- Homemade turbo oil line gasket
- What color does your transmission fluid come out?
- 03 evo 8 cam install quest
- newbie intake question
- helpp ?
- Fifth gear scratch?
- FP Oil Line + Oil Temp and Oil Pressure
- injector rubber garmet
- creating more power with a proper external wastegate dump setup
- 1200cc
- mechanic clutch ? quartermasters twin
- how many quarts of oil?
- What might be a cause of dying alternator???
- Buschur Intake Installed! (Pics)
- EVO IX TC Whine
- Tial bov white or black spring
- boost leak?
- Warning: Graphic Images inside.
- Evo IX crunch 2nd to 3rd gear
- Pls Help - Evo 5 Piston 2 & 4 Compression Drop
- car cuts out
- gt 3065 vids?
- Evo X bov on Evo 8?
- Carbonetic Twin user reviews?
- Harsh angle in BOV recirc line, is this bad??
- Synapse BOV installed in IX MR review
- Sparktech or Spoolin CoP
- Making the exhaust fit jdm bumper
- Asking tomei cam
- Big clutch debate for my car need opions and advice
- intake question!!! just need some advise and opions
- What happened at the dyno today?
- STM clutch fork stop?
- Before I make my clutch purchase...
- hallman mbc Q?
- Evo 9 MR exhaust question
- why am i only boosting 9psi?
- Aps twin vent and car wash
- Installed map open dump Mohave p0134 code
- Resonator w/Greddy Ti
- Need help with my motor!!!
- oil drain diameter
- idle issues on a very hot day
- JM Fab Race IM vs Drag IM
- Please Advise - Adjusting Stock Cams Evo 5
- Intercooler sprays
- Beryllium valve seats and the quest for the ultimate 4g63 cylinder head
- Best CoP kit
- MAP ultimate duty VS Manley TT rods
- GT35 turbo outlet pipe?
- 4G64 + O-Ring + .20 Advice
- Quartermaster Twin 3rd gear high rpm lockout
- Stalling problem.. Please help!!
- Clutch combo question
- TRE VS. Sheptrans
- What's the engine Main bores size?
- EVO Engine Weight...?
- Transfer Case Fluid Question
- A1000 fuel pump thread size?
- fuel line upgrades
- Boost Leaking ?
- gsc s2 or fp4r with bbk full
- LICP... need help???
- Trany noise
- Short shifter install, slight problem.
- When ACD fails what is the result?
- Help wanted, Norwegian Evo 8 owner
- Lifters
- Boost controller question
- HELP! Evo 9 engine ticking noise
- Opinions on Using Friction Modifier in your Diffs?
- Is my alternator dying???
- speedometer wobble?
- Kelford 272 cam install (need input)
- Knock and Boost
- Cleaning the EGR Valve?
- are fp-grn's as loud as fp-blk's?
- replacing drive shaft
- compression test results
- Buschur Intercooler
- Well Sh**! I think I just hit fuel cut!
- Pedal/clutch vibrations
- Can I do this too my evo?
- Tune after BR intake??
- Timing Fix?
- Safe WHP/WTQ for IX 5spd?
- I need Help
- exedy twin: check the inspection hole. is this normal?
- People with FP4R evo 9 cams..??
- Injector seals
- why am I having a hard time hitting target boost?
- magnitude performance rods??
- IC pipe blowout, fixed, now high idle?
- What Recirculating BOV???
- Thoughts on 280 cams
- help: Shifter bushings
- Car misses at higher rpm what is wrong!?!?
- Headgasket and 60k
- does buschur v-band tbe fit well?
- Clutch pedal woun't come up all the way! helpp
- Rebuild kit for Exedy carbon twinplate?
- Re-rebuild kit for Exedy carbon twinplate?
- DNP manifold
- eBay FMIC vs. Buschur Racing Street FMIC: Install, Pics, Initial Findings
- ACD issues!!! help
- Clutch Problems
- Passenger Output shaft install on 03 non-acd TC
- Just bought my new evo and need some help
- Exedy triple-disc noise
- help me with my clutch
- Strange Idle
- engine building questions
- Help! Did my cam install go terribly wrong?!
- BLE Solid Race Tensioners
- 2.3L Stroker
- Huge lag...4 month and no solution! help!
- Exedy twin questions
- Maybe a silly question...
- AMS tbe installed.. sucking down gas
- AVCR or AEM Tru boost
- spark plug help
- Valve spring question (stupid)
- Hole in Cv boot
- wiring acd tcase pump to run full pressure??
- t-belt issue
- Broken boost control solenoid
- Shepherd Transmission for Evo 03-06 MR 6 Speed (Sheptrans 6spd)
- QM Twin
- clutch pedal vibration and popping issue
- 6 speed trannies can use mobile-1 5w30???
- kelford cams help
- fuel injector wire extension
- BC 272 cams with quality control issues (pics inside)
- Analyze my old spark plugs, please (pics)
- Afr's
- Car not boosting at all!!
- p2228 cel on randomly???
- T4 vs T3 Spool and HP Difference???
- Head gasket/bolt ?
- Lifter Noise....after highway pull
- Transmission problem
- trouble going in gear
- Exhaust Manifold bolts????
- front oxygen sensor location vii
- HELP I need this Part number!!!
- Short blocks and cylinder heads cosworth vs gsc vs buschur which?
- Maf sensor wire issue/Help Plz
- Safety latching turbo bolts
- OEM Knock Sensor with Pistons?
- Evo 8 sas different to 9?
- Feeler: CBRD BBK FULL
- Shell Rotella T6 vs Mobil 1
- Clutch/Trans/Starter questions
- stock evo 8 Turbo Specs?
- valve relief size of 4g63 head
- wideband o2?????
- Trans gearing options for 2.3/FP Black build (daily/drag)
- Annoying tick
- How to Tune HKS264 CAMS On evo VIII 4g63
- Another Car won't start thread
- Who is leonevox
- Engine build tips
- bad fuel injectors?
- 8 and 9 intake manifold question
- Anyone making power on stock cams and 93octane gas without meth???ect.
- Trace amounts of yellow - gold specs in oil
- AEM Oil/Fuel pressure sensor differences
- Nology silver plugs....
- Brisk Racing silver plugs....
- Is this a good 2.3 setup?
- help with hks carbon ti catback
- opinions on squeezing out a little more power in my setup
- Tw/fs/ft: Ets 3.5'' fmic
- excessive oil on BOV and TB
- Still being battled by the boost monsters
- Will upgrade Intake manifold throw CEL?
- SuperTech 4G63 dual spring and retainers
- Stock spring rates in a tial 44mm?
- Anyone run a map sensor to two different sources?
- Is HTA 3586 too laggy for a stock engine
- A major spooling problem
- People who know there turbos and know them well please help with this
- Clutch fork stop with Competition Twin Disc??
- Exedy triple HR pedal adjustment questions...
- Popped off my UICP from the throttle body and have high idle
- Worth Putting Cams in a 06MR
- switchable stock ECU....
- Losing my mind with this ets kit !!!
- Help with broken cams(pics)
- Performance Racing Chip???
- Evo 7 RS rear Axles
- Motor Mounts??? Worth it???
- Yellow grease next to both axles.
- 1g/2g dsm cop on evo 8
- Anyone have a map sensor go bad?
- question about turbo noise
- HTA3582 Compressor Outlet Size?
- FP Black or smaller 6262 on a built 2.0
- FP BLack users question?
- What Rods based on weight and engine revs?
- Have a quick question about ECU Flash & launch control!
- Vacuum Line Routing Help!
- A challenge for the best on a boost leak (and testing)
- Need new clutch kit
- Car not starting? Help!
- Change old FP Green to HTA FP Green or Not?
- Ets uicp
- Inline Fuel Pump Install?
- Oil Temperature & grade
- What clamps do you guys have?
- Rate this installation. :/
- PTE Vband exhaust on Garrett?
- Please help! P0201 Injector circuit - Cylinder 1
- gsc s2 cams?
- Engine fan problem
- blown headgasket?
- Decent price on Mishimoto radiators, $229.99+free shipping
- Cam question
- What can you reuse from 8 turbo to 9??
- cryo treated clutch
- what cams are best with hta green turbo
- Blitz BOV, 70087
- Who here runs / has ran upgraded cams with OEM springs / retainers?
- Help! Car wont start...
- Replacing clutch disc...... safe?
- problems starting brand new stroker motor
- ex mani install leads to lose of boost?
- Rebuild Evo VII gearbox or not?
- Tial V-Band Housing vs. PT V-Band
- Clutch and CEL code question?
- damn
- front facing turbo AC condensor
- BF272s with stock retainers!?
- Want to upgrade Greddy T67 or wait
- How to tell if engine is built or stroked?
- Oil light comes on low rev
- Quick Question "What turbo is on my car?"
- Looking for a good short shifter
- Intercooler Pressure Test
- cams instalation!
- Evo IX OverHeating
- Clutch Replacement to Rid Decel Noise?
- Throttle Body Choke Causing High Idle?
- Where to get a battery?
- Options for TC when taking engine out the top?
- Transmission overhaul
- bc 272 cams any good?
- Repairing Titanium Catback? Cost Effective?
- which cam combo to use
