....
  199. best sparkplugs
  200. Works Clutch Line
  201. HELP.....Service Engine Light
  202. 272/280 cams
  203. Precision Dyno Tuned Buschur 20G Review
  204. Nitrous question?
  205. Underdrive pulleys revisited...
  206. My Switzer tuned Evo VIII
  207. hey what should i run 1/4
  208. 101 octane and bone stock IX?
  209. Might be stepping up in cams...
  210. EVO IX, CAI, WORKS Flash, BOV, boost issues
  211. How difficult is it to replace the syncro's?
  212. Alky Kit + Head Studs ?
  213. Where are the timing marks?
  214. Oil\Filter Receipts..
  215. Alky Kit Test/Prime Question
  216. whats the awd ratio
  217. Hi power exhaust
  218. WANTED TurboXS (RFL) Turbo back Exhaust
  219. 726.6 WHP EVO VIII from PR
  220. Diaqueen is $35 @ mitsubishiparts.net
  221. Anyone have problems with 20g?
  222. throw out bearing question
  223. Reuse exhaust gaskets?????
  224. OK, so how many of you believe this...
  225. intercooler piping: how much power?
  226. really really odd problem
  227. greddy bov make no sound
  228. Oil Pump Timing
  229. Ignition Questions:
  230. **Helix High Flow Cat Pipe**
  231. timing belt help PLEASE....
  232. Alchy Question
  233. bought espelir catback...but missing part? (need help) (pix)
  234. SO what are HKS Cams and Fidanza Camgears supposed to be set at???
  235. Another BR20G-EVO9 VS GT35R Dyno graph
  236. power gains w/ 3 inch turbo back
  237. PeakBoost BBTO4Rp pumpgas results
  238. Turbo XS Short Ram Intake
  239. replacement o2 sensor
  240. Is there a better o-ring seal for the t-case?
  241. considering down-grading cams
  242. Which Permatex to Use for Plugs?
  243. Driveline Noise Help
  244. Big problem
  245. Hands on experience with stroker kits?
  246. 10.5T Review
  247. Quick Exhaust Question
  248. Boost Spike off the Gauge!!!!
  249. AEM UEGO Wideband...
  250. Throwout Bearing
